TF536 Rev 2 Design Complete (all gone)
68030 + SDRAM + IDE
8 Bit Dreams
Moderator Team
Moderator Team
Re: TF536 Rev 2 Design Complete (all gone)
Post by 8 Bit Dreams »
Ok, will do it and report here :)
Ok, tried to pull pin1 high, amiga boots but ide isn't working,
Pulling pin1 low doesn't allow card to work, power led remains dimmed...
8 Bit Dreams wrote: 28 Apr 2020 13:45 Ok, will do it and report here :)
Did you make sure to lift the pin off the pad? otherwise you short IOR high.
Yes if you set it low then its not gonna boot thinking about it.. Just to be sure this is pin 1....
8 Bit Dreams wrote: 29 Apr 2020 22:17 Yes, Pin1 is lifted and connected to Pin8.. :?
Sorry no just lift it and connect it to pin 2. Sorry if the Diagram is misleading.
Subzero79
Post by Subzero79 »
Today recieved parts from mouser ,pcb not arrived yet
Ordered some goof flux and kester solder wire
PaulJ_2.0
Post by PaulJ_2.0 »
terriblefire wrote: 29 Apr 2020 22:57 Sorry no just lift it and connect it to pin 2. Sorry if the Diagram is misleading.
Aren't pin1 and pin2 connected?
PaulJ_2.0 wrote: 30 Apr 2020 17:05
No thats my corrected schematic... ignore the picture except for orientation.
PaulJ_2.0
Post by PaulJ_2.0 »
terriblefire wrote: 30 Apr 2020 17:09 No thats my corrected schematic... ignore the picture except for orientation.
Ah!
As you were then Sir :)
PaulJ_2.0 wrote: 30 Apr 2020 17:14 As you were then Sir :)
Its very confusing but lift pin 1 and attach it to pin 2 and nothing else. Essentially DIR pin should not be attached to IOR, That was a mistake.
8 Bit Dreams
Moderator Team
Moderator Team
Ok here is my update:
done like Stephen said (lifted Pin1 and connected it to Pin2) - card is fully working now!
Thumbs up!🖒🖒
Subzero79
Post by Subzero79 »
u removed all rns underside the ide and polulate ics? plus lift pin 1 and tie to high
Return to “TF536”
Users browsing this forum: ClaudeBot, semrush [bot] and 5 guests
