BOOKMARK THIS PAGE !
USB mouse issue
TF CD32 Riser
alenppc
Moderator Team
Moderator Team
Re: USB mouse issue
Post by alenppc »
Yeah, the TF riser is not ready to be sold.
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: USB mouse issue
Post by arkadiusz.makarenko »
I have spent substantial amount of time trying to tweek firmware to make it more reliable but I wasn't able to make it work on some machines.
This issue most likely would require new PCB or even different approach
~ Stanislaw Lem
NeilDeWheel
Re: USB mouse issue
Post by NeilDeWheel »
I bought it from a seller on Amibay, https://www.amibay.com/threads/amiga-cd ... st-2518496
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: USB mouse issue
NeilDeWheel wrote: 11 Nov 2024 20:43 I bought it from a seller on Amibay, https://www.amibay.com/threads/amiga-cd ... st-2518496
I would recommend you to contact the seller about the issue.
~ Stanislaw Lem
Re: USB mouse issue
I don't know if it's related but on my 1200 the usb-mouse (tom/jerry) was always 'clicking' randomly, even after updating it's firmware (which was supposed to fix it) I did a lot of research online and found a fix, it was replacing the inductors on the mouse port with values from the a4000 motherboard. This fixed it on my a1200. Sorry if unrelated!
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: USB mouse issue
Steve wrote: 12 Nov 2024 10:39 I don't know if it's related but on my 1200 the usb-mouse (tom/jerry) was always 'clicking' randomly, even after updating it's firmware (which was supposed to fix it) I did a lot of research online and found a fix, it was replacing the inductors on the mouse port with values from the a4000 motherboard. This fixed it on my a1200. Sorry if unrelated!
Unfortunately issue is between the riser and the chipset.
~ Stanislaw Lem
Return to “TF CD32 Riser”
Users browsing this forum: CCBot and 4 guests
