HomeGEMDOSGEMDOS function listLine-A
5.20 GEMDOS structures
5.20.1 CD-ROM definitions
/* CD-ROM address types */
#define CDROM_LBA               0x01
#define CDROM_MSF               0x02
/* SUB Q control bits */
#define CDROM_AUDIO_EMPHASIS    0x01
#define CDROM_COPY_PERMITTED    0x02
#define CDROM_DATA_TRACK        0x04
#define CDROM_FOUR_CHANNEL      0x08
/* The leadout track is always 0xAA, regardless of # of tracks on disc */
#define CDROM_LEADOUT   0xAA
/* return value from READ SUBCHANNEL DATA */
#define CDROM_AUDIO_INVALID     0x00  /* Audio status not supported         */
#define CDROM_AUDIO_PLAY        0x11  /* Audio play operation in progress   */
#define CDROM_AUDIO_PAUSED      0x12  /* Audio play operation paused        */
#define CDROM_AUDIO_COMPLETED   0x13  /* Audio play successfully completed  */
#define CDROM_AUDIO_ERROR       0x14  /* Audio play stopped due to error    */
#define CDROM_AUDIO_NO_STATUS   0x15  /* No current audio status to return  */
See also: CD-ROM opcodes for Fcntl
5.20.2 cdrom_audioctrl
struct cdrom_audioctrl
    /* input parameters */
    int16_t set;                   /* 0 = 0 == inquire only */
    /* input/output parameters */
    struct
        int8_t selection;
        int8_t volume;
    } channel[4];
5.20.3 cdrom_mcn
struct cdrom_mcn
    int8_t  mcn_audiostatus;
    int8_t  mcn_mcn[23];       /* Media catalog number as ASCII string */
See also: CD-ROM opcodes for Fcntl   ASCII table
5.20.4 cdrom_msf
struct cdrom_msf
    int8_t cdmsf_min0;       /* Start minute  */
    int8_t cdmsf_sec0;       /* Start second  */
    int8_t cdmsf_frame0;     /* Start frame   */
    int8_t cdmsf_min1;       /* End minute    */
    int8_t cdmsf_sec1;       /* End second    */
    int8_t cdmsf_frame1;     /* End frame     */
5.20.5 cdrom_read
struct cdrom_read
    int32_t  cdread_lba;       /* Logical block address */
    int8_t  *cdread_bufaddr;   /* Buffer pointer        */
    int32_t  cdread_buflen;    /* Byte count            */
5.20.6 cdrom_subchnl
struct cdrom_subchnl
    int8_t cdsc_format;             /* CDROM_MSF or CDROM_LBA */
    /* output parameters */
    int8_t   cdsc_audiostatus;
    unsigned cdsc_resvd: 8;         /* Reserved               */
    unsigned cdsc_adr  : 4;
    unsigned cdsc_ctrl : 4;
    int8_t   cdsc_track;            /* Current track          */
    int8_t   cdsc_ind;              /* Current index          */
    cd_ad    cdsc_absaddr;          /* Absolute address       */
    cd_ad    cdsc_reladdr;          /* Track relative address */
5.20.7 cdrom_ti
struct cdrom_ti
    int8_t cdti_trk0;        /* Start track */
    int8_t cdti_ind0;        /* Start index */
    int8_t cdti_trk1;        /* End track   */
    int8_t cdti_ind1;        /* End index   */
5.20.8 cdrom_tisrc
struct cdrom_tisrc
    int8_t tisrc_track;          /* Track number                 */
    int8_t tisrc_audiostatus;
    int8_t tisrc_tisrc[23];      /* Track International Standard
                                    Recording Code (ASCII)       */
5.20.9 cdrom_tocentry
struct cdrom_tocentry
    int8_t cdte_track;             /* Track number or CDROM_LEADOUT */
    int8_t cdte_format;            /* CDROM_LBA or CDROM_MSF        */
    unsigned cdte_adr:4;           /* the SUBQ channel encodes:
                                      0 = nothing
                                      1 = position data
                                      2 = MCN
                                      3 = ISRC
                                      Else: reserved                */
    unsigned cdte_ctrl:4;          /* Bit-0: Audio with pre-emphasis
                                      Bit-1: Digital copy permitted
                                      Bit-2: Data track
                                      Bit-3: Four channel           */
    int8_t   cdte_datamode;        /* Currently not se              */
    cd_ad    dte_addr;             /* Track start                   */
5.20.10 cdrom_tochdr
struct cdrom_tochdr
    int8_t cdth_trk0;        /* Start track */
    int8_t cdth_trk1;        /* End track   */
5.20.11 cdrom_volctrl
struct cdrom_volctrl
    int8_t  channel0;   /* Channel 1: Volume 0...255 */
    int8_t  channel1;   /* Channel 2: Volume 0...255 */
    int8_t  channel2;   /* Channel 3: Volume 0...255 */
    int8_t  channel3;   /* Channel 4: Volume 0...255 */
5.20.12 cd_ad
This union is defined as follows:
typedef union
    struct
       int8_t reserved;    /* Reserved   */
       int8_t minute;      /* Minute     */
       int8_t second;      /* Second     */
       int8_t frame;       /* Frame      */
    } msf;
    int32_t lba;
} cd_ad;
5.20.13 DISKINFO
This structure is defined as follows:
    uint32_t   b_free;    /* Number of free clusters  */
    uint32_t   b_total;   /* Total number of clusters */
    uint32_t   b_secsiz;  /* Bytes per sektor         */
    uint32_t   b_clsiz;   /* sector per cluster       */
} DISKINFO;
See also: Dfree   GEMDOS
5.20.14 DOSTIME
   uint16_t     time;  /* Time like Tgettime */
   uint16_t     date;  /* Date like Tgetdate */
} DOSTIME;
The structure of both integer values is arranged as follows:
Bit Time
0-4 Seconds in units of two (0-29)
5-10 Minutes (0-59)
11-15 Hours (0-23)
Bit Date
0-4 Day of month (1-31)
5-8 Month (1-12)
9-15 Year (0-119, 0=1980)
See also: Fdatime   GEMDOS
5.20.15 DOSVARS
   int8_t    *in_dos;                 /* Adress of the DOS semaphore  */
   int16_t   *dos_time;               /* Adress of the DOS time       */
   int16_t   *dos_date;               /* Adress of the DOS date       */
   int32_t   res1;                    /*                              */
   int32_t   res2;                    /*                              */
   int32_t   res3;                    /* is 0L                        */
   VOID      *act_pd;                 /* Running program              */
   int32_t   res4;                    /*                              */
   int16_t   res5;                    /*                              */
   VOID      *res6;                   /*                              */
   VOID      *res7;                   /* Internal DOS memory list     */
   VOID      (*resv_intmem)();        /* Extend DOS memory            */
   int32_t   (*etv_critic)();         /* etv_critic of the GEMDOS     */
   int8_t *  ((*err_to_str)(int8_t e)); /* Conversion code->plain text */
   int32_t   res8;                    /*                              */
   int32_t   res9;                    /*                              */
   int32_t   res10;                   /*                              */
} DOSVARS;
Note: These variables are READ-ONLY !
With the aid of the function resv_intmem one can reserve memory for internal memory management (similar to using FOLDRnnnn). In contrast to TOS however this is stressed far less, so that extension is not usually necessary. If memory has to be extended, which also happens with ADDMEM, then one passes to the function resv_intmem the address in register A0, and the length of the memory block to be reserved in register D0.
The prototype for the Event Critic Handler runs:
int32_t etv_critic (int16_t errcode, int16_t drvnr)
Note that the function expects the arguments on the stack, and hence in Pure-C must be declared as cdecl.
The function err_to_str expects in register D0 a TOS error-code, and returns in registers D0 and A0 a pointer to the descriptive character string. With an invalid error-code one receives in D0 a NULL, and in A0 a pointer to the character string 'TOS error'.
As seen by KAOS 1.4.2 the structure looks like this:
   int8_t    *in_dos;                 /* Address of the DOS semaphores */
   int16_t   *dos_time;               /* Address of the DOS time       */
   int16_t   *dos_date;               /* Address of the DOS date       */
   int32_t   dos_stack;               /* Stack for DOS itself          */
   int32_t   pgm_superset;            /* User-program super stack      */
   MD        *menlist[3];             /* Address of the 3 MD lists     */
   FCB       *fcbx;                   /* Files                         */
   int16_t   fcbn;                    /* Length of fcbx[]              */
   DMD       *dmdx;                   /* Pointer to 16 DMDs            */
   IMB       *imbx;                   /* Internal DOS memory list      */
   int8_t *  ((*err_to_str)(int8_t e)); /* Conversion code->clear text */
} DOSVARS;
See also: AESVARS   Cookie of MagiC   Sconfig
5.20.16 DTA
    int8_t    d_reserved[21];  /* Reserved for GEMDOS */
    uint8_t   d_attrib;        /* File attributes     */
    uint16_t  d_time;          /* Time                */
    uint16_t  d_date;          /* Date                */
    uint32_t  d_length;        /* File length         */
    int8_t    d_fname[14];     /* Filename            */
} DTA;
Recursive search in folders
In each DTA, all required information is stored that is required after a Fsfirst for further Fsnext calls. That means that one should never call Fsfirst anew for other directories/wildcards as long as further Fsnext calls are made in the same directory.(!nl) For a recursive search one must use a new DTA for each new Fsfirst, which must be maintained until all Fsnext for the Fsfirst have been made. Here an example in pseudo-C:
void search_directory (int8_t *pfadname)
  DTA_Record local_dta, saved_dta;
  saved_dta = GetDTA ();
  SetDTA (local_dta);
  err = Fsfirst (pfadname, ...);
  while (err == 0) {
    if (local_dta.attrib == subdir) {
      // recursive search in sub-dir
      search_directory (subdir-pfadname);
    } else {
      ... evaluate normal file
    err = Fsnext ();
  SetDTA (saved_dta);
See also: Fgetdta   Fsetdta   Fsfirst   Fsnext   GEMDOS
5.20.17 fcookie
typedef struct f_cookie
    struct filesys *fs; /* File-system that knows this cookie       */
    uint16_t dev;       /* Device info (e.g. Rwabs device number)   */
    uint16_t aux;       /* Further data for the file-system         */
    int32_t  index;     /* Serves together with dev for identifying */
                        /* a file                                   */
} fcookie;
See also: FILEPTR   FILESYS   XFS-concept in MagiC
5.20.18 FILEPTR
typedef struct fileptr
    int16_t         links;
    uint16_t        flags;
    int32_t         pos;
    int32_t         devinfo;
    fcookie         fc;
    struct devdrv  *dev;
    struct fileptr *next;
} FILEPTR;
See also: Dcntl   DEVDRV
5.20.19 flock, Fcntl
struct flock
    int16_t  l_type;     /* Type of lock                 */
    int16_t  l_whence;   /* SEEK_SET, SEEK_CUR, SEEK_END */
    int32_t  l_start;    /* Start of the locking region  */
    int32_t  l_len;      /* Length of the locking region */
    int16_t  l_pid;      /* PID of the locking process   */
Note: Possible values for l_type are: 0 = Read locking, 1 = Write locking as well as 3 = No locking.
5.20.20 LINE
    uint8_t   maxlen;        /* Maximum line length */
    uint8_t   actuallen;     /* Current line length */
    int8_t    buffer[255];   /* Line buffer         */
} LINE;
See also: Cconrs   GEMDOS
5.20.21 ltchars
struct ltchars
    int8_t t_suspc;
    int8_t t_dsuspc;
    int8_t t_rprntc;
    int8_t t_flushc;
    int8_t t_werasc;
    int8_t t_lnextc;
See also: struct tty   XFS-concept in MagiC
5.20.22 mutimbuf
struct mutimbuf
   uint16_t actime;     /* Access time               */
   uint16_t acdate;     /* Access date               */
   uint16_t modtime;    /* Time of last modification */
   uint16_t moddate;    /* Date of last modification */
See also: Dcntl   Fcntl   GEMDOS
5.20.23 Process Descriptor (PD) resp. BASEPAGE
typedef struct pd
   VOID     *p_lowtpa;      /* Start address of the TPA            */
   VOID     *p_hitpa;       /* First byte after the end of the TPA */
   VOID     *p_tbase;       /* Start address of the program code   */
   int32_t   p_tlen;        /* Length of the program code          */
   VOID     *p_dbase;       /* Start address of the DATA segment   */
   int32_t   p_dlen;        /* Length of the DATA section          */
   VOID     *p_bbase;       /* Start address of the BSS segment    */
   int32_t   p_blen;        /* Length of the BSS section           */
   DTA      *p_dta;         /* Pointer to the default DTA          */
                            /* Warning: Points first to the        */
                            /* command line !                      */
   struct pd *p_parent;     /* Pointer to the basepage of the      */
                            /* calling processes                   */
   int32_t   p_resrvd0;     /* Reserved                            */
   int8_t   *p_env;         /* Address of the environment string   */
   int8_t    p_resrvd1[80]; /* Reserved                            */
   int8_t    p_cmdlin[128]; /* Command line                        */
} PD; /* also: BASEPAGE */
Note about the command line: The number of characters is inserted in the first line. The maximum length of the command line does not amount to 127, but only to 124 characters! (This does not apply in MagiC as of Version 3 - see ARGV procedure).
See also: GEMDOS   OSHEADER   Pexec   Program launch and TPA
5.20.24 ploadinfo
struct ploadinfo
   int16_t fnamelen;  /* Lenght from 'fname'                         */
   int8_t *cmdlin;    /* Command line of the processes (128 bytes)   */
   int8_t *fname;     /* Complete path and filename of the processes */
See also: Fcntl   PLOADINFO
5.20.25 sgttyb
struct sgttyb
    int8_t   sg_ispeed;
    int8_t   sg_ospeed;
    int8_t   sg_erase;
    int8_t   sg_kill;
    uint16_t sg_flags;
5.20.26 struct sigaction
struct sigaction
   void cdecl (*sa_handler)(int32_t sig);
   int32_t    sa_mask;
   int16_t    sa_flags;
Note: The component sa_handler can assume various values here. A value of 0 means default signal-handling by the system, with a value of 1 the signal will be ignored; any other value will be interpreted as the address of a signal handling routine, which is then called.
The component sa_mask contains additionally (to the signal currently being processed) the signals to be masked during the signal handling. In that case mask = oldmask+(1<sa_flags one can influence the behaviour of a signal further. A value of 1 for sa_flags means in MiNT that the signal SIGCHLD is triggered only on termination and not on stopping the child; other values for sa_flags are not yet defined at the present time.
See also: Signals   Signal-handler in MagiC   GEMDOS   Psigaction   Process functions
5.20.27 tchars
struct tchars
    int8_t t_intrc;
    int8_t t_quitc;
    int8_t t_startc;
    int8_t t_stopc;
    int8_t t_eofc;
    int8_t t_brkc;
5.20.28 timeval
struct timeval
  int32_t int tv_sec;
  int32_t int tv_usec;
tv_sec holds the number of seconds elapsed since the epoch. The epoch is Thu, Jan 1 1970 00:00:00 UTC.
tv_usec holds the fractional part of tv_sec measured in microseconds.
5.20.29 timezone
struct timezone
  int32_t int tz_minuteswest;
  int32_t int tz_dsttime;
tz_minuteswest holds the offset to UTC in seconds. Timezones east of the zero-meridian (e.g. Eastern Europe) have a negative offset, timezones west of the zero-meridian (e.g. America) have a positive one.
tz_dsttime is non-zero if daylight savings time applies during some part of the year.
5.20.30 struct tty
struct tty
    int16_t         pgrp;
    int16_t         state;
    int16_t         use_cnt;
    int16_t         res1;
    struct sgttyb   sg;
    struct tchars   tc;
    struct ltchars  ltc;
    struct winsize  wsiz;
    int32_t         rsel;
    int32_t         wsel;
    int8_t          *xkey;
    int32_t         hup_ospeed;
    uint16_t        vmin, vtime;
    int32_t         resrvd[1];
See also: Dcntl   dev_descr   XFS-concept in MagiC
5.20.31 winsize
struct winsize
    int16_t  ws_row;
    int16_t  ws_col;
    int16_t  ws_xpixel;
    int16_t  ws_ypixel;
See also: Fcntl   TIOCGWINSZ
5.20.32 XATTR
typedef struct xattr
   uint16_t   mode;              /* File mode, statements for */
                                 /* - possible filetypes      */
                                 /* - special bits            */
                                 /* - access rights           */
   int32_t    index;             /* File number               */
   uint16_t   dev;               /* Device number             */
   uint16_t   rdev;              /* Actual device             */
                                 /* (e.g. for BIOS files)     */
                                 /* in MagiC however reserved */
   uint16_t   nlink;             /* Number of links           */
   uint16_t   uid;               /* User number               */
   uint16_t   gid;               /* Group number              */
   int32_t    size;              /* File length               */
   int32_t    blksize, nblocks;  /* Blocksize/occupied blocks */
   uint16_t   mtime, mdate;      /* Date of last modification */
   uint16_t   atime, adate;      /* Date of the last access   */
   uint16_t   ctime, cdate;      /* Creation date             */
   uint16_t   attr;              /* TOS file attributes       */
   uint16_t   reserved2;         /* Reserviert                */
   int32_t    reserved3[2];      /* Reserviert                */
} XATTR;
Note: MagiC returns for FAT file-systems the following index data:
• Directories: Start cluster in Motorola format
• Other files:
High word = Start cluster of the directory
Low word = Position within the directory >> 5
This procedure is similar to that used by Linux and Solaris. The drawback is that files alter their index during a move.
The component index is therefore a LONGword for the unambiguous identification of a file or a folder. The index must be unique within a file-system; together with the following field (dev) it completely pinpoints a file or a folder system-globally.
Under UNIX-like file-systems, index is the number of the Inode.
On Macintosh partitions, the hard file ID or the hard dir ID that the MacOS makes available is used. However, the MacOS uses FSSpec as the standard descriptors. For directories, i.e. for directory IDs, there are functions of the MacOS to calculate a FSSpec. Unfortunately the hard file IDs for normal files (i.e. not subdirectories) cannot continue to be used, as they are not processed by any function of the MacOS.
See also: XFS-concept in MagiC   Fxattr   Dxreaddir
5.20.32.1 XATTR, dev-components
Determines the file-system. On the Atari, 0..25 are the BIOS drives A: to Z:, Drive U: or other file-systems use higher numbers. On the Macintosh the 'volume ID' is used, which is assigned by the MacOS.
5.20.32.1.1 XATTR, possible filetypes
Possible filetypes that can be set or obtained via the XATTR structure:
#define S_IFMT  0170000  /* For isolating the filetype */
#define S_IFCHR 0020000  /* Special BIOS file          */
#define S_IFDIR 0040000  /* Directory                  */
#define S_IFREG 0100000  /* Normal file                */
#define S_IFIFO 0120000  /* FIFO (Pipe with name)      */
#define S_IMEM  0140000  /* Memory block/process file  */
#define S_IFLNK 0160000  /* Symbolic link              */
5.20.32.1.2 Sticky-bit
Special bits that can be set or obtained via the XATTR structure:
#define S_ISUID 04000  /* Set user ID of the owner */
#define S_ISGID 02000  /* Set group ID at call     */
#define S_ISVTX 01000  /* Sticky-bit               */
Note: The meaning of the sticky-bit depends on the filetype.
5.20.32.1.3 XATTR, size-components
On DOS partitions, folders return the value 0 as their length. The actual length unfortunately cannot be ascertained due to limitations of MSDOS. Only the length of the root directory can be obtained.
On Macintosh partitions folders always have the length 0, the actual length cannot be obtained (at least under System 7).
5.20.32.1.4 XATTR, special bits
Special bits that may be set or obtained via the XATTR structure:
Note: The meaning of sticky-bit depends on the filetype.
5.20.32.1.5 XATTR, access rights
Possible access rights that can be set or obtained via the XATTR structure:
#define S_IRUSR 0400   /* Owner may read file       */
#define S_IWUSR 0200   /* Owner may write           */
#define S_IXUSR 0100   /* Owner members may execute */
#define S_IRGRP 0040   /* Group members may read    */
#define S_IWGRP 0020   /* Group members may write   */
#define S_IXGRP 0010   /* Group members may execute */
#define S_IROTH 0004   /* Others may read file      */
#define S_IWOTH 0002   /* Others may write          */
#define S_IXOTH 0001   /* Others may execute        */
5.20.32.2 xkey
struct xkey
    int16_t   xk_num;
    int8_t    xk_def[8];
See also: Fcntl   TIOCGXKEY
