This structure is defined as follows:
int16_t frames;
int16_t delay;
MFORM form[32];
} ANI_MOUSE;
See also: graf_mouse
int8_t name[13];
int8_t desc[17];
APFLG flags;
KEYCODE open_key;
KEYCODE reserve_key[3];
} APPFLAGS;
See also: x_appl_flags
typedef union
struct
unsigned multitask :1;
unsigned special_types:1;
unsigned round_buttons:1;
unsigned kbd_equivs :1;
unsigned undo_equivs :1;
unsigned off_left :1;
unsigned exit_redraw :1;
unsigned AES40_msgs :1;
unsigned limit_handles:1;
unsigned limit_memory :1;
unsigned keep_deskmenu:1;
unsigned clear_memory :1;
unsigned maximize_wind:1;
unsigned unused :3; /* Reserved for future use */
unsigned mem_limit :16; /* Kb to limit memory allocation */
} s;
unsigned long l;
} APFLG;
See also: x_appl_flags APPFLAGS
int32_t type; /* Type of event */
int32_t what; /* Exact description of the event */
} APPLRECORD
For the components the following apply:
| type Meaning | what | ||||||||||||
| 0 Timer event | Number of 50-millisecond ticks | ||||||||||||
| 1 Button event | (high-WORD) Status of mouse buttons (0 = not depressed, 1 =
depressed):
(low-WORD) Always 1 | ||||||||||||
| 2 Mouse event | X-coordinate (high-WORD), Y-coordinate (low-WORD) of hotspot | ||||||||||||
| 3 Keyboard event |
Note: Under PC-GEM each event occupies only 6 bytes, as the component type of APPLRECORD is defined as a int16_t there.
See also: appl_tplay appl_trecord
A bit-image can always be used wherever a non-selectable icon could be placed; the crucial difference is that no mask exists for a bit-image. This structure is defined as follows:
int16_t *bi_pdata; /* Pointer to the graphics data */
int16_t bi_wb; /* Width of the image in bytes */
int16_t bi_hl; /* Height in lines */
int16_t bi_x; /* X-position, and */
int16_t bi_y; /* Y-position of top left corner */
int16_t bi_color; /* Colour */
} BITBLK;
Note: The width of a bit-image (component bi_wb) must always be divisible by 2.
See also: OBJECT AES object types
typedef struct cicon_data
int16_t num_planes; /* Number of planes for the following data */
int16_t *col_data; /* Pointer to colour bitmap in standard form */
int16_t *col_mask; /* Pointer to individual colour plane mask */
int16_t *sel_data; /* Pointer to colour bitmap of selected icon */
int16_t *sel_mask; /* Pointer to individual plane mask of the icon */
struct cicon_data *next_res; /* Pointer to icon of other resolution */
} CICON;
See also: CICONBLK ICONBLK OBJECT
typedef struct cicon_blk
ICONBLK monoblk; /* Default: monochrome icons */
CICON *mainlist; /* Colour icons for various resolutions */
} CICONBLK;
See also: OBJECT AES object structure
typedef struct clrcat
int16_t cc_foreground /* Foreground colour */
int16_t cc_background /* Background colour */
int16_t cc_style /* Fill style */
int16_t cc_pattern /* Fill pattern */
} CLRCAT;
The CLRCAT is used internally by ViewMAX/2 and later to store the colour categories.
See also: X_BUF_V2
typedef void *DIALOG;
typedef struct _dither_mode
struct _dither_mode *next; /* Pointer to successor */
int32_t length; /* Structure length */
int32_t format; /* Data format */
int32_t reserved; /* Reserved */
int32_t dither_id; /* Dither ID */
int32_t color_modes; /* Colour depths supported */
int32_t reserved1; /* Reserved */
int32_t reserved2; /* Reserved */
int8_t name[32]; /* Name of the dither process */
} DITHER_MODE;
See also: Print dialogs pdlg_add_printers
typedef struct _drv_entry
struct _drv_entry *next; /* Pointer to successor */
} DRV_ENTRY;
int32_t magic; /* 'pdnf' */
int16_t driver_id; /* Driver number for the VDI */
int16_t driver_type; /* Driver type */
int32_t reserved3; /* Reserved */
PRN_ENTRY *printers; /* List of printers belonging to */
/* the driver */
DITHER_MODE *dither_modes; /* List of dither processes */
/* supported by the driver */
int32_t reserved4; /* Reserved */
int32_t reserved5; /* Reserved */
int32_t reserved6; /* Reserved */
int32_t reserved7; /* Reserved */
int32_t reserved8; /* Reserved */
int32_t reserved9; /* Reserved */
int8_t device[128]; /* Printer driver output file */
} DRV_INFO;
int16_t mwhich; /* Type of events */
int16_t mx; /* X-coordinate of the mouse pointer */
int16_t my; /* Y-coordinate of the mouse pointer */
int16_t mbutton; /* Pressed mouse button */
int16_t kstate; /* Status of 'special' keys (kbshift) */
int16_t key; /* Scancode of pressed key */
int16_t mclicks; /* Number of mouse clicks */
int16_t reserved[9]; /* Reserved */
int16_t msg[16]; /* Message buffer */
} EVNT;
See also: fnts_evnt fslx_evnt wdlg_evnt
typedef struct _fnts_item
struct _fnts_item *next; /* Pointer to next font, or 0L (end of list) */
UTXT_FN display; /* Pointer to display function for user fonts */
int32_t id; /* Font ID, >= 65536 for user fonts */
int16_t index; /* Must be 0, as not a VDI font */
int8_t mono; /* Flag for mono-spaced font */
int8_t outline; /* Flag for vector font */
int16_t npts; /* Number of predefined point sizes */
int8_t *full_name; /* Pointer to the complete name */
int8_t *family_name; /* Pointer to the family name */
int8_t *style_name; /* Pointer to the style name */
int8_t *pts; /* Pointer to field with point sizes */
int32_t reserved[4]; /* Reserved, must be 0 */
} FNTS_ITEM;
See also: fnts_add Font selection
typedef void *FNT_DIALOG;
typedef int16_t (cdecl *HNDL_OBJ) ( void *dialog, EVNT *events, int16_t obj,
int16_t clicks, void *data );
| Parameter | Meaning | ||||
| dialog | Pointer to a dialog structure. One should not access the structure directly; the wdlg_xx functions should be used! | ||||
| events | If obj is an object number (>= 0), then events points to the EVNT structure that was passed by wdlg_evnt; otherwise events is basically 0L and can not be used for addressing | ||||
| obj |
Of these function numbers one only has to react to HNDL_CLSD; all other events need only be paid attention to when needed | ||||
| clicks | Number of mouse clicks (if obj is an object number). | ||||
| data | If the parameter obj is a positive object number, then the variable user_data from the wdlg_create function will be passed here; otherwise the value depends on the corresponding function number |
Note: The function is called when an EXIT or TOUCHEXIT object has been clicked on (in this case obj is a positive object number) or when an event pertinent to the dialog has occurred (in that case obj is negative and contains a corresponding function number (see above)).
The parameters are passed via the stack and the routine may alter registers d0-d2/a0-a2. If the function is called with an unknown function number in obj, or one of the above function numbers is to be ignored, the value 1 must be returned.
See also: Sample implementation wdlg_create
/* The following code is an example for an implementation of the
handle_exit function, such as that used as a parameter for
wdlg_create, for instance. */
int16_t cdecl handle_exit( void *dialog, EVNT *events, int16_t obj,
* Event or object number?
* All events except HNDL_CLSD are ignored in this example
if( obj < 0 )
if( obj == HNDL_CLSD ) /* Closer activated? */
return( 0 ); /* Finish */
if( obj == HNDL_EDIT )
/* In window-dialogs it may be useful to ignore key
combinations with [Control] in input fields, so that
keyboard shortcuts such as [Ctrl]-[U], [Ctrl]-[W] or
[Ctrl]-[Q] for instance may be evaluated in the event
loops of a program. In that case a 0 should be
returned after HNDL_EDIT so that the key is not
evaluated by objc_edit.
{ /* An object has been selected */
switch( obj ) /* Initiate action (if needed) */
case ...
case MY_EXIT_OBJECT: ..... return( 0 ); /* Finish */
return( 1 ); /* Continue */
data is the variable passed by wdlg_create.
If handle_exit returns 0, wdlg_create does not create a dialog structure (error).
The variable code is passed in clicks.
See also: HNDL_OBJ wdlg_create
data is user_data.
If handle_exit returns 0, the dialog will be closed - wdlg_evnt returns 0.
events points to the EVNT structure passed by wdlg_evnt.
HNDL_MESG is only passed if a message code between 20 and 39 was received that is not processed by other opcodes. Is required for iconification, for instance.
Warning: This opcode is only present from MagiC 4.5 of 18.4.96
data is the variable passed by wdlg_open.
data is user_data.
data is user_data.
data is user_data.
data is user_data.
data points to a WORD with the key-code.
If handle_exit returns 1, the key press will be evaluated, if the return value is 0 it will be ignored.
data points to a WORD with the object number of the new editable field.
uint16_t *ib_pmask; /* Pointer to the icon mask */
uint16_t *ib_pdata; /* Pointer to the icon image */
int8_t *ib_ptext; /* Pointer to the icon text */
uint16_t ib_char; /* Character that is to appear in the
icon, as well as the foreground
and background colour of the Icon */
uint16_t ib_xchar; /* X-coordinate of the character */
uint16_t ib_ychar; /* Y-coordinate of the character */
uint16_t ib_xicon; /* X-coordinate of the icon */
uint16_t ib_yicon; /* Y-coordinate of the icon */
uint16_t ib_wicon; /* Width of the icon */
uint16_t ib_hicon; /* Height of the icon */
int16_t ib_xtext; /* X-coordinate of the text */
int16_t ib_ytext; /* Y-coordinate of the text */
uint16_t ib_wtext; /* Width of the text */
uint16_t ib_htext; /* Height of the text */
uint16_t ib_resvd; /* Reserved */
} ICONBLK;
Notes about individual components:
ib_pmask: Pointer to a field of 16-bit values in which the bit-image of the icon mask is stored. The icon mask determines at which positions the icon is to be drawn, and which pixels are to remain transparent. This effect is achieved by first ANDing the icon background with the bits of the mask and then ORing this with the icon data.
ib_char:
| Bits | Meaning |
| 15..12 | Foreground colour of the icon |
| 11..08 | Background colour of the icon |
| 7.. 0 | Character that is to appear in icon |
ib_resvd: Unused, though it is recorded by most RCS (Resource Construction Set) programs when writing to the resource file.
For a colour icon under PC-GEM the following applies: In a colour icon, ib_pdata and ib_pmask point to MFDB objects. Otherwise, they point to the lines of the bitmap.
typedef struct _lbox_item
struct _lbox_item *next; /* Pointer to the next entry in the list */
int16_t selected; /* Specifies whether the object is selected */
int16_t data1; /* Data for the program... */
void *data2;
void *data3;
} LBOX_ITEM;
However the structure can well look like the following example with appropriate casting during the call:
void *next;
int16_t selected;
... From here on to suit the application ...
} LB_EXAMPLE;
One only has to ensure that as the first element a pointer to the successor, and as the second element a WORD specifying whether the corresponding entry is selected are present.
lbox_create lbox_free_list lbox_get_idx lbox_get_item
lbox_get_items
typedef void *LIST_BOX;
Description of a paper format.
typedef struct _media_size
struct _media_size *next; /* Pointer to successor */
int32_t size_id; /* Paper format size ID */
int8_t name[32]; /* Name of the paper format */
} MEDIA_SIZE;
Description of a paper type/print medium.
typedef struct _media_type
struct _media_type *next; /* Pointer to successor */
int32_t type_id; /* Paper format type ID */
} MEDIA_TYPE;
OBJECT *mn_tree; /* The object tree of the menu */
int16_t mn_menu; /* The parent object of the menu items */
int16_t mn_item; /* The starting menu item */
int16_t mn_scroll; /* The scroll field status of the menu: */
/* 0 - The menu will not scroll */
/* >0 - The menu will scroll */
int16_t mn_keystate; /* The [CTRL], [ALT], [SHIFT] key state at */
/* the time the mouse button was pressed */
} MENU;
See also: About the AES menu_attach menu_popup
The structure MFORM sets the appearance of the mouse pointer, and is defined as follows:
typedef struct mfstr
int16_t mf_xhot; /* X-position hot-spot */
int16_t mf_yhot; /* Y-position hot-spot */
int16_t mf_nplanes; /* Number of planes */
int16_t mf_fg; /* Mask colour */
int16_t mf_bg; /* Pointer colour */
int16_t mf_mask[16]; /* Mask form */
int16_t mf_data[16]; /* Pointer form */
} MFORM;
See also: About the AES graf_mouse
int32_t display; /* Submenu display delay */
int32_t drag; /* Submenu drag delay */
int32_t delay; /* Single-click scroll delay */
int32_t speed; /* Continuous scroll delay */
int16_t height; /* Menu scroll height (in items) */
} MN_SET;
The delay values are measured in milliseconds.
See also: About the AES menu_settings
int16_t ob_next; /* The next object */
int16_t ob_head; /* First child */
int16_t ob_tail; /* Last child */
uint16_t ob_type; /* Object type */
uint16_t ob_flags; /* Manipulation flags */
uint16_t ob_state; /* Object status */
int8_t *ob_spec; /* More under object type */
int16_t ob_x; /* X-coordinate of the object */
int16_t ob_y; /* Y-coordinate of the object */
int16_t ob_width; /* Width of the object */
int16_t ob_height; /* Height of the object */
} OBJECT;
| ob_next: | Number of the following object of the same generation or - if it is the last element of the generation - of the parent object |
| ob_head: | Number of the first child of the object, if none -1 |
| ob_next: | Number of the last child of the object, if none -1 |
| ob_type: | Object type of the AES |
| ob_flags: | Object flags of the AES |
| ob_state: | AES object stati |
See also: AES object structure
OBJECT *pb_tree; /* Pointer to the object tree */
int16_t pb_obj; /* Index of the object */
int16_t pb_prevstate; /* Previous object status */
int16_t pb_currstate; /* New object status */
int16_t pb_x; /* X-position of the object */
int16_t pb_y; /* Y-position of the object */
int16_t pb_w; /* Width of the object */
int16_t pb_h; /* Height of the object */
int16_t pb_xc; /* X-position of the clipping region */
int16_t pb_yc; /* Y-position of the clipping region */
int16_t pb_wc; /* Width of the clipping region */
int16_t pb_hc; /* Height of the clipping region */
int32_t pb_parm; /* Parameter of USERBLK structure */
} PARMBLK;
Note: The object only needs to be redrawn if the old and new states are identical; otherwise an 'update' of the object tree suffices. Furthermore, the following points should be respected:
A private function must return to the AES in data register d0 which aspects of the object status still have to be updated. With this it is not absolutely necessary to program out the code for inverting the object in a private output function. Generally one would want to process some bits of the object status oneself, and leave others to the AES.
The function receives the PARMBLK pointer on the stack, and hence must be declared in Pure-C as 'cdecl'.
A complete redraw of the object is required only if the compo nents pb_prevstate and pb_currstate are identical; otherwise only the obects status has changed (for example by being clicked on).
A private function is executed de facto as a sub-program of the AES, hence one should take care with regard to stack usage. Furthermore, one can of course make no further AES calls, since the AES is not re-entrant. On the other hand, calls of the VDI input functions are permitted here.
The component pb_parm serves to pass to one's private function further information (such as a pointer to a string, perhaps).
One should not stray too far from the original appearance of GEM. Rounded rectangles or italic texts certainly do not match the normal appearance of a GEM application.
See also: About the AES GEM USERBLK
typedef int32_t (cdecl *PDLG_HNDL)( struct _prn_settings *settings,
struct _pdlg_sub *sub,
int16_t exit_obj );
See also: Print dialogs pdlg_add_sub_dialogs PDLG_SUB
typedef int32_t (cdecl *PDLG_INIT) (struct _prn_settings *settings,
struct _pdlg_sub *sub );
typedef int32_t (cdecl *PDLG_RESET) ( struct _prn_settings *settings,
Sub-dialog for setting device.
typedef struct _pdlg_sub
struct _pdlg_sub *next; /* Pointer to successor in the list */
void *drivers; /* Only for internal dialogs */
int16_t option_flags; /* Flags */
int16_t sub_id; /* Sub-dialog ID */
DIALOG *dialog; /* Pointer to structure of window
dialog, or 0L */
OBJECT *tree; /* Pointer to assembled object tree */
int16_t index_offset; /* Index offset of the sub-dialog */
int16_t reserved1; /* Reserved */
PDLG_INIT init_dlg; /* Initialisation function */
PDLG_HNDL do_dlg; /* Handling function */
PDLG_RESET reset_dlg; /* Reset function */
OBJECT *sub_icon; /* Pointer to icon for the list box */
OBJECT *sub_tree; /* Pointer to object tree of sub-dialog */
int32_t private1; /* Dialog's private information 1 */
int32_t private2; /* Dialog's private information 2 */
int32_t private3; /* Dialog's private information 3 */
int32_t private4; /* Dialog's private information 4 */
} PDLG_SUB;
OBJECT *tree; /* Popup menu */
int16_t obnum; /* Current object of */
} POPINFO;
Note: The component tree points to an object tree which might serve as input for form_popup, for instance. This means that the box should contain as object 0 a G_BOX or G_IBOX which is covered completely by the other objects. Objects that are not selectable should be assigned a DISABLED state, as in a dropdown menu.
All selectable objects must have the state SELECTABLE. In addition, for using with G_POPUP, all selectable objects must be of the type G_STRING (or G_SHORTCUT) or G_BUTTON, and start with two spaces, the latter due to the tick that is set automatically by form_button or form_do!
It is important that ob_x and ob_y of object 0 of the menu is specified relative to the G_POPUP object, i.e. usually they will both be 0. It is recommended that a shadow or a frame of width -1 is specified.
typedef void *PRN_DIALOG;
typedef struct _prn_entry
struct _prn_entry *next; /* Pointer to next device description*/
int16_t driver_id; /* Driver ID */
int32_t printer_id; /* Printer ID */
int32_t printer_capabilities; /* Printer capabilities */
int32_t flags; /* Various flags */
struct _pdlg_sub *sub_dialogs; /* Pointer to list of sub-dialogs */
/* for this printer */
PRN_SWITCH setup_panel; /* Initialize sub-dialog at printer */
/* change */
PRN_SWITCH close_panel; /* Close sub-dialog at printer change*/
PRN_MODE *modes; /* List of available resolutions */
MEDIA_SIZE *papers; /* List of available paper formats */
PRN_TRAY *input_trays; /* List of feed trays */
PRN_TRAY *output_trays; /* List of output trays */
int8_t name[32]; /* Name of the printer */
} PRN_ENTRY;
Description of a print mode.
typedef struct _prn_mode
struct _prn_mode *next; /* Pointer to the next print mode */
int32_t mode_id; /* Mode ID (index within the file) */
int16_t hdpi; /* Horizontal resolution in dpi */
int16_t vdpi; /* Vertical resolution in dpi */
int32_t mode_capabilities; /* Mode capabilities */
int32_t color_capabilities; /* Colour capabilities */
int32_t dither_flags; /* Flags specifying whether the
corresponding colour mode is
accessible with or without
dithering */
MEDIA_TYPE *paper_types; /* Suitable paper types */
int8_t name[32]; /* Mode name */
} PRN_MODE;
typedef struct _prn_settings
int32_t magic; /* 'pset' */
int32_t length; /* (+) Structure length */
int32_t format; /* Structure type */
int32_t page_flags; /* (+) Flags, inc. even/odd pages:
0x0001 = Only pages with even number
0x0002 = Only pages with odd number*/
int16_t first_page; /* (+) First page to print (min. 1) */
int16_t last_page; /* (+) Last page to print (max. 9999) */
int16_t no_copies; /* (+) Number of copies */
int16_t orientation; /* (+) Page orientation:
0x0000 = Orientation unknown and
not adjustable
0x0001 = Output in portrait format
0x0002 = Output in landscape format*/
int32_t scale; /* (+) Scaling: 0x10000L = 100% */
int16_t driver_id; /* (+) VDI device number */
int16_t driver_type; /* Type of the selected driver */
int32_t driver_mode; /* Flags, inc. for background printing */
int32_t printer_id; /* Printer ID number */
int32_t mode_id; /* Mode ID number */
int16_t mode_hdpi; /* Horizontal resolution in dpi */
int16_t mode_vdpi; /* Vertical resolution in dpi */
int32_t quality_id; /* Printing mode (hardware-dependent
quality, e.g. Microweave or Econofast)*/
int32_t color_mode; /* Colour mode */
int32_t plane_flags; /* Flags for colour planes to be output
(e.g. cyan only) */
int32_t dither_mode; /* Rasterizing (dithering) process */
int32_t dither_value; /* Parameter for the dithering process */
int32_t size_id; /* Paper format */
int32_t type_id; /* Paper type (normal, glossy) */
int32_t input_id; /* Paper feed tray */
int32_t output_id; /* Paper output tray */
int32_t contrast; /* Contrast: 0x10000L = normal */
int32_t brightness; /* Brightness: 0x1000L = normal */
int8_t device[128]; /* Filename for the printout */
#ifdef __PRINTING__
TPrint mac_settings; /* Setting of the Mac printer driver */
#else
struct
uint8_t inside[120];
} mac_settings;
#endif
} PRN_SETTINGS;
Note: The structure elements marked with (+) can be read out by the application. All other entries should not be accessed. Data such as the printer resolution or number of colours should not be taken from the setting structure, but inquired for from the printer at the start of the printout (it would be possible, for instance, that due to a memory shortage the printer driver is forced to use a lower resolution compared to that entered in PRN_SETTINGS).
See also: Print dialogs pdlg_open
typedef int32_t (cdecl *PRN_SWITCH) ( struct _drv_entr *drivers,
struct _prn_entry *old_printer,
struct _prn_entry *new_printer );
Note: The component old_printer can also be 0L!
Description of a feed/output tray.
typedef struct _prn_tray
struct _prn_tray *next; /* Pointer to successor */
int32_t tray_id; /* Number of the feed or output tray */
int8_t name[32]; /* Name of the tray */
} PRN_TRAY;
uint16_t rsh_vrsn; /* Null */
uint16_t rsh_object; /* Position of the object field */
uint16_t rsh_tedinfo; /* Position of the TEDINFO structs */
uint16_t rsh_iconblk; /* Position of the ICONBLK structs */
uint16_t rsh_bitblk; /* Position of the BITBLK structs */
uint16_t rsh_frstr; /* Position of the free strings */
uint16_t rsh_string; /* Unused */
uint16_t rsh_imdata; /* Position of image data */
uint16_t rsh_frimg; /* Position of the free images */
uint16_t rsh_trindex; /* Position of the object tree table */
uint16_t rsh_nobs; /* Total number of objects */
uint16_t rsh_ntree; /* Total number of trees */
uint16_t rsh_nted; /* Total number of TEDINFO structs */
uint16_t rsh_nib; /* Total number of ICONBLK structs */
uint16_t rsh_nbb; /* Total number of BITBLK structs */
uint16_t rsh_nstring; /* Total number of strings */
uint16_t rsh_nimages; /* Total number of images */
uint16_t rsh_rssize; /* Total bytes in resource */
} RSHDR;
Note: All position specifications are to be understood as relative to the start of the file.
A word about the 'free strings': These include not just the character strings containing the data for alert boxes etc., but also all other strings that a program uses for its work. An example of this would be the filename or a file to be read in, or an entry that is altered with menu_text in a menu.
This header is followed by the actual resource data. One should note here that a resource file can have a total size of 64 kbyte maximum, due to the use of 16-bit values as pointers. Files of this format can be saved by all RCS (Resource Construction Set) programs.
Users of the programs Interface and RSM (Resource Master) can also work with resource files > 64 kbyte. The operating system MagiC as of version 3 also supports resource files larger than 64 kbyte; loading of the resource is performed with rsrc_load as usual, the rest is handled quite transparently by the system.
See also: rsrc_rcfix RSXHDR
uint16_t rsh_vrsn; /* Version number, should be 3 for new format */
uint16_t rsh_extvrsn; /* Not used, */
/* initialized to 'IN' for Interface, */
/* 'RM' for ResourceMaster */
uint32_t rsh_object; /* Offset to OBJECT structures from file start */
uint32_t rsh_tedinfo; /* Offset to TEDINFO structures */
uint32_t rsh_iconblk; /* Offset to ICONBLK structures */
uint32_t rsh_bitblk; /* Offset to BITBLK structures */
uint32_t rsh_frstr; /* Offset to string pointer table */
uint32_t rsh_string; /* Offset to string data */
uint32_t rsh_imdata; /* Offset to image data */
uint32_t rsh_frimg; /* Offset to image pointer table */
uint32_t rsh_trindex; /* Offset to tree pointer table */
uint32_t rsh_nobs; /* Number of OBJECTs in the file */
uint32_t rsh_ntree; /* Number of object trees in the file */
uint32_t rsh_nted; /* Number of TEDINFOs in the file */
uint32_t rsh_nib; /* Number of ICONBLKs in the file */
uint32_t rsh_nbb; /* Number of BITBLKs in the file */
uint32_t rsh_nstring; /* Number of free strings in the file */
uint32_t rsh_nimages; /* Number of free images in the file */
uint32_t rsh_rssize; /* In the newer format files this value can be
used as an offset to the extension array */
} RSXHDR;
int8_t scancode;
int8_t nclicks;
int16_t objnr;
} SCANX;
Note: The structure contains the assignment for the key with the scancode scancode, which when pressed performs an nclicks times mouse click on the object with the index objnr. The end of the table is marked by a scancode of NULL.
See also: About the AES MagiC XDO_INF Scancode table
typedef int16_t (cdecl *SET_ITEM)( LIST_BOX *box, OBJECT *tree,
struct _lbox_item *item,
int16_t obj_index, void *user_data,
GRECT *rect, int16_t first );
| box | points to the list box structure |
| tree | points to the object tree of the dialog |
| item | points to the LBOX_ITEM structure of the entry to be set |
| obj_index | is the number of the object to be set |
| user_data | is the pointer passed by lbox_create |
| rect | is the pointer to the GRECT for the object redraw or 0L |
| first | contains the number of the first visible item for Slider B |
For a list box that only contains text strings,
rect is 0L when a redraw of the dialog box is executed or when lbox_update has been called. rect is not 0L when the user has selected or deselected an object, and points to the GRECT for the redraw.
The return value is the number of the start object for objc_draw/wdlg_redraw.
For entries in the list box that consist of several objects it is
sometimes sensible to reduce the redraw rectangle when selecting/
deselecting an object, or to alter the start object, to prevent
unnecessary drawing operations and/or unnecessary flicker. In most
cases the list box routines call the function objc_draw/wdlg_redraw
after
first contains the number of the first visible item for
Slider B if the list box has two sliders. For a (vertical) list box
with text strings and two sliders, when calling lbox_create, for
instance, one enters the number of visible characters in
visible_b, the total string length in entries_b and
the index of the first visible character in first_b. If the
text is scrolled horizontally,
See also: List boxes lbox_create
int16_t dummy; /* A NULL-WORD */
int32_t magic; /* 'SHEL', if it's a shell */
int16_t isfirst; /* First call of the shell */
int32_t lasterr; /* Last error */
int16_t wasgr; /* Program was a graphic-app. */
} SHELTAIL;
Note: This information is conveyed to an alternative desktop by MagiC at program launch (can be obtained by shel_read). If the shell returns a negative error code, then MAGXDESK will be reactivated.
If isfirst is set then the status is to be read from something like DESKTOP.INF, if isfirst is not set then one takes the temporary file or shell-buffer.
lasterr is the return value of the program running previously. If this was a GEM program then the error will already have been displayed in an alert box. It is well known that the LONGword is negative if the error occurred with Pexec itself; a program return value always has the high-WORD 0.
See also: About the AES GEM shel_wdef
typedef void (cdecl *SLCT_ITEM)( LIST_BOX *box, OBJECT *tree,
void *user_data, int16_t obj_index,
int16_t last_state );
The following apply:
| item | points to the LBOX_ITEM-structure of the selected entry |
| obj_index | is the number of the selected object. For a double-click the top bit is set, similar to form_do. If it is 0, it signifies that no object is assigned to this entry; it is not visible. Normally this is only the case when one is scrolling and by selecting a new object the (now no longer visible) selection has to be cleared. |
| last_state | is the previous status of the object. last_state can also have the same value as item->selected. In that case one can normally quit the function immediately. |
See also: lbox_create
int8_t *string; /* Perhaps 'TOS|KAOS|MAG!X' */
int16_t num; /* Index of current character string */
int16_t maxnum; /* Maximum permitted num */
} SWINFO;
See also: About the AES GEM G_SWBUTTON
The TEDINFO structure is used to describe a text object more exactly, and is defined as follows:
int8_t *te_ptext; /* Pointer to a string */
int8_t *te_ptmplt; /* Pointer to the string template */
int8_t *te_pvalid; /* Pointer to the validation string */
int16_t te_font; /* Font type */
int16_t te_fontid; /* GDOS Font ID */
int16_t te_just; /* Text alignment:
0 = Ranged left
1 = Ranged right
2 = Centred */
int16_t te_color; /* Colour */
int16_t te_fontsize; /* GDOS font size in points */
int16_t te_thickness; /* Border width */
int16_t te_txtlen; /* Maximum length of the text */
int16_t te_tmplen; /* Length of the string template */
} TEDINFO;
The following matters should be noted for this:
te_ptext: If the first character is an 'at' symbol (@@), then all following characters will be taken to be place holders, and the string initially output will consist of space characters. Hence the 'at' symbol may never be placed at the start of an editable field!
te_ptmplt: Template. This is used only for G_FTEXT and G_FBOXTEXT, i.e. G_TEXT and G_BOXTEXT can have a NULL-pointer here. During output, all '_' characters in the template will be replaced successively with the characters in te_ptext, i.e. a mixed character string will be formed. So in general the template will have as many '_' characters as the length of the buffer for te_ptext (without the terminating NULLbyte). The template can also contain other characters, which will be displayed but cannot be overwritten.
te_pvalid: String that contains for each character in te_ptext validation characters that provide information about the type of character permitted at the matching string position. The following apply:
| Character | Meaning |
| 1 - 9 | Accept any digit from 0 to that number. This is handy for doing
octal ('7') or binary ('1') validation.
(Geneva) |
| 9 | Only digits 0..9 |
| A | Only uppercase (capital) letters A..Z and space |
| a | only Buchstaben/Leerzeichen |
| N | Only upper and lowercase letters and space |
| n | Digits 0..9, uppercase letters A..Z, and space |
| F | All characters valid for a GEMDOS filename, and '*', '?' and ':'. |
| f | All characters valid for a GEMDOS filename, without '*', '?' and ':'. |
| h | Hexadecimal character (Geneva) |
| H | Hexadecimal character; lowercase a..f keys are converted to keys A..F in uppercase (Geneva) |
| P | All characters valid for a GEMDOS pathname plus '\', ':', '?', '*' |
| p | Similar to 'P', but without the characters '?' and '*' |
| m | All characters that are valid for a long filename; i.e. all characters except control characters (ASCII < 32), and also without ':' and '\'. At present, this code is only supported by MagiC. |
| X | All characters |
| x | All characters, lowercase letters are converted to uppercase (Geneva) |
te_font:
3 = Standard monospaced system font
5 = Small monospaced system font
For further information, see below.
te_fontid:
te_color: For the colour of the bounding rectangle, the following assignments apply:
| Bit | Meaning | ||||||
| 12..15 | Border colour (0..15) | ||||||
| 08..11 | Text colour (0..15) | ||||||
| 7 | Text (0 = transparent, 1 = opaque)) | ||||||
| 4.. 6 | Intensity
| 0.. 3 | Inner colour (0..15) |
te_thickness: For the border frame, the following
values are valid:
| Value | Meaning |
| 0 | No border |
| 1.. 128 | Border lies 1 to 128 pixels within the object |
| -1..-127 | Border lies 1 to 127 pixels outside of the object |
Note: The components te_fontid and te_fontsize were previously reserved. As of AES Version 4.1 it is possible to use any GDOS fonts for TEDINFO objects.
For this one should specify with the component te_font the type of the font. The following apply:
| te_font | Meaning |
| 0 | SpeedoGDOS font |
| 1 | SpeedoGDOS font (monospaced) |
| 2 | GDOS bitmap font |
| 3 | Normal system font |
| 5 | Small system font |
To use values 0 and 1 of te_font, SpeedoGDOS or a substitute (such as NVDI) has to be installed on the system.
For values in the region 0..2 of te_font one can then set with the components te_fontid or te_fontsize the desired font and the desired point size.
The simplest way to check the presence of the new possibilities is to call appl_getinfo (opcode 13).
About the AES GEM OBJECT XTED Scrollable input fields
int16_t cdecl (*ub_code)(PARMBLK *parmblock);
int32_t ub_parm;
} USERBLK;
Note: The function ub_code is called for each call of objc_draw and objc_change for the corresponding object. The component ub_parm can be looked on as an optional parameter.
This function is declared as follows:
typedef void (cdecl *UTXT_FN) (int16_t x, int16_t y, int16_t *clip_rect,
int32_t id, int32_t pt, int32_t ratio,
int8_t *string);
See also: About the AES fnts_add FNTS_ITEM Font selection
Passing structure for linking in
typedef struct {
int16_t version; /* Version number of structure */
int32_t wsizeof; /* Size of the WINDOW-structure */
int16_t whshade; /* Height of the shaded window */
void (*wbm_create)( WININFO *w );
void (*wbm_skind) ( WININFO *w );
void (*wbm_ssize) ( WININFO *w );
void (*wbm_sslid) ( WININFO *w, int16_t vertical );
void (*wbm_sstr) ( WININFO *w );
void (*wbm_sattr) ( WININFO *w, int16_t chbits );
void (*wbm_calc) ( int16_t kind, int16_t *fg );
int16_t (*wbm_obfind)( WININFO *w, int16_t x, int16_t y );
} WINFRAME_HANDLER;
sys_set_winframe_manager WININFO WINFRAME_SETTINGS
Passing structure for global window settings
typedef struct {
int16_t flags;
int16_t h_inw;
void *finfo_inw;
} WINFRAME_SETTINGS;
Bits of flags:
#define NO_BDROP 1
sys_set_winframe_manager WINFRAME_HANDLER WININFO
WINDOW-structure for MagiC-kernel
typedef struct {
int16_t state;
int16_t attr;
void *own; /* (APPL *) */
int16_t kind; /* from wind_create() */
char *name; /* Pointer to title line */
char *info; /* Pointer to Info line */
GRECT curr;
GRECT prev;
GRECT full;
GRECT work;
GRECT overall; /* Outline */
GRECT unic;
GRECT min; /* Minimum size */
int16_t oldheight; /* Old height of shading */
int16_t hslide; /* Horizontal slider position */
int16_t vslide; /* Vertical slider position */
int16_t hslsize; /* Horizontal slider size */
int16_t vslsize; /* Vertical slider size */
void *wg; /* Rectangle list */
void *nextwg; /* Next rectangle of the list */
int16_t whdl;
OBJECT tree[N_OBJS];
int16_t is_sizer;
int16_t is_info;
int16_t is_rgtobjects;
int16_t is_botobjects;
TEDINFO ted_name;
TEDINFO ted_info;
} WININFO;
Bits of state:
#define OPENED 1
#define COVERED 2
#define ACTIVE 4
#define LOCKED 8
#define ICONIFIED 32
#define SHADED 64
sys_set_winframe_manager WINFRAME_HANDLER WINFRAME_SETTINGS
int16_t dst_apid; /* ID of target application */
int16_t unique_flg; /* Overwrite messages? */
void *attached_mem; /* Pointer to memory block */
int16_t *msgbuf; /* Message buffer */
} XAESMSG;
Note: The component unique_flg specifies if kindred messages (i.e. those with the same message type msgbuf[0]) are to be overwritten by the new message.
If attached_mem is not NULL, it is used to specify a memory block allocated with Malloc that contains the extended message information. The length of this block is arbitrary and is of no interest to the system - for instance it could be passed as the first LONGword of the block, or in msgbuf [4,5]. The system allocates the memory block to the destination application and passes its address in msgbuf[6,7].
Important: The called application must assume that msgbuf[6,7] are destroyed after a call of appl_write. The system reserves the right to copy the contents of the memory block elsewhere and to release the passed block. The caller may no longer access the block after an appl_write call, and may on no account release it!
If appl_write returns an error code, then the block has not been passed and still belongs to the calling application. An error arises when:
The destination application is invalid (non-existant or frozen)
The message buffer of the destination application is full
The destination application is not a process (e.g. the SCRENMGR and an attached memory block has been specified
See also: About the AES appl_write GEM
SCANX *unsh; /* Tables for non-[Shift] combinations */
SCANX *shift; /* Tables for [Shift] combinations */
SCANX *ctrl; /* Tables for [Control] combinations */
SCANX *alt; /* Tables for [Alternate] combinations */
void *resvd; /* Reserved */
} XDO_INF;
Note: This structure contains pointers to tables that assign to a scancode an object index of the dialog box. This makes it simple to service dialogs completely via the keyboard. The parameter resvd is reserved for future use, and must always be NULL.
About the AES form_keybd form_xdo MagiC Scancode table
int16_t font_id;
int16_t point_size;
int16_t gadget_wid;
int16_t gadget_ht;
} XFONTINFO;
See also: x_appl_font
typedef int16_t (cdecl XFSL_FILTER) (int8_t *path, int8_t *name, XATTR *xa);
int8_t *command;
int32_t limit;
int32_t nice;
int8_t *defdir;
int8_t *env;
} XSHW_COMMAND;
See also: shel_write
This structure is required in connection with scroll-capable editable text fields.
typedef struct _xted
int8_t *xte_ptmplt;
int8_t *xte_pvalid;
int16_t xte_vislen;
int16_t xte_scroll;
} XTED;
See also: Scrollable input fields TEDINFO
typedef struct x_buf_v2
int16_t buf_len /* Length of the structure, including this WORD */
/* Future versions of this structure (X_BUF_V3 etc.) */
/* may be bigger */
int16_t arch /* 16 for 16-bit AES, 32 for hypothetical 32-bit AES */
CLRCAT *cc /* Address of an array of 16 CLRCAT structures - */
/* this is so that they can be read by a program; in */
/* ViewMAX, the colours could be set but not reread */
OBJECT *w_active /* Address of an object tree (19 elements) used to */
/* draw window elements; included so a program can */
/* change symbols on window buttons */
int8_t *info /* Address of a 0-terminated ASCII string (at most */
/* 40 characters, no newlines) describing the AES */
int32_t abilities /* A bitmapped field describing what optional */
/* functions this AES provides: */
/* ABLE_GETINFO 1 bit 0 : xapp_getinfo supported */
/* ABLE_PROP 2 bit 1 : prop_get, prop_put and prop_del supported */
/* ABLE_WTREE 4 bit 2 : wind_get and wind_set can change glyphs */
/* ABLE_X3D 8 bit 3 : GEM/5 3D using DRAW3D */
/* ABLE_XSHL 16 bit 4 : xshl_getshell & xshl_putshell */
/* ABLE_PROP2 32 bit 5 : prop_gui_get, prop_gui_set */
/* ABLE_EMSDESK 64 bit 6 : xgrf_dtimage supports EMS */
/* ABLE_XBVSET 128 bit 7 : Supports 32 disc drives */
} X_BUF_V2;
An initialized X_BUF_V2 is one in which all members are 0 except buf_len. This initialized buffer is then passed to appl_init. On return, if arch is 0 then the structure was not filled in by the AES; otherwise it was. The buf_len field may be reduced if the AES was expecting an earlier version of the structure (i.e. X_BUF_V1); this should not be a problem because the structures are forward and backward compatible.
See also: appl_init
