HomeVDIEscape functionsControl functions
7.9 Colour table functions
• v_color2nearest Inquires nearest colour value
• v_color2value Translates colour value to pixel value
• v_create_ctab Creates colour table
• v_create_itab Creates inverse colour table reference
• v_ctab_idx2value Inquires colour table value
• v_ctab_idx2vdi Translates colour table index to VDI index
• v_ctab_vdi2idx Translates VDI colour index to colour table index
• v_delete_ctab Deletes colour table
• v_delete_itab Deletes inverse colour table reference
• v_get_ctab_id Gets unique ID for a new colour table
• v_value2color Translates pixel value to colour entry
• vq_ctab Inquires current colour table
• vq_ctab_entry Inquires colour table entry
• vq_ctab_id Inquires current colour table ID
• vq_dflt_ctab Inquires default (system) colour table
• vq_px_format Inquires pixel format and colour space
• vs_ctab Sets colour table
• vs_ctab_entry Sets colour value in the colour table
• vs_dflt_ctab Sets defaut (system) colour table
See also: VDI workstations   Style guidelines
7.9.1 v_color2nearest
Name: »Inquire Nearest Color Entry«
Opcode: 204 (Sub-Opcode 2)
Syntax: int32_t v_color2nearest( int16_t handle, int32_t color_space, COLOR_ENTRY *color, COLOR_ENTRY *nearest_color );
Description: The call v_color2nearest returns the nearest colour value for the desired COLOR_ENTRY.
handle Workstation identifier
color_space Colour space (at present only 0 for the colour space set, or CSPACE_RGB)
color COLOR_ENTRY of the colour
nearest_color COLOR_ENTRY of the colour
Return value: The function returns the colour value and the colour space of the nearest colour.
Availability: As of NVDI 5.00.
Group: Colour table functions
7.9.2 Bindings for v_color2nearest
C: int32_t v_color2nearest( int16_t handle, int32_t color_space, COLOR_ENTRY *color, COLOR_ENTRY *nearest_color );
                         COLOR_ENTRY *color,
   intin[0..1] = color_space;
   intin[2..5] = color;
   contrl[0] = 204;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 2;
   contrl[6] = handle;
   vdi ();
   nearest_color = intout[2..5];
   return ( (int32_t) intout[0] );
contrl contrl[0] 204 # Function opcode
contrl+2 contrl[1] 0 # Entry in ptsin
contrl+4 contrl[2] 0 # Entry in ptsout
contrl+6 contrl[3] 6 # Entry in intin
contrl+8 contrl[4] 6 # Entry in intout
contrl+10 contrl[5] 2 # Sub-opcode
contrl+12 contrl[6] handle
intin intin[0..1] color_space
intin+4 intin[2..5] color
intout intout[0..1] Return value
intout+4 intout[2..5] nearest_color
7.9.3 v_color2value
Name: »Translate colour entry to pixel value«
Opcode: 204 (Sub-Opcode 0)
Syntax: uint32_t v_color2value( int16_t handle, int32_t color_space, COLOR_ENTRY *color );
Description: The call v_color2value returns a colour value for a pixel value.
color COLOR_ENTRY of the background colour
Return value: The pixel value.
7.9.4 Bindings for v_color2value
C: uint32_t v_color2value( int16_t handle, int32_t color_space, COLOR_ENTRY *color );
   contrl[0] = 204;
   contrl[1] = 0;
   contrl[3] = 6;
   contrl[5] = 0;
   contrl[6] = handle;
   vdi ();
   return ( (uint32_t) intout[0] );
contrl+8 contrl[4] 2 # Entry in intout
contrl+10 contrl[5] 0 # Sub-opcode
7.9.5 v_create_ctab
Name: »Create colour table«
Opcode: 206 (Sub-Opcode 8)
Syntax: COLOR_TAB *v_create_ctab( int16_t handle, int32_t color_space, uint32_t px_format );
Description: The call v_create_ctab creates a colour table in the colour space color_space for a bitmap with px_format & PX_BITS bits. The colour table is initialized with the standard colours for this bit-depth. The application can write to the colour table and alter the colour entries; however if the colours are altered, one has to obtain a new ID by calling rev_get_ctab_id and enter this in the structure element . Otherwise false colours will be output.
After use the colour table can be cleared with v_delete_ctab.
px_format Pixel format (only the lower 8 bits will be evaluated, i.e. bits per pixel)
Return value: The function returns a pointer to the colour table.
7.9.6 Bindings for v_create_ctab
C: COLOR_TAB *v_create_ctab( int16_t handle, int32_t color_space, uint32_t px_format );
   intin[2..3] = px_format;
   contrl[0] = 206;
   contrl[1] = 0;
   contrl[3] = 4;
   contrl[5] = 8;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 206 # Function opcode
contrl+6 contrl[3] 4 # Entry in intin
contrl+10 contrl[5] 8 # Sub-opcode
intin+4 intin[2..3] px_format
7.9.7 v_create_itab
Name: »Create inverse colour table reference«
Opcode: 208 (Sub-Opcode 0)
Syntax: ITAB_REF v_create_itab( int16_t handle, COLOR_TAB *ctab, int16_t bits );
Description: The call v_create_itab creates an inverse colour table of the colour table passsed to it and returns a reference to it. Programs need to call this function only if they themselves manage bitmaps that are the destination of a vr_transfer_bits operation (if the off-screen bitmap is created by the VDI, i.e with v_opnbm or v_open_bm, the VDI does this automatically). See also the description of vr_transfer_bits.
ctab Pointer to colour table
bits Preferred resolution of the inverse colour table (3-5)
Return value: The function returns the reference to the inverse colour table.
7.9.8 Bindings for v_create_itab
C: ITAB_REF v_create_itab( int16_t handle, COLOR_TAB *ctab, int16_t bits );
                        int16_t bits )
   intin[0..1] = ctab;
   intin[2] = bits;
   intin[3] = 0;
   intin[4] = 0;
   contrl[0] = 208;
   contrl[1] = 0;
   contrl[3] = 5;
   contrl[5] = 0;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 208 # Function opcode
contrl+6 contrl[3] 5 # Entry in intin
intin intin[0..1] ctab
intin+4 intin[2] bits
intin+6 intin[3] 0
intin+8 intin[4] 0
7.9.9 v_ctab_idx2value
Name: »Inquire colour table value« - Return pixel value.
Opcode: 206 (Sub-Opcode 5)
Syntax: uint32_t v_ctab_idx2value( int16_t handle, int16_t index );
Description: The call v_ctab_idx2value returns the pixel value for an entry in the colour table. If the passed index is larger than the number of colour pens, then the pixel value of the colour black will be returned.
index Colour table index
Return value: The function returns the pixel value.
7.9.10 Bindings for v_ctab_idx2value
C: uint32_t v_ctab_idx2value( int16_t handle, int16_t index );
   intin[0] = index;
   contrl[0] = 206
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[5] = 5;
   contrl[6] = handle;
   vdi ();
contrl+6 contrl[3] 1 # Entry in intin
contrl+10 contrl[5] 5 # Sub-opcode
intin intin[0] index
7.9.11 v_ctab_idx2vdi
Name: »Translate VDI colour index to colour table index«
Opcode: 206 (Sub-Opcode 3)
Syntax: int16_t v_ctab_idx2vdi( int16_t handle, int16_t index );
Description: The call v_ctab_idx2vdi converts the colour table index into a VDI colour index.
index Index for the colour table
For resolutions up to 256 colours, index is the index for the COLOR_ENTRY in the current colour table and simultaneously also the actual pixel value that is entererd in the bitmap. For graphic formats with more than 256 colours, index continues to denote the entry in the colour table; the pixel value however is output by the VDI as a direct RGB value in the bitmap.
Return value: The function returns the old VDI colour index for vsl_color or similar functions
7.9.12 Bindings for v_ctab_idx2vdi
C: int16_t v_ctab_idx2vdi( int16_t handle, int16_t index );
   intin[0] = index;
   contrl[0] = 206
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[5] = 3;
   contrl[6] = handle;
   vdi ();
   return ( intout[0] );
contrl+8 contrl[4] 1 # Entry in intout
contrl+10 contrl[5] 3 # Sub-opcode
intout intout[0] Return value
7.9.13 v_ctab_vdi2idx
Name: »Translate VDI Color Index To Color Table Index«
Opcode: 206 (sub-opcode 4)
Syntax: int16_t v_ctab_vdi2idx( int16_t handle, int16_t vdi_index );
Description: The call v_ctab_vdi2idx translates the VDI colour index to a colour table index.
vdi_index Index for the colour table
Return value: The function returns the index for the colour table.
7.9.14 Bindings for v_ctab_vdi2idx
C: int16_t v_ctab_idx2vdi( int16_t handle, int16_t vdi_index );
   intin[0] = vdi_index;
   contrl[0] = 206
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[5] = 4;
   contrl[6] = handle;
   vdi ();
contrl contrl[0] 206 Function Opcode
contrl+2 contrl[1] 0 # entry in ptsin
contrl+4 contrl[2] 0 # entry in ptsout
contrl+6 contrl[3] 1 # entry in intin
contrl+8 contrl[4] 1 # entry in intout
contrl+10 contrl[5] 4
intin intin[0] vdi_index
intout intout[0] Rückgabewert
7.9.15 v_delete_ctab
Name: »Delete colour table«
Opcode: 206 (Sub-Opcode 9)
Syntax: int16_t v_delete_ctab( int16_t handle, COLOR_TAB *ctab );
Description: The call v_delete_ctab clears a colour table created with v_create_ctab.
Return value: 0: Error
1: All OK
See also: Binding   v_create_ctab
7.9.16 Bindings for v_delete_ctab
C: int16_t v_delete_ctab( int16_t handle, COLOR_TAB *ctab );
   intin[0..1] = ctab;
   contrl[0] = 206
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[5] = 9;
   contrl[6] = handle;
   vdi ();
contrl+6 contrl[3] 2 # Entry in intin
contrl+10 contrl[5] 9 # Sub-opcode
7.9.17 v_delete_itab
Name: »Delete inverse colour table reference«
Opcode: 208 (Sub-Opcode 1)
Syntax: int16_t v_delete_itab( int16_t handle, ITAB_REF *itab );
Description: The call v_delete_itab releases the memory used for an inverse colour table.
itab Reference to inverse colour table
1: All OK
7.9.18 Bindings for v_delete_itab
C: int16_t v_delete_itab( int16_t handle, ITAB_REF *itab );
   intin[0..1] = itab;
   contrl[0] = 208;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[5] = 1;
   contrl[6] = handle;
   vdi ();
contrl+6 contrl[3] 3 # Entry in intin
contrl+10 contrl[5] 1 # Sub-opcode
intin intin[0..1] itab
7.9.19 v_get_ctab_id
Name: »Get unique colour table ID« - Return unique ID for a new colour table.
Opcode: 206 (Sub-Opcode 6)
Syntax: int32_t v_get_ctab_id( int16_t handle );
Description: If a program builds up its own colour table, a unique ID has to be obtained from the VDI, so that different tables also have different IDs. v_get_ctab_id returns an ID for this case.
Return value: The function returns a unique ID for a new colour table.
7.9.20 Bindings for v_get_ctab_id
C: int32_t v_get_ctab_id( int16_t handle );
   contrl[0] = 206
   contrl[1] = 0;
   contrl[3] = 0;
   contrl[5] = 6;
   contrl[6] = handle;
   vdi ();
contrl+6 contrl[3] 0 # Entry in intin
contrl+10 contrl[5] 6 # Sub-opcode
7.9.21 v_value2color
Name: »Translate pixel value to colour entry«
Opcode: 204 (Sub-Opcode 1)
Syntax: int32_t v_value2color( int16_t handle, uint32_t value, COLOR_ENTRY *color );
Description: The call v_value2color returns the colour of a pixel value.
value Pixel value
Return value: The function returns the colour value and the set colour space.
7.9.22 Bindings for v_value2color
C: int32_t v_value2color( int16_t handle, uint32_t value, COLOR_ENTRY *color );
   intin[0..1] = value;
   contrl[0] = 204;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[5] = 1;
   contrl[6] = handle;
   vdi ();
intin intin[0..1] value
intout+4 intout[2..5] color
7.9.23 vq_ctab
Name: »Inquire current colour table«
Opcode: 206 (Sub-Opcode 0)
Syntax: int16_t vq_ctab( int16_t handle, int32_t ctab_length, COLOR_TAB *ctab );
Description: The call vq_ctab copies the current colour table, which the VDI manages under the passed handle, into the region to which ctab points. If the colour table is longer than ctab_length, then no value is returned in intout, and contrl[4] is then 0. A colour table can hold a maximum of 256 entries (as the VDI supports a maximum of 256 colour pens, there cannot be more) and hence this gives the maximum length from the size of the header plus 256 * sizeof( COLOR_ENTRY ).
ctab_length Length of memory block to which ctab points
ctab Memory block to which the colour table is copied
Return value: The function returns 0 for an error, or 1 for 'All OK'.
7.9.24 Bindings for vq_ctab
C: int16_t vq_ctab( int16_t handle, int32_t ctab_length, COLOR_TAB *ctab );
                 COLOR_TAB *ctab )
   intin[0..1] = ctab_length;
         intout points to ctab
   contrl[0] = 206;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[5] = 0;
   contrl[6] = handle;
   vdi ();
   if ( contrl[4] )
     return( 1 );                   /* All OK */
     return( 0 );
contrl+8 contrl[4] n # Entry in intout
intin intin[0..1] ctab_length
intout intout[0..n] ctab
7.9.25 vq_ctab_entry
Name: »Inquire colour table entry«
Opcode: 206 (Sub-Opcode 1)
Syntax: int32_t vq_ctab_entry( int16_t handle, int16_t index, COLOR_ENTRY *color );
Description: The call vq_ctab_entry obtains the colour space and the colour of a colour table entry.
color Holds colour of colour table entry after the call
Return value: The function returns the colour space of a colour table entry.
7.9.26 Bindings for vq_ctab_entry
C: int32_t vq_ctab_entry( int16_t handle, int16_t index, COLOR_ENTRY *color );
   intin[0] = index;
   contrl[0] = 206;
   contrl[1] = 0;
   contrl[3] = 1;
   contrl[5] = 1;
   contrl[6] = handle;
   vdi ();
   return( ( int32_t ) intout [0] );
7.9.27 vq_ctab_id
Name: »Inquire current colour table ID«
Opcode: 206 (Sub-Opcode 2)
Syntax: int32_t vq_ctab_id( int16_t handle );
Description: The call vq_ctab_id returns the ID of the current colour table for handle. From this ID a program can ascertain whether the colour table of the device that it is using has been changed.
Return value: The function returns the ID of the current colour
7.9.28 Bindings for vq_ctab_id
C: int32_t vq_ctab_id( int16_t handle );
   contrl[0] = 206;
   contrl[1] = 0;
   contrl[3] = 0;
   contrl[5] = 2;
   contrl[6] = handle;
   vdi ();
7.9.29 vq_dflt_ctab
Name: »Inquire default colour table« - Return system colour table.
Opcode: 206 (Sub-Opcode 7)
Syntax: int16_t vq_dflt_ctab( int16_t handle, int32_t ctab_length, COLOR_TAB *ctab );
Description: The call vq_dflt_ctab copies the preferred system colour table for the set colour depth into the memory block to which ctab points. If the colour table is longer than ctab_length, then no value is returned in intout, and contrl[4] is then 0. A colour table can hold a maximum of 256 entries (as the VDI supports a maximum of 256 colour pens, there cannot be more) and hence this gives the maximum length from the size of the header plus 256 * sizeof( COLOR_ENTRY ).
7.9.30 Bindings for vq_dflt_ctab
C: int16_t vq_dflt_ctab( int16_t handle, int32_t ctab_length, COLOR_TAB *ctab );
                      COLOR_TAB *ctab )
   intout zeigt auf ctab
   contrl[0] = 206;
   contrl[1] = 0;
   contrl[3] = 2;
   contrl[5] = 7;
   contrl[6] = handle;
   vdi ();
   if ( contrl[4] )
     return( 0 );
contrl+10 contrl[5] 7 # Sub-opcode
intin intin[0] ctab_length
7.9.31 vq_px_format
Name: »Inquire pixel format and colour space«
Opcode: 204 (Sub-Opcode 3)
Syntax: int32_t vq_px_format( int16_t handle, uint32_t *px_format );
Description: The call vq_px_format obtains the set pixel format and the set colour space.
px_format Holds the set pixel format after the call
Return value: The function returns the colour space set.
7.9.32 Bindings for vq_px_format
C: int32_t vq_px_format( int16_t handle, uint32_t *px_format );
   contrl[0] = 204;
   contrl[1] = 0;
   contrl[3] = 0;
   contrl[5] = 3;
   contrl[6] = handle;
   vdi ();
   px_format = intout[2..3];
contrl+8 contrl[4] 4 # Entry in intout
intout+4 intout[2..3] px_format
7.9.33 vs_ctab
Name: »Set colour table«
Opcode: 205 (Sub-Opcode 0)
Syntax: int16_t vs_ctab( int16_t handle, COLOR_TAB *ctab );
Description: The call vs_ctab copies the colour table, sets the colours in the hardware if a CLUT is present, and returns the number of set colour entries. If at all possible, programs should not change the colours of the screen!
Return value: The function returns the number of entries set.
7.9.34 Bindings for vs_ctab
C: int16_t vs_ctab( int16_t handle, COLOR_TAB *ctab );
   contrl[0] = 205;
   contrl[1] = 0;
   contrl[3] = ctab->length / 2;  /* Length of colour table / 2 */
   contrl[5] = 0;
   contrl[6] = handle;
   intin points to ctab
   vdi ();
contrl contrl[0] 205 # Function opcode
contrl+6 contrl[3] n # Entry in intin
intin intin Replace by ctab
7.9.35 vs_ctab_entry
Name: »Set colour table entry«
Opcode: 205 (sub-opcode 1)
Syntax: int16_t vs_ctab_entry( int16_t handle, int16_t index, int32_t color_space, COLOR_ENTRY *color );
Description: The call vs_ctab_entry sets a colour value in the colour table, i.e. for modes with up to 256 colours a CLUT entry will be changed. If at all possible, programs should not change the colours of the screen!
color Colour table index
7.9.36 Bindings for vs_ctab_entry
C: int16_t vs_ctab_entry( int16_t handle, int16_t index, int32_t color_space, COLOR_ENTRY *color );
   intin[0] = index;
   intin[1..2] = color_space;
   intin[3..6] = color;
   contrl[0] = 205;
   contrl[1] = 0;
   contrl[3] = 7;
   contrl[5] = 1;
   contrl[6] = handle;
   vdi ();
contrl+6 contrl[3] 7 # Entry in intin
intin+2 intin[1..2] color_space
intin+6 intin[3..6] color
7.9.37 vs_dflt_ctab
Name: »Set default colour table« - Set system colour table.
Opcode: 205 (Sub-Opcode 2)
Syntax: int16_t vs_dflt_ctab( int16_t handle );
Description: The call vs_dflt_ctab sets the system colour table for the current bit-depth.
7.9.38 Bindings for vs_dflt_ctab
C: int16_t vs_dflt_ctab( int16_t handle );
   contrl[0] = 205;
   contrl[1] = 0;
   contrl[3] = 0;
   contrl[5] = 2;
   contrl[6] = handle;
   vdi ();
