Black screen after tos upgrade
Groppo91
Post by Groppo91 »
I just swapped my tos chips from original 28pin 1.06 to 32pin 1.62 and soldered the jumpers but there seems to be an issue. I can only see a black screen when I turn the atari back on. Any ideas on what has caused this?
Re: Black screen after tos upgrade
Groppo91 wrote: Thu Mar 17, 2022 2:30 pm I just swapped my tos chips from original 28pin 1.06 to 32pin 1.62 and soldered the jumpers but there seems to be an issue. I can only see a black screen when I turn the atari back on. Any ideas on what has caused this?
Black is worrying. White is the normal TOS fault state.
What do you get if you remove the chips altogether?
Yes, go back to your old tos chips just to check everything is still working... from this point onwards you can diagnose.
Groppo91
Post by Groppo91 »
The thing worked before I attempted the upgrade. I wonder if I broke something when removing the resistors used for jumping. I struggled to get wire into the gap so bridged with solder. Could this be the issue? Or is solder bridging the jumps okay?
Groppo91
Post by Groppo91 »
Steve wrote: Thu Mar 17, 2022 2:54 pm Yes, go back to your old tos chips just to check everything is still working... from this point onwards you can diagnose.
Will I need to change the jumper settings back to original to test the old chip?
Groppo91
Post by Groppo91 »
Will I need to swap jumper settings back to use the old chips?
A solder bridge is messy, but shouldn't make any difference to jumpers, wire or zero ohm links.
I'd be more concerned you'd shorted a power line at this point.
Do you get a white screen with no ROM chips fitted? If not, you problem is likely more serious and you should get the solder wick out.
Groppo91 wrote: Thu Mar 17, 2022 2:55 pm The thing worked before I attempted the upgrade. I wonder if I broke something when removing the resistors used for jumping. I struggled to get wire into the gap so bridged with solder. Could this be the issue? Or is solder bridging the jumps okay?
Could be a jumper issue, but pictures would help.
The 'resistors' are zero ohm jumpers, so can be replaced by wire, bridging with solder isn't ideal, but should work.
Check the jumper settings here: http://atari-wiki.com/index.php/Ins ... _computers
Groppo91 wrote: Thu Mar 17, 2022 3:01 pm
Yes
Groppo91
Post by Groppo91 »
Badwolf wrote: Thu Mar 17, 2022 2:40 pm
Just tried this and same result it flashes to a black screen nothing else
