mrbomberzilly's MegaST maintenance
Hi all,
I've been doing some maintenance on @mrbombermillzy's MegaST. This is the board he has been doing dual-shifter research with and wanted it to be given some love. Here is the work I've been doing to it.
This is a Mega ST4 with C100167-001 Rev B motherboard
The Mega ST (please correct me if I'm wrong) has this little PCB which I think is called the 'blitter patch'. I haven't worked on a Mega ST before so I might be wrong, but either way that little board will need to come off. @mrbombermillzy wants the CPU to be socketed. It would be silly to have this blitter patch board soldered to the CPU, because if he removes the CPU to add an accelerator etc, then the blitter board would come off with the old CPU. So I'll have to work out a creative way to keep it attached to the motherboard.
Removal of blitter patch, will use the heat gun for this.
Always a good idea to add new solder to anything that needs to be removed on these old boards, this helps when using the solder removal tool and allows the old solder to be removed much more easily, protecting the pads and vias.
CPU socket is now removed
New CPU socket fitted
I'm going to attempt to fit the blitter patch board INSIDE the CPU socket, here I am chipping away at the plastic between pins 12-18.
Blitter patch before fitting
Blitter patch fitting nicely in the area
Now I carefully add wires to the pins
Now the blitter patch is fully installed within the CPU socket
Here is another photo angle of it installed
I was kind of hoping that there would be enough clearance for the CPU to fit in with the blitter patch board underneath it. This didn't turn out to be the case, so I added another layer of turn pin socket headers to give the CPU enough clearance.
CPU re-installed
The dual-shifter board does not seem to sit level!
The shifter board seems to be hitting the DMA chip. The DMA chip is so high because it is socketed. I will remove the socket for the DMA and solder it directly into the motherboard to give the shifter board enough clearance.
Here is the underside of the shifter board, it is using turn-pin PCB pins, so I will change the motherboard socket to turn-pin in order to give the shifter board a much more stable connection.
DMA removed
Argh!!! My solder sucker keeps getting clogged up on the REAR side, how frustrating!!
Re: mrbomberzilly's MegaST maintenance
DMA and shifter sockets removed
DMA resoldered, new socket for shifter.
Shifter board now sits flush, perfect!
Side view, lots of clearance now!
Time to socket the bus and address resistor networks. I always like to SOCKET them because many accelerators sometimes include pull-ups, so in some cases you don't want any on the motherboard. Other times it's good to be able to experiment with different resistor values.
Socket these too
Sockets fitted 1
Sockets fitted 2
Bus resistors re-installed 1
Bus resistors re-installed 2
Time to re-cap the motherboard! 1
Time to re-cap the motherboard! 2
Time to re-cap the motherboard! 3
Time to re-cap the motherboard! 4
The monitor port seems really iffy and not always outputting stable, so I'll swap it for a brand new one
Monitor port replacement:
If there is a later version of the blitter, then you don't even need the patch :)
exxos wrote: 02 Oct 2022 18:17 If there is a later version of the blitter, then you don't even need the patch :)
Ahh, knowledge sure is power ;D
@exxos The blitter says: S8918 / MM9092V. I don't know if this is old or not. Either way, no harm to having the patch fitted is there? I assume the patch was fitted with this blitter being the one originally installed in the machine.
Steve wrote: 02 Oct 2022 18:24 @exxos The blitter says: S8918 / MM9092V. I don't know if this is old or not. Either way, no harm to having the patch fitted is there? I assume the patch was fitted with this blitter being the one originally installed in the machine.
Have a look towards the bottom of the page https://exxosforum.co.uk/atari/last/MEGAST/index.htm
Not exactly sure on the brand, the logo looks like 'SS'. By the date code it's probably a newer blitter. All seems fine either way, just ran gem bench. Might ask @mrbombermillzy if he wants me to burn him a newer TOS EPROM since he's running 1.02.
DoG
Post by DoG »
Very nice documentation of all the work as usual. Much appreciated! I have four Mega ST. Here is my part bin full of the patches...
mrbombermillzy
Post by mrbombermillzy »
It seems while I've been busy away from the computer, @Steve has gone ahead and done all the necessary work already.
Thank you. Looks great, especially the tricky blitter inner CPU DIP patch. :dualthumbup:
Hopefully the machine is a bit more sturdy for its use with the twin shifter board and later a ST536.
viking272
Post by viking272 »
mrbombermillzy wrote: 02 Oct 2022 19:42 It seems while I've been busy away from the computer, @Steve has gone ahead and done all the necessary work already.
Great work @Steve!
ST536 sounds great @mrbombermillzy
Users browsing this forum: apple [bot], Badwolf, Baidu [Spider], ClaudeBot, exxos, Google [Bot] and 11 guests
