HomeAESFile-selector libraryEditable object functions
8.5 Print dialogs
The following routines were introduced with MagiC (also WDIALOG), and permit the creation and handling of print dialogs:
• pdlg_add_printers Adds application's printers
• pdlg_add_sub_dialogs Adds application's sub-dialogs
• pdlg_close Close window of a print dialog
• pdlg_create Initialise print dialog, allocate memory
• pdlg_delete Frees memory
• pdlg_dflt_settings Initialise memory region with printer settings
• pdlg_do Displays modal dialog
• pdlg_evnt Manages events for dialog in window
• pdlg_free_settings Frees memory used for printer settings
• pdlg_get_setsize Gets size of the structure
• pdlg_new_settings Returns pointer to initialized printer settings
• pdlg_open Opens selection dialog in window
• pdlg_remove_printers Removes application's printers
• pdlg_remove_sub_dialogs Removes application's sub-dialogs
• pdlg_save_default_settings Saves the default settings
• pdlg_update Updates window title
• pdlg_use_settings Validates and adopt printer settings
• pdlg_validate_settings Validates printer settings
Hint: The presence of this call should be checked for using appl_getinfo (opcode 7).
Display in a window   Display as modal dialog   AES   GEM   WDIALOG   Style guidelines
8.5.1 pdlg_add_printers
Name: »Print dialog - Add private printers« - Add application's own printer descriptions.
Opcode: 205 (sub-opcode 0)
Syntax: int16_t pdlg_add_printers ( PRN_DIALOG *prn_dialog, DRV_INFO *drv_info );
Description: The call pdlg_add_printer permits adding an application's own printer descriptions to the print dialog. The following apply:
prn_dialog Pointer to management structure
drv_info Pointer to the list of available printers and rastering processes
Note: The driver's index should be set to 0x7fff, so as to differentiate the custom driver from that of the operating system.
Return value: The function returns the value 1 if all went well, else the value 0 in case of error.
Availability: The presence of this function can be checked with appl_getinfo (opcode 7).
Group: Print dialogs
See also: Binding   WDIALOG
8.5.1.1 Bindings for pdlg_add_printers
C: int16_t pdlg_add_printers ( PRN_DIALOG *prn_dialog, DRV_INFO *drv_info );
   addr_in[0] = prn_dialog;
   addr_in[1] = drv_info;
   int_in[0] = 0;
   crys_if (205);
   return ( int_out[0] );
control control[0] 205 # Function opcode
control+2 control[1] 1 # Entry in int_in
control+4 control[2] 1 # Entry in int_out
control+6 control[3] 2 # Entry in addr_in
control+8 control[4] 0 # Entry in addr_out
addr_in addr_in[0] prn_dialog
addr_in+4 addr_in[1] drv_info
int_in int_in[0] 0 # Sub-opcode
int_out int_out[0] Return value
8.5.2 pdlg_add_sub_dialogs
Name: »Print dialog - Add private dialogs« - Add sub-dialogs to the printer dialog.
Opcode: 205 (sub-opcode 3)
Syntax: int16_t pdlg_add_sub_dialogs ( PRN_DIALOG *prn_dialog, PDLG_SUB *sub_dialog );
Description: The call pdlg_add_sub_dialogs permits adding an application's own sub-dialogs to the printer dialog. The following apply:
sub_dialog List of sub-dialogs
This function could be useful to add custom print options such as markers, watermarks or background images, for instance.
8.5.2.1 Bindings for pdlg_add_sub_dialogs
C: int16_t pdlg_add_sub_dialogs ( PRN_DIALOG *prn_dialog, PDLG_SUB *sub_dialog );
   addr_in[1] = sub_dialog;
   int_in[0] = 3;
   crys_if (205);
addr_in+4 addr_in[1] sub_dialog
int_in int_in[0] 3 # Sub-opcode
8.5.3 pdlg_close
Name: »Print dialog - Close window« - Close print dialog.
Opcode: 203
Syntax: int16_t pdlg_close ( PRN_DIALOG *prn_dialog, int16_t *x, int16_t *y );
Description: The call pdlg_close closes the window of the print dialog. The following apply:
x X-coordinate of the window
y Y-coordinate of the window
The parameters x and y are those of the last position of the print dialog.
Return value: The function always returns the value 1.
8.5.3.1 Bindings for pdlg_close
C: int16_t pdlg_close ( PRN_DIALOG *prn_dialog, int16_t *x, int16_t *y );
                     int16_t *y )
   int_out[1] = -1;
   int_out[2] = -1;
   crys_if (203);
   *x = int_out[1];
   *y = int_out[2];
control control[0] 203 # Function opcode
control+2 control[1] 0 # Entry in int_in
control+4 control[2] 3 # Entry in int_out
control+6 control[3] 1 # Entry in addr_in
int_out+2 int_out[1] x
int_out+4 int_out[2] y
8.5.4 pdlg_create
Name: »Print dialog - Create« - Initialize the print dialog.
Opcode: 200
Syntax: PRN_DIALOG *pdlg_create ( int16_t dialog_flags );
Description: The call pdlg_create initializes the print dialog and allocates memory for it. The following apply:
dialog_flags Diverse flags:
PDLG_3D (1) = Display selection in 3D-look
On calling the function a scan will be made for the printer drivers present and memory will be allocated for the resource.
Return value: The function returns a pointer to a PRN_DIALOG structure.
8.5.4.1 Bindings for pdlg_create
C: PRN_DIALOG *pdlg_create ( int16_t dialog_flags );
   int_in[0] = dialog_flags;
   crys_if (200);
   return ( addr_out[0] );
control control[0] 200 # Function opcode
control+4 control[2] 0 # Entry in int_out
control+6 control[3] 0 # Entry in addr_in
control+8 control[4] 1 # Entry in addr_out
int_in int_in[0] dialog_flags
addr_out addr_out[0] Return value
8.5.5 pdlg_delete
Name: »Print dialog - Delete« - Release the memory of the print dialog.
Opcode: 201
Syntax: int16_t pdlg_delete ( PRN_DIALOG *prn_dialog );
Description: The call pdlg_delete frees the memory used for the print dialog. The following applies:
8.5.5.1 Bindings for pdlg_delete
C: int16_t pdlg_delete ( PRN_DIALOG *prn_dialog );
   crys_if (201);
control control[0] 201 # Function opcode
8.5.6 pdlg_dflt_settings
Name: »Print dialog - Default settings« - Default initialization.
Opcode: 205 (sub-opcode 7)
Syntax: int16_t pdlg_dflt_settings ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings );
Description: The call pdlg_dflt_settings takes on the initialization of the default printer settings in memory. The following apply:
settings Printer settings
Structure length from PRN_SETTINGS can be found with pdlg_get_setsize.
8.5.6.1 Bindings for pdlg_dflt_settings
C: int16_t pdlg_dflt_settings ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings );
   addr_in[1] = settings;
   int_in[0] = 7;
   crys_if (205);
addr_in+4 addr_in[1] settings
int_in int_in[0] 7 # Sub-opcode
8.5.7 pdlg_do
Name: »Print dialog - Do« - Open a print dialog.
Opcode: 207
Syntax: int16_t pdlg_do ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings, int8_t *document_name, int16_t option_flags );
Description: The call pdlg_do opens a modal print dialog. The following apply:
document_name Document name
option_flags Diverse flags:
0x0000 = Display settings dialog
0x0001 = Display print dialog
0x0010 = Always offer No. of copies
0x0020 = Always offer landscape format
0x0040 = Always offer scaling
0x0100 = Offer option for even and odd pages
The function only returns to the caller when one of the exit buttons has been activated ('Cancel', 'OK').
Return value: The function returns the value of the selected button (1 = Cancel, 2 = OK), or the value 0 in case of error.
8.5.7.1 Bindings for pdlg_do
C: int16_t pdlg_do ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings, int8_t *document_name, int16_t option_flags );
   addr_in[2] = document_name;
   int_in[0] = option_flags;
   crys_if (207);
control control[0] 207 # Function opcode
control+6 control[3] 3 # Entry in addr_in
addr_in+8 addr_in[2] document_name
int_in int_in[0] option_flags
8.5.8 pdlg_evnt
Name: »Print dialog - Handle event« - Event processing of the print dialog.
Opcode: 206
Syntax: int16_t pdlg_evnt ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings, EVNT *events, int16_t *button );
Description: The call pdlg_evnt takes on the event management for a print dialog. The following apply:
events Pointer to EVNT structure
button Selected button (or 0)
  PDLG_CANCEL (1) = Cancel
  PDLG_OK (2)     = OK
The funcfunc evaluat and internally calls wdlg_evnt. If the dialog was confirmed, then the new printer settings are returned in settings.
Return value: The function returns the value 0 if one of the EXIT buttons was clicked on, else the value 1.
8.5.8.1 Bindings for pdlg_evnt
C: int16_t pdlg_evnt ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings, EVNT *events, int16_t *button );
   addr_in[2] = events;
   crys_if (206);
   *button = int_out[1];
control control[0] 206 # Function opcode
control+4 control[2] 2 # Entry in int_out
addr_in+8 addr_in[2] events
int_out+2 int_out[1] button
8.5.9 pdlg_free_settings
Name: »Print dialog - Free settings« - Release memory.
Opcode: 205 (sub-opcode 6)
Syntax: int16_t pdlg_free_settings ( PRN_SETTINGS *settings );
Description: The call pdlg_free_setting frees the memory that was reserved by the call pdlg_new_settings. The following applies:
Return value: The return value of the function is unknown at present.
8.5.9.1 Bindings for pdlg_free_settings
C: int16_t pdlg_free_settings ( PRN_SETTINGS *settings );
   addr_in[0] = settings;
   int_in[0] = 6;
   crys_if (205);
addr_in addr_in[0] settings
int_in int_in[0] 6 # Sub-opcode
8.5.10 pdlg_get_setsize
Name: »Print dialog - Get setting structure size« - Obtain the length of the PRN_SETTINGS structure.
Opcode: 204 (sub-opcode 0)
Syntax: int32_t pdlg_get_setsize ( void );
Description: The call pdlg_get_setsize returns the length of the PRN_SETTINGS structure.
Return value: The function returns the length of the structure in bytes.
8.5.10.1 Bindings for pdlg_get_setsize
C: int32_t pdlg_get_setsize ( void );
   int_in[0] = 0;
   crys_if (204);
   return ( int_out[0..1] );
control control[0] 204 # Function opcode
int_out int_out[0..1] Return value
8.5.11 pdlg_new_settings
Name: »Print dialog - New default settings« - Set default printer settings.
Opcode: 205 (sub-opcode 5)
Syntax: PRN_SETTINGS *pdlg_new_settings ( PRN_DIALOG *prn_dialog );
Description: The call pdlg_new_settings returns a pointer to the initialized printer settings. The following applies:
Return value: The function returns a pointer to a PRN_SETTINGS structure in which the current printer settings are stored.
8.5.11.1 Bindings for pdlg_new_settings
C: PRN_SETTINGS *pdlg_new_settings ( PRN_DIALOG *prn_dialog );
   int_in[0] = 5;
   crys_if (205);
int_in int_in[0] 5 # Sub-opcode
8.5.12 pdlg_open
Name: »Print Dialog - Open Window« - Druckdialog im Fenster öffnen.
Opcode: 202
Syntax: int16_t pdlg_open ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings, int8_t *document_name, int16_t option_flags, int16_t x, int16_t y );
Description: The call pdlg_open opens a window with the print dialog. The following apply:
0x0020 = lways offer landscape format
x X-coordinates of the window, or -1 (centred)
y Y-coordinates of the window, or -1 (centred)
Note: The structure settings contains the printer setting that should be saved with each document. If no setting exists yet for a document, it can either be created with pdlg_new_settings, or the application can call Malloc and subsequently pdlg_dflt_settings to initialize the memory.
In the parameter option_flags one can decide, amongst others, whether the dialog should be displayed as a settings or a print dialog. With further flags one can also determine whether scaling, copy options and landscape printing should be offered even if a driver does not support them, so that the application has to output the page rotated, for instance.
Return value: The function returns the ID of the created window, or the value 0 in case of error.
8.5.12.1 Bindings for pdlg_open
C: int16_t pdlg_open ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings, int8_t *document_name, int16_t option_flags, int16_t x, int16_t y );
                    int16_t x, int16_t y)
   int_in[1] = x;
   int_in[2] = y;
   crys_if (202);
control control[0] 202 # Function opcode
control+2 control[1] 3 # Entry in int_in
int_in+2 int_in[1] x
int_in+4 int_in[2] y
8.5.13 pdlg_remove_printers
Name: »Print dialog - Remove private printers« - Remove application's printers from the list.
Opcode: 205 (sub-opcode 1)
Syntax: int16_t pdlg_remove_printers ( PRN_DIALOG *prn_dialog );
Description: The call pdlg_remove_printers removes the application's printers registered with pdlg_add_printers. The following applies:
The function must be called before pdlg_delete.
8.5.13.1 Bindings for pdlg_remove_printers
C: int16_t pdlg_remove_printers ( PRN_DIALOG *prn_dialog );
   addr_in[0] = prn_dialog_dialog;
   int_in[0] = 1;
   crys_if (205);
int_in int_in[0] 1 # Sub-opcode
8.5.14 pdlg_remove_sub_dialogs
Name: »Print dialog - Remove private dialogs« - Remove sub-dialogs from the print dialog.
Opcode: 205 (sub-opcode 4)
Syntax: int16_t pdlg_remove_sub_dialogs ( PRN_DIALOG *prn_dialog );
Description: The call pdlg_remove_sub_dialogs removes the application's own sub-dialogs from the print dialog. The following applies:
8.5.14.1 Bindings for pdlg_remove_sub_dialogs
C: int16_t pdlg_remove_sub_dialogs ( PRN_DIALOG *prn_dialog );
   int_in[0] = 4;
   crys_if (205);
int_in int_in[0] 4 # Sub-opcode
8.5.15 pdlg_save_default_settings
Name: »Print dialog - Save default settings«
Opcode: 205 (sub-opcode 10)
Syntax: int16_t pdlg_save_default_settings ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings );
Description: The call pdlg_save_default_settings saves the default printer settings that were set with pdlg_new_settings. The following apply:
settings Pointer to printer settings
8.5.15.1 Bindings for pdlg_save_default_settings
C: int16_t pdlg_save_default_settings ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings );
   int_in[0] = 10;
   crys_if (205);
int_in int_in[0] 10 # Sub-opcode
8.5.16 pdlg_update
Name: »Print Dialog - Update Window« - neuen Fensternamen setzen.
Opcode: 205 (sub-opcode 2)
Syntax: int16_t pdlg_update ( PRN_DIALOG *prn_dialog, int8_t *document_name );
Description: »Print dialog - Update window« - Set new window title.
document_name New document name
Note: The function should be called if a window-dialog is lying in the background and the user tops a new document window (brings it to the front).
Return value: The function returns the value 1 if it operates correctly, else the value 0 in case of error.
8.5.16.1 Bindings for pdlg_update
C: int16_t pdlg_update ( PRN_DIALOG *prn_dialog, int8_t *document_name );
   addr_in[1] = 0;              /* Reserved (must be 0!) */
   int_in[0] = 2;
   crys_if (205);
addr_in+4 addr_in[1] 0
int_in int_in[0] 2 # Sub-opcode
8.5.17 pdlg_use_settings
Name: »Print dialog - Use settings« - Use validated settings.
Opcode: 205 (sub-opcode 9)
Syntax: int16_t pdlg_use_settings ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings );
Description: The call pdlg_use_settings serves to validate the printer settings that were set with pdlg_new_settings before adopting them for use. The following apply:
This function should be called if a program wants to print immediately and it is not possible to call pdlg_do or pdlg_open and pdlg_evnt (e.g. Calamus print dialogs). The passed printer settings will be validated (and saved for old drivers).
8.5.17.1 Bindings for pdlg_use_settings
C: int16_t pdlg_use_settings ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings );
   int_in[0] = 9;
   crys_if (205);
int_in int_in[0] 9 # Sub-opcode
8.5.18 pdlg_validate_settings
Name: »Print dialog - Validate settings« - Validates the printer settings.
Opcode: 205 (sub-opcode 8)
Syntax: int16_t pdlg_validate_settings ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings );
Description: The call pdlg_validate_settings validates the printer settings that were set with pdlg_new_settings. The following apply:
Note: Faulty structure contents will be corrected by the function if necessary.
8.5.18.1 Bindings for pdlg_validate_settings
C: int16_t pdlg_validate_settings ( PRN_DIALOG *prn_dialog, PRN_SETTINGS *settings );
   int_in[0] = 8;
   crys_if (205);
int_in int_in[0] 8 # Sub-opcode
8.5.19 Print selection in a window
Program start:
. pdlg_create()
Calling the print dialog: pdlg_open()
Event loop: pdlg_evnt()
Closing of the print dialog: pdlg_close()
. pdlg_delete()
Program end:
8.5.20 Print selection as a dialog
Program start:
. pdlg_create()
Calling the print dialog: pdlg_do()
. pdlg_delete()
Program end:
