In this hypertext there are references to the following data types:
int32_t magic; /* Has to be 0x87654321 */
void *membot; /* End of the AES variables */
void *aes_start; /* Start address */
int32_t magic2; /* Is 'MAGX' */
int32_t date; /* Creation date */
void (*chgres)(int16_t res, int16_t txt); /* Change resolution */
int32_t (**shel_vector)(void); /* Resident desktop */
int8_t *aes_bootdrv; /* Booting will be from here */
int16_t *vdi_device; /* Driver used by AES */
void *reservd1; /* Reserved */
void *reservd2; /* Reserved */
void *reservd3; /* Reserved */
int16_t version; /* Version (0x0201 is V2.1) */
int16_t release; /* 0=alpha..3=release */
} AESVARS;
Note: These variables are READ-ONLY!
The first three variables are also present under TOS, and can be obtained there from the operating system header. The vdi_device component is superfluous as of MagiC 2.0 as one gets the device number in a MultiTOS-compatible way with appl_getinfo (opcode 2). The routine for changing the resolution (chgres) expects in register d2 an optional Falcon-mode (as int16_t).
See also: MagiC's cookie DOMagixAESVars
int8_t a_fname[14]; /* Filename */
int32_t a_modti; /* Time of last access */
int8_t a_userid; /* Unused */
int8_t a_gid; /* Unused */
int16_t a_fimode; /* File mode */
int32_t a_fsize; /* File length */
int16_t reserved; /* Reserved */
} ARHEADER;
Note: An archive file in Digital Research format consists of a file- header, any number of files (each prefaced with an ARHEADER structure) as well as an end-identifier. The file-header here consists only of the WORD 0xff65, the end of the archive file is identified by the value 0x0000.
See also: OHEADER
typedef struct _bcb
struct _bcb *b_link; /* Next BCB */
int16_t b_negl; /* Initialize to -1 */
int16_t b_private[5]; /* Unknown */
void *b_buf; /* Actual buffer */
} BCB;
int16_t cdecl (*cpx_call)();
void cdecl (*cpx_draw)();
void cdecl (*cpx_wmove)();
void cdecl (*cpx_timer)();
void cdecl (*cpx_key)();
void cdecl (*cpx_button)();
void cdecl (*cpx_m1)();
void cdecl (*cpx_m2)();
int16_t cdecl (*cpx_hook)();
void cdecl (*cpx_close)();
} CPXINFO;
This structure plays a role in connection with MagiC Mac, and is defined as follows:
BOOLEAN inserted; /* True: disk is inserted and available */
/* to GEMDOS/BIOS functions */
BOOLEAN highDensity; /* True: HD disk inserted, false: no or */
/* DD disk inserted */
int16_t res1; /* Reserved */
int32_t res2; /* Reserved */
} FlpDrvInfo;
See also: The MagiC Mac cookie
This structure describes the 'GEM memory usage parameter block', which is defined as follows:
typdef struct
int32_t gm_magic; /* Magical value, has to be 0x87654321 */
void *gm_end; /* End of the memory required by GEM */
void *gm_init; /* Start address of GEM */
} GEM_MUPB;
See also: _sysbase OSHEADER System variables System vectors
int16_t x; /* X-coordinate */
int16_t y; /* Y-coordinate */
int16_t w; /* Width */
int16_t h; /* Height */
} GRECT;
See also: About the AES GEM About the VDI
int32_t dma_begin ( void);
int32_t dma_end ( void );
int32_t dma_wait ( d0 = int32_t ticks_200hz );
int32_t ncr_begin ( void );
int32_t ncr_end ( void );
int32_t ncr_wait ( d0 = int32_t ticks_200hz );
} HDFUNCS;
Note: Directly before the structure (2 bytes before) lies
an int16_t, which specifies the table length in int32_ts (in this case
6). All 6 pointers lie in the system variables area and may be altered
in case of need. The internal functions for the floppy drive also jump
via the 6 pointers.
Important: The pointer hddrv_functions in the
MagX cookie may not be altered.
See also: Background-DMA in MagiC
typedef struct /* 'vers' resource definition, see Inside Mac docs */
int8_t vm; /* First part of version number in BCD */
int8_t vn; /* Second and third part of version */
/* number in BCD */
int8_t vt; /* Development: 0x20, alpha: 0x40, */
/* beta: 0x60, release: 0x80 */
int8_t vd; /* Stage of pre-release version */
int16_t region; /* Region code */
int8_t str[]; /* Two version strings */
} MacVersion;
int32_t mcb_magic; /* 'ANDR' or 'KROM' (last) */
int32_t mcb_len; /* Nett length */
int32_t mcb_owner; /* Pointer to PD structure */
int32_t mcb_prev; /* Previous block, or NULL */
int8_t mcb_data[0];
} MCB;
Note: The component mcb_magic has the value 'KROM' if no futher MCB follows, else the value 'ANDR'. In the latter case the next MCB lies mcb_len bytes behind the currrent MCB. The list is chained backwards with mcb_prev which considerably speeds up many operations.
With all memory operations the component mcb_magic is always checked, and if an error is found the system is halted immediately. For a halt due to a memory error the address of the faulty MCB as well as the data (4 LONGwords) are output. Subsequently one is asked on which
drive one would like a core dump to be saved. If one specifies a valid drive, then the whole ST memory from 0 to phystop is written to the root directory of the specified drive, and is assigned the
name '_sys_'. The file, depending on the ST model, can be up to 4 or even 16 MB long, of course.
Memory-resident programs (terminating themselves with Ptermres) now work - unlike earlier - in a way that the blocks are not released, all MCBs remain intact and continue to be used (each time one clicks in the menu-bar the free memory is output, for which the whole list is run through once and during this all MCBs are checked). Those who wish to do so can therefore release memory-resident programs (or also parts of them) subsequently.
See also: GEMDOS MagiC MD Memory management
typedef struct md
struct md *m_link; /* Pointer to next MD */
int32_t m_start; /* Start address of the block */
int32_t m_length; /* Length of the block */
BASEPAGE *m_own; /* Pointer to the basepage */
} MD;
Note: The component m_own here points to the basepage of the process to which the memory block belongs.
These structures are administered in the internal memory management of TOS (but not of MagiC!). These descriptors, as far as they are used, hang in three memory lists, namely for free blocks, occupied blocks and for the next block to be occupied (mem_rover). With the mem_rover concept one attempts to achieve that consecutive Malloc calls reserve consecutive memory if possible (this has been described as an error already elsewhere). This is intended to reduce memory segmentation.
This idea is unusable if several programs are running simultaneously and call Mallocs alternately, however. The concept implemented by Atari has the advantage that it is not sensitive to programs that run amuck, since the MDs lie is system memory, far away from user memory. A known disadvantage of the described concept is that only a very restricted number of Malloc calls are possible, since every call swallows an MD of the limited system memory; this is also massively burdened by opened folders and files. A further disadvantage of the TOS memory management: If a program overspills a memory block, i.e. writes past its end, then this generally passes completely unnoticed.
Specially in multitasking systems the danger of an overwritten memory block is very much higher than in TOS. Furthermore, the number of memory blocks required, as well as those for folders (each program has its own files and standard directories) is appreciably higher. For these resons MagiC has a completely different concept; in that there is only one memory list whose pointers point to the first MCB.
See also: About the GEMDOS MCB MPB Memory management themd
int16_t x;
int16_t y;
int16_t buttons;
int16_t kstate;
} MRETS;
See also: cpx_button cpx_m1 cpx_m2 XCONTROL
This structure describes the header of an object file in Digital Research format:
int16_t magic; /* Magical value: 0x601a */
int32_t tsize; /* Size of the TEXT segment */
int32_t dsize; /* Size of the DATA segment */
int32_t bsize; /* Size of the BSS */
int32_t ssize; /* Size of the symbol table */
int8_t reserved[10]; /* Reserved, set to zero */
} OHEADER;
typedef struct _osheader
uint16_t os_entry; /* BRAnch instruction to Reset-handler */
uint16_t os_version; /* TOS version number */
void *reseth; /* Pointer to Reset-handler */
struct _osheader *os_beg; /* Base address of the operating system */
void *os_end; /* First byte not used by the OS */
int32_t os_rsvl; /* Reserved */
GEM_MUPB *os_magic; /* GEM memory-usage parameter block */
int32_t os_date; /* TOS date (English !) in BCD format */
uint16_t os_conf; /* Various configuration bits */
uint16_t os_dosdate; /* TOS date in GEMDOS format */
/* The following components are available only as of TOS Version
1.02 (Blitter-TOS) */
int8_t **p_root; /* Base address of the GEMDOS pool */
int8_t **pkbshift; /* Pointer to BIOS Kbshift variable
(for TOS 1.00 see Kbshift) */
BASEPAGE **p_run; /* Address of the variables containing
a pointer to the current GEMDOS
process. */
int8_t *p_rsv2; /* Reserved */
/* If EmuTOS is present, then 'ETOS' */
} OSHEADER;
The structure also appears under the name SYSHDR.
| os_conf | The component os_conf contains the so-called NTSC/PAL
flag in its lowest bit; if this bit is set, then the machine has a PAL
video system, if cleared NTSC. The remaining bits contain a country
identifier, which can serve to denote the language used for menus etc.
for instance. The folowing assignments apply:
Warning: To obtain the language in use, one should fall back not to the OSHEADER if possible, but use the _AKP cookie or the function appl_getinfo (opcode 3). | ||||||
| p_root | With older TOS versions the address of p_root is 0x56FA. | ||||||
| p_run | BASEPAGE **GetRun (void) { int32_t savessp = Super (0L); OSHEADER *O = *((OSHEADER **)(0x4f2L); Super ((void *) savessp ); O = O->os_beg; /* wegen eines Fehlers in alter AHDI-Version */ if (O->os_version < 0x102) { if ((O->os_conf >> 1) == 4) /* PAL-Modus wegshiften */ return ((BASEPAGE **)0x873c); /* Spanisches TOS 1.0 */ else return ((BASEPAGE **)0x602c); } else return O->p_run; } |
See also: Kbshift _sysbase System variables System vectors
THPrint printHdl; /* Printer-configuration for NVDI */
PrSetupProc doPrintSetup; /* ditto */
VoidProcPtr saveSetup; /* ditto */
int32_t reserved[7]; /* Reserved */
} PrintDesc;
uint16_t red; /* Red proportion in parts per thousand */
uint16_t green; /* Green proportion in parts per thousand */
uint16_t blue; /* Blue proportion in parts per thousand */
} RGB_LIST;
See also: XIMG format
int32_t cdecl (*proc)(void *par);
void *user_stack;
uint32_t stacksize;
int16_t mode;
int32_t res1;
} THREADINFO;
Note: If the component user_stack is NULL, then the system will create the stack itself. When the thread terminates, the system will release the stack again automatically. The component stacksize must always be specified so that the system can set the stack pointer of the thread to the end of the stack. The supervisior-stack is set by the operating system, so that its size cannot be influenced.
The components mode and res1 are reserved for future purposes, so they should be set to the value 0 or 0L. In Solaris 2.x, for instance, one can arrest the thread up to the final start with them. The started thread executes the function proc, which is passed as a parameter to the component par (on the stack). The CPU registers d0-d2 and a0-a2 may be altered by the function.
See also: Threads in MagiC shel_write Sample code
int16_t handle;
int16_t booting;
int16_t reserved;
int16_t SkipRshFix;
void *reserve1;
void *reserve2;
void cdecl (*rsh_fix) ( int num_objs, int num_frstr, int num_frimg,
int num_tree, OBJECT *rs_object,
TEDINFO *rs_tedinfo, char *rs_strings[],
ICONBLK *rs_iconblk, BITBLK *rs_bitblk,
long *rs_frstr, long *rs_frimg, long *rs_trindex,
struct foobar *rs_imdope );
void cdecl (*rsh_obfix) ( OBJECT *tree, int curob );
int16_t cdecl (*Popup) ( char *items[], int num_items, int default_item,
int font_size, GRECT *button, GRECT *world );
void cdecl (*Sl_size) ( OBJECT *tree, int base, int slider, int num_items,
int visible, int direction, int min_size );
void cdecl (*Sl_x) ( OBJECT *tree, int base, int slider, int value,
int num_min, int num_max, void (*foo)() );
void cdecl (*Sl_y) ( OBJECT *tree, int base, int slider, int value,
void cdecl (*Sl_arrow) ( OBJECT *tree, int base, int slider, int obj,
int inc, int min, int max, int *numvar,
int direction, void (*foo)() );
void cdecl (*Sl_dragx) ( OBJECT *tree, int base, int slider,
int min, int max, int *numvar, void (*foo)() );
void cdecl (*Sl_dragy) ( OBJECT *tree, int base, int slider,
int16_t cdecl (*Xform_do) ( OBJECT *tree, int start_field, int puntmsg[] );
GRECT * cdecl (*GetFirstRect) ( GRECT *prect );
GRECT * cdecl (*GetNextRect) ( void );
void cdecl (*Set_Evnt_Mask)( int mask, MOBLK *m1, MOBLK *m2, long time );
int16_t cdecl (*XGen_Alert) ( int id );
int16_t cdecl (*CPX_Save) ( void *ptr, long num );
void * cdecl (*Get_Buffer) ( void );
int16_t cdecl (*getcookie) ( long cookie, long *p_value );
int16_t Country_Code;
void cdecl (*MFsave) ( int saveit, MFORM *mf );
} XCPB;
