2014-12-23 Tuesday 19:00 Gerhard Stoll
* gem/vdi/control/: v_opnvwk.ui, v_opnwk.ui:
Value for work_in[0] is only x = 2 + Getrez() (Mike Fulton)
2014-11-15 Saturday 10:29 Gerhard Stoll
* magic/magic_en.u:
Correct label (Lonny Pursell)
2014-10-28 Tuesday 18:36 Gerhard Stoll
* gem/aes/aes_f.u:
Add function appl_options (Lonny Pursell)
* gem/aes/graf_/graf_multirubber.ui:
Wrong parameter name (Lonny Pursell)
2014-07-20 Sunday 08:51 Gerhard Stoll
* gem/vdi/vdi_f.u:
Add function from the MATRIX TC-VDI
2014-04-06 Sunday 15:39 Gerhard Stoll
* bios/structures/pun_info.ui:
Add bit for Falcon IDE and USB
2014-04-05 Saturday 08:12 Gerhard Stoll
* xbios/pci_bios/pci_bios.u:
Correct cookie
2014-04-05 Saturday 08:11 Gerhard Stoll
* protokol/xssi.u:
Correct text
2014-04-05 Saturday 08:10 Gerhard Stoll
* gem/aes/appl_/appl_get_cicon.ui:
Add english version
* bios/cookie/description/XSSI.ui:
Add link
* bios/cookie/description/PCI_.ui:
Change link
2014-04-05 Saturday 08:09 Gerhard Stoll
* bios/cookie/description/_PCI.ui:
Change Link
2014-03-18 Tuesday 19:44 Gerhard Stoll
* protokol/xssi.u:
ID from BUBBLES
* html/tos_hyp.u:
Link to the archives
2014-03-18 Tuesday 19:43 Gerhard Stoll
* anhang/typedefs.u:
Change headline from MCB for MagiC
2014-03-18 Tuesday 16:17 Gerhard Stoll
* gem/aes/: aes_f.u, appl_/appl_.u, appl_/appl_get_cicon.ui:
New function appl_get_cicon from Olivier Landemarre
2014-03-14 Friday 18:58 Gerhard Stoll
* gem/aes/evnt_/messages/messages.u:
Messages from Tetrax
2014-02-02 Sunday 15:59 Michael Bernstein
* gem/aes/structures/applrecord.ui:
Change field descriptions to values evaluated by tests from Roger Burrows
2013-09-17 Tuesday 13:41 Gerhard Stoll
* gemdos/gemdos_f.u:
Function from BiNet100 and Atari Network Service
2013-06-30 Sunday 08:32 Gerhard Stoll
* bios/bios_f.u:
Add function from the Drive B Simulator
2013-03-24 Sunday 09:32 Gerhard Stoll
* xbios/xbios_f.u:
XBIOS function from Hatari and the Hatari version from DHS
2013-03-04 Monday 17:49 Gerhard Stoll
* anhang/anhang/ascii.ui:
Lowercase letter "c" was shown instead of "e" (Hex code 65). (David Gálvez)
2013-01-20 Sunday 08:29 Gerhard Stoll
* gem/vdi/inquire/vq_color.ui:
Declaration wrong, there is a return value (init16_t and not void).
2012-11-26 Monday 17:34 Gerhard Stoll
* gem/vdi/control/v_opnprn.ui:
Wrong Opcode in binding.
2012-09-21 Friday 18:22 Gerhard Stoll
* gemdos/memory/malloc.ui:
Info about the limits from that function.
2012-09-19 Wednesday 17:03 Gerhard Stoll
* gemdos/datetime/tsetitim.ui:
Correct C prototyp
2012-03-10 Saturday 15:59 Gerhard Stoll
* gem/aes/appl_/appl_getinfo.ui:
more detailed AES_ARCH-defines
2012-03-01 Thursday 18:45 Gerhard Stoll
Correct OSHEADER for EmuTOS (Helmut Karlowski)
2012-01-20 Friday 10:25 Gerhard Stoll
* gem/aes/appl_/appl_find.ui:
Add MyAES for Mode -3.
2011-07-30 Saturday 17:16 Gerhard Stoll
* bios/cookie/: list.ui, description/AmAN.ui, description/cVDI.ui,
description/ALIC.ui:
Delete german paragraph in english doc. Contributed by Paul Wratt.
2011-05-29 Sunday 08:23 Gerhard Stoll
* bios/sys_var_en.u, bios/sys_vec_en.ui, magic/magic_en.u:
Small changes from Peter A. West
2011-01-16 Sunday 15:00 Gerhard Stoll
* gem/aes/wind_/: wind_get_set.ui, wind_set.ui,
wind_set/WF_TOPMOST.ui:
Add WF_TOPMOST
2011-01-01 Saturday 17:53 Gerhard Stoll
* bios/cookie/cookie.u:
_PCI and XPCI are displayed in the ST-Guideversion
2010-11-01 Monday 07:52 Gerhard Stoll
* bios/cookie/description/PCI_.ui,
bios/cookie/description/XPCI.ui,
Add links
2010-10-20 Wednesday 18:51 Gerhard Stoll
* bios/cookie/: cookie.u, list.ui, description/8_8.ui,
description/BIGS.ui, description/BSTE.ui:
Add some more cookies
2010-10-11 Monday 16:49 Gerhard Stoll
* bios/cookie/: cookie.u, list.ui, description/CT40.ui,
description/FALT.ui, description/Lity.ui, description/MFMV.ui,
description/MgPC.ui, description/ceci.ui, description/iTMA.ui,
description/nAES.ui:
2010-10-07 Thursday 09:15 Gerhard Stoll
* bios/cookie/list.ui:
Some changes (Olivier Landemarre)
2010-09-30 Thursday 07:29 Gerhard Stoll
* anhang/anhang/xhdi/: xhdi_de.ui, xhdi_en.ui:
Correct short description from XHMediumChanged (by David Gálvez)
2010-08-08 Sunday 16:37 Gerhard Stoll
* xbios/spezial/puntaes.ui:
Some more infos from MagiC.
2010-07-31 Saturday 20:14 Gerhard Stoll
Some more info from MagiC
2010-07-24 Saturday 11:52 Gerhard Stoll
* gem/aes/: aes_f.u, structures/WINFRAME_HANDLER.ui,
structures/WINFRAME_SETTINGS.ui, structures/WININFO.ui,
structures/structures.u, wind_/sys_set_winframe_manager.ui,
wind_/wind_.u:
Add sys_set_winframe_manager from MagiC 6
2010-07-24 Saturday 11:50 Gerhard Stoll
* gem/aes/rsrc_/sys_recalc_cicon_colours.ui:
Correct binding
2010-07-21 Wednesday 19:53 Gerhard Stoll
* bios/cookie/: cookie.u, list.ui, description/Xgem.ui:
Add cookie Xgem from Winframe Xgem.
2010-07-21 Wednesday 18:52 Gerhard Stoll
* gem/aes/aes_f.u:
Wrong opcode in edit_set.
2010-07-04 Sunday 16:21 Gerhard Stoll
* bios/cookie/description/_MCH.ui:
Delete the values from M5484LITE and Coldari, which was in some EmuTOS
version, which was never released.
2010-06-26 Saturday 17:56 Gerhard Stoll
OSHEADER: More info about p_run and p_root
2010-06-17 Thursday 18:51 Gerhard Stoll
* gem/aes/scrp_/scrp_clear.ui:
Translate from english to german
2010-06-17 Thursday 18:50 Gerhard Stoll
* gem/aes/appl_/: _appl_yield.ui, appl_.u, appl_yield.ui:
Add _appl_yield
2010-04-25 Sunday 07:04 Gerhard Stoll
* protokol/vscreen.u:
Add id from NOVA VDI
2010-04-18 Sunday 17:07 Gerhard Stoll
* protokol/AV/: av_de.ui, av_en.ui:
VA_COPY_COMPLETE is the anser from AV_COPY_DRAGGED
2010-04-17 Saturday 09:31 Gerhard Stoll
* gem/vdi/inquire/v_delete_driver_info.ui:
Correct binding
2010-04-14 Wednesday 18:00 Gerhard Stoll
* gemdos/network/Nversion.ui:
Correct binding
2010-02-04 Thursday 21:25 Gerhard Stoll
* gemdos/gemdos.u:
Add some info to the programflags
2010-02-04 Thursday 21:24 Gerhard Stoll
* magic/sharelib.u:
Example how to make a shared library
2010-01-24 Sunday 17:05 Gerhard Stoll
* gem/vdi/: vdi_f.u, inquire/inquire.u, inquire/vq_devinfo.ui,
inquire/vq_ext_devinfo.ui, inquire/vqt_devinfo.ui:
Add vqt_devinfo
2010-01-13 Wednesday 20:49 Gerhard Stoll
2+Getrez()
2009-12-19 Saturday 20:22 Gerhard Stoll
* xbios/: bildscrm/Setscreen_ct60.ui, ct60/cache.ui,
ct60/ct60_vmalloc.ui, ct60/rd_param.ui:
Update to new ct60 document
2009-12-13 Sunday 10:57 Gerhard Stoll
Add values from M5484LITE and Coldari
2009-10-10 Saturday 16:21 Gerhard Stoll
* bios/cookie/: list.ui, description/CT60.ui, description/_CF_.ui:
Add _CF_ cookie
2009-06-12 Friday 13:33 Gerhard Stoll
Add function Fchdir, Ffdopendir and Fdirfd from FreeMiNT 1.17
2009-01-06 Tuesday 17:05 Gerhard Stoll
Bit 15 in WINOWS
2008-11-19 Wednesday 17:49 Gerhard Stoll * config.u, e_aes.u, e_bios.u, e_cpxdok.u, e_funk_l.u, e_gemdos.u, e_linea.u, e_magic.u, e_olga.u, e_protok.u, e_tos.u, e_tos_li.u, e_vdi.u, e_view.u, e_vt52.u, e_xbios.u, e_xbra.u, e_xhdi.u, tos_hyp.u, gem/aes/evnt_/messages/messages.u, gemdos/filesys.u, gemdos/*, xbios/*: Change line end 2008-11-18 Tuesday 20:19 Gerhard Stoll * doc/liesmich, doc/styl.u, emulator.en/sonstige.u, emulator.en/stem.u, emulator.en/tos2win.u, gem/*, linea/*, magic/*, n_aes/n_aes.u, protokol/*, tos/tos_de.ui, tos/tos_en.ui, tos/tosmain.u, xaaes/xaaes.u: Change lineend 2008-11-16 Sunday 14:25 Gerhard Stoll * gem/aes/: appl_/*, edit_/*, evnt_/*: Change line end 2008-11-16 Sunday 14:24 Gerhard Stoll * xbios/xbios_f.u: Add function form ct60 2008-11-09 Sunday 14:30 Gerhard Stoll * anhang/*, bios/*: Change line end to unix 2008-11-09 Sunday 08:51 Gerhard Stoll * gem/vdi/output/v_arc.ui: Test upload 2008-11-06 Thursday 20:38 Michael Bernstein * gemdos/system/ssystem.ui: Syntaxfehler in begin_table end_tabel in deutschen Teil behoben. Bugfix of syntax error with begin_table end_table in german part. 2008-11-05 Wednesday 21:04 Michael Bernstein * gemdos/: argv.u, gemdos_f.u, chrinout/cauxin.ui, chrinout/cauxos.ui, chrinout/cauxout.ui, chrinout/cconis.ui, chrinout/cconout.ui, chrinout/cconrs.ui, chrinout/cconws.ui, chrinout/cprnos.ui, chrinout/crawcin.ui, chrinout/crawio.ui, datetime/tgettime.ui, datetime/tsettime.ui, dir/dclosedi.ui, dir/dcntl.ui, dir/dcreate.ui, dir/ddelete.ui, dir/dfree.ui, dir/dgetcwd.ui, dir/dgetdrv.ui, dir/dgetpath.ui, dir/dreadlab.ui, dir/dsetdrv.ui, dir/dsetpath.ui, dir/dwritela.ui, dir/dxopendir.ui, dir/dxreaddi.ui, file/fattrib.ui, file/fclose.ui, file/fdatime.ui, file/fdelete.ui, file/fgetdta.ui, file/fread.ui, file/fsnext.ui, file/fwrite.ui, memory/mfree.ui, memory/mshrink.ui, memory/mxalloc.ui, network/Nversion.ui, prozess/pseteuid.ui, prozess/psigintr.ui, prozess/pterm.ui, prozess/pterm0.ui, structures/DISKINFO.ui, structures/DTA.ui, structures/FILEPTR.ui, structures/LINE.ui, structures/PD.ui, structures/XATTR.ui, structures/cd_ad.ui, structures/cdrom_tocentry.ui, structures/fcookie.ui, structures/mutimbuf.ui, structures/ploadinfo.ui, structures/tty.ui, structures/winsize.ui, structures/xkey.ui, system/slbclose.ui, system/slbopen.ui, system/super.ui: Doppelte Zeilenumbrüch entfernt, die aus jeder Zeile einen Absatz gemacht hatten. Remove double newlines which case UDO to take every line as a separate paragraph 2008-11-02 Sunday 21:48 Michael Bernstein * gemdos/: chrinout/chrinout.u, system/system.u: Fehler in Verschachtelung iflang-endif mit begin_node end_node Bugfix in iflang-endif with begin_node end_node 2008-11-01 Saturday 18:29 Michael Bernstein * gemdos/system/ssystem.ui: Syntaxfehler in Item eienr XLIST im deutschen Teil behoben. Bugfix in item part of xlist from german part. 2008-10-31 Friday 08:31 Gerhard Stoll * gem/vdi/attribut/bitmap/vsr_bg_color.ui, gem/vdi/attribut/text/vst_error.ui, gemdos/gemdos.u, gemdos/signale.u, gemdos/dir/dclosedi.ui, gemdos/dir/dcntl.ui, gemdos/dir/dcreate.ui, gemdos/dir/ddelete.ui, gemdos/dir/dfree.ui, gemdos/dir/dgetcwd.ui, gemdos/dir/dgetdrv.ui, gemdos/dir/dgetpath.ui, gemdos/dir/dlock.ui, gemdos/dir/dopendir.ui, gemdos/dir/dpathcon.ui, gemdos/dir/dreaddir.ui, gemdos/dir/dreadlab.ui, gemdos/dir/drewindd.ui, gemdos/dir/dsetdrv.ui, gemdos/dir/dsetpath.ui, gemdos/dir/dwritela.ui, gemdos/dir/dxopendir.ui, gemdos/dir/dxreaddi.ui, gemdos/file/fchown.ui, gemdos/file/fsnext.ui, xbios/intrface/dosound.ui, xbios/laufwerk/floprd.ui, xbios/spezial/blitmode.ui, xbios/spezial/cachectr.ui, xbios/spezial/cjar.ui, xbios/spezial/dbmsg.ui, xbios/spezial/janus.ui, xbios/spezial/puntaes.ui, xbios/spezial/random.ui, xbios/spezial/ssbrk.ui, xbios/spezial/supexec.ui, xbios/spezial/trapper.ui, xbios/spezial/wdgctrl.ui, xbios/startrac/hardplay.ui: Correct links 2008-10-27 Monday 19:52 Gerhard Stoll * anhang/hilfe.u: Add address 2008-10-27 Monday 19:37 Gerhard Stoll * anhang/anhang/tos_vers.u: Some more AES versions 2008-10-25 Saturday 20:51 Michael Bernstein * gemdos/: chrinout/chrinout.u, datetime/datetime.u, datetime/talarm.ui, datetime/tgettofd.ui, datetime/tsetitim.ui, dir/dclosedi.ui, dir/dcntl.ui, dir/dgetcwd.ui, dir/dir.u, dir/dlock.ui, dir/dopendir.ui, dir/dreaddir.ui, dir/drewindd.ui, file/fchmod.ui, file/fchown.ui, file/file.u, file/flink.ui, file/fmidipip.ui, file/fpipe.ui, file/freadlin.ui, file/fsymlink.ui, memory/memory.u, network/network.u, prozess/pgetegid.ui, prozess/pgeteuid.ui, prozess/pmsg.ui, prozess/prenice.ui, prozess/prozess.u, prozess/psemapho.ui, prozess/psetauid.ui, prozess/psigacti.ui, prozess/psigpaus.ui, prozess/pumask.ui, prozess/pwaitpid.ui, structures/timeval.ui, structures/timezone.ui, system/salert.ui, system/ssync.ui, system/system.u: kleine englische Teile im deutschen Zweig aud deutsch übersetzt. Translate small english parts in german part to german. 2008-10-19 Sunday 18:50 Michael Bernstein * gemdos/: filesys.u, gemdos.u, signale.u, chrinout/cnecin.ui, datetime/talarm.ui, dir/dcntl.ui, dir/dir.u, dir/dopendir.ui, file/fchmod.ui, file/fcntl.ui, file/fdup.ui, file/fforce.ui, file/file.u, file/flock.ui, file/fsfirst.ui, memory/memory.u, network/network.u, prozess/pause.ui, prozess/prozess.u, prozess/prusage.ui, prozess/psigpaus.ui, structures/cdrom.ui, structures/sigaction.ui, system/salert.ui, system/ssystem.ui, system/system.u: Ändern einiger Formatierungen nach Vorlagen von Peter West, soweit mit UDO möglich. Korrektur von verschachtelten if-else mit begin_node end_node. Modify some formats found by Peter West if they can be done with UDO. Bugfix in some nested if-else with begin_node end_node 2008-10-17 Friday 21:02 Michael Bernstein * gemdos/: dir/dpathcon.ui, file/fcntl.ui, file/fgetchar.ui, file/finstat.ui, file/foutstat.ui, file/fputchar.ui, file/fselect.ui, prozess/pause.ui, prozess/pdomain.ui, prozess/pfork.ui, prozess/pgetgid.ui, prozess/pgetpgrp.ui, prozess/pgetppid.ui, prozess/pgetuid.ui, prozess/pkill.ui, prozess/pnice.ui, prozess/prusage.ui, prozess/psetgid.ui, prozess/psetlimi.ui, prozess/psetpgrp.ui, prozess/psetuid.ui, prozess/psigbloc.ui, prozess/psignal.ui, prozess/psigpend.ui, prozess/psigretu.ui, prozess/psigsetm.ui, prozess/pusrval.ui, prozess/pvfork.ui, prozess/pwait.ui, prozess/pwait3.ui, system/shutdown.ui, system/sysconf.ui: Beschreibung der Verfügbarkeit für ab MultiTOS vorhandene Funktionen um MiNT Versionsnummer 1.04 erweitert Expand description of availability for functions which are available as of MultiTOS by MiNT version number 1.04 2008-10-12 Sunday 16:52 Gerhard Stoll * bios/cookie/description/: _FDC.ui, hade.ui: Add some infos from the Hades 2008-10-05 Sunday 07:48 Gerhard Stoll * protokol/vscreen.u: Add a table with program and identifier 2008-10-05 Sunday 07:47 Gerhard Stoll * gemdos/gemdos_f.u: Add function from SysMon 2008-10-03 Friday 15:19 Gerhard Stoll * gem/aes/appl_/appl_exit.ui, gem/vdi/*, gemdos/datetime/tgettime.ui, gemdos/datetime/tsettime.ui, gemdos/dir/dcreate.ui, gemdos/dir/ddelete.ui, gemdos/dir/dfree.ui, gemdos/dir/dgetdrv.ui, gemdos/dir/dsetpath.ui, gemdos/file/fattrib.ui, gemdos/file/fchown.ui, gemdos/file/fclose.ui, gemdos/file/fdatime.ui, gemdos/file/fdelete.ui, gemdos/file/fforce.ui, gemdos/file/fgetdta.ui, gemdos/file/fwrite.ui, gemdos/memory/mfree.ui, gemdos/memory/mshrink.ui, gemdos/prozess/pseteuid.ui, gemdos/prozess/pterm.ui, gemdos/prozess/pterm0.ui, gemdos/system/slbclose.ui, magic/magic.u, xbios/bildscrm/cursconf.ui, xbios/bildscrm/getrez.ui, xbios/interrpt/jenabint.ui, xbios/intrface/dosound.ui, xbios/intrface/giaccess.ui, xbios/intrface/ikbdws.ui, xbios/intrface/iorec.ui, xbios/intrface/kbdvbase.ui, xbios/intrface/mfpint.ui, xbios/intrface/midiws.ui, xbios/intrface/offgibit.ui, xbios/intrface/ongibit.ui, xbios/intrface/rsconf.ui, xbios/laufwerk/flopfmt.ui, xbios/laufwerk/floprd.ui, xbios/laufwerk/flopver.ui, xbios/laufwerk/flopwr.ui, xbios/laufwerk/protobt.ui, xbios/spezial/blitmode.ui, xbios/spezial/cachectr.ui, xbios/spezial/cjar.ui, xbios/spezial/dbmsg.ui, xbios/spezial/janus.ui, xbios/spezial/puntaes.ui, xbios/spezial/random.ui, xbios/spezial/ssbrk.ui, xbios/spezial/supexec.ui, xbios/spezial/trapper.ui, xbios/spezial/wdgctrl.ui: Add some nolink 2008-09-23 Tuesday 21:02 Michael Bernstein * gemdos/gemdos.u: Shorten paragraph about mint compatible function in introduction because the same text occures in the chapter about filesystems. Kürzen des Absatz über Mint kompatible Funktionen in der Einleitung, da der Text ganauso im Kapitel üner Dateisystem erscheint. 2008-09-21 Sunday 20:58 Michael Bernstein * gemdos/prozess/pusrval.ui: remove short part which cause problem for translation and gives not additional information kurze Passage entfernt, die keine Zusatzinformation liefert, aber Probleme mit der Übersetzung machte 2008-09-21 Sunday 20:53 Michael Bernstein * gemdos/prozess/prozess.u: modify short description of Psigaction Kurzbeschreibung von Psigaction geändert 2008-09-21 Sunday 20:50 Michael Bernstein * gemdos/prozess/pexec.ui: modify names of some modes to names given by atari compendium Namen einiger Modi auf die Namen geändert, die das Atari Compendium benutzt 2008-09-18 Thursday 18:26 Gerhard Stoll * gem/aes/evnt_/messages/description/cab.ui: Translation by Peter A. West 2008-09-17 Wednesday 17:53 Gerhard Stoll * xbios/: xbios.u, bildscrm/*, centscrn/*, crazydot/*, ct60/*, datetime/datetime.ui, datetime/gettime.ui, datetime/nvmacces.ui, datetime/settime.ui, datetime/xbtimer.ui, drucker/*, dsp56001/*, interrpt/*, intrface/*, laufwerk/*, overscan/*, pci_bios/*, sound/*, startrac/*, tastatur/*: Change the psition of Group and Availability 2008-09-09 Tuesday 15:02 Gerhard Stoll * gemdos/network/Nversion.ui, gemdos/network/network.u, gem/vdi/escape/camera/vqp_error.ui, gem/vdi/escape/camera/vqp_films.ui, gem/vdi/escape/camera/vqp_state.ui, gem/vdi/escape/camera/vsp_save.ui, gem/vdi/escape/camera/vsp_state.ui: Translation by Peter A. West 2008-09-09 Tuesday 15:01 Gerhard Stoll * bios/bios_en.ui, bios/bios_trap.ui, bios/sys_var_en.u, bios/sys_vec_en.ui, bios/vt52.u, bios/xbra.u, bios/cookie/cookie_en.ui, bios/cookie/description/_FSR.ui, bios/function/bconin.u, bios/function/bconout.u, bios/function/bconstat.u, bios/function/bcostat.u, bios/function/drvmap.u, bios/function/getbpb.u, bios/function/getmpb.u, bios/function/kbshift.u, bios/function/mediach.u, bios/function/rwabs.u, bios/function/setexc.u, bios/function/tickcal.u, bios/structures/bpb.ui, bios/structures/md.ui, bios/structures/mpb.ui, bios/structures/pun_info.ui, tos/tos_en.ui: Correct some text and links 2008-09-09 Tuesday 13:27 Gerhard Stoll * tos_hyp.u, anhang/gpl.ui, anhang/hilfe.u: Add GPL 2008-09-03 Wednesday 23:39 Gerhard Stoll * anhang/typedefs.u, anhang/anhang/anhang.u, anhang/anhang/pmmu.u, anhang/anhang/xhdi/xhdi_en.ui, emulator.en/stem.u, magic/magic.u, magic/magic_en.u, magic/magicerr.u, magic/magicinf.u, magic/sharelib.u, magic/DFS/dfs_en.ui, magic/MagiC_PC/magicpc_en.ui, magic/XFS/xfs_en.ui, magic/threads/threads.u, protokol/dd.u, protokol/dhst.u, protokol/font.u, protokol/gdps.ui, protokol/ltlproto.u, protokol/xfsl.u, protokol/AV/av_en.ui, protokol/BubbleGEM/bubble_en.ui, protokol/olga/olga_en.ui, protokol/xacc/xacc_en.ui: Correct links and wrong UDO commandos 2008-09-03 Wednesday 07:45 Gerhard Stoll * gem/cpxdoku.u: Correct links 2008-09-03 Wednesday 07:44 Gerhard Stoll * bios/cookie/cookie_en.ui, gem/*, gemdos/*, linea/*, protokol/ssp/ssp.u, xbios/laufwerk/laufwerk.u: Correct links and wrong UDO commandos 2008-09-01 Monday 12:28 Gerhard Stoll * magic/magic_en.u, magic/DFS/dfs_en.ui, magic/MagiC_Mac/magicmac_en.ui, magic/shutdown/shutdown_en.ui, tos/tos_en.ui, tos_hyp.u, xbios/intrface/giaccess.ui, xbios/intrface/ikbdws.ui, xbios/intrface/iorec.ui, xbios/laufwerk/flopfmt.ui, xbios/overscan/oscanscr.ui, xbios/overscan/oscanvb.ui, xbios/pci_bios/pci_bios.u, xbios/pci_bios/read_config_byte.ui, xbios/pci_bios/read_config_longword.ui, xbios/pci_bios/read_config_word.ui, xbios/pci_bios/set_interrupt.ui, xbios/pci_bios/special_cycle.ui, xbios/pci_bios/unhook_interrupt.ui, xbios/sound/sound.u, xbios/sound/soundcmd.ui, xbios/startrac/wr_dconv.ui, xbios/startrac/wr_dpat1.ui, xbios/startrac/wr_dpat2.ui, xbios/startrac/wr_dpdat.ui, xbios/startrac/wr_dport.ui, xbios/startrac/wr_raes.ui, xbios/startrac/wr_rdsp.ui, xbios/startrac/wr_rhi.ui, xbios/startrac/wr_rlow.ui, xbios/structures/DSPBLOCK.ui, xbios/structures/OVERPATCH.ui, xbios/structures/PBDEF.ui, xbios/tastatur/keytbl.ui, gem/guidelns/style_en.u, gem/vdi/vdi_en.u, gemdos/gemdos.u, gemdos/file/fforce.ui, gem/aes/shel_/shel_write.ui, gem/aes/fnts_/fnts_.u, gem/aes/fnts_/fnts_add.ui, gem/aes/fnts_/fnts_close.ui, gem/aes/fnts_/fnts_create.ui, gem/aes/fnts_/fnts_delete.ui, gem/aes/fnts_/fnts_do.ui, gem/aes/fnts_/fnts_evnt.ui, gem/aes/fnts_/fnts_get_info.ui, gem/aes/fnts_/fnts_get_name.ui, gem/aes/fnts_/fnts_get_no_styles.ui, gem/aes/fnts_/fnts_get_style.ui, gem/aes/fnts_/fnts_open.ui, gem/aes/fnts_/fnts_remove.ui, gem/aes/fnts_/fnts_update.ui, anhang/typedefs.u, anhang/anhang/anhang.u, anhang/anhang/ascii.ui, anhang/anhang/pmmu.u, anhang/anhang/scan-code.ui, anhang/anhang/tos_vers.u, anhang/anhang/xhdi/xhdi_en.ui, bilder/farbe/olga_1.img, bilder/farbe/olga_2.img, bilder/farbe/olga_3.img, bilder/farbe/olga_4.img, bilder/gif/olga_1.gif, bilder/gif/olga_2.gif, bilder/gif/olga_3.gif, bilder/gif/olga_4.gif, bilder/mono/olga_1.img, bilder/mono/olga_2.img, bilder/mono/olga_3.img, bilder/mono/olga_4.img, bios/bios_en.ui, bios/sys_var_en.u, bios/xbra.u, bios/cookie/cookie_en.ui, bios/function/bconin.u, bios/function/getmpb.u: Change links 2008-09-01 Monday 12:27 Gerhard Stoll * protokol/: xfsl.u, xssi.u, olga/olga_de.ui, olga/olga_en.ui, ssp/ssp.u: Translation by Peter A. West 2008-08-26 Tuesday 13:59 Gerhard Stoll * protokol/: dd.u, dhst.u, font.u, gdps.ui, ltlproto.u, view.u, vscreen.u, AV/av_en.ui, BubbleGEM/bubble_de.ui, BubbleGEM/bubble_en.ui, olga/olga_de.ui, olga/olga_en.ui, seproto/seproto_de.ui, seproto/seproto_en.ui, ssp/ssp.u, xacc/xacc_de.ui, xacc/xacc_en.ui: Translation by Peter A. West 2008-08-03 Sunday 09:47 Gerhard Stoll * config.u, bios/bios_trap.ui, bios/sys_vec_en.ui, gem/aes/appl_/appl_search.ui, gem/aes/fslx_/fslx_.u, gem/aes/menu_/menu_settings.ui, gem/aes/objc_/objc_sysvar.ui, gem/guidelns/style_en.u, gemdos/dir/dreadlab.ui, gemdos/prozess/prozess.u, magic/DFS/dfs_en.ui, magic/XFS/xfs_en.ui, xbios/laufwerk/laufwerk.u: Correct links 2008-07-31 Thursday 18:00 Gerhard Stoll * bilder/: farbe/img2035_en.img, farbe/img2037_en.img, farbe/img2040_en.img, farbe/img2041_en.img, farbe/img2042_en.img, farbe/img2043_en.img, farbe/img2044_en.img, farbe/img2045_en.img, gif/img2035_en.gif, gif/img2037_en.gif, gif/img2040_en.gif, gif/img2041_en.gif, gif/img2042_en.gif, gif/img2043_en.gif, gif/img2044_en.gif, gif/img2045_en.gif, mono/img2035_en.img, mono/img2037_en.img, mono/img2040_en.img, mono/img2041_en.img, mono/img2042_en.img, mono/img2043_en.img, mono/img2044_en.img, mono/img2045_en.img: Translation by Peter A. West 2008-07-31 Thursday 17:54 Gerhard Stoll * xbios/pci_bios/: get_routing.ui, set_interrupt.ui, special_cycle.ui: Wrong UDO syntax 2008-07-31 Thursday 17:49 Gerhard Stoll * gem/aes/: appl_/appl_control.ui, wind_/wind_set.ui: Wrong UDO commando 2008-07-31 Thursday 17:49 Gerhard Stoll * emulator.en/sonstige.u, emulator.en/stem.u, emulator.en/tos2win.u, gem/guidelns/style_en.u, magic/XFS/xfs.u, n_aes/n_aes.u, * magic/: * xaaes/xaaes.u, tos_hyp.u, e_magic.u: Translation by Peter A. West 2008-07-27 Sunday 15:28 Michael Bernstein * gemdos/: gemdos.u, datetime/talarm.ui, datetime/tgetdate.ui, dir/dopendir.ui, file/fcntl.ui, file/fgetdta.ui, file/finstat.ui, file/flink.ui, file/foutstat.ui, file/fputchar.ui, file/fread.ui, prozess/pexec.ui, prozess/psetpgrp.ui, prozess/psigbloc.ui, prozess/psigpaus.ui, prozess/pwait.ui, structures/DTA.ui, system/sversion.ui, system/sysconf.ui: Bugfixes aufgrund von Anmerkungen, die Peter West beim Vergleich mit dem Atari Compendium bei der Übersetzung gemacht hatte. Bugfixes made because of annotations made by Peter West as a result of comparing with Atari Compendium while translating from german to english. 2008-07-19 Saturday 18:39 Gerhard Stoll * magic/: * gem/cpxdoku.u, gem/guidelns/style.u, gem/guidelns/style_en.u: Translation by Peter A. West 2008-06-29 Sunday 13:46 Gerhard Stoll * anhang/hilfe.u, anhang/typedefs.u, anhang/anhang/anhang.u, anhang/changes/04_90.ui, anhang/changes/04_93.ui, anhang/changes/04_95.ui, anhang/changes/old.ui, bios/sys_vec_de.ui, bios/sys_vec_en.ui, bios/vt52.u, bios/cookie/list.ui, bios/cookie/description/DYJD.ui, bios/cookie/description/DYwl.ui, bios/cookie/description/MagX.ui, bios/cookie/description/MgMc.ui, bios/cookie/description/MgMx.ui, bios/cookie/description/MgSn.ui, bios/cookie/description/StIc.ui, bios/cookie/description/SwTm.ui, bios/cookie/description/WICO.ui, bios/cookie/description/_FDC.ui, bios/cookie/description/_FLK.ui, gem/aes/aes_f.u, gem/aes/evnt_/messages/evnts_de.ui, gem/aes/evnt_/messages/messages.u, gem/aes/fnts_/fnts_.u, gem/aes/fsel_/fsel_.u, gem/aes/fsel_/fsel_boxinput.ui, gem/aes/fslx_/fslx_.u, gem/aes/fslx_/use.ui, gem/aes/lbox_/lbox_.u, gem/aes/menu_/menu_.u, gem/aes/objc_/objc_.u, gem/aes/objc_/objc_sysvar.ui, gem/aes/shel_/shel_.u, gem/aes/shel_/shel_get.ui, gem/aes/shel_/shel_put.ui, gem/aes/shel_/shel_write.ui, gem/aes/structures/hndl_obj.ui, gem/aes/structures/prn_settings.ui, gem/aes/wdlg_/wdlg_.u, gem/aes/wdlg_/wdlg_get_edit.ui, gem/aes/wind_/wind_create.ui, gem/aes/wind_/wind_get.ui, gem/aes/wind_/wind_open.ui, gem/aes/wind_/wind_set.ui, gem/guidelns/style.u, gem/guidelns/style_en.u, gem/vdi/vdi.u, gem/vdi/vdi_en.u, gemdos/dir/dfree.ui, gemdos/dir/dgetdrv.ui, gemdos/dir/dsetdrv.ui, gemdos/file/fcreate.ui, gemdos/file/fdelete.ui, gemdos/file/fdup.ui, gemdos/file/fforce.ui, gemdos/file/frename.ui, gemdos/file/fselect.ui, gemdos/file/fsfirst.ui, gemdos/system/sconfig.ui, gemdos/system/slbclose.ui, gemdos/system/slbopen.ui, magic/magic.u, magic/magicinf.u, magic/magicmac.u, magic/magicpc.u, magic/xfs.u, magic/shutdown/shutdown_de.ui, magic/threads/threads.u, protokol/ltlproto.u, tos/tos_de.ui, tos/tos_en.ui, xbios/xbios.u, xbios/drucker/prtblk.ui, xbios/drucker/scrdmp.ui, xbios/laufwerk/floprate.ui, xbios/pci_bios/pci_bios.u, xbios/spezial/blitmode.ui, xbios/spezial/ssbrk.ui, xbios/structures/META_INFO_2.ui, xbios/structures/bconmap.ui: Change MagiCMac and MagiCPC to MagiC Mac and MagiC PC 2008-06-12 Thursday 17:59 Gerhard Stoll * gem/aes/: * gem/structures/: * gem/aes/appl_/: * gem/aes/shel_/: Translation by Peter A. West 2008-06-08 Sunday 07:07 Gerhard Stoll * gem/aes/wind_/wind_get_set.ui: Add source from WF_MINXYWH and WF_INFOXYWH 2008-06-08 Sunday 07:07 Gerhard Stoll * gem/aes/objc_/: * gem/aes/rsrc_/: * gem/aes/menu_/: * gem/aes/xgrf_/: * gem/aes/lbox_/: Translation by Peter A. West 2008-06-03 Tuesday 19:24 Gerhard Stoll * gem/aes/appl_/appl_getinfo.ui: Wrong number fron WinX 2008-05-31 Saturday 06:14 Gerhard Stoll * gem/aes/: * gem/scrp_/: * gem/aes/form_/: Translation by Peter A. West 2008-05-27 Tuesday 16:14 Gerhard Stoll * bios/cookie/: cookie.u, list.ui, description/AMCG.ui: Add the cookie AMCG (AMC-GDOS) 2008-05-27 Tuesday 16:11 Gerhard Stoll * xbios/: xbios_f.u, xbios_f.u: Wrong opcode by GetActiveFeatures 2008-05-23 Friday 07:39 Gerhard Stoll * gem/aes/fslx_/: * gem/aes/wind_/: * gem/aes/wdlg_/: * gem/aes/evnt_/: * gem/aes/edit_/: * gem/aes/pdlg_/: * gem/aes/fsel_/: * gem/aes/: aes_f.u, toolbar.ui * gem/aes/appl_/: Translation by Peter A. West 2008-05-13 Tuesday 14:11 Gerhard Stoll * xbios/: xbios_f.u, pci_bios/get_routing.ui, pci_bios/pci_bios.u, pci_bios/set_interrupt.ui, pci_bios/special_cycle.ui: Add more PCI-XBIOS function 2008-05-01 Thursday 16:55 Gerhard Stoll * gem/aes/: aes.u, aes_en.u, toolbar.ui: Translation by Peter A. West 2008-05-01 Thursday 16:54 Gerhard Stoll * bilder/: gif/fenster_en.gif, farbe/fenster_en.img, mono/fenster_en.img: New picture from Peter A. West 2008-03-30 Sunday 09:31 Gerhard Stoll * gem/vdi/raster/: Translation by Peter A. West 2008-03-29 Saturday 20:21 Gerhard Stoll * gem/vdi/attribut/: * gem/vdi/control/: * gem/vdi/inquire/: * gem/vdi/output/: * gem/vdi/colortable/: * gem/vdi/escape/: * bios/bios_en.ui, bios/sys_vec_en.ui, gem/aes/aes_en.u, * gem/aes/appl_/appl_getinfo.ui, gem/vdi/vdi_en.u, gem/vdi/attribut/text/*, gem/vdi/attribut/uebergeordnete/*, gem/vdi/escape/metafile/*, gem/vdi/output/*, gem/vdi/structures/xfnt_info.ui, gemdos/gemdos.u, gemdos/signale.u, gemdos/file/fforce.ui, gemdos/file/fopen.ui, xbios/xbios.u: Translation by Peter A. West 2008-03-22 Saturday 09:06 Gerhard Stoll * gem/vdi/input/: input.u, v_hide_c.ui, v_show_c.ui, vex_butv.ui, vex_curv.ui, vex_motv.ui, vex_timv.ui, vex_wheelv.ui, vq_key_s.ui, vq_mouse.ui, vrq_choice.ui, vrq_locator.ui, vrq_string.ui, vrq_valuator.ui, vsc_form.ui, vsin_mode.ui, vsm_choice.ui, vsm_locator.ui, vsm_string.ui, vsm_valuator.ui: Translation by Peter A. West 2008-03-21 Friday 14:41 Gerhard Stoll * gem/vdi/inquire/: disable_nvdi.ui, fontheader.ui, inquire.u, v_create_driver_info.ui, v_delete_driver_info.ui, v_get_driver_info.ui, v_getbitmap_info.ui, v_read_default_settings.ui, v_write_default_settings.ui, vq_cellarray.ui, vq_color.ui, vq_devinfo.ui, vq_ext_devinfo.ui, vq_extnd.ui, vq_scrninfo.ui, vqf_attributes.ui, vqf_bg_color.ui, vqf_fg_color.ui, vqin_mode.ui, vql_attributes.ui, vql_bg_color.ui, vql_fg_color.ui, vqm_attributes.ui, vqm_bg_color.ui, vqm_fg_color.ui, vqr_bg_color.ui, vqr_fg_color.ui, vqt_advance.ui, vqt_advance32.ui, vqt_attributes.ui, vqt_bg_color.ui, vqt_cachesize.ui, vqt_char_index.ui, vqt_ext_name.ui, vqt_extent.ui, vqt_f_extent.ui, vqt_fg_color.ui, vqt_fontheader.ui, vqt_fontinfo.ui, vqt_get_table.ui, vqt_justified.ui, vqt_name.ui, vqt_name_and_id.ui, vqt_pairkern.ui, vqt_real_extent.ui, vqt_trackkern.ui, vqt_width.ui, vqt_xfntinfo.ui: Translation by Peter A. West 2008-03-17 Monday 13:25 Gerhard Stoll * gemdos/gemdos_f.u: Wrong opcode from Maccess 2008-03-16 Sunday 16:34 Gerhard Stoll * gem/vdi/output/: output.u, v_arc.ui, v_bar.ui, v_bez.ui, v_bez_fill.ui, v_cellarray.ui, v_circle.ui, v_contourfill.ui, v_ellarc.ui, v_ellipse.ui, v_ellpie.ui, v_etext.ui, v_fillarea.ui, v_ftext.ui, v_ftext_offset.ui, v_gtext.ui, v_justified.ui, v_pieslice.ui, v_pline.ui, v_pmarker.ui, v_rbox.ui, v_rfbox.ui, vr_recfl.ui: Translation by Peter A. West 2008-03-12 Wednesday 18:33 Gerhard Stoll * gemdos/: prozess/pwait3.ui, system/ssystem.ui: Wrong UDO syntax 2008-03-12 Wednesday 18:32 Gerhard Stoll * bios/bios.u, bios/bios_en.ui, xbios/xbios.u, gemdos/gemdos.u, magic/magicerr.u: Translation by Peter A. West 2008-03-07 Friday 17:56 Gerhard Stoll * bios/cookie/: list.ui, description/*: * gem/vdi/: vdi_f.u, attribut/*, structures/*: * bios/cookie/description/_VDI.ui, xbios/bildscrm/getrez.ui, xbios/bildscrm/setpalet.ui, xbios/bildscrm/vsetmask.ui, gem/vdi/assign_sys.ui, gem/vdi/metafile.u, gem/vdi/vdi.u, gem/vdi/vdi_en.u, gem/vdi/attribut/attribut.u, gem/vdi/attribut/bitmap/bitmap.u, gem/vdi/attribut/fill/fill.u, gem/vdi/attribut/linien/lines.u, gem/vdi/attribut/marker/marker.u, gem/vdi/attribut/text/text.u, gem/vdi/attribut/uebergeordnete/superior.u: Translation by Peter A. West 2008-01-27 Sunday 13:34 Gerhard Stoll * tos/: tos_de.ui, tos_en.ui: * linea/: Translation by Peter A. West 2008-01-13 Sunday 20:41 Michael Bernstein * gemdos/: signale.u * gemdos/chrinout/: * gemdos/dir/: * gemdos/file/: * gemdos/prozess/: * gemdos/structures/PD.ui, structures/flock.ui: Erweiterungen hinzugefuegt, die Peter West beim Uebersetzen von Deutsch nach Englisch mit Hilfe des AC eingefuegt hatte. Add extensions made by Peter West with help of AC while translate from german to english. 2008-01-08 Tuesday 18:32 Gerhard Stoll * gemdos/: filesys.u, gemdos.u, gemdos_f.u, signale.u, chrinout/cauxin.ui, chrinout/cconws.ui, file/fforce.ui, prozess/psetauid.ui, prozess/psignal.ui, prozess/pwait3.ui, structures/PD.ui, structures/sigaction.ui, system/ssystem.ui, system/super.ui: Translation by Peter A. West 2008-01-01 Tuesday 19:38 Michael Bernstein * gemdos/: argv.u, filesys.u, gemdos.u, gemdos_f.u, signale.u, tekbios.u, chrinout/*, datetime/*, dir/*, file/*, memory/*, prozess/*, structures/*, system/*: Uebersetzung von Peter West integriert. Seine Kommentare wurden noch nicht beachtet, da sie etwas Recherche erfordern. Add translations from Peter West. His comments ignored at this time because they need some research work. 2007-12-30 Sunday 09:33 Gerhard Stoll * xbios/*, bios/sys_var_en.u, bios/xbra.u, bios/cookie/description/FSMC.ui, bios/cookie/description/NVDI.ui, bios/cookie/description/_FLK.ui, bios/cookie/description/_NET.ui, bios/structures/mpb.ui, anhang/anhang/ascii.ui: Translation by Peter A. West 2007-12-27 Thursday 10:22 Gerhard Stoll * xbios/: startrac/installe.ui * xbios/structures/: * xbios/: xbios_f.u * xbios/spezial/: * xbios/tastatur/: * xbios/: sound/*, startrac/*: * xbios/pci_bios/: Translation by Peter A. West 2007-12-09 Sunday 10:30 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Messages from Porthos add 2007-12-04 Tuesday 20:10 Gerhard Stoll * xbios/overscan/: oscanis.ui, oscanpat.ui, oscanphy.ui, oscanscr.ui, oscanswi.ui, oscantab.ui, oscanvb.ui, overscan.u: Translation by Peter A. West 2007-12-04 Tuesday 20:10 Gerhard Stoll * gemdos/gemdos_f.u: Add function from GEMTASK Royal to the list 2007-12-02 Sunday 09:50 Gerhard Stoll * xbios/: datetime/settime.ui, dsp56001/iostream.ui, dsp56001/outstrea.ui, interrpt/jdisint.ui, interrpt/jenabint.ui, laufwerk/*: * xbios/centscrn/: vattrib.ui, vclose.ui, vcreate.ui, vdelete.ui, vfirst.ui, vload.ui, vlock.ui, vnext.ui, voffset.ui, vopen.ui, vread.ui, vsave.ui, vscroll.ui, vseek.ui, vsize.ui, vvalid.ui, vwrite.ui: * xbios/: dsp56001/*, interrpt/interrpt.u, interrpt/jdisint.ui, interrpt/jenabint.ui: Translation by Peter A. West 2007-10-07 Sunday 08:59 Gerhard Stoll * bios/cookie/description/: CT60.ui, FSMC.ui, NVDI.ui, _MCH.ui: More infos from some cookies 2007-10-07 Sunday 08:58 Gerhard Stoll * xbios/: datetime/datetime.u, datetime/datetime.ui, datetime/gettime.ui, datetime/nvmacces.ui, datetime/settime.ui, datetime/xbtimer.ui, drucker/drucker.u, drucker/prtblk.ui, drucker/scrdmp.ui, drucker/setprt.ui, dsp56001/availabl.ui, dsp56001/blkbytes.ui, dsp56001/blkhndsh.ui, dsp56001/dsp56001.u: * config.u, bios/cookie/example_en.ui, gem/vdi/vdi.u, gem/vdi/vdi_en.u, xbios/bildscrm/*, xbios/centscrn/*, xbios/crazydot/*, xbios/crazydot/resetscr.ui, xbios/ct60/cache.ui, xbios/ct60/ct60.u, xbios/ct60/ct60_vmalloc.ui, xbios/ct60/fl_cache.ui, xbios/ct60/rcortemp.ui, xbios/ct60/rd_param.ui: * config.u, gem/aes/aes_f.u, gem/aes/appl_/appl_getinfo.ui, gemdos/gemdos_f.u, xbios/xbios.u, xbios/bildscrm/bildscrm.u, xbios/bildscrm/cursconf.ui, xbios/bildscrm/egetpale.ui, xbios/bildscrm/egetshif.ui, xbios/bildscrm/esetbank.ui, xbios/startrac/scmsmode.ui: Translation by Peter A. West 2007-08-26 Sunday 16:37 Gerhard Stoll * xbios/pci_bios/get_machine_id.ui: Manufacturer code from ARAnyM 2007-08-26 Sunday 16:36 Gerhard Stoll * bios/: bios_en.ui, cookie/cookie.u, cookie/cookie_en.ui, cookie/description/CHBT.ui, cookie/description/CHN1.ui, cookie/description/CHNG.ui, cookie/description/FSER.ui: Small text changes 2007-08-13 Monday 19:50 Gerhard Stoll * magic/magic.u, anhang/typedefs.u: Wrong label 2007-08-13 Monday 19:50 Gerhard Stoll * protokol/dhst.u: Add define DHST_ADD and DHST_ACK 2007-08-13 Monday 19:49 Gerhard Stoll * gem/aes/evnt_/messages/: geneva.ui, messages.u, rsdaemon.ui, description/cab.ui, description/geneva.ui, description/rsdaemon.ui: CAB Protocol 2007-08-13 Monday 19:48 Gerhard Stoll * bios/cookie/: list.ui, description/GSND.ui: GSND is a cookie 2007-08-04 Saturday 05:52 Gerhard Stoll * bios/cookie/description/GMTC.ui: Infos for programmer 2007-08-04 Saturday 05:52 Gerhard Stoll * gemdos/structures/flock.ui: Add some lables 2007-08-04 Saturday 05:52 Gerhard Stoll * anhang/typedefs.u: Wrong syntax in XCPB 2007-07-03 Tuesday 18:01 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Message from the GFA-Basic Editor (GBE) 2007-07-03 Tuesday 18:00 Gerhard Stoll * gemdos/: gemdos.u, network/Nversion.ui, network/network.u: Network function 2007-07-03 Tuesday 17:59 Gerhard Stoll * anhang/: neu.u, changes/04_98.ui: Start with version 4.98 2007-06-17 Sunday 17:05 Gerhard Stoll * anhang/changes/04_97.ui: Make Release 4.97 2007-06-17 Sunday 06:52 Gerhard Stoll * bios/cookie/: cookie.u, list.ui: Delete some links 2007-06-16 Saturday 12:14 Gerhard Stoll * bios/bios_en.ui: Small chnages 2007-06-16 Saturday 12:13 Gerhard Stoll * gem/aes/wind_/wind_get_set_geneva.ui: Double defined symbol 2007-06-16 Saturday 08:24 Gerhard Stoll * bios/cookie/description/PRNß.ui: Delete file with no good filename 2007-06-15 Friday 17:07 Gerhard Stoll * bios/cookie/description/PRNSS.ui: Change filename 2007-06-15 Friday 16:40 Gerhard Stoll * bios/cookie/list.ui: Wrong UDO syntax 2007-06-15 Friday 16:40 Gerhard Stoll * bios/cookie/description/LMus.ui: Wrong headline
2007-06-15 Friday 16:40 Gerhard Stoll * anhang/anhang/tos_vers.u: Add TOS 4.06 2007-06-03 Sunday 07:16 Gerhard Stoll * bios/cookie/description/MAGN.ui: More info about the cookie 2007-06-03 Sunday 07:13 Gerhard Stoll * bios/bios_f.u: Correct Bios function 0x10 2007-05-28 Monday 08:01 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Add messages from MyOSD 2007-05-19 Saturday 08:38 Gerhard Stoll * bios/cookie/description/LOGB.ui: More info about the cookie 2007-05-05 Saturday 13:20 Gerhard Stoll * config.u, bilder/farbe/cl_width_en.img, bilder/farbe/extent_en.img, bilder/farbe/f_select_en.img, bilder/farbe/fenster_en.img, bilder/farbe/fontinfo_en.img, bilder/farbe/img2034_en.img, bilder/farbe/koords_en.img, bilder/farbe/raster_en.img, bilder/farbe/taskman_en.img, bilder/farbe/tpa_en.img, bilder/farbe/wr_modi_en.img, bilder/farbe/xcontrol_en.img, bilder/gif/cl_width_en.gif, bilder/gif/extent_en.gif, bilder/gif/f_select_en.gif, bilder/gif/fenster_en.gif, bilder/gif/fontinfo_en.gif, bilder/gif/img2034_en.gif, bilder/gif/koords_en.gif, bilder/gif/raster_en.gif, bilder/gif/taskman_en.gif, bilder/gif/tpa_en.gif, bilder/gif/wr_modi_en.gif, bilder/gif/xcontrol_en.gif, bilder/mono/cl_width_en.img, bilder/mono/extent_en.img, bilder/mono/f_select_en.img, bilder/mono/fenster_en.img, bilder/mono/fontinfo_en.img, bilder/mono/img2034_en.img, bilder/mono/koords_en.img, bilder/mono/raster_en.img, bilder/mono/taskman_en.img, bilder/mono/tpa_en.img, bilder/mono/wr_modi_en.img, bilder/mono/xcontrol_en.img, gem/aes/fsel_/fsel_exinput.ui, gem/aes/wind_/components.ui, gem/aes/wind_/wind_get_set_geneva.ui, gem/guidelns/style_en.u, gem/vdi/vdi_en.u, gem/vdi/attribut/fill/filltypes.ui, gem/vdi/control/v_opnbm.ui, gem/vdi/control/v_pat_rotate.ui, gem/vdi/inquire/vqt_extent.ui, gem/vdi/inquire/vqt_fontinfo.ui, gem/vdi/inquire/vqt_width.ui, gemdos/gemdos.u: Translation by Peter A. West 2007-04-28 Saturday 13:02 Gerhard Stoll * config.u, tos_hyp.u, bios/bios_en.ui, gem/aes/wind_/wind_get.ui, xbios/bildscrm/cursconf.ui, xbios/bildscrm/egetpale.ui, xbios/bildscrm/egetshif.ui, xbios/bildscrm/esetbank.ui, xbios/bildscrm/esetcolo.ui, xbios/bildscrm/esetgray.ui, xbios/bildscrm/esetpale.ui, xbios/bildscrm/esetshif.ui, xbios/bildscrm/esetsmea.ui, xbios/bildscrm/getrez.ui, xbios/bildscrm/initmous.ui, xbios/bildscrm/logbase.ui, xbios/bildscrm/mon_type.ui, xbios/bildscrm/physbase.ui, xbios/bildscrm/setcolor.ui, xbios/bildscrm/setpalet.ui, xbios/bildscrm/setscree.ui, xbios/bildscrm/vgetrgb.ui, xbios/bildscrm/vgetsize.ui, xbios/bildscrm/vsetmask.ui, xbios/bildscrm/vsetmode.ui, xbios/bildscrm/vsetrgb.ui, xbios/bildscrm/vsetscre.ui, xbios/bildscrm/vsetsync.ui, xbios/bildscrm/vsync.ui, xbios/centscrn/multimon.ui, xbios/centscrn/setmon.ui, xbios/centscrn/sizecomp.ui, xbios/centscrn/vattrib.ui, xbios/centscrn/vclose.ui, xbios/centscrn/vcreate.ui, xbios/centscrn/vdelete.ui, xbios/centscrn/vfirst.ui, xbios/centscrn/vload.ui, xbios/centscrn/vlock.ui, xbios/centscrn/vnext.ui, xbios/centscrn/voffset.ui, xbios/centscrn/vopen.ui, xbios/centscrn/vread.ui, xbios/centscrn/vsave.ui, xbios/centscrn/vscroll.ui, xbios/centscrn/vseek.ui, xbios/centscrn/vsize.ui, xbios/centscrn/vvalid.ui, xbios/centscrn/vwrite.ui, xbios/crazydot/acmodenr.ui, xbios/crazydot/cpmd2amd.ui, xbios/crazydot/gamddesc.ui, xbios/crazydot/getafeat.ui, xbios/crazydot/getfeat.ui, xbios/crazydot/getnofpm.ui, xbios/crazydot/getpmode.ui, xbios/crazydot/gregbase.ui, xbios/crazydot/gscrdesc.ui, xbios/crazydot/readmode.ui, xbios/crazydot/resetscr.ui: Translation by Peter A. West 2007-04-28 Saturday 12:57 Gerhard Stoll * bios/cookie/description/Gnva.ui, gem/aes/appl_/appl_yield.ui, gem/aes/appl_/x_appl_flags.ui, gem/aes/appl_/x_appl_sleep.ui, gem/aes/evnt_/messages/geneva.ui, gem/aes/graf_/graf_slidebox.ui, gem/aes/structures/rsxhdr.ui, gem/aes/wind_/wind_.u, gem/aes/wind_/wind_get_set.ui, gem/aes/wind_/wind_get_set_geneva.ui, gem/aes/form_/form_.u, gem/aes/form_/form_center.ui, gem/aes/form_/form_dial.ui, gem/aes/form_/x_form_center.ui, gem/aes/form_/x_form_error.ui: Infos from Geneva add 2007-04-24 Tuesday 18:39 Gerhard Stoll * gem/aes/: appl_/x_appl_flags.ui, structures/ANI_MOUSE.ui, structures/APPFLAGS.ui, structures/APPFLG.ui, structures/XFONTINFO.ui, structures/menu.ui, structures/structures.u: Add some structures from Geneva 2007-04-22 Sunday 17:34 Gerhard Stoll * tos_hyp.u, anhang/hilfe.u, anhang/anhang/anhang.u, anhang/anhang/ascii.ui, anhang/anhang/scan-code.ui, anhang/anhang/xhdi/xhdi_en.ui, bios/bios_en.ui, bios/bios_trap.ui, bios/sys_vec_en.ui, bios/vt52.u, bios/xbra.u, bios/function/bconin.u, bios/function/bconout.u, bios/function/bconstat.u, bios/function/bcostat.u, bios/function/drvmap.u, bios/function/getbpb.u, bios/function/getmpb.u, bios/function/kbshift.u, bios/function/mediach.u, bios/function/rwabs.u, bios/function/setexc.u, bios/function/tickcal.u, gem/aes/evnt_/evnt_keybd.ui, gem/aes/structures/scanx.ui, gem/aes/structures/xdo_inf.ui, gem/guidelns/style_en.u, protokol/AV/av_en.ui, xbios/tastatur/keytbl.ui, xbios/tastatur/tastatur.u: Translation by Peter A. West 2007-04-21 Saturday 06:51 Gerhard Stoll * config.u, e_aes.u, e_bios.u, e_cpxdok.u, e_funk_l.u, e_gemdos.u, e_linea.u, e_magic.u, e_olga.u, e_protok.u, e_tos.u, e_tos_li.u, e_vdi.u, e_view.u, e_vt52.u, e_xbios.u, e_xbra.u, e_xhdi.u, tos_hyp.u, anhang/hilfe.u, anhang/anhang/tos_vers.u, bios/bios.u, bios/bios_en.ui, bios/sys_var.u, bios/sys_var_de.u, bios/sys_var_en.u, bios/sys_vec_de.ui, bios/sys_vec_en.ui, gem/gem.u, tos/tos_de.ui, tos/tos_en.ui: Translation by Peter A. West 2007-04-08 Sunday 08:38 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Message form Aniplayer and M_PLAYER 2007-04-06 Friday 10:02 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Message form Suji 2007-03-25 Sunday 17:33 Gerhard Stoll * protokol/AV/: av.u, av_de.ui, av_en.ui: Update AV protocol VA_THAT_IZIT : VA_OB_NOTEPAD and VA_OB_NOTE VA_PROTOSTATUS: Bit 5 (AV_SENDCLICK) AV_XWIND : Bit 2 AV_VIEW : msg[5] 2007-03-09 Friday 10:27 Gerhard Stoll * protokol/AV/av.u, protokol/AV/av_de.ui, protokol/AV/av_en.ui, protokol/av.u, e_protok.u, tos_hyp.u: First translation of the AV protocol 2007-03-07 Wednesday 07:48 Gerhard Stoll * gem/aes/wind_/wind_get.ui: Description the bug in TOS 1.02 by WF_SCREEN 2007-02-16 Friday 17:39 Gerhard Stoll * xbios/: xbios_f.u, pci_bios/error.ui, pci_bios/fast_read_config_byte.ui, pci_bios/fast_read_config_longword.ui, pci_bios/fast_read_config_word.ui, pci_bios/fpclassc.ui, pci_bios/fpdevice.ui, pci_bios/get_machine_id.ui, pci_bios/get_resource.ui, pci_bios/hook_interrupt.ui, pci_bios/pci_bios.u, pci_bios/read_config_longword.ui, pci_bios/unhook_interrupt.ui, pci_bios/write_config_longword.ui, pci_bios/write_config_word.ui, structures/PCI_RSC_DESC.ui, structures/structures.u: Add PCI-BIOS function get_machine_id, get_resource and unhook_interrupt 2007-02-12 Monday 06:37 Gerhard Stoll * xbios/bildscrm/mon_type.ui: Value Value four and five from the ct60 2007-02-11 Sunday 14:39 Gerhard Stoll * bios/cookie/: cookie.u, description/MN3D.ui: Cookie form the MENU3D.PRG 2007-02-11 Sunday 14:34 Gerhard Stoll * bios/cookie/: cookie.u, list.ui, description/Nspd.ui: Cookie form the acceleration-card Nemesis 2007-02-03 Saturday 16:06 Gerhard Stoll * xbios/: xbios_f.u, bildscrm/Setscreen_Milan.ui, bildscrm/Setscreen_ct60.ui, bildscrm/bildscrm.u, bildscrm/vsetscre.ui, ct60/cache.ui, ct60/ct60.u, ct60/ct60_vmalloc.ui, ct60/fl_cache.ui, ct60/rcortemp.ui, ct60/rd_param.ui, structures/SCREENINFO.ui, structures/SCRMEMBLK.ui: Add new XBIOS functions from the ct60 (2007-01-24) 2007-01-20 Saturday 16:20 Gerhard Stoll * gem/vdi/: vdi_en.u, attribut/attribut.u, attribut/bitmap/bitmap.u, attribut/fill/vsf_xperimeter.ui, attribut/linien/lines.u, attribut/linien/v_bez_qual.ui, attribut/linien/vsl_bg_color.ui, attribut/linien/vsl_color.ui, attribut/linien/vsl_ends.ui, attribut/linien/vsl_fg_color.ui, attribut/linien/vsl_type.ui, attribut/linien/vsl_udsty.ui, attribut/linien/vsl_width.ui, attribut/marker/marker.u, attribut/marker/vsm_bg_color.ui, attribut/marker/vsm_color.ui, attribut/marker/vsm_fg_color.ui, attribut/text/text.u, attribut/text/v_topbot.ui, attribut/text/vst_alignment.ui, attribut/text/vst_arbpt.ui, attribut/text/vst_bg_color.ui, attribut/text/vst_fg_color.ui, attribut/text/vst_scratch.ui, attribut/text/vst_setsize.ui, attribut/uebergeordnete/superior.u, attribut/uebergeordnete/v_ps_halftone.ui, attribut/uebergeordnete/v_setrgb.ui, attribut/uebergeordnete/v_setrgbi.ui, attribut/uebergeordnete/vs_color.ui, attribut/uebergeordnete/vs_color2.ui, attribut/uebergeordnete/vs_grayoverride.ui, attribut/uebergeordnete/vswr_mode.ui: Small Update for the english version 2007-01-01 Monday 15:43 Gerhard Stoll * bios/cookie/: cookie.u, list.ui, description/FAX_.ui, description/MCWR.ui: Cookie from STarFax 2007-01-01 Monday 15:42 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Messages from QFax/Pro, STarFax and ViewFax 2006-12-15 Friday 18:10 Gerhard Stoll * bios/cookie/: cookie.u, list.ui, description/CHBT.ui, description/CHTW.ui, description/CICN.ui, description/CLOK.ui, description/DATE.ui, description/DYDL.ui, description/DYwl.ui, description/EURO.ui, description/FSER.ui, description/Gnva.ui, description/HSND.ui, description/MCSP.ui, description/McSn.ui, description/MgSn.ui, description/PAUL.ui, description/PDEB.ui, description/RFLX.ui, description/RSVE.ui, description/SCSI.ui, description/SSND.ui, description/TIME.ui, description/Tmon.ui, description/Typ1.ui, description/UFSL.ui, description/UsNm.ui, description/WRAP.ui, description/XSDD.ui, description/_FSR.ui, description/ck01.ui, description/nTOS.ui: More Cookies and XBRA 2006-12-15 Friday 18:08 Gerhard Stoll * xbios/sound/soundcmd.ui: Add info about mode 7 2006-11-19 Sunday 09:53 Gerhard Stoll * anhang/anhang/tos_vers.u: Add more TOS versions 2006-11-18 Saturday 19:45 Gerhard Stoll * bios/cookie/list.ui: VDLY is a cookie 2006-11-04 Saturday 09:36 Gerhard Stoll * gemdos/system/sconfig.ui: Small translation 2006-11-04 Saturday 09:33 Gerhard Stoll * xbios/bildscrm/bildscrm.u: Small correcting 2006-11-04 Saturday 09:32 Gerhard Stoll * bios/cookie/: cookie.u, list.ui, description/KAOS.ui: Add KAOS cookie
2006-10-21 Saturday 13:30 Gerhard Stoll * bios/cookie/: list.ui, description/EdDI.ui: More info about EdDI 2006-10-21 Saturday 13:30 Gerhard Stoll * bios/sys_var.u: More info from memcntrl 2006-09-14 Thursday 14:54 Gerhard Stoll * gem/aes/shel_/shel_write.ui, gem/aes/structures/sheltail.ui, magic/magic.u, magic/magicmac.u, magic/shutdown/shutdown.u, magic/shutdown/shutdown_de.ui, magic/shutdown/shutdown_en.ui: Translate a little bit 2006-09-07 Thursday 16:24 Gerhard Stoll * bios/cookie/: cookie.u, list.ui: Cookie DCSD, fVDI and VDI, CKBD is also a cookie 2006-09-07 Thursday 16:24 Gerhard Stoll * bios/cookie/description/: DCSD.ui, VDIp.ui, fVDI.ui: Cookie DCSD, fVDI and VDI 2006-08-27 Sunday 08:35 Gerhard Stoll * anhang/anhang/tos_vers.u: Mistake in UDO syntax 2006-08-18 Friday 16:01 Gerhard Stoll * bios/cookie/description/_MCH.ui: Mistake in UDO syntax 2006-08-12 Saturday 19:25 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Messages from MultiGEM2 2006-08-12 Saturday 19:24 Gerhard Stoll * gemdos/gemdos_f.u, gem/aes/aes_f.u: Function from MultiGEM2 2006-08-08 Tuesday 17:11 Gerhard Stoll * gem/aes/: aes_f.u, appl_/appl_.u, appl_/appl_search.ui, appl_/x_appl_flags.ui, appl_/x_appl_font.ui, appl_/x_appl_sleep.ui, appl_/x_appl_term.ui, evnt_/evnt_multi.ui, form_/form_alert.ui, form_/form_dial.ui, form_/form_error.ui, graf_/graf_mouse.ui, graf_/graf_slidebox.ui, rsrc_/rsrc_load.ui, shel_/shel_write.ui, wind_/wind_get.ui, wind_/wind_set.ui: x_appl_flags, x_appl_font, x_appl_sleep, x_appl_term and other infos form Geneva 2006-08-08 Tuesday 15:54 Gerhard Stoll * bios/cookie/list.ui: AHVR is also a cookie 2006-08-08 Tuesday 15:50 Gerhard Stoll * gemdos/structures/DOSVARS.ui, gem/aes/rsrc_/rsrc_rcfix.ui: Change the look of the text 2006-08-08 Tuesday 15:50 Gerhard Stoll * gem/vdi/control/v_savecache.ui: Correcting the binding 2006-08-07 Monday 18:08 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Messages from Interface 2006-08-06 Sunday 17:14 Gerhard Stoll * gem/aes/structures/: rshdr.ui, rsxhdr.ui, structures.u, tedinfo.ui: Add extend resource header 2006-08-06 Sunday 17:13 Gerhard Stoll * gem/aes/evnt_/messages/: evnts_de.ui, evnts_en.ui, geneva.ui, messages.u: Add Messages from Geneva 2006-08-06 Sunday 17:12 Gerhard Stoll * gem/aes/appl_/appl_read.ui: Add link to appl_getinfo 2006-08-06 Sunday 17:12 Gerhard Stoll * gem/aes/aes.u, gem/aes/aes_en.u, gem/aes/evnt_/evnt_mesag.ui, gem/aes/menu_/menu_attach.ui, bios/cookie/description/_MCH.ui: Change the look of the text 2006-08-06 Sunday 17:11 Gerhard Stoll * bios/cookie/list.ui: BLOW used as cookie and XBRA 2006-06-19 Monday 20:45 Gerhard Stoll * bios/cookie/: cookie.u, list.ui, description/LEmu.ui, description/LMus.ui, description/Lace.ui, description/MgSn.ui: Cookie MgSn, Lace, LEmu and LMus add 2006-06-19 Monday 20:43 Gerhard Stoll * anhang/typedefs.u: Adress from p_run for TOS < 1.02 (OSHEADER) 2006-06-19 Monday 20:43 Gerhard Stoll * protokol/vscreen.u: Small translation 2006-06-16 Friday 14:40 Gerhard Stoll * anhang/typedefs.u: Detecting from EmuTOS (OSHEADER) 2006-06-12 Monday 09:55 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Messages from EB DUMP 2006-06-11 Sunday 09:47 Gerhard Stoll * anhang/: changes/04_96.ui, neu.u: Start with version 4.96 2006-06-11 Sunday 09:38 Gerhard Stoll * config.u, anhang/changes/04_95.ui: Make Release 4.95 2006-06-11 Sunday 09:36 Gerhard Stoll * anhang/hilfe.u: Change email 2006-06-11 Sunday 09:36 Gerhard Stoll * bilder/gif/email.gif: Email as graphic
2006-06-09 Friday 18:30 Gerhard Stoll * bios/cookie/description/MaTC.ui: Add structure 2006-06-05 Monday 10:45 Gerhard Stoll * bios/cookie/list.ui: TK40 used for cookie and XBRA 2006-06-03 Saturday 15:35 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Message from XaAESnap 2006-06-02 Friday 16:51 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Messages from Qdialer (STiK) 2006-06-02 Friday 16:51 Gerhard Stoll * xbios/xbios_f.u: Add XBIOS function from MATRIX grahpic cards 2006-06-02 Friday 16:50 Gerhard Stoll * bios/cookie/description/_NET.ui: Add structure netinfo 2006-05-27 Saturday 07:15 Gerhard Stoll * config.u, gemdos/structures/cdrom_msf.ui, gemdos/structures/cdrom_read.ui, gemdos/structures/cdrom_subchnl.ui, gemdos/structures/cdrom_ti.ui, gemdos/structures/cdrom_tocentry.ui, xbios/laufwerk/metainit.ui, gemdos/structures/cdrom.ui, gemdos/structures/cdrom_audioctrl.ui, gemdos/structures/cdrom_mcn.ui, gemdos/structures/cdrom_tisrc.ui, gemdos/structures/cdrom_tochdr.ui, xbios/laufwerk/metaopen.ui, xbios/structures/CD_DISC_INFO.ui, xbios/structures/META_INFO_1.ui, xbios/structures/META_INFO_2.ui: Translation from some MetaDOS structures 2006-05-25 Thursday 17:03 Gerhard Stoll * anhang/typedefs.u: Remove some structures to an other place 2006-05-25 Thursday 17:02 Gerhard Stoll * gemdos/: gemdos.u, struktur.ui, structures/DISKINFO.ui, structures/DOSTIME.ui, structures/DOSVARS.ui, structures/DTA.ui, structures/FILEPTR.ui, structures/LINE.ui, structures/PD.ui, structures/XATTR.ui, structures/cd_ad.ui, structures/cdrom.ui, structures/cdrom_audioctrl.ui, structures/cdrom_mcn.ui, structures/cdrom_msf.ui, structures/cdrom_read.ui, structures/cdrom_subchnl.ui, structures/cdrom_ti.ui, structures/cdrom_tisrc.ui, structures/cdrom_tocentry.ui, structures/cdrom_tochdr.ui, structures/cdrom_volctrl.ui, structures/fcookie.ui, structures/flock.ui, structures/ltchars.ui, structures/mutimbuf.ui, structures/ploadinfo.ui, structures/sgttyb.ui, structures/sigaction.ui, structures/structures.u, structures/tchars.ui, structures/timeval.ui, structures/timezone.ui, structures/tty.ui, structures/winsize.ui, structures/xkey.ui: New structures dircetory and some translations 2006-05-23 Tuesday 19:49 Gerhard Stoll * config.u, e_bios.u, tos_hyp.u, anhang/typedefs.u, bilder/farbe/bubblegem.img, bilder/farbe/pipeline.img, bilder/farbe/sspicon_.img, bilder/gif/aligment.gif, bilder/gif/bubblegem.gif, bilder/gif/cl_width.gif, bilder/gif/disk.gif, bilder/gif/drv_u.gif, bilder/gif/drv_udev.gif, bilder/gif/drvuproc.gif, bilder/gif/extent.gif, bilder/gif/f_select.gif, bilder/gif/fenster.gif, bilder/gif/filesys.gif, bilder/gif/fontinfo.gif, bilder/gif/frage.gif, bilder/gif/gdos_ahn.gif, bilder/gif/img2034.gif, bilder/gif/img2035.gif, bilder/gif/img2036.gif, bilder/gif/img2037.gif, bilder/gif/img2038.gif, bilder/gif/img2039.gif, bilder/gif/img2040.gif, bilder/gif/img2041.gif, bilder/gif/img2042.gif, bilder/gif/img2043.gif, bilder/gif/img2044.gif, bilder/gif/img2045.gif, bilder/gif/info.gif, bilder/gif/koords.gif, bilder/gif/linien.gif, bilder/gif/marker.gif, bilder/gif/meta_3.gif, bilder/gif/metafile.gif, bilder/gif/muster.gif, bilder/gif/pipeline.gif, bilder/gif/raster.gif, bilder/gif/rufen.gif, bilder/gif/sspicon_.gif, bilder/gif/stop.gif, bilder/gif/taskman.gif, bilder/gif/tpa.gif, bilder/gif/wr_modi.gif, bilder/gif/xcontrol.gif, bilder/mono/bubblegem.img, bilder/mono/pipeline.img, bilder/mono/sspicon_.img, bios/bios_en.ui, bios/sys_var.u, bios/cookie/cookie_en.ui, bios/cookie/description/CHTW.ui, bios/cookie/description/MagX.ui, bios/cookie/description/_MCH.ui, bios/function/bconin.u, bios/function/bconout.u, bios/function/bconstat.u, bios/function/bcostat.u, bios/function/drvmap.u, bios/function/getbpb.u, bios/function/getmpb.u, bios/function/kbshift.u, bios/function/mediach.u, bios/function/rwabs.u, bios/function/setexc.u, bios/function/tickcal.u, emulator.en/stem.u, gem/cpxdoku.u, gem/aes/aes.u, gem/aes/aes_en.u, gem/aes/toolbar.ui, gem/aes/appl_/appl_bvset.ui, gem/aes/appl_/appl_getinfo.ui, gem/aes/appl_/appl_options.ui, gem/aes/evnt_/messages/evnts_de.ui, gem/aes/evnt_/messages/evnts_en.ui, gem/aes/menu_/menu_istart.ui, gem/aes/structures/media_type.ui, gem/aes/structures/object.ui, gem/aes/structures/prn_settings.ui, gem/aes/structures/prn_tray.ui, gem/aes/structures/scanx.ui, gem/aes/wind_/components.ui, gem/aes/wind_/wind_get.ui, gem/aes/wind_/wind_set.ui, gem/guidelns/img2034.gif, gem/guidelns/img2035.gif, gem/guidelns/img2036.gif, gem/guidelns/img2037.gif, gem/guidelns/img2038.gif, gem/guidelns/img2039.gif, gem/guidelns/img2040.gif, gem/guidelns/img2041.gif, gem/guidelns/img2042.gif, gem/guidelns/img2043.gif, gem/guidelns/img2044.gif, gem/guidelns/img2045.gif, gem/guidelns/style.u, gem/guidelns/style_en.u, gem/vdi/vdi.u, gem/vdi/vdi_en.u, gem/vdi/attribut/fill/filltypes.ui, gem/vdi/control/v_resize_bm.ui, gem/vdi/escape/camera/vqp_films.ui, gem/vdi/escape/camera/vsc_expose.ui, gem/vdi/input/vrq_valuator.ui, gem/vdi/inquire/vq_ext_devinfo.ui, gem/vdi/inquire/vq_extnd.ui, gem/vdi/inquire/vqf_attributes.ui, gemdos/filesys.u, gemdos/gemdos.u, gemdos/struktur.ui, gemdos/datetime/datetime.u, gemdos/dir/dcreate.ui, gemdos/dir/ddelete.ui, gemdos/dir/dfree.ui, gemdos/dir/dgetdrv.ui, gemdos/dir/dgetpath.ui, gemdos/dir/dsetdrv.ui, gemdos/dir/dsetpath.ui, gemdos/file/fattrib.ui, gemdos/file/fclose.ui, gemdos/file/fcntl.ui, gemdos/file/fcreate.ui, gemdos/file/fdatime.ui, gemdos/file/fdelete.ui, gemdos/file/fdup.ui, gemdos/file/fforce.ui, gemdos/file/fgetdta.ui, gemdos/file/flock.ui, gemdos/file/fopen.ui, gemdos/file/fread.ui, gemdos/file/frename.ui, gemdos/file/fseek.ui, gemdos/file/fsetdta.ui, gemdos/file/fsfirst.ui, gemdos/file/fsnext.ui, gemdos/file/fwrite.ui, gemdos/prozess/pexec.ui, gemdos/system/ssystem.ui, gemdos/system/system.u, magic/magicpc.u, magic/xfs.u, protokol/font.u, protokol/ltlproto.u, protokol/view.u, protokol/BubbleGEM/bubble_de.ui, protokol/BubbleGEM/bubble_en.ui, protokol/BubbleGEM/img20.img, protokol/ssp/pipeline.gif, protokol/ssp/pipeline.img, protokol/ssp/ssp.u, protokol/ssp/sspicon_.gif, protokol/ssp/sspicon_.img, xbios/bildscrm/bildscrm.u, xbios/bildscrm/cursconf.ui, xbios/bildscrm/egetpale.ui, xbios/bildscrm/egetshif.ui, xbios/bildscrm/esetbank.ui, xbios/bildscrm/esetcolo.ui, xbios/bildscrm/esetgray.ui, xbios/bildscrm/esetpale.ui, xbios/bildscrm/esetshif.ui, xbios/bildscrm/esetsmea.ui, xbios/bildscrm/getrez.ui, xbios/bildscrm/initmous.ui, xbios/bildscrm/logbase.ui, xbios/bildscrm/mon_type.ui, xbios/bildscrm/physbase.ui, xbios/bildscrm/setcolor.ui, xbios/bildscrm/setpalet.ui, xbios/bildscrm/setscree.ui, xbios/bildscrm/vgetrgb.ui, xbios/bildscrm/vgetsize.ui, xbios/bildscrm/vsetmask.ui, xbios/bildscrm/vsetrgb.ui, xbios/bildscrm/vsetscre.ui, xbios/bildscrm/vsetsync.ui, xbios/bildscrm/vsync.ui, xbios/centscrn/centscrn.u, xbios/ct60/rcortemp.ui, xbios/datetime/datetime.u, xbios/datetime/datetime.ui, xbios/datetime/gettime.ui, xbios/datetime/nvmacces.ui, xbios/datetime/settime.ui, xbios/datetime/xbtimer.ui, xbios/drucker/drucker.u, xbios/drucker/prtblk.ui, xbios/drucker/scrdmp.ui, xbios/drucker/setprt.ui, xbios/interrpt/interrpt.u, xbios/interrpt/jdisint.ui, xbios/interrpt/jenabint.ui, xbios/laufwerk/flopfmt.ui, xbios/laufwerk/floprd.ui, xbios/laufwerk/flopver.ui, xbios/laufwerk/flopwr.ui, xbios/laufwerk/laufwerk.u, xbios/laufwerk/protobt.ui, xbios/sound/buffoper.ui, xbios/sound/buffptr.ui, xbios/sound/devconne.ui, xbios/sound/gpio.ui, xbios/sound/locksnd.ui, xbios/sound/setbuffe.ui, xbios/sound/setinter.ui, xbios/sound/setmode.ui, xbios/sound/setmontr.ui, xbios/sound/sndstatu.ui, xbios/sound/sound.u, xbios/sound/soundcmd.ui, xbios/sound/unlocksn.ui, xbios/sound/waveplay.ui, xbios/spezial/spezial.u, xbios/tastatur/tastatur.u: - Change for a HTML version - Binding for GFA-Basic - Change Status and download from Chatwin and STJ-Oberon-2 - MagiC PC DLL-ID from Draconis Windows Sockets 2006-05-14 Sunday 14:29 Gerhard Stoll * xbios/laufwerk/metaopen.ui: Missing syntay 2006-05-14 Sunday 14:29 Gerhard Stoll * xbios/laufwerk/floprate.ui: Undocumented systemvariable for the seek rate 2006-05-11 Thursday 17:36 Gerhard Stoll * magic/: magic.u, magicmac.u: Change links for new cookie structure 2006-05-11 Thursday 17:36 Gerhard Stoll * bios/: sys_vec.u, sys_vec_de.ui, sys_vec_en.ui, bios_en.ui: some translations 2006-05-11 Thursday 17:31 Gerhard Stoll * bios/: bios.u, bios_f.u, cookie.u, sys_var.u, vt52.u, xbra.u, cookie/cookie.u, cookie/cookie_de.ui, cookie/cookie_en.ui, cookie/example_de.ui, cookie/example_en.ui, cookie/list.ui, cookie/description/3DMN.ui, cookie/description/3RDB.ui, cookie/description/60Hz.ui, cookie/description/8_8.ui, cookie/description/ACCS.ui, cookie/description/AFnt.ui, cookie/description/AHVR.ui, cookie/description/ALHP.ui, cookie/description/ALIC.ui, cookie/description/AMC1.ui, cookie/description/AMC2.ui, cookie/description/ANSe.ui, cookie/description/ASum.ui, cookie/description/AVOJ.ui, cookie/description/AVmw.ui, cookie/description/AgK0.ui, cookie/description/AmAN.ui, cookie/description/BASH.ui, cookie/description/BBD2.ui, cookie/description/BCKW.ui, cookie/description/BGEM.ui, cookie/description/BGHD.ui, cookie/description/BHLP.ui, cookie/description/BHdl.ui, cookie/description/BLNK.ui, cookie/description/BLOW.ui, cookie/description/BSIM.ui, cookie/description/BUG1.ui, cookie/description/C24P.ui, cookie/description/CACH.ui, cookie/description/CALD.ui, cookie/description/CASE.ui, cookie/description/CB2K.ui, cookie/description/CBDF.ui, cookie/description/CBHD.ui, cookie/description/CBHY.ui, cookie/description/CBIT.ui, cookie/description/CCDA.ui, cookie/description/CDOT.ui, cookie/description/CFIX.ui, cookie/description/CFsl.ui, cookie/description/CHAM.ui, cookie/description/CHN1.ui, cookie/description/CHNG.ui, cookie/description/CJar.ui, cookie/description/CKBD.ui, cookie/description/CKJR.ui, cookie/description/CLCK.ui, cookie/description/CLK1.ui, cookie/description/CLOK.ui, cookie/description/CM16.ui, cookie/description/CNTS.ui, cookie/description/CPSL.ui, cookie/description/CRAC.ui, cookie/description/CRIT.ui, cookie/description/CSMD.ui, cookie/description/CT60.ui, cookie/description/CTCH.ui, cookie/description/CTSF.ui, cookie/description/CtCp.ui, cookie/description/DATE.ui, cookie/description/DATL.ui, cookie/description/DAWN.ui, cookie/description/DBFX.ui, cookie/description/DCF7.ui, cookie/description/DECD.ui, cookie/description/DEPI.ui, cookie/description/DHST.ui, cookie/description/DIG2.ui, cookie/description/DJBX.ui, cookie/description/DKEY.ui, cookie/description/DNTR.ui, cookie/description/DPAT.ui, cookie/description/DPRS.ui, cookie/description/DRIV.ui, cookie/description/DRRH.ui, cookie/description/DSSO.ui, cookie/description/DYJA.ui, cookie/description/DYJD.ui, cookie/description/A2sv.ui, cookie/description/ALRM.ui, cookie/description/APGM.ui, cookie/description/ARTS.ui, cookie/description/DYNL.ui, cookie/description/DYwl.ui, cookie/description/Dsel.ui, cookie/description/EBPO.ui, cookie/description/EDFX.ui, cookie/description/EGON.ui, cookie/description/EMNP.ui, cookie/description/ENV$.ui, cookie/description/ENVN.ui, cookie/description/ENVR.ui, cookie/description/EPro.ui, cookie/description/ETM.ui, cookie/description/EURO.ui, cookie/description/EXRA.ui, cookie/description/EXTD.ui, cookie/description/EdDI.ui, cookie/description/FALT.ui, cookie/description/FAXR.ui, cookie/description/FHFX.ui, cookie/description/FIX2.ui, cookie/description/FLTP.ui, cookie/description/FLXD.ui, cookie/description/FOse_.ui, cookie/description/FSEL.ui, cookie/description/FSER.ui, cookie/description/FSMC.ui, cookie/description/FSmp.ui, cookie/description/F_3D.ui, cookie/description/FaKE.ui, cookie/description/Fose.ui, cookie/description/FrmD.ui, cookie/description/GABI.ui, cookie/description/GBel.ui, cookie/description/GCOM.ui, cookie/description/GDEV.ui, cookie/description/GEHC.ui, cookie/description/GEHD.ui, cookie/description/GEMB.ui, cookie/description/GENV.ui, cookie/description/GI30.ui, cookie/description/GIGA.ui, cookie/description/GLAS.ui, cookie/description/GLBL.ui, cookie/description/GMTC.ui, cookie/description/GNUC.ui, cookie/description/GOBJ.ui, cookie/description/GOff.ui, cookie/description/GSND.ui, cookie/description/GSXB.ui, cookie/description/GULM.ui, cookie/description/Gfix.ui, cookie/description/Gnva.ui, cookie/description/HABO.ui, cookie/description/HAMM.ui, cookie/description/BIGS.ui, cookie/description/BIOC.ui, cookie/description/CBCE.ui, cookie/description/CHTW.ui, cookie/description/CISY.ui, cookie/description/CJAR_.ui, cookie/description/COLO.ui, cookie/description/CWCo.ui, cookie/description/CaTT.ui, cookie/description/CatS.ui, cookie/description/HBFS.ui, cookie/description/HDDR.ui, cookie/description/HDEX.ui, cookie/description/HDEY.ui, cookie/description/HDJR.ui, cookie/description/HDLD.ui, cookie/description/HDPR.ui, cookie/description/HDRC.ui, cookie/description/HDST.ui, cookie/description/HDSW.ui, cookie/description/HFIX.ui, cookie/description/HIDS.ui, cookie/description/HMDU.ui, cookie/description/HMOC.ui, cookie/description/HMRD.ui, cookie/description/HMRS.ui, cookie/description/HPHC.ui, cookie/description/HPLJ.ui, cookie/description/HSCD.ui, cookie/description/HSND.ui, cookie/description/HWAM.ui, cookie/description/HcP6.ui, cookie/description/IBMP.ui, cookie/description/ICFS.ui, cookie/description/ICST.ui, cookie/description/IDSK.ui, cookie/description/IMAC.ui, cookie/description/IMNE.ui, cookie/description/INSJ.ui, cookie/description/INXR.ui, cookie/description/IRSB.ui, cookie/description/JAM1.ui, cookie/description/JB2G.ui, cookie/description/JCLK.ui, cookie/description/JCNB.ui, cookie/description/JCNC.ui, cookie/description/JCNH.ui, cookie/description/JCNT.ui, cookie/description/JFTP.ui, cookie/description/JMLB.ui, cookie/description/JMLS.ui, cookie/description/JSHD.ui, cookie/description/JUST.ui, cookie/description/J_Sc.ui, cookie/description/KEYT.ui, cookie/description/KGTF.ui, cookie/description/KIDI.ui, cookie/description/KREG.ui, cookie/description/KbEv.ui, cookie/description/KyMp.ui, cookie/description/LACY.ui, cookie/description/LALA.ui, cookie/description/LASB.ui, cookie/description/LAWC.ui, cookie/description/DCdd.ui, cookie/description/DYJT.ui, cookie/description/EADC.ui, cookie/description/LDGE.ui, cookie/description/LEDP.ui, cookie/description/LLCR.ui, cookie/description/LPJM.ui, cookie/description/LTMF.ui, cookie/description/MADD.ui, cookie/description/MADN.ui, cookie/description/MAGN.ui, cookie/description/MBRD.ui, cookie/description/MCL_.ui, cookie/description/MCSP.ui, cookie/description/MCWR.ui, cookie/description/MDIA.ui, cookie/description/MDRK.ui, cookie/description/MDSa.ui, cookie/description/MFAC.ui, cookie/description/MFFM.ui, cookie/description/MFIX.ui, cookie/description/MFNT.ui, cookie/description/MGEM.ui, cookie/description/MID3.ui, cookie/description/MIMA.ui, cookie/description/MIPS.ui, cookie/description/MJAF.ui, cookie/description/MM2X.ui, cookie/description/MMAC.ui, cookie/description/MMUT.ui, cookie/description/MM_2.ui, cookie/description/MNAM.ui, cookie/description/MOAF.ui, cookie/description/MOGR.ui, cookie/description/MPRO.ui, cookie/description/MRAM.ui, cookie/description/MSPD.ui, cookie/description/MSPO.ui, cookie/description/MTft.ui, cookie/description/MUPF.ui, cookie/description/MWHL.ui, cookie/description/MZTR.ui, cookie/description/MaTC.ui, cookie/description/MagC.ui, cookie/description/MagX.ui, cookie/description/MbAr.ui, cookie/description/McSn.ui, cookie/description/MgMc.ui, cookie/description/MgMx.ui, cookie/description/GMNI.ui, cookie/description/GSP1.ui, cookie/description/MiNT.ui, cookie/description/MkJr.ui, cookie/description/N203.ui, cookie/description/NBEL.ui, cookie/description/NBLL.ui, cookie/description/NCLN.ui, cookie/description/NERV.ui, cookie/description/NETS.ui, cookie/description/NEXB.ui, cookie/description/NEXK.ui, cookie/description/NFMT.ui, cookie/description/NFnt.ui, cookie/description/NKCC.ui, cookie/description/NLdr.ui, cookie/description/NMGE.ui, cookie/description/NO7P.ui, cookie/description/NOR5.ui, cookie/description/NOVA.ui, cookie/description/NSC1.ui, cookie/description/NTK4.ui, cookie/description/NUL_.ui, cookie/description/NVDI.ui, cookie/description/OBNL.ui, cookie/description/OFLS.ui, cookie/description/OPMM.ui, cookie/description/OSBL.ui, cookie/description/OSTT.ui, cookie/description/OTOS.ui, cookie/description/OV24.ui, cookie/description/OVDJ.ui, cookie/description/OVEP.ui, cookie/description/OVER.ui, cookie/description/OVEX.ui, cookie/description/OVFS.ui, cookie/description/OVIM.ui, cookie/description/OVLS.ui, cookie/description/OVRD.ui, cookie/description/OVUT.ui, cookie/description/OVWI.ui, cookie/description/PAMN.ui, cookie/description/PBUG.ui, cookie/description/PCI_.ui, cookie/description/PDEB.ui, cookie/description/PDOS.ui, cookie/description/PDRZ.ui, cookie/description/PFIX.ui, cookie/description/PKSH.ui, cookie/description/PMMU.ui, cookie/description/POIS.ui, cookie/description/POWM.ui, cookie/description/PRCS.ui, cookie/description/PRDS.ui, cookie/description/PRMD.ui, cookie/description/PRN!.ui, cookie/description/PRNß.ui, cookie/description/PRO5.ui, cookie/description/PROB.ui, cookie/description/PROT.ui, cookie/description/JINX.ui, cookie/description/KyWt.ui, cookie/description/LOGB.ui, cookie/description/LPCD.ui, cookie/description/LP_2.ui, cookie/description/LoSe.ui, cookie/description/M16X.ui, cookie/description/M16s.ui, cookie/description/MAST.ui, cookie/description/MKHC.ui, cookie/description/PRTD.ui, cookie/description/PRTO.ui, cookie/description/PRTR_.ui, cookie/description/PSND.ui, cookie/description/PSSG.ui, cookie/description/PTOS.ui, cookie/description/Pinp.ui, cookie/description/QIKM.ui, cookie/description/QMAC.ui, cookie/description/QMCP.ui, cookie/description/QST2.ui, cookie/description/QST3.ui, cookie/description/QUAN.ui, cookie/description/RAIL.ui, cookie/description/RESG.ui, cookie/description/RFLX.ui, cookie/description/RFUS.ui, cookie/description/RGUS.ui, cookie/description/RING.ui, cookie/description/ROT8.ui, cookie/description/RREG.ui, cookie/description/RSLT.ui, cookie/description/RSVE.ui, cookie/description/RSVF.ui, cookie/description/RSpd.ui, cookie/description/RTKC.ui, cookie/description/RTOB.ui, cookie/description/RWIN.ui, cookie/description/RaSn.ui, cookie/description/SAM.ui, cookie/description/SBKM.ui, cookie/description/SBTE.ui, cookie/description/SBTS.ui, cookie/description/SCAH.ui, cookie/description/SCKM.ui, cookie/description/SCPN.ui, cookie/description/SCRD.ui, cookie/description/SCRN.ui, cookie/description/SCRS.ui, cookie/description/SCRW.ui, cookie/description/SCSI.ui, cookie/description/SCSV.ui, cookie/description/SDCH.ui, cookie/description/SDES.ui, cookie/description/SDWN.ui, cookie/description/SDsk.ui, cookie/description/SELC.ui, cookie/description/SENV.ui, cookie/description/SFA^.ui, cookie/description/SFIX.ui, cookie/description/SFMN.ui, cookie/description/SKEY.ui, cookie/description/SLCT.ui, cookie/description/SLIP.ui, cookie/description/SLif.ui, cookie/description/SM00.ui, cookie/description/SM01.ui, cookie/description/SM02.ui, cookie/description/SMAL.ui, cookie/description/SMAU.ui, cookie/description/SMTT.ui, cookie/description/SMon.ui, cookie/description/SNAP.ui, cookie/description/SOFS.ui, cookie/description/SOSW.ui, cookie/description/SPCK.ui, cookie/description/SPEE.ui, cookie/description/SPEK.ui, cookie/description/SPEX.ui, cookie/description/SPRG.ui, cookie/description/SSND.ui, cookie/description/ST-C.ui, cookie/description/ST17.ui, cookie/description/STAT.ui, cookie/description/STEM.ui, cookie/description/STEW.ui, cookie/description/STFA.ui, cookie/description/STMS.ui, cookie/description/STRX.ui, cookie/description/STiK.ui, cookie/description/SVAR.ui, cookie/description/SVGA.ui, cookie/description/SWAP.ui, cookie/description/SYMB.ui, cookie/description/SYNL.ui, cookie/description/SYNT.ui, cookie/description/SYST.ui, cookie/description/SZ_M.ui, cookie/description/S_DR.ui, cookie/description/ShLk.ui, cookie/description/SpcE.ui, cookie/description/Spol.ui, cookie/description/StIc.ui, cookie/description/SwTm.ui, cookie/description/SysE.ui, cookie/description/Syso.ui, cookie/description/T206.ui, cookie/description/T2GM.ui, cookie/description/TAPE.ui, cookie/description/TASS.ui, cookie/description/TCFS.ui, cookie/description/TCRB.ui, cookie/description/TFIX.ui, cookie/description/THNX.ui, cookie/description/THRM.ui, cookie/description/THST.ui, cookie/description/TIM3.ui, cookie/description/TIM5.ui, cookie/description/TIME.ui, cookie/description/TK40.ui, cookie/description/TL3D.ui, cookie/description/TLWV.ui, cookie/description/TOUC.ui, cookie/description/TOpW.ui, cookie/description/TPGM.ui, cookie/description/TPat.ui, cookie/description/TRAK.ui, cookie/description/TRUE.ui, cookie/description/TSEN.ui, cookie/description/TSWP.ui, cookie/description/TTTF.ui, cookie/description/TUBS.ui, cookie/description/TWFS.ui, cookie/description/Tenv.ui, cookie/description/Tmon.ui, cookie/description/TraP.ui, cookie/description/Trpp.ui, cookie/description/Typ1.ui, cookie/description/UFSL.ui, cookie/description/UIS3.ui, cookie/description/UKB1.ui, cookie/description/UKB3.ui, cookie/description/USCK.ui, cookie/description/USHD.ui, cookie/description/USPK.ui, cookie/description/USRS.ui, cookie/description/UTRK.ui, cookie/description/VBLF.ui, cookie/description/VDLY.ui, cookie/description/VECS.ui, cookie/description/VFIX.ui, cookie/description/VFNT.ui, cookie/description/VGAS.ui, cookie/description/VI-2.ui, cookie/description/VIRA.ui, cookie/description/VMEM.ui, cookie/description/VPCH.ui, cookie/description/VRAM.ui, cookie/description/VREP.ui, cookie/description/VSCR.ui, cookie/description/VSTM.ui, cookie/description/VSco.ui, cookie/description/VTFX.ui, cookie/description/VXCK.ui, cookie/description/VeiL.ui, cookie/description/View.ui, cookie/description/WARP.ui, cookie/description/WBrd.ui, cookie/description/WDOG.ui, cookie/description/WEGA.ui, cookie/description/WFSL.ui, cookie/description/WICO.ui, cookie/description/WINX.ui, cookie/description/WINZ.ui, cookie/description/WPRO.ui, cookie/description/WRAP.ui, cookie/description/WaHW.ui, cookie/description/WaSA.ui, cookie/description/WfNa.ui, cookie/description/WinK.ui, cookie/description/XALT.ui, cookie/description/XBTN.ui, cookie/description/XDsk.ui, cookie/description/XFRB.ui, cookie/description/XFS1.ui, cookie/description/XHDI.ui, cookie/description/XKBD.ui, cookie/description/XMMU.ui, cookie/description/XMuz.ui, cookie/description/XPCI.ui, cookie/description/XSND.ui, cookie/description/XSSI.ui, cookie/description/XTOS.ui, cookie/description/XWin.ui, cookie/description/_AFM.ui, cookie/description/_AKP.ui, cookie/description/_CPU.ui, cookie/description/_DOS.ui, cookie/description/_FDC.ui, cookie/description/_FLK.ui, cookie/description/_FPU.ui, cookie/description/_FRB.ui, cookie/description/_FSC.ui, cookie/description/_FSR.ui, cookie/description/_IDT.ui, cookie/description/_INF.ui, cookie/description/_INU.ui, cookie/description/_ISO.ui, cookie/description/_JPD.ui, cookie/description/_MCH.ui, cookie/description/_MET.ui, cookie/description/_MIL.ui, cookie/description/_NET.ui, cookie/description/_OOL.ui, cookie/description/_PCI.ui, cookie/description/_PKT.ui, cookie/description/_PWR.ui, cookie/description/_SLM.ui, cookie/description/_SND.ui, cookie/description/_SWI.ui, cookie/description/_T2W.ui, cookie/description/_T30.ui, cookie/description/_VDI.ui, cookie/description/_VDO.ui, cookie/description/__NF.ui, cookie/description/asGT.ui, cookie/description/cVDI.ui, cookie/description/cdMC.ui, cookie/description/fMSX.ui, cookie/description/gk5_.ui, cookie/description/gkCO.ui, cookie/description/hFRB.ui, cookie/description/hade.ui, cookie/description/iPRN.ui, cookie/description/iTMA.ui, cookie/description/lanc.ui, cookie/description/macc.ui, cookie/description/mstx.ui, cookie/description/nAES.ui, cookie/description/nTAS.ui, cookie/description/ne2k.ui, cookie/description/noCF.ui, cookie/description/oVDI.ui, cookie/description/prtr.ui, cookie/description/shlp.ui, cookie/description/spMR.ui, cookie/description/strk.ui, cookie/description/un_x.ui, cookie/description/vT52.ui, cookie/description/wdlg.ui, cookie/description/xFSL.ui, cookie/description/xNet.ui, cookie/description/xRmt.ui, cookie/description/xUFC.ui, cookie/description/zCAC.ui, cookie/description/zDCF.ui, function/kbshift.u: Cookie- and XBRA-List 2006-05-11 Thursday 17:24 Gerhard Stoll * bios/structures/: md.ui, structures.u: Add structure MD 2006-05-07 Sunday 09:51 Gerhard Stoll * gem/aes/wind_/wind_get_set.ui: WF_USER_POINTER, WF_WIND_ATTACH and WF_WIND_ATTACH add to the list 2006-04-18 Tuesday 22:38 Gerhard Stoll * gem/aes/appl_/appl_control.ui: Internal modes from OAESis and XaAES 2006-04-16 Sunday 18:10 Gerhard Stoll * xbios/structures/bconmap.ui: Undocument element 2006-04-10 Monday 12:24 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Messages from Geneva add 2006-04-04 Tuesday 16:04 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Messages from MyPDF add 2006-04-03 Monday 06:07 Gerhard Stoll * gem/aes/shel_/shel_write.ui: shel_write (9) NM_INHIBIT_HIDE 2006-04-03 Monday 06:06 Gerhard Stoll * gem/aes/aes_f.u: Add objc_data to the list 2006-04-03 Monday 06:06 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Add WM_WHEEL to the list 2006-04-03 Monday 06:06 Gerhard Stoll * gem/aes/evnt_/messages/: evnts_de.ui, evnts_en.ui: Fixed docu from SM_M_SPECIAL 2006-04-03 Monday 06:05 Gerhard Stoll * gem/aes/structures/: menu.ui, mn_set.ui: Translate 2006-03-12 Sunday 08:33 Gerhard Stoll * gem/aes/wind_/wind_new.ui: Available since AES version 1.4 2006-03-12 Sunday 08:33 Gerhard Stoll * protokol/dd.u: Add some labels
2006-02-25 Saturday 09:45 Gerhard Stoll * gem/aes/evnt_/messages/messages.u: Labels for the messages from EnhancedGEM 2006-02-19 Sunday 09:04 Gerhard Stoll * bios/function/kbshift.u: Adress from pkbshift in TOS 1.00 2006-02-09 Thursday 17:00 Gerhard Stoll * linea/linea.u: Same text correcting 2006-02-09 Thursday 16:59 Gerhard Stoll * xbios/: pci_bios/error.ui, pci_bios/fast_read_config_byte.ui, pci_bios/fast_read_config_longword.ui, pci_bios/fast_read_config_word.ui, pci_bios/fpclassc.ui, pci_bios/fpdevice.ui, pci_bios/hook_interrupt.ui, pci_bios/pci_bios.u, pci_bios/read_config_byte.ui, pci_bios/read_config_longword.ui, pci_bios/read_config_word.ui, pci_bios/write_config_byte.ui, pci_bios/write_config_longword.ui, pci_bios/write_config_word.ui, struktur.ui, xbios_f.u: Some function from the PCI BIOS add 2006-02-09 Thursday 16:24 Gerhard Stoll * magic/threads/: exapmle.ui, threads.u, vdi.u: some translations 2006-02-08 Wednesday 18:01 Gerhard Stoll * gem/vdi/vdi.u: Add some NVDI and SpeedoGDOS version number, only as comment 2006-02-08 Wednesday 18:00 Gerhard Stoll * bios/cookie.u: Add quality to FSMC structure 2006-02-08 Wednesday 18:00 Gerhard Stoll * gem/aes/form_/xfrm_popup.ui: More info about some parameter 2006-02-08 Wednesday 18:00 Gerhard Stoll * magic/magicpc.u: Add DLL_ID from MPCSTiK 2006-01-26 Thursday 17:49 Gerhard Stoll * gemdos/system/sconfig.ui: Add new modes 2006-01-26 Thursday 17:49 Gerhard Stoll * gem/aes/form_/form_xdial.ui: Correct binding 2006-01-26 Thursday 17:49 Gerhard Stoll * gem/aes/appl_/appl_getinfo.ui: Interface resource file supported from MyAES 2006-01-21 Saturday 15:42 Gerhard Stoll * e_olga.u, e_protok.u, tos_hyp.u, protokol/font.u, protokol/olga.u, protokol/olga/olga.u, protokol/olga/olga_de.ui, protokol/olga/olga_en.ui: Start with an english version from OLGA 2006-01-08 Sunday 18:16 Gerhard Stoll * gemdos/dir/: dir.u, dxopendir.ui: New Gemdos function Dxopendir from Dir_Lwr 2005-12-29 Thursday 16:46 Gerhard Stoll * bios/bios.u, bios/bios_str.u, bios/structures/bpb.ui, bios/structures/mpb.ui, bios/structures/pun_info.ui, bios/structures/structures.u, xbios/structures/CD_DISC_INFO.ui, xbios/structures/CD_TOC_ENTRY.ui, xbios/structures/DSPBLOCK.ui, xbios/structures/IOREC.ui, xbios/structures/KBDVBASE.ui, xbios/structures/KEYTAB.ui, xbios/structures/MAPTAB.ui, xbios/structures/META_DRVINFO.ui, xbios/structures/META_INFO_1.ui, xbios/structures/META_INFO_2.ui, xbios/structures/MOD_DESC.ui, xbios/structures/MOUSE.ui, xbios/structures/OVERPATCH.ui, xbios/structures/PBDEF.ui, xbios/structures/PMODE.ui, xbios/structures/SCREEN.ui, xbios/structures/SCREENINFO.ui, xbios/structures/SCREEN_OverScan.ui, xbios/structures/SCRMEMBLK.ui, xbios/structures/VDO_MODE.ui, xbios/structures/VDO_PARAM.ui, xbios/structures/VPOS.ui, xbios/structures/bconmap.ui, xbios/structures/structures.u, xbios/xbios.u: New structure 2005-12-11 Sunday 14:56 Gerhard Stoll * gem/aes/evnt_/messages/evnts.ui: English version 2005-12-11 Sunday 14:52 Gerhard Stoll * gem/aes/menu_/menu_unregister.ui: Add Info about KAOS 1.4.2, thanks to Michael Schroeter 2005-12-11 Sunday 14:51 Gerhard Stoll * gem/aes/wind_/: wind_get.ui, wind_get_set.ui, wind_set.ui, wind_xget.ui, wind_xset.ui: WF_CALCF2W and WF_CALCW2F from XaAES 2005-12-11 Sunday 14:45 Gerhard Stoll * gem/aes/appl_/: appl_.u, appl_options.ui: New function aes_options from XaAES, not finished 2005-12-11 Sunday 14:45 Gerhard Stoll * gem/aes/appl_/appl_getinfo.ui: Add new modes (98, 99) from XaAES 2005-12-11 Sunday 14:44 Gerhard Stoll * gem/vdi/attribut/text/vst_error.ui: Some error codes from SpeedoGDOS 5 add 2005-12-08 Thursday 21:00 Gerhard Stoll * gem/aes/xgrf_/: xgrf_2box.ui, xgrf_stepcalc.ui: Add Info about KAOS 1.4.2, thanks to Michael Schroeter 2005-12-08 Thursday 20:56 Gerhard Stoll * gem/aes/appl_/appl_bvset.ui, gem/aes/appl_/appl_init.ui, anhang/anhang/tos_vers.u, gemdos/system/sconfig.ui, gemdos/struktur.ui, bios/sys_var.u, gem/aes/evnt_/messages/evnts_de.ui, gem/aes/evnt_/messages/evnts_en.ui, gem/aes/evnt_/messages/messages.u, gem/aes/wind_/wind_get.ui, gem/aes/wind_/wind_get_set.ui, gem/aes/wind_/wind_set.ui, gem/aes/menu_/menu_click.ui, gem/aes/scrp_/scrp_clear.ui, gem/aes/shel_/shel_rdef.ui, gem/aes/shel_/shel_wdef.ui: Add Info about KAOS 1.4.2, thanks to Michael Schroeter 2005-12-08 Thursday 20:43 Gerhard Stoll * gem/aes/appl_/appl_find.ui: Special mode in KAOS and MagiC 2005-12-08 Thursday 13:06 Gerhard Stoll * gemdos/system/sconfig.ui: Wrong description from bit 4 2005-12-03 Saturday 10:53 Gerhard Stoll * gem/aes/: aes.u, aes_en.u, aes_f.u, struktur.ui, toolbar.ui, appl_/appl_getinfo.ui, fnts_/fnts_create.ui, form_/form_.u, form_/form_popup.ui, fslx_/fslx_close.ui, fslx_/fslx_do.ui, fslx_/fslx_evnt.ui, fslx_/fslx_getnxtfile.ui, fslx_/fslx_open.ui, fslx_/fslx_set_flags.ui, lbox_/flags.ui, lbox_/lbox_create.ui, pdlg_/pdlg_.u, pdlg_/pdlg_add_printers.ui, pdlg_/pdlg_add_sub_dialogs.ui, pdlg_/pdlg_close.ui, pdlg_/pdlg_create.ui, pdlg_/pdlg_delete.ui, pdlg_/pdlg_dflt_settings.ui, pdlg_/pdlg_do.ui, pdlg_/pdlg_evnt.ui, pdlg_/pdlg_free_settings.ui, pdlg_/pdlg_get_setsize.ui, pdlg_/pdlg_new_settings.ui, pdlg_/pdlg_open.ui, pdlg_/pdlg_remove_printers.ui, pdlg_/pdlg_remove_sub_dialogs.ui, pdlg_/pdlg_save_default_settings.ui, pdlg_/pdlg_update.ui, pdlg_/pdlg_use_settings.ui, pdlg_/pdlg_validate_settings.ui, pdlg_/use.ui, shel_/shel_.u, structures/applrecord.ui, structures/bitblk.ui, structures/cicon.ui, structures/ciconblk.ui, structures/clrcat.ui, structures/dialog.ui, structures/dither_mode.ui, structures/drv_entry.ui, structures/drv_info.ui, structures/evnt.ui, structures/fnt_dialog.ui, structures/fnts_item.ui, structures/hndl_obj.ui, structures/iconblk.ui, structures/lbox_item.ui, structures/list_box.ui, structures/media_size.ui, structures/media_type.ui, structures/menu.ui, structures/mform.ui, structures/mn_set.ui, structures/object.ui, structures/parmblk.ui, structures/pdlg_hndl.ui, structures/pdlg_init.ui, structures/pdlg_reset.ui, structures/pdlg_sub.ui, structures/popinfo.ui, structures/prn_dialog.ui, structures/prn_entry.ui, structures/prn_mode.ui, structures/prn_settings.ui, structures/prn_switch.ui, structures/prn_tray.ui, structures/rshdr.ui, structures/scanx.ui, structures/set_item.ui, structures/sheltail.ui, structures/slct_item.ui, structures/structures.u, structures/swinfo.ui, structures/tedinfo.ui, structures/userblk.ui, structures/utxt_fn.ui, structures/x_buf_v2.ui, structures/xaesmsg.ui, structures/xdo_inf.ui, structures/xfsl_filter.ui, structures/xshw_command.ui, structures/xted.ui, wind_/wind_get_set.ui, wind_/wind_set.ui, wind_/wind_xget.ui: New structures dircetory and some translations 2005-12-03 Saturday 10:49 Gerhard Stoll * gem/aes/evnt_/messages/: evnts_de.ui, evnts_en.ui: Wrong parameter number in AC_CLOSE 2005-12-03 Saturday 10:48 Gerhard Stoll * gem/aes/evnt_/: evnt_.u, evnts.ui, messages/evnts_de.ui, messages/evnts_en.ui: English version 2005-11-13 Sunday 07:51 Gerhard Stoll * magic/magicmac.u: Add cookie elements from version 1.11 2005-11-13 Sunday 07:50 Gerhard Stoll * xbios/pci_bios/: error.ui, fpclassc.ui, fpdevice.ui, pci_bios.u: error codes 2005-11-13 Sunday 07:50 Gerhard Stoll * xbios/xbios_f.u: Add the function form the ct60 2005-11-01 Tuesday 07:59 Gerhard Stoll * gem/vdi/inquire/vq_extnd.ui: work_out[32] indicate new style colour routines (NVDI 5.xx) 2005-11-01 Tuesday 07:58 Gerhard Stoll * anhang/anhang/tos_vers.u: Translate 2005-10-19 Wednesday 18:26 Gerhard Stoll * gem/vdi/: assign_sys.ui, struktur.ui, vdi.u, vdi_en.u, attribut/attribut.u, attribut/fill/vsf_color.ui, attribut/fill/vsf_interior.ui, attribut/fill/vsf_perimeter.ui, attribut/fill/vsf_style.ui, attribut/fill/vsf_udpat.ui, attribut/linien/v_bez_qual.ui, attribut/linien/vsl_color.ui, attribut/linien/vsl_ends.ui, attribut/linien/vsl_type.ui, attribut/linien/vsl_udsty.ui, attribut/linien/vsl_width.ui, attribut/marker/vsm_color.ui, attribut/marker/vsm_height.ui, attribut/marker/vsm_type.ui, attribut/text/vst_alignment.ui, attribut/text/vst_arbpt32.ui, attribut/text/vst_charmap.ui, attribut/text/vst_color.ui, attribut/text/vst_effects.ui, attribut/text/vst_font.ui, attribut/text/vst_height.ui, attribut/text/vst_kern.ui, attribut/text/vst_map_mode.ui, attribut/text/vst_name.ui, attribut/text/vst_point.ui, attribut/text/vst_rotation.ui, attribut/text/vst_setsize32.ui, attribut/text/vst_skew.ui, attribut/text/vst_track_offset.ui, attribut/text/vst_width.ui, attribut/uebergeordnete/vs_color.ui, attribut/uebergeordnete/vswr_mode.ui, control/v_bez_off.ui, control/v_bez_on.ui, control/v_clrwk.ui, control/v_clsbm.ui, control/v_clswk.ui, control/v_getoutline.ui, control/v_opnbm.ui, control/v_opnvwk.ui, control/v_opnwk.ui, control/v_opnwk_pc_gem.ui, control/vs_clip.ui, control/vst_load_fonts.ui, escape/escape.u, escape/graphic/v_bit_image.ui, escape/graphic/v_copies.ui, escape/graphic/v_orient.ui, escape/graphic/v_page_size.ui, escape/graphic/v_tray.ui, escape/graphic/vq_calibrate.ui, escape/graphic/vq_page_name.ui, escape/graphic/vq_tray_names.ui, escape/graphic/vs_calibrate.ui, escape/metafile/v_meta_extents.ui, escape/metafile/v_write_meta.ui, escape/metafile/vm_coords.ui, escape/metafile/vm_filename.ui, escape/metafile/vm_pagesize.ui, escape/special/v_escape2000.ui, escape/text/v_curaddress.ui, escape/text/v_curdown.ui, escape/text/v_curleft.ui, escape/text/v_curright.ui, escape/text/v_curtext.ui, escape/text/v_curup.ui, escape/text/vq_chcells.ui, escape/text/vq_curaddress.ui, input/input.u, input/v_hide_c.ui, input/v_show_c.ui, input/vex_butv.ui, input/vex_curv.ui, input/vex_motv.ui, input/vex_timv.ui, input/vq_key_s.ui, input/vq_mouse.ui, input/vrq_choice.ui, input/vrq_locator.ui, input/vrq_string.ui, input/vsc_form.ui, input/vsin_mode.ui, input/vsm_choice.ui, input/vsm_string.ui, inquire/inquire.u, inquire/v_getbitmap_info.ui, inquire/vq_color.ui, inquire/vq_devinfo.ui, inquire/vq_ext_devinfo.ui, inquire/vq_extnd.ui, inquire/vq_scrninfo.ui, inquire/vqf_attributes.ui, inquire/vqin_mode.ui, inquire/vql_attributes.ui, inquire/vqm_attributes.ui, inquire/vqt_advance32.ui, inquire/vqt_attributes.ui, inquire/vqt_char_index.ui, inquire/vqt_ext_name.ui, inquire/vqt_extent.ui, inquire/vqt_f_extent.ui, inquire/vqt_fontheader.ui, inquire/vqt_fontinfo.ui, inquire/vqt_get_table.ui, inquire/vqt_name_and_id.ui, inquire/vqt_pairkern.ui, inquire/vqt_real_extent.ui, inquire/vqt_trackkern.ui, inquire/vqt_width.ui, inquire/vqt_xfntinfo.ui, output/output.u, output/v_arc.ui, output/v_bar.ui, output/v_bez.ui, output/v_bez_fill.ui, output/v_circle.ui, output/v_contourfill.ui, output/v_ellarc.ui, output/v_ellipse.ui, output/v_ellpie.ui, output/v_fillarea.ui, output/v_ftext.ui, output/v_ftext_offset.ui, output/v_gtext.ui, output/v_justified.ui, output/v_pieslice.ui, output/v_pline.ui, output/v_pmarker.ui, output/v_rbox.ui, output/v_rfbox.ui, output/vr_recfl.ui, raster/v_get_pixel.ui, raster/vr_trnfm.ui, raster/vro_cpyfm.ui, raster/vrt_cpyfm.ui, structures/color_entry.ui, structures/color_rgb.ui, structures/color_tab.ui, structures/fix31.ui, structures/font_hdr.ui, structures/gcbitmap.ui, structures/mfdb.ui, structures/point16.ui, structures/point32.ui, structures/pxyarray.ui, structures/rect16.ui, structures/rect32.ui, structures/structures.u, structures/xfnt_info.ui: A very raw translation 2005-10-19 Wednesday 18:21 Gerhard Stoll * magic/magicmac.u: Delete info about the ASH-Mailbox 2005-08-30 Tuesday 16:41 Gerhard Stoll * bios/sys_vec.u: NVDI use TRAP #15, Cubase MROS use TRAP #8 2005-08-23 Tuesday 16:51 Gerhard Stoll * protokol/dhst.u: English version form Document History Protocol (DHST) 2005-08-06 Saturday 06:40 Gerhard Stoll * gem/vdi/control/v_opnbm.ui: Change availability 2005-08-06 Saturday 06:39 Gerhard Stoll * gem/vdi/inquire/: disable_nvdi.ui, v_read_default_settings.ui, v_write_default_settings.ui: Missing Subfunction 2005-08-06 Saturday 06:39 Gerhard Stoll * gem/vdi/inquire/vqr_bg_color.ui: Wrong subfunction number 2005-08-06 Saturday 06:39 Gerhard Stoll * gem/vdi/attribut/uebergeordnete/v_setrgb.ui: Wrong opcode 2005-08-04 Thursday 10:16 Gerhard Stoll * gem/aes/appl_/appl_getinfo.ui: New bits in mode 11 and new mode 97 from XaAES 2005-08-04 Thursday 10:15 Gerhard Stoll * gem/aes/appl_/appl_getinfo_str.ui: Replace appl_getinfo with appl_getinfo_str 2005-07-18 Monday 08:19 Gerhard Stoll * protokol/xacc/: xacc.u, xacc_de.ui, xacc_en.ui: XACC protocol; parts of the text from Thomas Much 2005-07-16 Saturday 07:59 Gerhard Stoll * bios/cookie.u: Hades add to _FDC 2005-07-10 Sunday 15:16 Gerhard Stoll * anhang/anhang/: xhdi.u, xhdi/xhdi.u, xhdi/xhdi_de.ui, xhdi/xhdi_en.ui: English version
2005-07-03 Sunday 08:35 Gerhard Stoll
Messages from WinDom, LDG and Output add
2005-06-04 Saturday 17:47 Gerhard Stoll
Messages from MyTask add
2005-06-03 Friday 07:35 Gerhard Stoll
* gem/aes/evnt_/: evnt_.u, messages/messages.u,
messages/rsdaemon.ui:
GEM-Messageslist from Martin Elsaesser add
2005-06-03 Friday 07:33 Gerhard Stoll
* anhang/anhang/anhang.u:
ResourceMaster add to developer tools
2005-06-03 Friday 07:29 Gerhard Stoll
* gem/aes/wind_/: wind_.u, wind_get.ui, wind_get_set.ui,
Overwork all about wind_get and wind_set, add new modes from XaAES
2005-05-24 Tuesday 21:27 Gerhard Stoll
* gem/aes/evnt_/: evnt_multi.ui, evnt_timer.ui:
Do not use with timer vaule 0 with TOS 1.0
* gem/aes/struktur.ui:
Better description from APPLRECORD
2005-05-24 Tuesday 21:26 Gerhard Stoll
* protokol/view.u:
Some messages defines add
* protokol/seproto/: seproto.u, seproto_de.ui, seproto_en.ui:
English version
2005-05-24 Tuesday 21:24 Gerhard Stoll
WF_NAME also available since MagiC 6
* gem/aes/menu_/menu_register.ui:
Mode -1 from the programs A-MAN and MenuBar
* gem/aes/menu_/menu_bar.ui:
Mode -2 and -3 from the programs A-MAN and MenuBar
2005-05-24 Tuesday 21:23 Gerhard Stoll
* gem/aes/appl_/appl_xbvset.ui:
Function appl_xbvset from GEM/4, GEM/5 and FreeGEM
2005-05-24 Tuesday 21:22 Gerhard Stoll
Worng type number for XaAES and WINX
Mode -3 also in XaAES available
* e_protok.u, tos_hyp.u:
Add BubbleGEM
* protokol/BubbleGEM/: bubble.u, bubble_de.ui, bubble_en.ui,
img20.img:
Add BubbleGEM
Thanks to Thomas Much and Goetz Hoffart, which allow
to use some parts of the original doc.
2005-03-05 Saturday 10:22 Gerhard Stoll
* bios/cookie.u:
Wrong description of the _AKP cookie
* magic/xfs.u:
New elements in MX_KERNEL
* bios/sys_vec.u:
Trap#3 is used from the Omega-Color-CAD
* xbios/datetime/datetime.ui:
More info about the NVRAM
2005-03-05 Saturday 10:21 Gerhard Stoll
* gem/vdi/: inquire/disable_nvdi.ui, inquire/inquire.u,
inquire/v_create_driver_info.ui, inquire/v_delete_driver_info.ui,
inquire/v_read_default_settings.ui,
inquire/v_write_default_settings.ui, vdi_f.u:
Add Funktion 180, 181 and 182 form NVDI 5.xx (WDialog)
2005-02-20 Sunday 10:27 Gerhard Stoll
* gem/aes/graf_/graf_xhandle.ui:
Description from parameter device
* n_aes/n_aes.u:
XaAES fake 'nAES' cookie
2005-01-30 Sunday 09:39 Gerhard Stoll
* gem/aes/objc_/objc_.u:
objc_xedit listen
2005-01-30 Sunday 09:38 Gerhard Stoll
* magic/magicpc.u:
Some DLL IDs for MagiC PC DLLs add
2005-01-24 Monday 16:54 Gerhard Stoll
2005-01-24 Monday 16:53 Gerhard Stoll
* gem/aes/graf_/graf_mouse.ui:
Add mouse form from N.AES and XaAES
2005-01-02 Sunday 11:29 Gerhard Stoll
* anhang/typedefs.u, bios/bios.u, gem/aes/aes.u, gem/aes/aes_en.u,
gem/aes/aes_f.u, gem/aes/struktur.ui, gem/aes/appl_/appl_.u,
gem/aes/appl_/appl_bvset.ui, gem/aes/appl_/appl_find.ui,
gem/aes/appl_/appl_init.ui, gem/aes/evnt_/evnt_button.ui,
gem/aes/evnt_/evnt_dclick.ui, gem/aes/evnt_/evnt_multi.ui,
gem/aes/form_/form_alert.ui, gem/aes/fsel_/fsel_exinput.ui,
gem/aes/fsel_/fsel_input.ui, gem/aes/graf_/graf_mouse.ui,
gem/aes/graf_/graf_rubberbox.ui, gem/aes/menu_/menu_bar.ui,
gem/aes/objc_/objc_draw.ui, gem/aes/objc_/objc_edit.ui,
gem/aes/rsrc_/rsrc_gaddr.ui, gem/aes/rsrc_/rsrc_saddr.ui,
gem/aes/scrp_/scrp_clear.ui, gem/aes/scrp_/scrp_read.ui,
gem/aes/scrp_/scrp_write.ui, gem/aes/wind_/wind_get_set.ui,
gem/vdi/vdi_f.u, gem/vdi/escape/graphic/v_xbit_image.ui,
gem/vdi/inquire/vq_extnd.ui, gem/vdi/inquire/vqt_name.ui:
Add some more infos from GEM/3, GEM/4, ViewMAX and FreeGEM
2004-12-31 Friday 14:28 Gerhard Stoll
* gem/aes/appl_/: appl_.u, appl_getinfo.ui, appl_getinfo_str.ui:
AES_VERSION
2004-12-31 Friday 14:27 Gerhard Stoll
* gem/aes/appl_/appl_search.ui:
APP_TASKINFO, APP_HIDDEN and APP_FOCUS from XaAES
wind_set.ui:
Overview about all subfunction form wind_get/set
2004-12-31 Friday 14:26 Gerhard Stoll
Some new links in HNDL_OBJ
2004-12-31 Friday 14:25 Gerhard Stoll
* anhang/changes/04_93.ui:
Changelog updated
* xbios/xbios.u:
Errorlist formated
Table formated
2004-12-28 Tuesday 15:12 Gerhard Stoll
* gem/aes/wind_/wind_create.ui:
Add BORDER
* gem/aes/wdlg_/wdlg_close.ui:
Wrong Syntax, missing parameter X and Y
* gem/aes/fsel_/fsel_boxinput.ui:
The GEM-Arrays was wrong
TOS Bootprferenz is 0x80 and not 0x00
* xbios/bildscrm/vsetmode.ui:
mode VM_INQUIRE (-1)
2004-12-19 Sunday 10:52 Gerhard Stoll
* protokol/gdps.ui, e_protok.u, tos_hyp.u:
New: GDPS: Gerti's Driver Piping System
TOS 7.0x
* bios/bios_f.u:
DOLMEN function
* gemdos/prozess/: prozess.u, ptrace.ui:
Add function Ptrace
* gemdos/file/freadlin.ui:
Wrong Binding
* gemdos/gemdos.u:
GEMDOS errors from FreeMiNT add
2004-12-19 Sunday 10:51 Gerhard Stoll
* magic/magicpc.u:
mec1 interface from MagiC PC
2004-12-05 Sunday 14:55 Gerhard Stoll
* xbios/: struktur.ui, bildscrm/Setscreen_Milan.ui,
bildscrm/bildscrm.u, bildscrm/vsetscre.ui:
Milan Setscreen
2004-12-05 Sunday 14:51 Gerhard Stoll
TOS 3.00 add
Info about the size of the NVM from the Milan
* gem/vdi/vdi.u:
Add the device ID number form 101 to 130
2004-12-05 Sunday 14:50 Gerhard Stoll
* gem/aes/appl_/: appl_control.ui, appl_find.ui, appl_getinfo.ui:
Small translation
2004-11-22 Monday 17:58 Gerhard Stoll
* gem/vdi/vdi.u:
Add fVDI at vq_vgdos
2004-11-15 Monday 19:24 Gerhard Stoll
* linea/linea.u:
Remove the label Line-A, because it was twice
2004-11-15 Monday 19:23 Gerhard Stoll
* gemdos/memory/mxalloc.ui:
Change bit3 to reserved
2004-11-09 Tuesday 16:59 Gerhard Stoll
* gem/aes/fslx_/use.ui, gem/aes/pdlg_/pdlg_.u,
xbios/bildscrm/setscree.ui, xbios/ct60/rd_param.ui,
xbios/datetime/datetime.ui, xbios/pci_bios/fpclassc.ui:
Some small translation
2004-11-09 Tuesday 16:55 Gerhard Stoll
wind_set.ui:
Overview from the wind_get and wind_set mode
* gem/aes/evnt_/evnt_keybd.ui:
Link to ASCII- and scancode
* emulator.en/sonstige.u:
New parameter from Steem v3.2 add
2004-10-22 Friday 16:53 Gerhard Stoll
* doc/tos_hyp.upl:
Description for upload
2004-10-22 Friday 16:48 Gerhard Stoll
* xbios/xbios_f.u:
Add PCI-BIOS function name and VideoCtrl from MilanTOS
2004-10-15 Friday 16:47 Gerhard Stoll
* gemdos/datetime/tsetitim.ui:
Parameter which is int16_t and not int32_t
2004-10-15 Friday 16:46 Gerhard Stoll
* gemdos/datetime/tsetdate.ui:
Return value is a int16_t and not uint32_t
2004-10-02 Saturday 13:19 Gerhard Stoll
* gem/aes/: struktur.ui, evnt_/evnts.ui,
fnts_/...,
lbox_/lbox_delete.ui:
A raw translation of some parts
2004-10-02 Saturday 13:18 Gerhard Stoll
Change typdef
* gem/aes/graf_/: graf_.u, graf_handle.ui, graf_xhandle.ui:
graf_xhandle was missed in the overview
2004-09-26 Sunday 08:56 Gerhard Stoll
* gem/aes/edit_/...
gem/aes/lbox_/...
gem/aes/rsrc_/sys_recalc_cicon_colours.ui,
gem/aes/wind_/wind_get.ui, gem/vdi/vdi.u, gemdos/gemdos_f.u,
xbios/spezial/cachectr.ui:
2004-09-26 Sunday 08:53 Gerhard Stoll
* xbios/ct60/rd_param.ui:
New 'type_param' add
2004-09-22 Wednesday 07:38 Gerhard Stoll
* gem/aes/: appl_/appl_getinfo.ui, evnt_/evnts.ui,
wind_/wind_calc.ui, wind_/wind_get.ui, wind_/wind_set.ui:
Add WINX informations
Add defined names
2004-09-22 Wednesday 07:37 Gerhard Stoll
* gem/aes/: aes.u, aes_en.u:
Add links
* gem/vdi/vdi_f.u:
Add function from the SpeedoGDOS driver from Thierry Rodolfo
2004-09-22 Wednesday 07:36 Gerhard Stoll
* xbios/spezial/cjar.ui:
new link
* xbios/spezial/puntaes.ui:
infos about the MagiC subfunction
* xbios/xbios.u:
forget to include the drucker.u
* bios/cookie.u:
_FDC: Add >Mac<
The tos.hyp goes CVS.
2004-08-31 Tuesday 16:00 Gerhard Stoll
* n_aes/n_aes.u:
add a ~ in the formula
* gem/vdi/: colortable/v_color2nearest.ui,
colortable/v_ctab_idx2value.ui, colortable/vq_dflt_ctab.ui,
control/v_pat_rotate.ui:
correct the binding
2004-08-31 Tuesday 15:59 Gerhard Stoll
* bios/cookie.u:
Cookie _FPU: add 68060
2004-08-07 Saturday 17:29 Gerhard Stoll
* tos_hyp.u, bios/cookie.u, gem/aes/aes.u, gem/aes/aes_f.u,
gem/aes/toolbar.ui, gem/aes/appl_/appl_getinfo.ui,
gem/aes/appl_/appl_yield.ui, gem/aes/evnt_/evnt_.u,
gem/aes/evnt_/evnt_multi.ui, gem/aes/evnt_/evnts.ui,
gem/aes/form_/form_alert.ui, gem/aes/wind_/wind_create.ui,
xaaes/xaaes.u:
Added info about XaAES
2004-07-31 Saturday 09:09 Gerhard Stoll
* gem/vdi/inquire/vqt_get_table.ui:
Add mapping tables
2004-07-31 Saturday 09:07 Gerhard Stoll
* xbios/struktur.ui:
KEYTAB: undocumented tables add
2004-07-29 Thursday 19:58 Gerhard Stoll
* bios/cookie.u:
Cookie: _FDC: Milan add
2004-07-17 Saturday 16:52 Gerhard Stoll
* bios/cookie.u:
Cookie _MCH: Medusa T40 add
2004-06-25 Friday 17:29 Gerhard Stoll
* gem/aes/: appl_/appl_init.ui, fsel_/fsel_boxinput.ui,
fsel_/fsel_exinput.ui, menu_/menu_bar.ui, pdlg_/pdlg_do.ui,
pdlg_/pdlg_open.ui, wind_/wind_draw.ui:
Small text correcting
* gem/aes/form_/: form_wbutton.ui, form_wkeybd.ui:
Add availability
2004-06-25 Friday 17:27 Gerhard Stoll
* gem/vdi/attribut/uebergeordnete/vs_bkcolor.ui:
Comments in GEM-Array wrong
* gem/vdi/attribut/marker/vsm_bg_color.ui:
Wrong group
2004-06-25 Friday 17:26 Gerhard Stoll
* gem/aes/objc_/: objc_edit.ui, objc_xedit.ui:
Chance availability
Add Return-Value in Binding
2004-05-13 Thursday 19:04 Gerhard Stoll
* gem/vdi/escape.u:
Binding fuer vqp_error geschrieben
2004-05-10 Monday 19:36 Gerhard Stoll
* linea/: bitblt.ui, drsprite.ui, fillpoly.ui, fillrect.ui,
getpixel.ui, hdmouse.ui, hline.ui, init.ui, line.ui, putpixel.ui,
seedfill.ui, shmouse.ui, textblt.ui, trmouse.ui, udrsprit.ui:
Im Assemblerteil Lina-A Opcode durch Line-A Opcode ersetzt
* linea/cpraster.ui:
Im deutschen Binding stand linea_init. Im Assemblerteil Lina-A Opcode
* linea/linea.u:
Strukture LINEA um Kommentare ergaenzt. Alle Strukturen etwas formatiert
* tos_hyp.u:
Korrekte Schreibweise von Line-A
2004-05-10 Monday 19:35 Gerhard Stoll
* gem/vdi/eingabe.u:
Verfügbarkeit eingetragen, Datentypen angepasst. Beim Binding von
vex_wheelv den korrekten Funktionsnamen eingetragen
2004-05-08 Saturday 19:51 Gerhard Stoll
* gem/vdi/: ausgabe.u, auskunft.u:
* gem/vdi/attribut.u:
Statt des Bindings steht nun die Deklaration auf der Beschreibungsseite
2004-05-07 Friday 16:36 Gerhard Stoll
Verfuegabekeit und Datentypen geaendert
2004-05-05 Wednesday 18:32 Gerhard Stoll
* xbios/drucker/prtblk.ui:
Statt Prtblk stand nur c bei begin_node
* tos_hyp.u:
Linea eingefuegt
2004-05-05 Wednesday 18:31 Gerhard Stoll
Der Befehl end_node war nicht vorhanden
2004-05-04 Tuesday 20:31 Gerhard Stoll
* magic/magic.u:
Fuer die Links in den Zeilen 1176 und 11617 haben sich die Ueberschriften
geaendert
2004-05-04 Tuesday 20:30 Gerhard Stoll
* xbios/xbios.u:
Fuer die Links in den Zeilen 1210 und 1211 haben sich die Ueberschriften
geaendert
* bios/bios.u:
Versuchte die Datei bios_strukt.u statt bios_str.u zu oeffnen
2004-05-04 Tuesday 19:51 Gerhard Stoll
TOS 1.60 nach 1.06 genaendert und TOS 1.62 hinzugefuegt
2004-05-04 Tuesday 19:49 Gerhard Stoll
end_node bei OSHEADER an falscher Stelle.
2004-05-04 Tuesday 19:46 Gerhard Stoll
* bios/function/rwabs.u:
Titel kam nicht in den Index
* bios/cookie.u:
Quellenangabe bei _FPU
2004-05-04 Tuesday 19:20 Gerhard Stoll
* bilder/: farbe/disk.img, farbe/info.img, mono/disk.img,
mono/info.img:
config.u - Die zusätzlichen Sprachen gelöscht, da es nur deutsch und
englisch gibt.
tos_hyp.u - Neuse Kapitel Emulatoren eingefügt.
cpxdoku.u - Darstellung der Auflistung der Funktionen verbessert.
vdi.u - Hinweis auf einen möglichen Absturz von ABC-GEM.
Bei Assmblerquelltext von vq_vgdos stand die falsche
Bezeichnung.
Einige Rückgabewerte von vq_vgdos ergänzt.
metafile.u - DIN-A3 und ähnliche heißen jetzt DIN A3.
attribut.u - Bei (!begin_liste) [Beschreibung:] den Doppelpunkt gelöscht.
!item [Verfügbarkeit] eingefügt und entsprechend eingtragen.
Bei allen restlichen Dateien des VDIs:
!item [Verfügbarkeit] eingefügt.
aes.u - Reihenfolge der Nodes geändert. Die Funktionen kommen nun
zum Schluß.
appl_.u - Bei (!begin_liste) [Beschreibung:] den Doppelpunkt gelöscht.
Appl_getinfo 13: Wert um objc_sysvar erweitert.
wind_.u - wind_create: wi_crkind um MENUBAR von XaAES ergänzt.
wind_set: Beschränkung von WF_INFO und WF_NAME
form_.u - form_alert: Icon Info und Diskettesymbol von AES 4.10
aes_f.u - Opcodenummer bei den fsel_ Funktionen korrigiert.
Funktionen von XaAES und Geneva nachgetragen.
aes/struktur.ui - Tedinfo: te_pvalid Beschreibung verbessert und neuer
Typ ergänzt.
style.u - Ein Label von einem " befreit.
tosmain.u - Neuer Querverweis beim Node "Das Betriebssystem TOS".
magic/dfs.u - Bei (!begin_liste) [Beschreibung:] den Doppelpunkt ge-
löscht.
magic/xfs.u - Bei (!begin_liste) [Beschreibung:] den Doppelpunkt ge-
löscht.
magic/magic.u - Teile heraus genommen.
magic/magicmac.u - Supervisor-Modus anstatt Supervisormodus.
magic/sharelib.u - Minimale Übersetzungen ins englische.
magic/magicerr.u - Übersetzt ins englische.
n_aes/n_aes.u - ~ ein ! vorrangestellt, dass es angezeigt wird.
bios.u - Die einzelnen Funktionen aus dem Text gelöst.
cookie.u - Niederlande heißt jetzt Holland.
_MCH: ARAnyM ergänzt
sys_var.u - Nummerisch sortierte Liste
sys_vec.u - Hinweis auf SuperCharger (Trap #4), Wind-XES (Trap #5)
und TapeBIOS (Trap #10)
bios_str.u - Struktur BPB und PUN_INFO hierher kopiert. Letztere um
einige Erklärung erweitert.
bios_f.u - Ein paar Ergänzungen.
typedef.u - Einige Strukturen sind gewandert.
neu.u - Version 4.92 angefangen
anhang.u - Scancode um Milan Alt Gr erweitert.
pmmu.u - Bei (!begin_liste) [Beschreibung:] den Doppelpunkt
gelöscht.
xhdi.u - Bei (!begin_liste) [Beschreibung:] den Doppelpunkt
gelöscht.
tos_vers.u - Einige TOS Versionen ergänzt.
gemdos.u - Neue Struktur erstellt.
signale.u - Querverweise an neue Überschriften angepasst.
gemdos/struktur.u- Ein Struktieren sind hierher gekommen.
Erläuterung zum rekursiven Bearbeiten von Directories.
tekbios.u - Erweitert für englische Übersetzung
olga.u - Hinweis auf das Archiv gelöscht, Maus KA gibt es nicht
mehr.
gelöscht.
Neuer Ordner bios/function mit den einzelnen Funktionen.
Neuer Ordner emulator.en angelegt mit den Dateien sonstige.u, stem.u,
tos2win.u. disk.img und info.img in Bilder/Farbe und Bilder/mono abgelegt.
2004-04-15 Thursday 20:32 Michael Bernstein
* .cvsignore, Makefile, config.u, e_linea.u, linea/bitblt.ui,
linea/cpraster.ui, linea/drsprite.ui, linea/fillpoly.ui,
linea/fillrect.ui, linea/getpixel.ui, linea/hdmouse.ui,
linea/hline.ui, linea/init.ui, linea/line.ui, linea/linea.u,
linea/putpixel.ui, linea/seedfill.ui, linea/shmouse.ui,
linea/textblt.ui, linea/trmouse.ui, linea/udrsprit.ui:
Beschreibung von Lina-A mit Makefile hinzugefuegt
Version 4.80
Version 4.70
Version 4.65
Version 4.60
Version 4.50
Version 4.35
Version 4.30
Version 4.20
Version 4.10
Version 4.01
Version 4.00
Version 3.75
Version 3.70
Version 3.60
Version 3.50
Version 3.10
Version 3.00
Version 2.60
Version 2.40
Version 2.30
Version 2.10
Version 2.00
Version 1.95
Version 1.80
Version 1.70
Version 1.50
Version 1.30
Version 1.20
Version 1.10
Version 1.00
Version 0.99
Version 0.98
Version 0.97
Version 0.96
Version 0.95
Version 0.90
Version 0.85
Version 0.80
Version 0.70
Version 0.60
Version 0.50
Version 0.40
