BOOKMARK THIS PAGE !
USB mouse issue
alenppc
- Moderator Team
Re: USB mouse issue
Yeah, the TF riser is not ready to be sold.
arkadiusz.makarenko
- Moderator Team
Re: USB mouse issue
I have spent substantial amount of time trying to tweek firmware to make it more reliable but I wasn't able to make it work on some machines.
This issue most likely would require new PCB or even different approach
~ Stanislaw Lem
~ Stanislaw Lem
NeilDeWheel
Re: USB mouse issue
I bought it from a seller on Amibay, https://www.amibay.com/threads/amiga-cd ... st-2518496
arkadiusz.makarenko
- Moderator Team
Re: USB mouse issue
I would recommend you to contact the seller about the issue.NeilDeWheel wrote: 11 Nov 2024 20:43 I bought it from a seller on Amibay, https://www.amibay.com/threads/amiga-cd ... st-2518496
~ Stanislaw Lem
~ Stanislaw Lem
Re: USB mouse issue
I don't know if it's related but on my 1200 the usb-mouse (tom/jerry) was always 'clicking' randomly, even after updating it's firmware (which was supposed to fix it) I did a lot of research online and found a fix, it was replacing the inductors on the mouse port with values from the a4000 motherboard. This fixed it on my a1200. Sorry if unrelated!
arkadiusz.makarenko
- Moderator Team
Re: USB mouse issue
Unfortunately issue is between the riser and the chipset.Steve wrote: 12 Nov 2024 10:39 I don't know if it's related but on my 1200 the usb-mouse (tom/jerry) was always 'clicking' randomly, even after updating it's firmware (which was supposed to fix it) I did a lot of research online and found a fix, it was replacing the inductors on the mouse port with values from the a4000 motherboard. This fixed it on my a1200. Sorry if unrelated!
~ Stanislaw Lem
~ Stanislaw Lem
Users browsing this forum: CCBot and 2 guests
