HomeProtocolsProtocolsBubbleGEM
15.1 AV protocol
The AV protocol (Accessory-Venus) was developed by Stefan Eissing and used for the first time in the alternative desktop Gemini. Since then however this protocol has been supported in many further shells (Ease, Jinnee, MagXDesk, Thing, ...).
This section describes the version of the protocol from the Gemini distribution of 29th January 1995 (Gemini 1.a). All references to 'Venus' in the following can be substituted with 'Client' or 'Server' as appropriate when using other shells.
The communication between two processes takes place with AV protocol via the exchange of (extended) AES messages, which can be allocated to one of the following categories:
Warning: Here one must point out that with a view to future operating system versions, memory blocks used for communication between various programs, or allocated via pointers, have to be global (Mxalloc function with Global flag set). Otherwise memory protection violations would arise on computers with PMMU (e.g. Atari TT030 or Falcon030).
If paths or filenames are to be included in messages, then one must always quote the absolute path (i.e. including the drive) and the drive letters must be in upper case. Paths should always end with a backslash!
With an AV_PROTOKOLL call, each application can inquire which messages are unnderstood (not all shells support the complete protocol). It would be nice if other programs too would react to this protocol. At least AV_SENDKEY is certainly easy to implement and is the only method by which keypresses can be simulated via messages.
Under normal TOS, a desk accessory that has received an AC_CLOSE message from the AES inquires of the application (with ID) 0 via AV_PROTOKOLL whether it has understood this. In a multitasking environment (MultiTOS, MiNT/N.AES or MagiC) the program need no longer have the ID 0; besides, there will be (hardly) any AC_CLOSE messages any more. In addition, not just desk accessories but also normal programs will want to communicate with the AV-Server. So what do we do?
If more than one main application can exist, then the program or the desk accessory should try to extablish contact with GEMINI. After all, the ID can be obtained with appl_find. If this fails, then one can still search for AVSERVER or the contents of the (AES) nnvironmental variable AVSERVER. The latter possibility in particular permits easy configuration from the outside. The new versions of the library VAFUNC by Stephan Gerle (available in well-sorted mailboxes) proceed in almost the same way.
See also: Messages   Drag&Drop protocol   OLGA protocol
15.1.1 AV protocol, Quoting in
Quoting in AV protocol means that filenames can optionally be enclosed in single quote-marks (e.g. 'name'). However, this is permitted only if both parties (Server and Client) are of the same mind, i.e. both understand it.
So why should one want to do this and how does it work? Let us assume that the Server sends a filename to the application which contains a space. An application that does not understand quoting will take this as two filenames having been passed instead of one, since normally spaces are used to separate filenames. But if the application does understand quoting (bit 4 in its protocol status is set), then the Server will enclose the filename with 's and the application will recognize that the space belongs to the filename. The same applies for filenames that are sent by an application to a Server, of course.
The question remains of how one sends single quote-marks. Well, such characters forming part of the filename are simply doubled up. So, for instance, Zorros hypertext will be passed as 'Zorro's hypertext'. So in such cases the same method is used as for the Drag&Drop protocol.
AV_PROTOKOLL   VA_ACC_QUOTING(a)   VA_SERVER_QUOTING(a)   VA_PROTOSTATUS   Drag&Drop protocol
15.1.2 AV functions
These messages are sent by an application to Gemini or a present AV-Server:
• AV_ACCWINDCLOSED Application has closed a window
• AV_ACCWINDOPEN Application has opened a window
• AV_ASKCONFONT Obtain the font for the console
• AV_ASKFILEFONT Obtain the font for filenames
• AV_ASKOBJECT Obtain the currently selected object
• AV_COPY_DRAGGED Provide information about a copy action
• AV_COPYFILE Copy/move files or folders
• AV_DELFILE Delete files or folders
• AV_DRAG_ON_WINDOW Provide information about moved objects
• AV_EXIT Unlink from the AV protocol
• AV_FILEINFO Display file or folder information
• AV_GETSTATUS Obtain current status
• AV_OPENCONSOLE Open the console window
• AV_OPENWIND Open a file window
• AV_PATH_UPDATE Contents of a directory was altered
• AV_PROTOKOLL Provide information about supported messages
• AV_SENDCLICK Send mouse event
• AV_SENDKEY Send keyboard event
• AV_SETWINDPOS Set position for directory window
• AV_STARTED Reply to a VA_START message
• AV_STARTPROG Start an application or file
• AV_STATUS Set current status
• AV_VIEW Load a viewer for a given filetype
• AV_WHAT_IZIT Information about position on the screen
• AV_XWIND Open a file windnow
See also: VA functions   Messages
15.1.2.1 AV_ACCWINDCLOSED
Number: 0x4726
Description: An application informs the AV-Server that a window has been closed. This is only necessary if it closed the window itself. If the window is closed due to an AC_CLOSE message, the Server knows that all windows are closed.
WORD 3 AES handle of the window
Group: AV functions
See also: AV_ACCWINDOPEN   AV protocol
15.1.2.2 AV_ACCWINDOPEN
Number: 0x4724
Description: This message can be used by an application to inform the AV-Server about its own (opened) window.
WORD 3 AES handle of the opened window
Group: AV functions
See also: AV_ACCWINDCLOSED   AV protocol
15.1.2.3 AV_ASKCONFONT
Number: 0x4714
Description: With this message an application asks the AV-Server for the font currently set for the console window.
Group: AV functions
See also: AV_ASKFILEFONT   VA_CONFONT   VA_FILEFONT   AV protocol
15.1.2.4 AV_ASKFILEFONT
Number: 0x4712
Description: Using this message the Client can request the current font used for filenames in directory windows.
Group: AV functions
See also: AV_ASKCONFONT   VA_CONFONT   VA_FILEFONT   AV protocol
15.1.2.5 AV_ASKOBJECT
Number: 0x4716
Description: Ask about the currently selected object(s). The name(s) of the selected object(s) is (are) returned. If no object is selected, the string is empty.
If several objects are selected, their names are separated by spaces.
Group: AV functions
See also: VA_OBJECT   AV protocol
15.1.2.6 AV_COPY_DRAGGED
Number: 0x4728
Description: An application tells the AV-Server that the objects that have been dragged to its window should be copied. This may be the case, e.g. if objects are dragged to the TreeView window.
WORD 3 The keyboard state ([Alternate], [Control], [Shift])
WORD 4+5 Pointer to a string which must contain the name of the destination object This HAS to be a pathname!
This message may only be used as reply to a VA_DRAGACCWIND message.
Group: AV functions
See also: VA_DRAGACCWIND   AV protocol
15.1.2.7 AV_COPYFILE
Number: 0x4755
Description: This command directs the AV-Server to copy or move certain file(s) or folder(s).
WORD 3+4 Pointer to the source file/s and folder/s
WORD 5+6 Pointer to the destination folder
WORD 7 Various flags:
  Bit 0 = Delete original (= move)
  Bit 1 = Rename copy
  Bit 2 = Overwrite destination without comment
  Bit 3 = Only create symbolic links of
          sources (bit 0 in that case
          has no meaning)
  Bit 4-15 = Reserved, always 0
Note: All further bits are reserved for future purposes.
Multiple files must be separated by space characters. Folders must include a trailing backslash '\' character!
Group: AV functions
See also: VA_FILECOPIED   AV protocol
15.1.2.8 AV_DELFILE
Number: 0x4757
Description: This command directs the AV-Server to delete certain file(s) or folder(s).
WORD 3+4 Pointer to the file(s)/folder(s) to be deleted
WORD 5-7 Reserved, always 0
Multiple files or folders must be separated by space characters. Folders must include a trailing backslash '\' character!
Group: AV functions
See also: VA_FILEDELETED   AV protocol
15.1.2.9 AV_DRAG_ON_WINDOW
Number: 0x4734
Description: An application tells the AV-Server that objects have been dragged onto one of its windows inquired for with AV_WHATIZIT.
WORD 3 X-position to which the mouse was dragged
WORD 4 Y-position to which the mouse was dragged
WORD 5 Keyboard state ([Alternate], [Control], [Shift])
WORD 6+7 Pointer to a string that contain the names of the objects
The names are the names of files, folders or drives; multiple names are separated by a space character. Names of folders or drives must include a trailing backslash '\' character!
Group: AV functions
See also: VA_DRAG_COMPLETE   VA_DRAGACCWIND   AV protocol
15.1.2.10 AV_EXIT
Number: 0x4736
Description: An application tells the AV-Server that it doesn't link into the protocol any longer.
WORD 3 AES id of the application
This message must be used, before terminating a program if the program did use AV_PROTOKOLL!
Group: AV functions
See also: appl_init   AV protocol
15.1.2.11 AV_FILEINFO
Number: 0x4753
Description: This command directs the AV-Server to display an information dialog for a given file or folder.
WORD 3+4 Pointer to file or folder name
Multiple files/folders may be separated using space characters. Folders must include a trailing backslash '\' character!
Group: AV functions
See also: VA_FILECHANGED   AV protocol
15.1.2.12 AV_GETSTATUS
Number: 0x4703
Description: An accessory asks Venus for the current status that it has given to Venus via the AV_STATUS message.
Group: AV functions
See also: AV_STATUS   AV protocol
15.1.2.13 AV_OPENCONSOLE
Number: 0x4718
Description: Venus should open the console window. If it is open already, it will be topped. This action is of use if a desk accessory is about to launch a TOS program using the system function.
Note: No GEM programs should be started by an accessory via the system function! The message should only be used if the user explicitly wants to, as otherwise it can quickly lead to confusion.
This message is only available in Gemini at present.
Group: AV functions
See also: AV_OPENWIND   AV_XWIND   VA_CONSOLEOPEN   VA_XOPEN   VA_WINDOPEN   AV_STARTPROG
15.1.2.14 AV_OPENWIND
Number: 0x4720
Description: An application directs the AV-Server to open a file window.
WORD 3+4 Pointer to the path for the window
WORD 5+6 Pointer to a string containing the wildcards for the files which should be displayed
Note: This message should only be used when the reason is clearly evident to the user.
Group: AV functions
See also: AV_OPENCONSOLE   AV_XWIND   VA_CONSOLEOPEN   VA_WINDOPEN   VA_XOPEN
15.1.2.15 AV_PATH_UPDATE
Number: 0x4730
Description: A program/accessory tells the AV-Server that the contents of a folder has been changed. The AV-Server redraws this folder if it is displayed in a window, even if subdirectories are shown.
WORD 3+4 Pointer to the complete (!) pathname
The update of "C:\" for example results in redisplaying everything on drive C:.
Group: AV functions
See also: AV_OPENWIND   AV_XWIND   AV protocol
15.1.2.16 AV_PROTOKOLL
Number: 0x4700
Description: This message should be used to ask an application or the AV-Server whether or which messages are supported.
WORD 3 Bit 0 = VA_SETSTATUS
  Bit 1 = VA_START
  Bit 2 = AV_STARTED
  Bit 3 = VA_FONTCHANGED
  Bit 4 = Provides & uses filename quoting
  Bit 5 = VA_PATH_UPDATE
  Bit 6-15 = Reserved, always 0
WORD 4+5 Reserved, always 0
WORD 6+7 A pointer to the name of the desk
  accessory/application for use with
  appl_find (aligned to 8 characters
  and terminated by a '\0' byte).
Group: AV functions
See also: AV_STARTED   VA_FONTCHANGED   VA_SETSTATUS   VA_START
15.1.2.17 AV_SENDCLICK
Number: 0x4709
Description: An application sends a mouse event to the AV-Server.
WORD 3 ev_mmox
WORD 4 ev_mmoy
WORD 5 ev_mmobutton
WORD 6 ev_mmokstate
WORD 7 ev_mbreturn
Group: AV functions
See also: evnt_button   evnt_multi
15.1.2.18 AV_SENDKEY
Number: 0x4710
Description: Using this message a Client can send the AV-Server any key events it may not use for itself.
WORD 3 Keyboard state (ev_mmokstate)
WORD 4 Scan code of the pressed key (ev_mkreturn)
As an unofficial extension ('CodeAlpha') there is a concept that allows ASCII characters for which no scancode exists to be passed as well. For this one passes 0 for the scancode, the desired ASCII value and in msg[5] the value $5048 (the latter to indicate that msg[4] is indeed valid and that no conversion via the scancode tables is required.
This message should always be supported If possible, as with its help trans-application window cycling can be realised, for instance.
Group: AV functions
See also: evnt_keybd   evnt_multi   Scancode table
15.1.2.19 AV_SETWINDPOS
Number: 0x4759
Description: With this the Client can be informed of the position and size of the next directory window to be opened by the AV-Server (with AV_XWIND or AV_OPENWIND).
WORD 3 X-position
WORD 4 Y-position
WORD 5 Width of window
WORD 6 Height of window
WORD 7 Reserved, always 0
The coordinates are given in absolute coordinates. If AV_XWIND tops an existing window rather than opening a new window, this message has no effect!
Group: AV functions
15.1.2.20 AV_STARTED
Number: 0x4738
Description: A Client informs the AV-Server it has received and understood the VA_START message and the memory reserved for the command line can be released.
WORD 3+4 Pointer to the command line containing path or filename received by VA_START; can also be NULL.
To recognize which VA_START message is being dealt with, the values of VA_START are returned.
Group: AV functions
See also: VA_START   AV protocol
15.1.2.21 AV_STARTPROG
Number: 0x4722
Description: An application requests the AV-Server to start a program (or file).
WORD 3+4 Pointer to the program's name (with complete path!)
WORD 5+6 Pointer to the command line for the program (may be NULL)
WORD 7 Any 16-bit WORD, which will be returned by VA_PROGSTART
In Gemini the installed applications are also taken into account. This makes it possible to specify a file for which a program is then searched for.
Group: AV functions
See also: VA_PROGSTART   AV protocol
15.1.2.22 AV_STATUS
Number: 0x4704
Description: An accessory can give its current state to Venus, which will store it in the INF-file and can be restored using AV_GETSTATUS. Before sending AV_STATUS it must send AV_PROTOKOLL to Venus!
WORD 3+4 A pointer to a string, which must not contain any control characters and must not be longer than 256 characters; the pointer may be NULL
The application must first have registered itself with the Server via AV_PROTOKOLL.
Group: AV functions
See also: AV_GETSTATUS   AV_PROTOKOLL   AV protocol
15.1.2.23 AV_VIEW
Number: 0x4751
Description: The AV-Server calls the viewer for a specific file.
WORD 3+4 Pointer to the name of the file to be displayed (only a single file is allowed!)
WORD 5 0 = Calls the viewer
  1 = Calls the editor
WORD 6-7 Reserved, always 0
Note: Only a single file may be specified. If no suitable viewer is available, an error-message will be returned to the user.
Group: AV functions
See also: VA_VIEWED   AV protocol
15.1.2.24 AV_WHAT_IZIT
Number: 0x4732
Description: A Client requests details about what is located at a given position of the screen.
WORD 3 X-coordinate
WORD 4 Y-coordinate
The coordinates are the normal VDI coordinates (the origin is the left upper corner of the screen).
Group: AV functions
See also: VA_THAT_IZIT   AV protocol
15.1.2.25 AV_XWIND
Number: 0x4740
Description: Thing opens a directory window, similar to AV_OPENWIND except additional options are available:
WORD 3+4 Pointer to the path for opening directories
WORD 5+6 Pointer to the mask (wildcard) for the available files
WORD 7 Bit-mask:
  0x0001 = Use current top window, if available
  0x0002 = Use wildcard for object selection
  0x0004 = Continue using existing window
  All other bit must be set to zero.
Group: AV functions
See also: AV_OPENCONSOLE   AV_OPENWIND   VA_CONSOLEOPEN   VA_WINDOPEN   VA_XOPEN   AV protocol
15.1.3 VA functions
These messages are sent by Gemini or other present AV-Server to an application:
• VA_ACC_QUOTING(a) Test accessory protocol status for quoting
• VA_CONFONT Convey font of the console
• VA_CONSOLEOPEN Convey whether the console window is open
• VA_COPY_COMPLETE Reply to AV_COPY
• VA_DRAGACCWIND Objects were dragged to application's window
• VA_DRAG_COMPLETE AV_DRAG_ON_WINDOW action is completed
• VA_FILECHANGED Reply to AV_FILEINFO.
• VA_FILECOPIED Reply to AV_COPYFILE.
• VA_FILEDELETED Reply to AV_DELFILE.
• VA_FILEFONT Convey font for file window
• VA_FONTCHANGED A set font has been changed
• VA_OBJECT Returns the names of the selected objects
• VA_PATH_UPDATE Contents of a directory have changed
• VA_PROGSTART Information about whether a program could be started
• VA_PROTOSTATUS Reply to AV_PROTOKOLL.
• VA_SERVER_QUOTING(a) Test Server protocol status for quoting
• VA_SETSTATUS Convey status of an application
• VA_START An application has been activated
• VA_THAT_IZIT Provides information about object at screen position
• VA_VIEWED Reply to AV_VIEW.
• VA_WINDOPEN Conveys whether the console window is open
• VA_XOPEN Conveys whether a window could be opened
See also: AV functions
15.1.3.1 VA_ACC_QUOTING(a)
This is a test of the protocol status of an accessory for quoting.
In C the test may be realized as a macro as follows:
#define VA_ACC_QUOTING(a)   ((a) & 0x10)
15.1.3.2 VA_CONFONT
Number: 0x4715
Description: Gives the currently selected font for the console window. Valid are:
WORD 3 Console font (ID)
WORD 4 Console font size (points)
Group: VA functions
See also: AV_ASKCONFONT   AV_ASKFILEFONT   VA_FILEFONT
15.1.3.3 VA_CONSOLEOPEN
Number: 0x4719
Description: Returns the state of the console window (whether it has been topped or opened). Valid are:
WORD 3 0 = Not topped/opened
  <> 0 = Is topped
Group: VA functions
See also: AV_OPENCONSOLE   AV protocol
15.1.3.4 VA_COPY_COMPLETE
Number: 0x4729
Description: This message is a direct reply to AV_COPY_DRAGGED. Valid are:
WORD 3 State of the copying process
!= 0 means that something really was copied or moved. This may be useful if a window has to be redrawn.
Group: VA functions
See also: AV_COPY_DRAGGED   AV protocol
15.1.3.5 VA_DRAGACCWIND
Number: 0x4725
Description: The AV-Server (e.g. Thing) sends a message to the Client sharing the information that one or more object/s has/have been dragged to its window that was notified with AV_ACCWINDOPEN. Valid are:
WORD 4 X-position of the mouse
WORD 5 Y-position of the mousee
WORD 6+7 Pointer to a string containing the names of the objects.
Group: VA functions
See also: AV_ACCWINDOPEN   AV_ACCWINDCLOSED   AV_DRAG_ON_WINDOW
15.1.3.6 VA_DRAG_COMPLETE
Number: 0x4735
Description: Reply to AV_DRAG_ON_WINDOW message. The AV-Server informs an application that the action that was triggered by AV_DRAG_ON_WINDOW has terminated.
WORD 3 Status of the action
A value <> 0 means that something was really copied or moved; the application may use this for building up a window anew
The returned value corresponds to the one that is also returned for VA_COPY_COMPLETE.
Group: VA functions
See also: AV_DRAG_ON_WINDOW   VA_DRAGACCWIND   AV protocol
15.1.3.7 VA_FILECHANGED
Number: 0x4754
Description: Reply to AV_FILEINFO sent by the AV-Server to the Client.
WORD 3+4 Pointer to the name of a file/folder, passed via AV_FILEINFO, which can naturally contain a new file/folder name
Note: One should heed that the user may have altered the name in the dialog and therefore it is possible that the string reachable via words 3+4 will no longer match that of AV_FILEINFO.
Group: VA functions
See also: AV_FILEINFO   AV protocol
15.1.3.8 VA_FILECOPIED
Number: 0x4756
Description: Reply to AV_COPYFILE message sent by the AV-Server to the Client.
WORD 3 0 = Error
  1 = All OK
WORD 4-7 Reserved, always 0
Group: VA functions
See also: AV_COPYFILE   AV protocol
15.1.3.9 VA_FILEDELETED
Number: 0x4758
Description: Reply to AV_DELFILE from the AV-Server to the Client.
WORD 3 0 = Error
  1 = All OK
Group: VA functions
See also: AV_DELFILE   AV protocol
15.1.3.10 VA_FILEFONT
Number: 0x4713
Description: The Server returns the ID and size (in points) of the current font used for filenames in directory windows.
WORD 3 ID of font (vst_font)
WORD 4 Size in points (vst_point)
Group: VA functions
See also: AV_ASKCONFONT   AV_ASKFILEFONT   VA_CONFONT
15.1.3.11 VA_FONTCHANGED
Number: 0x4739
Description: The AV-Server informs an application that one of its set fonts has been changed. Valid are:
WORD 3 ID of the font used for directories (vst_font)
WORD 4 Size in points for font used in directories (vst_point)
WORD 5 ID of the font used in the console window (vst_font)
WORD 6 Size in points for font used in the console window (vst_point)
The message is sent to all applications that have previously enquired about a font from the AV-Server.
Group: VA functions
15.1.3.12 VA_OBJECT
Number: 0x4717
Description: Return the currently selected object(s).
WORD 3+4 Pointer to a command line with the name(s) of the selected object(s)
Group: VA functions
See also: AV_ASKOBJECT   AV protocol
15.1.3.13 VA_PATH_UPDATE
Number: 0x4760
Description: With this message the AV-Server informs a Client that the contents of a directory have changed.
WORD 3+4 Pointer to the directory
The specified directory always includes a trailing backslash '\' character. The Client has to first establish via AV_PROTOKOLL that the Server supports this message, and informs the Server whenever it changes the contents of a directory or subdirectory. The Client should then re-read all affected directories and subdirectories, closing any subdirectories which no longer exist if necessary.
Group: VA functions
See also: AV_PROTOKOLL   AV protocol
15.1.3.14 VA_PROGSTART
Number: 0x4723
Description: The AV-Server informs an application whether a specified program was started.
WORD 3  0  = Error
  <>0 = Program started
WORD 4 Return code of the program (where available)
WORD 7 16-bit WORD from AV_STARTPROG
In general the application will receive a message immediately in case of error; but if the program is started, then the application receives this message only after the start of the program, since the routine which executes the Pexec can no longer know that an application still has to get a message quickly. With a GEM program one can recognize a success also from the AC_CLOSE message.
The error recognition unfortunately is sub-optimal; furthermore the return value does not indicate whether the program has run free of error.
Group: VA functions
See also: AV_STARTPROG   VA_START   AV protocol
15.1.3.15 VA_PROTOSTATUS
Number: 0x4701
Description: Tells the sender of AV_PROTOKOLL that the application knows something about the VA protocol. The words 3-7 of the message buffer contain information about which messages are understood.
WORD 3 Bit 0 = AV_SENDKEY
  Bit 1  = AV_ASKFILEFONT
  Bit 2  = AV_ASKCONFONT, AV_OPENCONSOLE
  Bit 3  = AV_ASKOBJECT
  Bit 4  = AV_OPENWIND
  Bit 5  = AV_STARTPROG
  Bit 6  = AV_ACCWINDOPEN, AV_ACCWINDCLOSED
  Bit 7  = AV_STATUS, AV_GETSTATUS
  Bit 8  = AV_COPY_DRAGGED
  Bit 9  = AV_PATH_UPDATE, AV_WHAT_IZIT, AV_DRAG_ON_WINDOW
  Bit 10 = AV_EXIT
  Bit 11 = AV_XWIND
  Bit 12 = VA_FONTCHANGED
  Bit 13 = AV_STARTED
  Bit 14 = Quoting of filenames is
           understood and used
  Bit 15 = AV_FILEINFO
WORD 4 Bit 0 = AV_COPYFILE
  Bit 1 = AV_DELFILE
  Bit 2 = AV_VIEW
  Bit 3 = AV_SETWINDPOS
  Bit 4 = Permits creation of symbolic links
      with AV_COPYFILE
  Bit 5 = AV_SENDCLICK
WORD 5 Reserved, always 0
WORD 6+7 Pointer to the program names of the Servers, prepared for appl_find (8 characters long and NULL-terminated).
If a bit is set, the message (group) is supported. All other bits are reserved for future use and should be set to zero (all unused bits of words 4 and 5 too).
Group: VA functions
15.1.3.16 VA_SERVER_QUOTING(a)
This is a test of the protocol status of a Server for quoting.
#define VA_SERVER_QUOTING(a)  ((a) & 0x40)
15.1.3.17 VA_SETSTATUS
Number: 0x4705
Description: The AV-server tells an accessory about its stored state as a reply to AV_GETSTATUS. The state can be set by the accessory.
WORD 3+4 Pointer to the saved string or NULL if no information is available.
The returned status can be set subsequently by the application.
Group: VA functions
See also: AV_GETSTATUS   AV protocol
15.1.3.18 VA_START
Number: 0x4711
Description: Using this message an AV-Server passes parameters to desktop accessories or parallel running applications.
WORD 3+4 A pointer to the command line, which may be NULL. The command line contains paths or filenames.
Group: VA functions
See also: AV_STARTPROG   AV_STARTED   VA_PROGSTART
15.1.3.19 VA_THAT_IZIT
Number: 0x4733
Description: The AV-Server tells an application on request what object is placed at a given position on the screen.
WORD 3 ID of the appropriate application
WORD 4 Object type:
  VA_OB_UNKNOWN   (0) = Unknown
  VA_OB_TRASHCAN  (1) = Trash can
  VA_OB_SHREDDER  (2) = Shredder
  VA_OB_CLIPBOARD (3) = Clipboard
  VA_OB_FILE      (4) = File
  VA_OB_FOLDER    (5) = Folder
  VA_OB_DRIVE     (6) = Drive
  VA_OB_WINDOW    (7) = Window
  VA_OB_NOTEPAD   (8) = Notepad
  VA_OB_NOTE      (9) = Note
WORD 5+6 Pointer to the name of the object(s), or NULL if there was nothing.
All other values are reserved for future purposes.
Group: VA functions
See also: AV_WHAT_IZIT   AV protocol
15.1.3.20 VA_VIEWED
Number: 0x4752
Description: Reply to AV_VIEW from the AV-Server to the Client.
WORD 3 0 = Error
  1 = All OK
The Server informs the Client whether the file will be displayed or not. The answer is immediate and always sent out if an error occured. Otherwise, in a multitasking environment, the answer is received as soon as the viewer is topped (made active), Under Single-TOS the answer is received after exiting the viewer, in the case that the Server had not already been ended.
Group: VA functions
See also: AV_VIEW   AV protocol
15.1.3.21 VA_WINDOPEN
Number: 0x4721
Description: Returns the state of the file window (see VA_CONSOLEOPEN).
Group: VA functions
See also: AV_OPENCONSOLE   VA_CONSOLEOPEN   AV protocol
15.1.3.22 VA_XOPEN
Number: 0x4741
Description: Reply to AV_XWIND, similar to VA_WINDOPEN. The AV-Server informs an application whether a given window could be opened.
WORD 3 0 = no
  <> 0 = Window opened and the directory
  completely read i.e. an available
  window could be topped.
Group: VA functions
See also: AV_OPENWIND   AV_XWIND   VA_WINDOPEN
