USB mouse issue
TF CD32 Riser
tlt
USB mouse issue
Post by tlt »
Hi, I built a couple of TF CD32 Risers a while back and now I have gotten around to try them out some more. I have an issue with USB mouse. The pointer is jumping down or right and than back again really fast, it also randomly clicks. I have tried different risers and mice and the behavior is the same. Is this a known issue? Can I fix it somehow?
I'm trying finish my Amiga CF32 ;)
Amiga CF32.jpg (258.92 KiB) Viewed 3880 times
!Message from: Moderator
@tlt, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
arkadiusz.makarenko
Re: USB mouse issue
Post by arkadiusz.makarenko »
Unfortunately no, some setups, some cd32 with usb riser and mainly tf330 just don't work, and I don't know why.
~ Stanislaw Lem
tlt
Re: USB mouse issue
Post by tlt »
Ok, let me know if there is any testing or troubleshooting I can help out with.
Re: USB mouse issue
tlt wrote: Sun Sep 04, 2022 10:45 am Ok, let me know if there is any testing or troubleshooting I can help out with.
@arkadiusz.makarenko you made some performance improvements for the TFMSX... could this be applied to the riser too?
alenppc
Re: USB mouse issue
Post by alenppc »
This is a known issue. We tried to debug it a while back, you might even find the thread somewhere. The mouse only works with the tf328/tf360 but not 330. So you should use an Amiga mouse instead…
tlt
Re: USB mouse issue
Post by tlt »
I tried to test without the TF330 and then the mouse does not work at all. Kind of hard to test as I usually boot from CF on the TF330 so I mostly tested in the boot menu and booted a cd.
alenppc
Re: USB mouse issue
Post by alenppc »
I don’t think I ever tried it without any accelerator, the original firmware didn’t work on 020 either (tf328), but Arek fixed that. It was just the 030 that proved difficult to fix.
arkadiusz.makarenko
Re: USB mouse issue
terriblefire wrote: Sun Sep 04, 2022 10:54 am
I started rewriting firmware, but I don't think I completed it. Need to check it was while back.
~ Stanislaw Lem
NeilDeWheel
Re: USB mouse issue
Post by NeilDeWheel »
Hi all,
Was this jumping mouse issue fixed? I just bought a tf riser and am having the jumping mouse issue.
Thanks.
Re: USB mouse issue
NeilDeWheel wrote: Mon Nov 11, 2024 2:50 pm Hi all,
Thanks.
Hey, Who is selling the TF riser? Its still very much alpha.
Return to “TF CD32 Riser”
