HomeVDIVDI bindingsOutput functions
7.4 Attribute functions
This library contains functions that allow the setting of certain attributes. The following categories are available for this:
Note: The attributes set here are valid for a single workstation, and retain their validity until the program terminates, or the attributes are reset elsewhere.
See also: VDI workstations   Style guidelines
7.4.1 Bitmap attributes
• vsr_bg_color Sets background colour
• vsr_fg_color Sets foreground colour
VDI workstations   Style guidelines   VDI fundamentals
7.4.2 Fill attributes
This group of functions enables various attributes for the filling of areas to be manipulated. The following routines are available for this purpose:
• vsf_bg_color Sets background colour
• vsf_color Selects fill colour
• vsf_fg_color Sets foreground colour
• vsf_interior Selects fill-type
• vsf_perimeter Draws or doesn't draw perimeter
• vsf_style FSelects hatching pattern
• vsf_udpat Defines user-defined hatching pattern
• vsf_xperimeter Sets fill parameter visibility
VDI workstations   Fill-type and pattern index   Style guidelines   VDI fundamentals
7.4.3 Lines attributes
This group of functions enables various attributes for the drawing of lines to be manipulated. The following routines are available for this purpose:
• v_bez_qual Sets quality of Bezier-spline generation
• vsl_bg_color Sets background colour
• vsl_color Sets line colour
• vsl_ends Defines line-end type
• vsl_fg_color Sets foreground colour
• vsl_type Sets type of line depiction
• vsl_udsty Defines user-defined line depiction
• vsl_width Defines line width
7.4.4 Marker attributes
This group of functions enables various attributes for the drawing of markers to be manipulated. The following routines are available for this purpose:
• vsm_bg_color Sets background colour
• vsm_color Sets marker colour
• vsm_fg_color Sets foreground colour
• vsm_height Sets marker size
• vsm_type Selects marker type
7.4.5 Text attributes
This group of functions enables various attributes for the handling of text to be manipulated. The following routines are available for this purpose:
• v_topbot Sets text height
• vst_alignment Sets horizontal and vertical alignment of a text
• vst_arbpt Sets character cell height in points
• vst_arbpt32 Sets character cell height in points (fix31)
• vst_bg_color Sets background colour
• vst_charmap Selects character mapping mode (Atari/Bitstream)
• vst_color Sets colour for text output
• vst_effects Selects text effects
• vst_error Sets the GDOS error handling
• vst_fg_color Sets foreground colour
• vst_font Selects face
• vst_height Sets text size
• vst_kern Sets kerning mode
• vst_map_mode Selects character mapping mode (Atari/Bitstream/Unicode).
• vst_name Finds and sets text face by name
• vst_point Sets size of character cell
• vst_rotation Sets rotation of text output
• vst_scratch Designates size of the scratch buffer
• vst_setsize Sets character cell width in points
• vst_setsize32 Sets character cell width in points (fix31)
• vst_skew Sets angle of skew for skewed text ('italic')
• vst_track_offset Sets offset for track kerning
• vst_width Sets character width in pixels
7.4.6 Superior attributes
This group of functions permits setting of the writing mode as well as the intenstity of a colour; it encompasses the following routines:
• v_ps_halftone Sets PostScript halftoning type
• v_setrgb Sets colour intensity
• v_setrgbi Sets colour or intensity
• vs_bkcolor Sets background colour
• vs_color Sets colour intensity of a colour
• vs_color2 Sets colour intensity and colour for attributes
• vs_grayoverride Fine-tunes grey level
• vswr_mode Selects writing mode
7.4.6.1 vsr_bg_color
Name: »Set Background Color«
Opcode: 201 (sub-opcode 4)
Syntax: int16_t vsr_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: This function sets the background colour for bitmaps.
handle Workstation identifier
color_space Colour space (at present only 0 for the colour space set, or CSPACE_RGB)
fg_color COLOR_ENTRY der Hintergrundfarbe
Return value: -1 = Wrong subfunction number
 0 = Function not present
 1 = All OK
Availability: As of NVDI 5.00
Group: Bitmap attributes
7.4.6.2 Bindings for vsr_bg_color
C: int16_t vsr_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vsr_bg_color( int16_t handle, int32_t color_space,
   intin[0..1] = color_space;
   intin[2..5] = fg_color;
   contrl[0] = 201;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 4;
   contrl[6] = handle;
   vdi ();
   return ( intout[0] );
contrl contrl[0] 201 # Function Opcode
contrl+2 contrl[1] 0 # entry in ptsin
contrl+4 contrl[2] 0 # entry in ptsout
contrl+6 contrl[3] 6 # entry in intin
contrl+8 contrl[4] 1 # entry in intout
contrl+10 contrl[5] 4
contrl+12 contrl[6] handle
intin intin[0..1] color_space
intin+4 intin[2..5] fg_color
intout intout[0] Return Value
7.4.6.3 vsr_fg_color
Name: »Set Foreground Color«
Opcode: 200 (Sub-Opcode 4)
Syntax: int16_t vsr_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: This function sets the foreground colour for bitmaps.
fg_color COLOR_ENTRY of the foreground colour
 1 = All OK
Availability: As of NVDI 5.00.
7.4.6.4 Bindings for vsr_fg_color
C: int16_t vsr_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vsr_fg_color( int16_t handle, int32_t color_space,
   contrl[0] = 200;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 4;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 200 # Function Opcode
intout intout[0] Return value
7.4.6.5 Graphical overview of fill-type and pattern index
The following illustration shows the possible combinations of the fill-type and the pattern index. The first number here specifies the fill-type (blank (0), pattern (2) or hatching (3)), the second the index of the fill-pattern or hatching style.
Note: A fill-type with the value 1 followed by any hatching index always corresponds to fill-type 2 with hatching index 8 (solid). Index 1 for patterns of type 2 is always the pattern with the lowest intensity on the relevant output device, and in addition always in monochrome.
See also: vsf_interior   vsf_style
7.4.6.6 Description of the VDI writing modes
Replace: In this mode the VDI overwrites the background with the foreground colour in places where the corresponding bit is set, or with the colour white if the corresponding bit has the value 0. The logical combination is as follows:
New := (foreground AND mask) OR (background AND NOT mask)
If we look at this in terms of working with pencil and paper, one can imagine this as follows: First one draws a figure on white paper, cuts it out and then sticks it over the graphic.
Transparent: In this mode, all bits of the figure to be drawn that have the value 0 (i.e. are not set) are ignored by the VDI. So only those bits are output that are set. The logical combination in this case is as follows:
New := (foreground AND mask ) OR (colour AND NOT mask)
Here again a comparison of working with pencil and paper: This mode corresponds to the Replace mode, only one is not drawing on normal paper but on transparent foil.
XOR: In this mode all bits of the background and the figure to be drawn are combined with an exclusive-OR (XOR), which shows a useful and interesting feature:
If the same figure is drawn a second time in this mode, then it will suddenly disappear again. Reason: An XOR combination of a bit with itself always results in the inverses value. This is why this mode is well suited for simple animations like a rubber box; the recipe for this is as follows:
1. Output the object once
2. Output the object again (it has now disappeared again)
3. Alter the size or position of the object
4. Back to step 1
The logical combination here is: New := (mask XOR colour)
Im allgemeinen läßt sich über diesen Modus nur aussagen, daß aus der Farbe Schwarz die Farbe Weiß wird, und umgekehrt; alles andere ist nicht fest definiert.
Reverse transparent: In this mode, only those pixels are taken into account which are set to the value 0 in the figure to be drawn. The logical combination in this case is:
New := (colour AND mask) OR (foreground AND NOT mask)
This mode too offers some interesting application ppossibilities; thus it can be used together with Transparent mode, for instance, to let text appear with an additional background colour.
The following illustration should clarify the VDI writing modes:
See also: vswr_mode
7.4.6.7 vsf_bg_color
Name: »Set Background Color« - Set the background colour for objects
Opcode: 201 (Sub-Opcode 1)
Syntax: int16_t vsf_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: The call vsf_bg_color sets the background colour for drawn objects.
fg_color COLOR_ENTRY of the background colour
 1 = All OK
Group: Fill attributes
7.4.6.8 Bindings for vsf_bg_color
C: int16_t vsf_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vsf_bg_color( int16_t handle, int32_t color_space,
   contrl[0] = 201;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 1;
   contrl[6] = handle;
   vdi ();
contrl+10 contrl[5] 1
7.4.6.9 vsf_color
Name: »Set fill colour index« - Set the colour with which a 2-dimensional graphic object is to be filled.
Opcode: 25
Syntax: int16_t vsf_color ( int16_t handle, int16_t color_index );
Description: The call vsf_color sets the fill colour for 2-dimensional graphic objects.
color_index Requested fill color index
Note: The colour indices 0 and 1 are always available; all others depend on the output device being used. An invalid colour index will be replaced by the value 1. The colour index has no effect on multicoloured patterns; it should be set to 1 in this case.
Return value: The function returns the actual colour set.
Availability: Supported by all drivers.
See also: Binding   v_fillarea   v_contourfill   vr_recfl v_bar   v_pieslice   v_circle   v_ellipse   v_ellpie   v_rfbox   vsf_udpat
7.4.6.10 Bindings for vsf_color
C: int16_t vsf_color ( int16_t handle, int16_t color_index );
int16_t vsf_color (int16_t handle, int16_t color_index)
   intin[0] = color_index;
   contrl[0] = 25;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 25 # Function Opcode
contrl+6 contrl[3] 1 # entry in intin
intin intin[0] color_index
7.4.6.11 vsf_fg_color
Name: »Set foreground colour« - Set the foreground colour for a filled object.
Opcode: 200 (Sub-Opcode 1)
Syntax: int16_t vsf_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: This function sets the foreground colour for a filled 2-dimensional graphic object.
 1 = All OK
7.4.6.12 Bindings for vsf_fg_color
C: int16_t vsf_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vsf_fg_color( int16_t handle, int32_t color_space,
   contrl[0] = 200;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 1;
   contrl[6] = handle;
   vdi ();
7.4.6.13 vsf_interior
Name: »Set fill interior style« - Set the fill-pattern type.
Opcode: 23
Syntax: int16_t vsf_interior ( int16_t handle, int16_t style );
Description: This function selects the fill-pattern type for a filled 2-dimensional graphic object.
style Requested fill type
0 = Hollow
1 = Solid
2 = Pattern
3 = Hatch
4 = User-defined style
Note: If the requested type is invalid, type 0 (hollow) will be selected.
Return value: The function returns the fill-type actually selected.
See also: Binding   v_fillarea   v_contourfill   vr_recfl   v_bar   v_pieslice   v_circle   v_ellipse   v_ellpie   v_rfbox   vsf_style   vsf_udpat
7.4.6.14 Bindings for vsf_interior
C: int16_t vsf_interior ( int16_t handle, int16_t style );
int16_t vsf_interior (int16_t handle, int16_t style)
   intin[0] = style;
   contrl[0] = 23;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 23 # Function Opcode
intin intin[0] style
7.4.6.15 vsf_perimeter
Name: »Set fill perimeter visibility« - Determine whether an outline is to be drawn around filled areas.
Opcode: 104
Syntax: int16_t vsf_perimeter ( int16_t handle, int16_t per_vis );
Description: This function turns the outline border of a filled area (rectangle, polygon, ellipse, ...) on or off.
per_vis Visibility flag:
   0 = Invisible
<> 0 = Visible
Note: With outlining activated (default), the border will be drawn in the current fill colour and as a continuous line.
Return value: The function returns the mode actually set.
See also: Binding   vsf_xperimeter   v_fillarea   v_contourfill   vr_recfl   v_bar   v_pieslice   v_circle   v_ellipse   v_ellpie   v_rfbox
7.4.6.16 Bindings for vsf_perimeter
C: int16_t vsf_perimeter ( int16_t handle, int16_t per_vis );
int16_t vsf_perimeter (int16_t handle, int16_t per_vis)
   intin[0] = per_vis;
   contrl[0] = 104;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 104 # Function Opcode
intin intin[0] per_vis
7.4.6.17 vsf_style
Name: »Set fill style index« - Set the fill-pattern.
Opcode: 24
Syntax: int16_t vsf_style ( int16_t handle, int16_t style_index );
Description: The call vsf_style determines the fill-pattern. The following apply:
style_index Index
Note: The function can only be used sensibly when the fill type was not chosen as empty, opaque or user-defined. Unavailable indices are replaced by pattern index 1.
Return value: The function returns the fill-pattern actually set.
See also: Binding   v_fillarea   v_contourfill   vr_recfl   v_bar   v_pieslice   v_circle   v_ellipse   v_ellpie   v_rfbox   vsf_interior
7.4.6.18 Bindings for vsf_style
C: int16_t vsf_style ( int16_t handle, int16_t style_index );
int16_t vsf_style (int16_t handle, int16_t style_index)
   intin[0] = style_index;
   contrl[0] = 24;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 24 # Function Opcode
intin intin[0] style_index
7.4.6.19 vsf_udpat
Name: »Set user-defined fill-pattern« - Define a new fill-pattern.
Opcode: 112
Syntax: void vsf_udpat ( int16_t handle, int16_t *pfill_pat, int16_t planes );
Description: The call vsf_udpat sets up a new fill-pattern, freely defined by the user. The following apply:
pfill_pat Pointer to an array of 16 * planes WORDs that define the bit pattern for a line of the fill
planes Number of colour planes
Notes: Each line reproduces the fill-pattern for one colour plane. The first entry of a line corresponds here to the first line of the pattern, etc.
Patterns with multiple colours have to be stored in standard format and must have the same number of planes as the device. Exception: If the device is a HiColor or TrueColor device (direct colour mapping) you always pass a pattern width of 32-bit pixels (xrgb) and pfill_pat points to a 16 * 16 array of LONGs.
If you use a pattern with multiple colours you should select colour index 1 and writing mode REPLACE.
See also: Binding   vsf_interior
7.4.6.20 Bindings for vsf_udpat
C: void vsf_udpat ( int16_t handle, int16_t *pfill_pat, int16_t planes );
void vsf_udpat (int16_t handle, int16_t *pfill_pat,
                int16_t planes)
   intin[0..16n-1] = pfill_pat[0..16n-1];
   contrl[0] = 112;
   contrl[1] = 0;
   contrl[3] = planes * 16;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 112 # Function Opcode
contrl+6 contrl[3] 16*n # entry in intin
contrl+8 contrl[4] 0 # entry in intout
intin intin[0] pfill_pat[0]
intin+32n-2 intin[16n-1] pfill_pat[16n-1]
7.4.6.21 vsf_xperimeter
Name: »Set fill perimeter visibility« - Determine whether an outline is to be drawn round filled areas.
Opcode: 104
Syntax: int16_t vsf_xperimeter ( int16_t handle, int16_t on_off, int16_t f_or_l );
Description: This function turns the outline border of a filled area (rectangle, polygon, ellipse, ...) on or off and sets the line style for the perimeter outline.
on_off Desired mode:
   0 = Turn perimeter outlining off
   1 = Turn perimeter outlining on
  -1 = Do not change perimeter outlining
f_or_l Line type, as for vsl_type:
  0 = Use normal fill colour for perimeter
  1 = Use line style attributes for perimeter
Availability: GEM/3 Release 3.1
See also: Binding   vsf_perimeter   v_fillarea   v_contourfill   vr_recfl   v_bar   v_pieslice   v_circle   v_ellipse   v_ellpie   v_rfbox
7.4.6.22 Bindings for vsf_xperimeter
C: int16_t vsf_xperimeter ( int16_t handle, int16_t on_off, int16_t f_or_l );
int16_t vsf_xperimeter (int16_t handle, int16_t on_off,
                        int16_t f_or_l )
   intin[0] = on_off;
   intin[1] = f_or_l;
   contrl[0] = 104;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[6] = handle;
   vdi ();
contrl+6 contrl[3] 2 # entry in intin
intin intin[0] on_off
intin+2 intin[1] f_or_l
7.4.6.23 vsl_bg_color
Name: »Set background colour« - Set background colour for lines.
Opcode: 201 (Sub-Opcode 2)
Syntax: int16_t vsl_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: The call vsl_bg_color sets the background colour for drawn lines.
 1 = All OK
Availability: NVDI 5.00 onwards.
Group: Lines attributes
7.4.6.24 Bindings for vsl_bg_color
C: int16_t vsl_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vsl_bg_color( int16_t handle, int32_t color_space,
   contrl[0] = 201;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 2;
   contrl[6] = handle;
   vdi ();
contrl+10 contrl[5] 2
7.4.6.25 vsl_color
Name: »Set polyline colour index« - Set the line colour.
Opcode: 17
Syntax: int16_t vsl_color ( int16_t handle, int16_t color_index );
Description: The call vsl_color sets the colour index for lines.
color_index Line colour
Note: The colour indices 0 and 1 are available on all devices; all other values depend on the output device being used at the time.
If the index is invalid, colour index 1 will be selected.
Return value: The function returns the line colour actually set.
Availability: Supported by all devices.
See also: Binding   v_pline   v_arc   v_ellarc   v_rbox
7.4.6.26 Bindings for vsl_color
C: int16_t vsl_color ( int16_t handle, int16_t color_index );
int16_t vsl_color (int16_t handle, int16_t color_index)
   contrl[0] = 17;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 17 # Function Opcode
7.4.6.27 vsl_ends
Name: »Set polyline end styles« - Set the shape of line ends.
Opcode: 108
Syntax: void vsl_ends ( int16_t handle, int16_t beg_style, int16_t end_style );
Description: The call vsl_ends sets the appearance of the line ends. The following apply:
Parameter Meaning Symbole
beg_style End style for the first point:
0 = Squared (default)
1 = Arrowed
2 = Rounded
end_style End style for the last point (as above)
Note: Both the squared style and the arrow style end at the end of the polyline. The rounded style is drawn such that the center of the rounding is at the end of the polyline.
7.4.6.28 Bindings for vsl_ends
C: void vsl_ends ( int16_t handle, int16_t beg_style, int16_t end_style );
void vsl_ends (int16_t handle, int16_t beg_style,
               int16_t end_style)
   intin[0] = beg_style;
   intin[1] = end_style;
   contrl[0] = 108;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 108 # Function Opcode
intin intin[0] beg_style
intin+2 intin[1] end_style
7.4.6.29 vsl_fg_color
Name: »Set foreground colour« - Set foreground colour for lines.
Opcode: 200 (Sub-Opcode 2)
Syntax: int16_t vsl_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: The call vsl_fg_color sets the foreground colour for drawn lines.
 1 = All OK
7.4.6.30 Bindings for vsl_fg_color
C: int16_t vsl_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vsl_fg_color( int16_t handle, int32_t color_space,
   contrl[0] = 200;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 2;
   contrl[6] = handle;
   vdi ();
7.4.6.31 vsl_type
Name: »Set polyline type« - Set the line type.
Opcode: 15
Syntax: int16_t vsl_type ( int16_t handle, int16_t style );
Description: The call vsl_type sets the line type for polyline operations.
style Requested line type:
1 = Solid
2 = Long dash
3 = Dot
4 = Dash,dot
5 = Dash
6 = Dash,dot,dot
7 = User-defined, vsl_udsty
Note: Line types from the value 8 on depend on the output device in each case. If the requested line type is not available, line type 1 will be selected (solid).
You can obtain the available line types with the function vq_extnd.
Return value: The function returns the line type actually set.
See also: Binding   v_pline   v_arc   v_ellarc   v_rbox   vsl_udsty
7.4.6.32 Bindings for vsl_type
C: int16_t vsl_type ( int16_t handle, int16_t style );
int16_t vsl_type (int16_t handle, int16_t style)
   intin[0] = style;
   contrl[0] = 15;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 15 # Function Opcode
intin+2 intin[1] Return Value
7.4.6.33 vsl_udsty
Name: »Set user-defined line style pattern«
Opcode: 113
Syntax: void vsl_udsty ( int16_t handle, int16_t pattern );
Description: The call vsl_udsty sets the freely-definable line style for vsl_type. The following apply:
pattern Line style pattern WORD, 16 bits
Note: The Most Significant Bit (MSB) of the pattern WORD is the first pixel in the line. The default value is a completely solid line.
See also: Binding   vsl_type
7.4.6.34 Bindings for vsl_udsty
C: void vsl_udsty ( int16_t handle, int16_t pattern );
void vsl_udsty (int16_t handle, int16_t pattern)
   intin[0] = pattern;
   contrl[0] = 113;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 113 # Function Opcode
intin intin[0] pattern
7.4.6.35 vsl_width
Name: »Set polyline width«
Opcode: 16
Syntax: int16_t vsl_width ( int16_t handle, int16_t width );
Description: The call vsl_width sets the line width for lines and perimeters. The following apply:
width Line width (must be odd!)
Note: The width of the line always refers to the coordinates in the X-direction. As the VDI can only draw lines an odd number of pixels thick, the actually set width is smaller or equal to the selected width as values will be rounded down to the nearest odd number. The function is not available on all output devices.
Most device drivers ignore the line type and draw solid lines if the line is more than one pixel wide.
Return value: The function returns the line width actually set.
7.4.6.36 Bindings for vsl_width
C: int16_t vsl_width ( int16_t handle, int16_t width );
int16_t vsl_width (int16_t handle, int16_t width)
   ptsin[0] = width;
   ptsin[1] = 0;
   contrl[0] = 16;
   contrl[1] = 1;
   contrl[3] = 0;
   contrl[6] = handle;
   vdi ();
   return ( ptsout[0] );
contrl contrl[0] 16 # Function Opcode
contrl+2 contrl[1] 1 # entry in ptsin
contrl+4 contrl[2] 1 # entry in ptsout
contrl+6 contrl[3] 0 # entry in intin
ptsin ptsin[0] width
ptsin+2 ptsin[1] 0
ptsout ptsout[0] Return value
ptsout+2 ptsout[1] 0
7.4.6.37 v_bez_qual
Name: »Set Bezier quality« - Set quality of the Bezier spline creation.
Opcode: 5 (Escape 99, Opcode 32)
Syntax: int16_t v_bez_qual ( int16_t handle, int16_t qual, int16_t *set_qual );
Description: The call v_bez_qual sets a new factor that determines the quality and speed with which Bezier splines are drawn. The following apply:
qual Requested Bezier quality
set_qual Realized Bezier quality (not available with GEM/3 Release 3.1).
Note: The quality of the Beziers can be set as usual in percent (i.e. from 0 to 100), where 0 is fastest but produces the lowest quality while 100 is slowest with the highest possible quality. set_qual may not be an exact percentage as the rendering engine may not support every possible value between 1 and 99.
Return value: The function returns the old quality factor.
The GEM/3 and NVDI bindings also returns set_qual.
Availability: As of GEM/3 Release 3.1, SpeedoGDOS 4.00 onwards and NVDI 2.10 onwards.
See also: Binding   v_bez_on   v_bez_off   v_bez   v_bez_fill   v_set_app_buff
7.4.6.38 Bindings for v_bez_qual
C: int16_t v_bez_qual ( int16_t handle, int16_t qual, int16_t *set_qual );
Für GEM/3 Release 3.1 gilt:
int16_t v_bez_qual ( int16_t handle, int16_t qual );
int16_t v_bez_qual (int16_t handle, int16_t qual,
                    int16_t *set_qual)
   intin[0] = 32;
   intin[1] = 1;
   intin[2] = qual;
   contrl[0] = 5;
   contrl[1] = 0;
   contrl[3] = 3;
   contrl[5] = 99;
   contrl[6] = handle;
   vdi ();
   *set_qual = intout[0];
   return intout[0];
contrl contrl[0] 5 # Function Opcode
contrl+6 contrl[3] 3 # entry in intin
contrl+10 contrl[5] 99 Sub-Opcode
intin intin[0] 32
intin+2 intin[1] 1
intin+4 intin[2] qual
intout intout[0] set_qual
7.4.6.39 vsm_bg_color
Name: »Set background colour« - Set background colour for markers.
Opcode: 201 (Sub-Opcode 3)
Syntax: int16_t vsm_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: The call vsm_bg_color sets the background colour for markers.
 1 = All OK
Group: Marker attributes
7.4.6.40 Bindings for vsm_bg_color
C: int16_t vsm_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vsm_bg_color( int16_t handle, int32_t color_space,
   contrl[0] = 201;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 3;
   contrl[6] = handle;
   vdi ();
contrl+10 contrl[5] 3
7.4.6.41 vsm_color
Name: »Set polymarker colour index« - Set the colour of the marker points.
Opcode: 20
Syntax: int16_t vsm_color ( int16_t handle, int16_t color_index );
Description: The call vsm_color sets the colour of the markers. The following apply:
color_index Marker colour
Note: The colour indices 0 and 1 are always available, all further ones depend on the output device. If the index is invalid, colour index 1 will be selected.
Return value: The function returns the colour index actually selected.
See also: Binding   v_pmarker
7.4.6.42 Bindings for vsm_color
C: int16_t vsm_color ( int16_t handle, int16_t color_index );
int16_t vsm_color (int16_t handle, int16_t color_index)
   contrl[0] = 20;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 20 # Function Opcode
7.4.6.43 vsm_fg_color
Name: »Set foreground colour« - Set foreground colour for markers.
Opcode: 200 (Sub-Opcode 3)
Syntax: int16_t vsm_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: The call vsm_fg_color sets the foreground colour for markers.
 1 = All OK
7.4.6.44 Bindings for vsm_fg_color
C: int16_t vsm_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vsm_fg_color( int16_t handle, int32_t color_space,
   contrl[0] = 200;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 3;
   contrl[6] = handle;
   vdi ();
7.4.6.45 vsm_height
Name: »Set polymarker height« - Set height of the marker object.
Opcode: 19
Syntax: int16_t vsm_height ( int16_t handle, int16_t height );
Description: The call vsm_height sets the current marker height.
height Requested polymarker height (pixels)
The number of available heights can be obtained during opening of the virtual workstation with v_opnvwk.
Note: The width of the markers is adapted automatically. If an invalid height is chosen, the VDI selects the next suitable one. The dot's size can not be altered, it is always one pixel high and wide.
Return value: The function returns the size actually selected.
7.4.6.46 Bindings for vsm_height
C: int16_t vsm_height ( int16_t handle, int16_t height );
int16_t vsm_height (int16_t handle, int16_t height)
   ptsin[0] = 0;
   ptsin[1] = height;
   contrl[0] = 19;
   contrl[1] = 1;
   contrl[3] = 0;
   contrl[6] = handle;
   vdi ();
   return ( ptsout[1] );
contrl contrl[0] 19 # Function Opcode
ptsin ptsin[0] 0
ptsin+2 ptsin[1] height
ptsout ptsout[0] set_height_x
ptsout+2 ptsout[1] Return Value
Note: The component set_height_x describes the selected marker height with reference to the X-direction; PC-GEM always returns the value 0.
7.4.6.47 vsm_type
Name: »Set polymarker type« - Set the type of the marker object.
Opcode: 18
Syntax: int16_t vsm_type ( int16_t handle, int16_t typ );
Description: The call vsm_type determines the appearance of the current marker. The following apply:
typ Polymarker type:
1 = Dot
2 = Plus
3 = Asterisk
4 = Square
5 = Diagonal cross
6 = Diamond
7 ... n = Device-dependent
Note: If the requested marker type is out of range, the GEM VDI will use an asterisk, type 3. Marker 1 is the smallest dot that GEM VDI can depict on the device (usually one pixel); it cannot be scaled.
Return value: The function returns the marker actually selected.
See also: Binding   v_pmarker   vsm_height
7.4.6.48 Bindings for vsm_type
C: int16_t vsm_type ( int16_t handle, int16_t typ );
int16_t vsm_type (int16_t handle, int16_t typ)
   intin[0] = typ;
   contrl[0] = 18;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 18 # Function Opcode
intin intin[0] type
7.4.6.49 vst_alignment
Name: »Set graphic text alignment« - Set the alignment for normal and justified text output.
Opcode: 39
Syntax: void vst_alignment ( int16_t handle, int16_t hor_in, int16_t vert_in, int16_t *hor_out, int16_t *vert_out );
Description: The call vst_alignment determines the horizontal and vertical alignment of a text.
Example:
The function is passed the following Parameters:
hor_in Horizontal alignment:
0 = Left justified (default)
1 = Centered
2 = Right justified
vert_in Vertical alignment:
0 = Baseline (default)
1 = Half line
2 = Ascent line
3 = Bottom line
4 = Descent line
5 = Top line
hor_out Selected horizontal alignment
vert_out Selected vertical alignment
Note: The default setting is the left edge of the baseline. For an invalid input for the horizontal alignment, the text is flushed left ('left-justified'). For an invalid input for the vertical alignment, the text will be aligned on the baseline.
Group: Text attributes
See also: Binding   v_gtext   v_justified
7.4.6.50 Bindings for vst_alignment
C: void vst_alignment ( int16_t handle, int16_t hor_in, int16_t vert_in, int16_t *hor_out, int16_t *vert_out );
void vst_alignment (int16_t handle, int16_t hor_in,
                    int16_t *vert_out)
   intin[0] = hor_in;
   intin[1] = vert_in;
   contrl[0] = 39;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[6] = handle;
   vdi ();
   *hor_out  = intout[0];
   *vert_out = intout[1];
contrl contrl[0] 39 # Function Opcode
contrl+8 contrl[4] 2 # entry in intout
intin intin[0] hor_in
intin+2 intin[1] vert_in
intout intout[0] hor_out
intout+2 intout[1] vert_out
7.4.6.51 vst_arbpt
Name: »Set character cell height in arbitrary points« - Set the character cell height in points.
Opcode: 246
Syntax: int16_t vst_arbpt ( int16_t handle, int16_t point, int16_t *chwd, int16_t *chht, int16_t *cellwd, int16_t *cellht );
Description: The call vst_arbpt sets the current character height for an outline font in printer points. The following apply:
point Desired character height
chwd Resulting character width
chht Resulting character height
cellwd Resulting character cell width
cellht Resulting character cell height
Notes: In contrast to vst_point, the function permits the scaling to any integer point size, irrespective of the sizes listed in EXTEND.SYS. If you want to set a fractional point size, use vst_arbpt32.
If negative values are set, the characters will be mirrored (reflected) about the X-axis.
The returned character widths are rounded-off values, which cannot be used without more ado for calculating overall text widths.
Return value: The function returns the character height set in points.
Availability: With FSM-GDOS, and SpeedoGDOS Version 4.00 onwards.
See also: Binding   vst_arbpt32   vst_point   vst_setsize   SpeedoGDOS   NVDI
7.4.6.52 Bindings for vst_arbpt
C: int16_t vst_arbpt ( int16_t handle, int16_t point, int16_t *chwd, int16_t *chht, int16_t *cellwd, int16_t *cellht );
int16_t vst_arbpt (int16_t handle, int16_t point,
                   int16_t *cellwd, int16_t *cellht)
   intin[0] = point;
   contrl[0] = 246;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[6] = handle;
   vdi ();
   *chwd   = ptsout[0];
   *chht   = ptsout[1];
   *cellwd = ptsout[2];
   *cellht = ptsout[3];
contrl contrl[0] 246 # Function Opcode
contrl+4 contrl[2] 2 # entry in ptsout
intin intin[0] point
ptsout ptsout[0] chwd
ptsout+2 ptsout[1] chht
ptsout+4 ptsout[2] cellwd
ptsout+6 ptsout[3] cellht
7.4.6.53 vst_arbpt32
Name: »Set character cell height in arbitrary points« - Set the character cell height in points for an outline font.
Opcode: 246
Syntax: fix31 vst_arbpt32 ( int16_t handle, fix31 point, int16_t *chwd, int16_t *chht, int16_t *cellwd, int16_t *cellht );
Description: The call vst_arbpt32 sets the current character height for an outline font in printer points, and can include fractional sizes. The following apply:
Notes: In contrast to vst_point, the function permitsthe scaling to any point size, irrespective of the values listed in EXTEND.SYS.
If negative values are set, the characters will be mirrorred (reflected) about the X-axis.
Return value: The function returns the character height actually set in 1/65536 of a point.
This is not clear from the SpeedoGDOS documentation. It's possible that only the character height in points is returned.
Availability: With FSM-GDOS, SpeedoGDOS as of Version 4.00, and NVDI 3.00 onwards. In the documentation for NVDI 3.00 this function is wrongly called vst_arbpt.
See also: Binding   vst_point   vst_setsize   SpeedoGDOS   NVDI
7.4.6.54 Bindings for vst_arbpt32
C: fix31 vst_arbpt32 ( int16_t handle, fix31 point, int16_t *chwd, int16_t *chht, int16_t *cellwd, int16_t *cellht );
fix31 vst_arbpt32 (int16_t handle, fix31 point,
   intin[0..1] = point;
   contrl[0] = 246;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[6] = handle;
   vdi ();
   *chwd   = ptsout[0];
   *chht   = ptsout[1];
   return ( intout[0..1] );
intin intin[0..1] point
intout intout[0..1] Return value
ptsout+4 ptsout[2] cellwe
7.4.6.55 vst_bg_color
Name: »Set background color« - Set background colour for text.
Opcode: 201 (Sub-Opcode 0)
Syntax: int16_t vst_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: The call vst_bg_color sets the background colour for text.
 1 = All OK
7.4.6.56 Bindings for vst_bg_color
C: int16_t vst_bg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vst_bg_color( int16_t handle, int32_t color_space,
   contrl[0] = 201;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 0;
   contrl[6] = handle;
   vdi ();
contrl+10 contrl[5] 0
7.4.6.57 vst_charmap
Name: »Set character mapping mode« - Select the type of font indexing.
Opcode: 236
Syntax: void vst_charmap ( int16_t handle, int16_t mode );
Description: The call vst_charmap sets the type of font indexing, offering a choice between the standard Atari ASCII interpretation of text strings or the Bitstream character indices. The following apply:
mode Mapping mode:
0 = Direct mapping (WORD), i.e. no translation of the character index
1 = ASCII mapping (byte-sized)
For SpeedoGDOS the following applies:
mode Type of indexing:
0 = Atari characters
1 = Bitstream
Note: If you switch to direct mapping, the number of characters per font (minADE and maxADE/vqt_fontinfo) is changed to the number of really existing characters.
As of NVDI 4.00 there is an extended version: vst_map_mode
Availability: SpeedoGDOS 4.0, NVDI 3.00
See also: Binding   vst_map_mode   vqt_fontinfo   ASCII table
7.4.6.58 Bindings for vst_charmap
C: void vst_charmap ( int16_t handle, int16_t mode );
void vst_charmap (int16_t handle, int16_t mode)
   intin[0] = mode;
   contrl[0] = 236;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 236 # Function Opcode
intin intin[0] mode
7.4.6.59 vst_color
Name: »Set graphic text colour index« - Set the colour of the text output.
Opcode: 22
Syntax: int16_t vst_color ( int16_t handle, int16_t color_index );
Description: The call vst_color sets the colour index for subsequent graphic text operations.
color_index Requested text colour index
Note: All devices support at least two colour indices, 0 and 1 (monochrome). All others depend on the output device in use. If an invalid index is specified then the value 1 will be assumed.
Return value: The function returns the colour actually set.
7.4.6.60 Bindings for vst_color
C: int16_t vst_color ( int16_t handle, int16_t color_index );
int16_t vst_color (int16_t handle, int16_t color_index)
   contrl[0] = 22;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 22 # Function Opcode
7.4.6.61 vst_effects
Name: »Set graphic text special effects«
Opcode: 106
Syntax: int16_t vst_effects ( int16_t handle, int16_t effect );
Description: The call vst_effects defines various special effects to be applied to text. The following apply:
effect Texteffekt in Bit-Darstellung
0x00 = Normal
0x01 = Thickened
0x02 = Lightened
0x04 = Skewed
0x08 = Underlined
0x10 = Outlined
0x20 = Shadowed (not currently supported)
Notes: The text effects can also be mixed with an OR combination; unavailable effects will not be set.
Apart from underlining, these special effects do not usually work well with outline (vector) text.
Return value: The function returns the text effect actually selected.
7.4.6.62 Bindings for vst_effects
C: int16_t vst_effects ( int16_t handle, int16_t effect );
int16_t vst_effects (int16_t handle, int16_t effect)
   intin[0] = effect;
   contrl[0] = 106;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 106 # Function Opcode
intin intin[0] effect
7.4.6.63 vst_error
Name: »Set outline font error mode« - Set the GDOS error handling.
Opcode: 245
Syntax: void vst_error ( int16_t handle, int16_t mode, int16_t *errorvar );
Description: The call vst_error determines the type of GDOS error handling and can stop error-messages being sent to the screen. The following apply:
mode Type of error handling:
0 = Errors reported in error variable errorvar
1 = Default) Errors go to screen
errorvar Address of the error variables; should be initialized with a NULL. The following error codes apply for SpeedoGDOS 4.xx:
1 = Out of system memory (Misc cache)
2 = Error opening font file
3 = Error reading font file
4 = Error while writing out cache buffer
5 = Font scaler error
6 = (Not implemented)
7 = Not enough memory for scratch buffer
8 = Out of system memory (character cache)
255 = Misc. Speedo error
With SpeedoGDOS 5.0 the meaning seems to have altered to:
1 = Insufficient font data loaded
3 = Invalid font specifications ordered
4 = Font format error (very often a customer-specific font that is licensed only for a given program).
7 = Rules requested; not supported
8 = Mode not available
10 = Font not specified
12 = Character data not available
13 = Track kerning data not available
14 = Pair kerning data not available
Notes: The error variable errorvar should be checked before the call of the following GDOS functions:
v_gtext            v_ftext
v_justified        vst_point
vst_height         vst_font
vst_arbpt          vqt_advance
vst_setsize        vqt_fontinfo
vqt_name           vqt_width
vqt_extent         vqt_f_extent
v_opnwk            v_opnvwk
vst_load_fonts     vst_unload_fonts
It is up to each application to process the errors correctly. It should also reset the value pointed to by errorvar to 0 after each reported error.
Return value: This function does not return a result.
Availability: With FSM-GDOS, Font-GDOS and SpeedoGDOS as of Version 4.00.
See also: Binding   GDOS   SpeedoGDOS
7.4.6.64 Bindings for vst_error
C: void vst_error ( int16_t handle, int16_t mode, int16_t *errorvar );
                 int16_t *errorvar )
   intin[0] = mode;
   intin[1..2] = errorvar;
   contrl[0] = 245;
   contrl[1] = 0;
   contrl[3] = 3;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 245 # Function Opcode
intin intin[0] mode
intin+2 intin[1..2] errorvar
7.4.6.65 vst_fg_color
Name: »Set foreground colour« - Set foreground colour for text.
Opcode: 200 (Sub-Opcode 0)
Syntax: int16_t vst_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
Description: The call vst_fg_color sets the foreground colour for text.
 1 = All OK
7.4.6.66 Bindings for vst_fg_color
C: int16_t vst_fg_color ( int16_t handle, int32_t color_space, COLOR_ENTRY *fg_color );
int16_t vst_fg_color( int16_t handle, int32_t color_space,
   contrl[0] = 200;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 0;
   contrl[6] = handle;
   vdi ();
7.4.6.67 vst_font
Name: »Set text face« - Select a font for text output.
Opcode: 21
Syntax: int16_t vst_font ( int16_t handle, int16_t font );
Description: The call vst_font selects the current font for outputting text.
font Requested font
Note: The names and indices of the fonts can be obtained with the function vqt_name. Whether the fonts are supported depends on the output device in each case.
If a requested font does not exist, the system font will be chosen.
Return value: The function returns the number of the selected font.
See also: Binding   vst_load_fonts   vqt_name   v_gtext v_justified
7.4.6.68 Bindings for vst_font
C: int16_t vst_font ( int16_t handle, int16_t font );
int16_t vst_font (int16_t handle, int16_t font)
   intin[0] = font;
   contrl[0] = 21;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 21 # Function Opcode
intin intin[0] font
7.4.6.69 vst_height
Name: »Set character height, absolute mode« - Set the character height for text output.
Opcode: 12
Syntax: void vst_height ( int16_t handle, int16_t height, int16_t *char_width, int16_t *char_height, int16_t *cell_width, int16_t *cell_height );
Description: The call vst_height sets the character height in pixels.
height Requested character height
char_width Selected character width
char_height Selected character height
cell_width Selected character cell width
cell_height Selected character cell height
Note: If the desired character height does not map exactly to a device size, VDI selects the closest character size that does not exceed the requested size.
Most screen drivers using this function can reduce available fonts by any amount, or scale them to double size. This applies in particular to the screen driver implemented in ROM.
If the font is a vector font, char_width and cell_width are not the exact character widths but only rounded values.
See also: Binding   v_gtext   v_justified   vst_point
7.4.6.70 Bindings for vst_height
C: void vst_height ( int16_t handle, int16_t height, int16_t *char_width, int16_t *char_height, int16_t *cell_width, int16_t *cell_height );
void vst_height (int16_t handle, int16_t height,
                 int16_t *cell_width, int16_t *cell_height)
   ptsin[0] = 0;
   ptsin[1] = height;
   contrl[0] = 12;
   contrl[1] = 1;
   contrl[3] = 0;
   contrl[6] = handle;
   vdi ();
   *char_width  = ptsout[0];
   *char_height = ptsout[1];
   *cell_width  = ptsout[2];
   *cell_height = ptsout[3];
contrl contrl[0] 12 # Function Opcode
ptsin ptsin[0] 0
ptsout ptsout[0] char_width
ptsout+2 ptsout[1] char_height
ptsout+4 ptsout[2] cell_width
ptsout+6 ptsout[3] cell_height
7.4.6.71 vst_kern
Name: »Set kerning mode«
Opcode: 237
Syntax: void vst_kern ( int16_t handle, int16_t tmode, int16_t pmode, int16_t *tracks, int16_t *pairs );
Description: The call vst_kern permits setting of the desired kerning mode and its values.
tmode Track kerning:
0 = No track kerning
1 = Normal
2 = Tight
3 = Very tight
pmode Pair kerning:
0 = No pair kerning
1 = Use pair kerning
tracks Track kerning mode
pairs Number of kerning pairs defined in font
Note: Most Speedo fonts have 3 kerning tracks. Ordinary TrueType fonts do not have any kerning tracks, but some GX TrueTypes do.
NVDI allows the caller to set a user-defined track kerning (vst_track_offset). The track kerning mode must be 255 (track_mode) and intin[2..3] contain the offset in 1/65536 pixels.
Availability: As of SpeedoGDOS 4.00, and NVDI 3.00 onwards.
See also: Binding   vqt_pairkern   vqt_trackkern   vst_track_offset
7.4.6.72 Bindings for vst_kern
C: void vst_kern ( int16_t handle, int16_t tmode, int16_t pmode, int16_t *tracks, int16_t *pairs );
void vst_kern (int16_t handle, int16_t tmode, int16_t pmode,
               int16_t *tracks, int16_t *pairs)
   intin[0] = tmode;
   intin[1] = pmode;
   contrl[0] = 237;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[6] = handle;
   vdi ();
   *tracks = intout[0];
   *pairs  = intout[1];
contrl contrl[0] 237 # Function Opcode
intin intin[0] tmode
intin+2 intin[1] pmode
intout intout[0] tracks
intout+2 intout[1] pairs
7.4.6.73 vst_map_mode
Name: »Set character mapping mode« - Set the type of font indexing (extended version of vst_charmap).
Opcode: 236
Syntax: int16_t vst_map_mode ( int16_t handle, int16_t mode );
Description: The call vst_map_mode sets the type of font indexing, allowing choices between standard Atari ASCII interpretation of text strings, the Bitstream character indices or Unicode mapping. The following apply:
mode Mapping mode:
2 = Unicode mapping (WORD)
If you select Unicode and if you want to determine whether a certain character exists, you should call vqt_width. If the index returned by vqt_width is -1, the character does not exist. Instead of vqt_width you can also call vqt_char_index and map the Unicode index into a direct index.
Return value: The function returns the selected mapping.
Availability: NVDI 4.0
See also: Binding   vst_charmap   vqt_fontinfo   ASCII table
7.4.6.74 Bindings for vst_map_mode
C: int16_t vst_map_mode ( int16_t handle, int16_t mode );
int16_t vst_charmap (int16_t handle, int16_t mode)
   intin[0] = mode;
   intin[1] = 1;       /* Mapping zurückliefern */
   contrl[0] = 236;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[6] = handle;
   vdi ();
intin intin[0] mode
intin+2 intin[1] 1
7.4.6.75 vst_name
Name: »Set text face by name« - Find and set font.
Opcode: 230 (Opcode 0)
Syntax: int16_t vst_name ( int16_t handle, int16_t font_format, int8_t *font_name, int8_t *ret_name );
Description: The call vst_name searches for a font by name, and sets it as the current one.
font_format Possible font formats:
1 = Bitmap font
2 = Speedo font
4 = TrueType font
8 = Type-1 font
font_name Font name
ret_name Name of the selected font
Note: Missing or extra spaces in the font name are ignored. If the requested font is not available, the system font is selected.
Return value: The function returns the ID of the selected font.
Availability: The function is available under NVDI as of Version 3.02.
See also: Binding   vqt_name   vqt_xfntinfo
7.4.6.76 Bindings for vst_name
C: int16_t vst_name ( int16_t handle, int16_t font_format, int8_t *font_name, int8_t *ret_name );
int16_t vst_name (int16_t handle, int16_t font_format,
                  int8_t *font_name, int8_t *ret_name)
   intin[0] = font_format;
   intin[1..n] = font_name[0..n-1];
   contrl[0] = 230;
   contrl[1] = 0;
   contrl[3] = n;
   contrl[5] = 0;
   contrl[6] = handle;
   vdi ();
   ret_name[0..m-1] = intout[1..m];
contrl contrl[0] 230 # Function Opcode
contrl+6 contrl[3] n # entry in intin
contrl+8 contrl[4] m # entry in intout
contrl+10 contrl[5] 0 Sub-Opcode
intin intin[0] font_format
intin+2 intin[1..n] font_name[0..n-1]
intout+2 intout[1..m] ret_name[0..m-1]
7.4.6.77 vst_point
Name: »Set character height, points mode« - Set the character cell size for text output.
Opcode: 107
Syntax: int16_t vst_point ( int16_t handle, int16_t point, int16_t *char_width, int16_t *char_height, int16_t *cell_width, int16_t *cell_height );
Description: The call vst_point sets the character cell size, i.e. the distance between two baselines, in points (1/72"). The following apply:
point Requested character cell height (points)
The sizes are measured in points, each of which is 1/72 inch or roughly 0.353mm.
Note: Should the desired character height not be available, the next smaller one will be chosen. With proportional fonts, the maximum possible values are returned for width and height.
If the font is a vector font, only predefined heights can be selected (usually 8, 9, 10, 11, 12, 14, 18, 24, 36, and 48 pt).
Warning: The screen driver in ROM can scale each of the available fonts to double size, so that it is not possible without further ado to differentiate between fonts that have been scaled and those actually present. One can help oneself here by using a routine that can locate all present point sizes, as, when a wrong size is specified, vst_point selects the next smallest available size; if one finds with this method that all point sizes are present, then we are evidently dealing with a vector font.
Return value: The function returns the character cell height in points.
See also: Binding   v_gtext   v_justified   vst_height
7.4.6.78 Bindings for vst_point
C: int16_t vst_point ( int16_t handle, int16_t point, int16_t *char_width, int16_t *char_height, int16_t *cell_width, int16_t *cell_height );
int16_t vst_point (int16_t handle, int16_t point,
   intin[0] = point;
   contrl[0] = 107;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 107 # Function Opcode
7.4.6.79 vst_rotation
Name: »Set character baseline vector« - Set the orientation of the baseline for text output.
Opcode: 13
Syntax: int16_t vst_rotation ( int16_t handle, int16_t angle );
Description: The call vst_rotation sets the orientation of the baseline for graphic text output. The following apply:
angle Requested angle of rotation of character baseline
Note: The angle is specified in 1/10 of a degree. If the selected font is a bitmap font, rotation works only in steps of 90 degrees; for vector fonts it is continuous. On some devices this function is not available.
Return value: The function returns the angle actually selected.
Availability: Supported by all drivers. For specific character rotation abilities, check the values returned in vq_extnd.
7.4.6.80 Bindings for vst_rotation
C: int16_t vst_rotation ( int16_t handle, int16_t angle );
int16_t vst_rotation (int16_t handle, int16_t angle)
   intin[0] = angle;
   contrl[0] = 13;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 13 # Function Opcode
intin intin[0] angle
7.4.6.81 vst_scratch
Name: »Set scratch buffer allocation mode«
Opcode: 244
Syntax: void vst_scratch ( int16_t handle, int16_t mode );
Description: The call vst_scratch selects the way that the scratch buffer is created. The following apply:
mode Type of buffer
0 = Allocated size is large enough for bitmap and vector fonts with any special text effects (default)
1 = Size is governed by the bitmap fonts; one should forgo text effects for vector fonts
2 = Do not create a scratch buffer, and forgo text effects
Notes: The scratch buffer is used for generation of text effects. As vector fonts are freely scalable, one cannot allocate a unique size for the scratch buffer.
Atari recommends that at least mode 1 is set prior to vst_load_fonts to prevent scratch buffer overruns.
Availability: FSM-GDOS, and SpeedoGDOS as of version 4.00.
See also: Binding   GDOS   SpeedoGDOS   vst_effects
7.4.6.82 Bindings for vst_scratch
C: void vst_scratch ( int16_t handle, int16_t mode );
   intin[0] = mode;
   contrl[0] = 244;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 244 # Function Opcode
intin intin[0] mode
7.4.6.83 vst_setsize
Name: »Set character cell width in points« - Set the character cell width in points.
Opcode: 252
Syntax: int16_t vst_setsize ( int16_t handle, int16_t point, int16_t *chwd, int16_t *chht, int16_t *cellwd, int16_t *cellht );
Description: The call vst_setsize sets the character width in points (1/72") for outline characters. The following apply:
point Desired character width in points
chwd Resultant character width
chht Resultant character height
cellwd Resultant character cell width
cellht Resultant character cell height
Note: The next call of vst_point, vst_arbpt or vst_height resets the width set by this function and the width required by the relevant characters is set instead. With negative widths the characters will be mirrored about the Y-axis.
Return value: The function returns the character cell width set in points.
See also: Binding   vst_setsize32   vst_point   vst_height   vst_arbpt
7.4.6.84 Bindings for vst_setsize
C: int16_t vst_setsize ( int16_t handle, int16_t point, int16_t *chwd, int16_t *chht, int16_t *cellwd, int16_t *cellht );
int16_t vst_setsize (int16_t handle, int16_t point,
   intin[0] = point;
   contrl[0] = 252;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
   *chwd   = ptsout[0];
   *chht   = ptsout[1];
contrl contrl[0] 252 # Function Opcode
7.4.6.85 vst_setsize32
Name: »Set character cell width in arbitrary points« - Set the character cell width in fractional points.
Opcode: 252
Syntax: fix31 vst_setsize32 ( int16_t handle, fix31 point, int16_t *chwd, int16_t *chht, int16_t *cellwd, int16_t *cellht );
Description: The call vst_setsize32 sets the character width as a fix31 fractional value in 1/65536 of a point.
point Desired character width (in points)
chwd Selected character width
chht Selected character height
cellwd Selected character cell width
cellht Selected character cell height
Note: A call of vst_point, vst_arbpt or vst_height resets the width set by this function and the width required by the relevant characters is set instead. With negative widths the characters are mirrored about the Y-axis.
Return value: The function returns the set character cell width in 1/65536 of a point.
Availability: As of SpeedoGDOS 4.00, and NVDI 3.00 onwards. In the documentation for NVDI 3.00 this function is wrongly called vst_setsize.
See also: Binding   vst_point   vst_height   vst_arbpt
7.4.6.86 Bindings for vst_setsize32
C: fix31 vst_setsize32 ( int16_t handle, fix31 point, int16_t *chwd, int16_t *chht, int16_t *cellwd, int16_t *cellht );
fix31 vst_setsize32 (int16_t handle, fix31 point,
   contrl[0] = 252;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[6] = handle;
   vdi ();
   *chwd   = ptsout[0];
   *chht   = ptsout[1];
7.4.6.87 vst_skew
Name: »Set outline font skew« - Set the slope for 'italic' text.
Opcode: 253
Syntax: int16_t vst_skew ( int16_t handle, int16_t skew );
Description: The call vst_skew sets the skew of vector font characters in steps of 1/10 degrees. The skewing angle is independent of vst_effects and must be in a range between -90 and +90 degrees. Positive angles will lean the characters to the left, whereas negative angles will lean them to the right.
skew Angle in 1/10 degrees
Note: This function can really only be seen as a bit of a lark, as characters created in this way basically look worse than a true italic font (which should be available for most font families).
Return value: The function returns the set skew angle.
Availability: FSM-GDOS, SpeedoGDOS as of Version 4.00, and NVDI 3.00 onwards.
See also: Binding   vst_effects   SpeedoGDOS   NVDI
7.4.6.88 Bindings for vst_skew
C: int16_t vst_skew ( int16_t handle, int16_t skew );
int16_t vst_skew (int16_t handle, int16_t skew)
   intin[0] = skew;
   contrl[0] = 253;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 253 # Function Opcode
intin intin[0] skew
7.4.6.89 vst_track_offset
Name: Set track kerning offset« - Set offset for track kerning.
Opcode: 237 (Opcode 255)
Syntax: void vst_track_offset ( int16_t handle, fix31 offset, int16_t pairmode, int16_t *tracks, int16_t *pairs );
Description: The call vst_track_offset allows the setting of a user-defined value for track kerning. The following apply:
offset Offset
pairmode Pair kerning:
0 = Disable
1 = Enable
Availability: NVDI 3.00 onwards.
See also: Binding   vqt_pairkern   vqt_trackkern   vst_kern
7.4.6.90 Bindings for vst_track_offset
C: void vst_track_offset ( int16_t handle, fix31 offset, int16_t pairmode, int16_t *tracks, int16_t *pairs );
void vst_track_offset (int16_t handle, fix31 offset,
                       int16_t *pairs)
   intin[0] = 255;
   intin[1] = pairmode;
   intin[2..3] = offset;
   contrl[0] = 237;
   contrl[1] = 0;
   contrl[3] = 4;
   contrl[6] = handle;
   vdi ();
   *pairs  = intout[1];
contrl+6 contrl[3] 4 # entry in intin
intin intin[0] 255
intin+2 intin[1] pairmode
intin+4 intin[2..3] offset
7.4.6.91 vst_width
Name: »Set character width (absolute mode)« - Set character width in pixels.
Opcode: 231
Syntax: void vst_width ( int16_t handle, int16_t width, int16_t *char_width, int16_t *char_height, int16_t *cell_width, int16_t *cell_height );
Description: The call vst_width sets the character width in pixels. The following apply:
width Desired character width
char_height Seleted character height
Note: The next call of vst_height, vst_point or vst_arbpt32 resets the width. You should use vst_setsize32 instead of vst_width because vst_width uses only an integer value as a relative width and therefore it does not offer the required accuracy.
Availability: As of SpeedoGDOS 4.20, and NVDI 3.00 onwards.
See also: Binding   vst_arbpt   vst_height   vst_point   vst_setsize
7.4.6.92 Bindings for vst_width
C: void vst_width ( int16_t handle, int16_t width, int16_t *char_width, int16_t *char_height, int16_t *cell_width, int16_t *cell_height );
void vst_width (int16_t handle, int16_t width,
   ptsin[0] = width;
   contrl[0] = 231;
   contrl[1] = 1;
   contrl[3] = 0;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 231 # Function Opcode
7.4.6.93 v_topbot
Name: »Set character height, absolute mode« - Set character height for text output.
Opcode: 5 (Escape 18501)
Syntax: void v_topbot ( int16_t handle, int16_t height, int16_t *char_width, int16_t *char_height, int16_t *cell_width, int16_t *cell_height );
Description: The call v_topbot is an alternative to vst_height. It uses top to bottom distance for text scaling, instead of top to baseline distance.
height Character height
cell_width Character cell width
cell_height Character cell height
Note: If the desired character height is not available, the next smaller one is chosen automatically. With proportional fonts, the output parameters contain the width of the widest character in the font.
With vector fonts, the widths output by char_width and cell_width represent rounded-off values.
Availability: GEM/3 Release 3.1.
See also: Binding   v_gtext   v_justified   vst_point   vst_height
7.4.6.94 Bindings for v_topbot
C: void v_topbot ( int16_t handle, int16_t height, int16_t *char_width, int16_t *char_height, int16_t *cell_width, int16_t *cell_height );
void v_topbot (int16_t handle, int16_t height,
   ptsin[0] = 0;
   ptsin[1] = height;
   contrl[0] = 5;
   contrl[1] = 1;
   contrl[3] = 0;
   contrl[5] = 18501;
   contrl[6] = handle;
   vdi ();
contrl+4 contrl[2] 4 # entry in ptsout
contrl+10 contrl[5] 18501
ptsin ptsin[0] 0
7.4.6.95 vswr_mode
Name: »Set writing mode« - Set the writing mode for almost all graphic functions.
Opcode: 32
Syntax: int16_t vswr_mode ( int16_t handle, int16_t mode );
Description: The call vswr_mode determines the way that source pixels and destination pixels are combined to form the resulting colour values. The following apply:
mode Writing mode:
1 = Replace
2 = Transparent
3 = XOR
4 = Reverse transparent
Notes: The normal writing mode is the Replace mode. The number of available modes can be obtained with the vq_extnd function; if a mode that is not present is passed, then the Replace mode will be used.
Description of the VDI writing modes provides more detailed particulars and an illustration of the effect of various writing modes.
Return value: The function returns the writing mode actually set.
Group: Superior attributes
See also: Binding   v_pline   v_pmarker   v_gtext   v_fillarea   v_contourfill   vr_recfl   v_bar   v_arc   v_pieslice   v_circle   v_ellarc   v_ellpie   v_ellipse   v_rbox   v_rfbox   v_justified   Description of the VDI writing modes
7.4.6.96 Bindings for vswr_mode
C: int16_t vswr_mode ( int16_t handle, int16_t mode );
int16_t vswr_mode (int16_t handle, int16_t mode)
   intin[0] = mode;
   contrl[0] = 32;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 32 # Function Opcode
intin intin[0] mode
7.4.6.97 vs_bkcolor
Opcode: 5 (Escape 102)
Syntax: void vs_bkcolor ( int16_t handle, int16_t color );
Description: The call vs_bkcolor sets the background colour for the device associated with handle, usually a camera device.
color Background colour index
7.4.6.98 Bindings for vs_bkcolor
C: void vs_bkcolor ( int16_t handle, int16_t color );
void vs_bkcolor (int16_t handle, int16_t color)
   intin[0] = color;
   contrl[0] = 5;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[5] = 102;
   contrl[6] = handle;
   vdi ();
contrl+10 contrl[5] 102
7.4.6.99 vs_color
Name: »Set colour representation« - Set the colour intensity of a palette index.
Opcode: 14
Syntax: void vs_color ( int16_t handle, int16_t index, int16_t *rgb_in );
Description: The call vs_color sets the colour intensity for the individual colour registers of a palette index. The following apply:
index Colour register index (pen)
rgb_in[0] Red colour intensity (in tenths of a percent, 0-1000)
rgb_in[1] Green colour intensity (in tenths of a percent, 0-1000)
rgb_in[2] Blue colour intensity (in tenths of a percent, 0-1000)
As not every output device needs to offer 1000 possible colour tints, several input intensities of the RGB colours may share the intensities that have actually been set.
Note: The function can only be used if lookup table support is present. If an invalid colour number is passed, then the next achievable value will be set.
For devices with a CLUT (graphics systems with up to 8 planes, i.e. 256 colours) the settings are effective immediately on all pixels that were drawn on the screen with the colour index index.
Important: For this reason the first 16 colour numbers should not be altered, as these are used by the AES.
If a device has more than 256 colours displayable simultaneously, it usually does not have a CLUT. In that case the pixels do not contain a colour value or index but a direct colour value in RGB (e.g. a pixel with 32 bits has 8 unused bits, 8 bits for red, 8 bits for green and 8 bits for blue). This means that the VDI creates a pseudo-CLUT with 256 pens, and calling vs_color for one of these pens will not change the colour of the pixels which have been drawn with this pen, though it will change the colour of new pixels drawn with this pen. Note that the palettes are handled per workstation, which means that each workstation has its own palette (pseudo-CLUT) and changing the RGB value for a colour index on one workstation will not change the value of the same pen on another workstation.
See also: Binding   v_pline   v_pmarker   v_gtext   v_fillarea   v_cellarray   v_contourfill   vr_recfl   v_bar   v_arc   v_pieslice   v_circle   v_ellarc   v_ellpie   v_ellipse   v_rbox   v_rfbox   v_justified   vq_color   vq_scrninfo
7.4.6.100 Bindings for vs_color
C: void vs_color ( int16_t handle, int16_t index, int16_t *rgb_in );
void vs_color (int16_t handle, int16_t index, int16_t *rgb_in)
   int16_t i;
   intin[0] = index;
   for (i=1; i<4; i++)
      intin[i] = *rgb_in++;
   contrl[0] = 14;
   contrl[1] = 0;
   contrl[3] = 4;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 14 # Function Opcode
intin intin[0] index
intin+2 intin[1..3] rgb_in[0..2]
7.4.6.101 vs_color2
Name: »Set colour representation-2« - Set colour intensity and colour for attributes.
Opcode: 138 (Opcode 0,1,2)
Syntax: void vs_color2 ( int16_t handle, int16_t *rgb, int16_t index );
Description: The call vs_color2 sets the colour intensity and colour for certain attribute functions. The following apply:
handle Workstation identifier
rgb[0] Red portion in tenths of a percent
rgb[1] Green portion in tenths of a percent
rgb[2] Blue portion in tenths of a percent
index Colour number
Note: The function is available directly only under PC-GEM. However it can be emulated on the Atari, which some applications (e.g. Kandinsky and GEM) actually do.
It works similarly to vs_color, with the difference that with an opcode of
0 the text colour
1 the fill colour
2 the line colour
is altered, and so the corresponding calls of vsl_color etc. are no longer necessary. Due to lack of documentation, one unfortunately cannot say for certain whether the name of the function (vs_color2) is really correct.
Return value: Die Funktion liefert kein Ergebnis zurück.The function does not return a result.
Availability: The above statement cannot be confirmed. It is to be assumed that the function v_setrgb is actually meant here; however the passing of parameters is somewhat different.
See also: Binding   v_setrgb   vs_color vswr_mode
7.4.6.102 Bindings for vs_color2
C: void vs_color2 ( int16_t handle, int16_t *rgb, int16_t index );
void vs_color2 (int16_t handle, int16_t *rgb, int16_t index)
   int16_t i;
   for (i=0; i<3; i++)
      intin[i] = *rgb;
   intin[3] = index;
   contrl[0] = 138;
   contrl[1] = 0;
   contrl[3] = 4;
   contrl[5] = opcode;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 138 # Function Opcode
contrl+2 contrl[1] 0 # entry in ptsin
contrl+4 contrl[2] 0 # entry in ptsout
contrl+10 contrl[5] opcode
contrl+12 contrl[6] handle
intin intin[0..2] rgb
intin+6 intin[3] index
7.4.6.103 vs_grayoverride
Name: »Override gray level«
Opcode: 133
Syntax: void vs_grayoverride ( int16_t handle, int16_t grayval );
Description: The call vs_grayoverride overrides the grey level specified with the vsf_style call patterns 2,1 through 2,8. The application should specify the closest index in the normal fill pattern set and follow it with a vs_grayoverride call to "fine-tune" that gray level on devices that support such fine tuning. This call is currently implemented in the PostScript driver.
grayval Grey value in tenths of a percent
   0  White
1000  Black
7.4.6.104 Bindings for vs_grayoverride
C: void vs_grayoverride ( int16_t handle, int16_t grayval );
void vs_grayoverride (int16_t handle, int16_t grayval)
   intin[0] = grayval;
   contrl[0] = 133;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 133 # Function Opcode
intin intin[0] grayval
7.4.6.105 v_ps_halftone
Name: »PostScript halftoning« - Set PostScript halftoning.
Opcode: 5 (Escape 32)
Syntax: void v_ps_halftone( int16_t handle, int16_t index, int16_t angle, int16_t frequency );
Description: The call v_ps_halftone controls the parameters for PostScript halftoning. It provides direct access to analogous PostScript language parameters. It is implemented only for the PostScript driver.
index Halftone type:
0: Dot screen
1: Line screen
2: Ellipse screen
3: Custom (user-defined)
angle Hallftone screen angle
frequency Hallftone screen frequency
7.4.6.106 Bindings for v_ps_halftone
C: void v_ps_halftone( int16_t handle, int16_t index, int16_t angle, int16_t frequency );
   intin[0] = index;
   intin[1] = angle;
   intin[2] = frequency;
   contrl[0] = 5;
   contrl[1] = 0;
   contrl[3] = 3;
   contrl[5] = 32;
   contrl[6] = handle;
   vdi ();
contrl+10 contrl[5] 32 # Escape/Sub-opcode
intin+2 intin[1] angle
intin+4 intin[2] frequency
7.4.6.107 v_setrgb
Name: »Set colour representation« - Set colour intensity.
Opcode: 138
Syntax: void v_setrgb( int16_t handle, int16_t type, int16_t r, int16_t g, int16_t b );
Description: The call v_setrgb selects the colour intensity of the individual colour registers. The following apply:
type 0: Text colour
1: Fill colour
2: Line colour
3: Marker colour
r Red portion in tenths of a percent
g Green portion in tenths of a percent
b Blue portion in tenths of a percent
This is allegedly an old GEM/3 function. However such a function could not be found until now.
7.4.6.108 Bindings for v_setrgb
C: void v_setrgb( int16_t handle, int16_t type, int16_t r, int16_t g, int16_t b );
   intin[0] = r;
   intin[1] = g;
   intin[2] = b;
   contrl[0] = 138;
   contrl[1] = 0;
   contrl[3] = 3;
   contrl[5] = type;
   contrl[6] = handle;
   vdi ();
contrl+10 contrl[5] type
intin intin[0] r
intin+2 intin[1] g
intin+4 intin[2] b
7.4.6.109 v_setrgbi
Name: »Set colour representation« - Set the colour or intensity.
Opcode: 5 (Escape 18500)
Syntax: void v_setrgbi( int16_t handle, int16_t primtype, int16_t r, int16_t g, int16_t b, int16_t i );
Description: The call v_setrgbi overrides a previously set colour specification with an RGB triple (for colour devices) or intensity (for monochrome devices). This call is currently implemented only for the PostScript driver.
primtype Primitive type:
17: Line
20: Marker
22: Text
25: Fill
i Intensity
7.4.6.110 Bindings for v_setrgbi
C: void v_setrgbi( int16_t handle, int16_t primtype, int16_t r, int16_t g, int16_t b, int16_t i );
   intin[0] = primtype;
   intin[1] = r;
   intin[2] = g;
   intin[3] = b;
   intin[4] = i;
   contrl[0] = 5;
   contrl[1] = 0;
   contrl[3] = 5;
   contrl[5] = 18500;
   contrl[6] = handle;
   vdi ();
contrl+6 contrl[3] 5 # entry in intin
contrl+10 contrl[5] 18500 # Escape/Sub-opcode
intin intin[0] primtype
intin+2 intin[1] r
intin+4 intin[2] g
intin+6 intin[3] b
intin+8 intin[4] i
HomeVDIVDI bindingsOutput functions
