| Description: |
This XBIOS function reads or changes a parameter inside the
flash eprom. The function returns the value.
| mode |
CT60_MODE_READ (0)
The value is read.
CT60_MODE_WRITE (1)
The value is write. |
| type_param |
CT60_PARAM_TOSRAM (0)
If the value is set to 1, the TOS is copied inside the SDRAM
during boot (PMMU used and cookie PMMU created). If the value is set
to 0, the TOS in flash eprom is used.
CT60_BLITTER_SPEED (1)
If the value is set to 0, the blitter runs a 8/10 MHz. If the
value is set to 1, the blitter runs a 16/20 MHz.
CT60_CACHE_DELAY (2)
If the bit 0 of the value is cleared, the Pexec function is normal
(flushes cache).
If the bit 0 of the value is set, the caches are disabled for 5
seconds when a program is started under TOS with the Pexec
function.
If the bit 1 of the value is set, there are an Fread test and
maybe a copyback alert if the code begin by $601A. With this alert you
can remove the cache during 5 seconds.
If the bit 1 of the value is cleared, there is no copyback alert.
CT60_BOOT_ORDER (3)
New boot
If the value is set to 0, TOS boots from SCSI drives (0-7)
before IDE drives (0-1).
If the value is set to 1, TOS boots from IDE drives (0-1)
before SCSI drives (0-7).
If the value is set to 2, TOS boots from SCSI drives (7-0)
before IDE drives (1-0).
If the value is set to 3, TOS boots from IDE drives (1-0)
before SCSI drives (7-0).
Old boot
If the value is set to 4, TOS boots from SCSI drives (0-7)
If the value is set to 5, TOS boots from IDE drives (0-1)
If the value is set to 6, TOS boots from SCSI drives (7-0)
If the value is set to 7, TOS boots from IDE drives (1-0)
CT60_CPU_FPU (4)
If the bit 0 of the value is cleared, the FPU is disabled.
CT60_BOOT_LOG (5)
If the bit 0 is cleared, the stdout output of the AUTO folder
files is writed inside a boot.log on the boot drive.
CT60_VMODE (6)
Boot extended modecode for CTPCI graphic card: F030 modecode +
extended bits:
| HORFLAG |
0x200 |
for double width |
| HORFLAG2 |
0x400 |
for width increased |
| VESA_600 |
0x800 |
for SVGA 600 |
| VESA_768 |
0x1000 |
for SVGA 768 |
| VERTFLAG2 |
0x2000 |
for double height |
| BPS32 |
5 |
for True Color |
CT60_SAVE_NVRAM_1 (7)
CT60_SAVE_NVRAM_2 (8)
CT60_SAVE_NVRAM_3 (9)
Reserved for TOS NVM backup, do not use.
CT60_PARAM_OFFSET_TLV (10)
value contains a signed offset in points. A point is equal
to 2.8 °C.
CT60_ABE_CODE (11)
CT60_SDR_CODE (12)
Reserved for save ABE/SDR versions, do not use.
CT60_CLOCK (13)
CTPCM boot clock frequency in KHz (65000-110000)
WARNING, if you increase frequency !!!
CT60_PARAM_CTPCI (14)
If the bit 0 of the value is cleared, the TOS boot on the native
F030 IDE port.
If the bit 0 of the value is set, the TOS boot n the CTPCI IDE
port who replaces the F030 at the same address.
If the bit 1 of the value is cleared, the VDI not use the CTPCI
PLX DMA (slower for vro_cpyfm).
If the bit 1 of the value is set, the VDI use the CTPCI PLX DMA
(faster for vro_cpyfm).
