Link to mobo information here
I've always wondered what this SCSI capacitor mod was for, it's on most C-Lab falcons, @mikro do you know? thx
Start with the easiest job, fix up the floppy header
I'm not quite happy with the soldering
Here I can see some bridged pins
I've cleaned up the soldering, removed any bridges and removed the patch for the clock pin because I didnt like the look of it. I've pulled the clock pin up where I'll run a patch cable to.
Okay clock pin re-patched. Now check under the board.
One of the via patch cables done previously are just sticking out quite far and doesn't look soldered properly.
Okay that's fixed now...
Yay! passing all tests now!
Users browsing this forum: Baidu [Spider], ClaudeBot and 14 guests
