TF536 Rev 2 Design Complete (all gone)
8 Bit Dreams
- Moderator Team
Re: TF536 Rev 2 Design Complete (all gone)
Ok, will do it and report here :)
Ok, tried to pull pin1 high, amiga boots but ide isn't working,
Pulling pin1 low doesn't allow card to work, power led remains dimmed...
- Admin sponsor
Did you make sure to lift the pin off the pad? otherwise you short IOR high.8 Bit Dreams wrote: 28 Apr 2020 13:45 Ok, will do it and report here :)
Yes if you set it low then its not gonna boot thinking about it.. Just to be sure this is pin 1....
- Admin sponsor
Sorry no just lift it and connect it to pin 2. Sorry if the Diagram is misleading.
Subzero79
Today recieved parts from mouser ,pcb not arrived yet
Ordered some goof flux and kester solder wire
PaulJ_2.0
Aren't pin1 and pin2 connected?terriblefire wrote: 29 Apr 2020 22:57 Sorry no just lift it and connect it to pin 2. Sorry if the Diagram is misleading.
- Admin sponsor
No thats my corrected schematic... ignore the picture except for orientation.PaulJ_2.0 wrote: 30 Apr 2020 17:05Aren't pin1 and pin2 connected?terriblefire wrote: 29 Apr 2020 22:57 Sorry no just lift it and connect it to pin 2. Sorry if the Diagram is misleading.
PaulJ_2.0
Ah!terriblefire wrote: 30 Apr 2020 17:09 No thats my corrected schematic... ignore the picture except for orientation.
As you were then Sir :)
- Admin sponsor
Its very confusing but lift pin 1 and attach it to pin 2 and nothing else. Essentially DIR pin should not be attached to IOR, That was a mistake.
8 Bit Dreams
- Moderator Team
Ok here is my update:
done like Stephen said (lifted Pin1 and connected it to Pin2) - card is fully working now!
Thumbs up!🖒🖒
Thumbs up!🖒🖒
Subzero79
u removed all rns underside the ide and polulate ics? plus lift pin 1 and tie to high
Users browsing this forum: ClaudeBot, OAI-Search [Bot] and 2 guests
