If we are talking about p4 of my schematics ("U102 U103 - EPROMS"), the pin 2 of the eproms is named "A16", and is wired to "A16_SELECT" that goes to W104 and then connected either to GND or A17 of the address bus. So in fact all is normal on your board :)Groppo91 wrote: 30 Mar 2022 14:39 Based on the schematics provided sporniket I am finding the Address pins wrong on my board:
Pin 2 says it should be going to A16 on the CPU (pin 47) but mine seems to be going to pin 48 which is A17.
I then tested pin 3 on ROM that should be going to A15 on the CPU (Pin 46) but mine seems too be going to pin 47 which is A16.
Black screen after tos upgrade
sporniket
Re: Black screen after tos upgrade
Groppo91
Ah many thanks for the clarification. I am now puzzled to what is causing my issues as everything is testing fine. Has anyone got any ideas of what I could try next?sporniket wrote: 30 Mar 2022 14:47If we are talking about p4 of my schematics ("U102 U103 - EPROMS"), the pin 2 of the eproms is named "A16", and is wired to "A16_SELECT" that goes to W104 and then connected either to GND or A17 of the address bus. So in fact all is normal on your board :)Groppo91 wrote: 30 Mar 2022 14:39 Based on the schematics provided sporniket I am finding the Address pins wrong on my board:
You could always just swap the new ROMs over and see what happens. Wouldn't hurt anything... Just in case they were marked up incorrectly. :-)
+1 for this.stephen_usher wrote: 30 Mar 2022 15:15 You could always just swap the new ROMs over and see what happens. Wouldn't hurt anything... Just in case they were marked up incorrectly. :-)
Groppo91
Just tried this no difference, still black screenstephen_usher wrote: 30 Mar 2022 15:15 You could always just swap the new ROMs over and see what happens. Wouldn't hurt anything... Just in case they were marked up incorrectly. :-)
Users browsing this forum: ClaudeBot, OAI-Search [Bot] and 3 guests
