Thanks, but I have a feeling that the hardest is to come...
PAK 68/3 in STE
Re: PAK 68/3 in STE
Re: PAK 68/3 in STE
Finally got it !
The trick was to leave the blitter in its socket while fitting the PAK (and exxos' adapter).
This is weird as it is recommended to disable and remove it in the Mega ST...
ACSI (Ultrasatan) and FDD works great now.
Sysinfo shows 48Mhz but the actual oscillator is only 32 Mhz.
Results are quite impressive with Gembench:
Next step is to try higher oscillator values.
Re: PAK 68/3 in STE
With a 40 Mhz oscillator:
Re: PAK 68/3 in STE
Unfortunately, I have bombs at 50 Mhz...
It might be too much for the Ultrasatan.
Got to try with IDE next week.
That's all for today I think.
8-)
8-)
Re: PAK 68/3 in STE
Just forgot a bench in Medium Res:
Darklord
Re: PAK 68/3 in STE
Well done.
I didn't have to worry about the blitter in my Pak 68/3 equipped STacy
because it doesn't have one. One less thing to worry about for me. :)
IIRC, when I was testing after first installing my Pak (and getting it
working), Sysinfo did report some strange speeds. I'll run it again
and see if I'm remembering correctly and report back here.
Darklord
Re: PAK 68/3 in STE
Okay, I did remember correctly. Sysinfo also reports my Pak 68/3 incorrectly here as well. It should be 40mhz.
Just for comparison, I ran Gembench on my Pak 68/3 board as well. Again, this is at 40mhz, both CPU and FPU.
Just to show what a difference NVDI makes: :)
Rustynutt
Re: PAK 68/3 in STE
SYSINFO reports my Afterburner at 32MHz, but it's clocked at 46. :)
Re: PAK 68/3 in STE
@Darklord
Yes, NVDI is really good.
@Rustynutt
Centek bench shows the right speed, but Sysinfo has a quirk.
@Rustynutt
Re: PAK 68/3 in STE
Didn't have really much time today, but tried Badwolf's adapter with the 5 SILs (3.3k) soldered to it.
Result: no go with my PAK68.
Don't know if it's worth checking with 4.7k SILs (same values as on exxos' adapter), but I might try later as I have other projects pending now.
If @Badwolf has some clues. it would be great as his adapter is really good with other configurations.
