mrbomber's Falcon service blog
I'm doing some work on @mrbombermillzy's Falcon, namely: removing old clock patch, installing exxos clock patch, fit new floppy header, investigate DSP issues.
Link to mobo information here
I've always wondered what this SCSI capacitor mod was for, it's on most C-Lab falcons, @mikro do you know? thx
Start with the easiest job, fix up the floppy header
broken fdd.jpg (415.47 KiB) Viewed 2955 times
fdd gone.jpg (469.23 KiB) Viewed 2955 times
new fdd.jpg (589.12 KiB) Viewed 2955 times
Re: mrbomber's Falcon service blog
New clock patch:
Time to investigate the DSP issues. Beforehand the DSP was not working at all, failing all tests. It was previously replaced by someone and some traces were patched.
I'm not quite happy with the soldering
Here I can see some bridged pins
I've cleaned up the soldering, removed any bridges and removed the patch for the clock pin because I didnt like the look of it. I've pulled the clock pin up where I'll run a patch cable to.
Okay clock pin re-patched. Now check under the board.
One of the via patch cables done previously are just sticking out quite far and doesn't look soldered properly.
Okay that's fixed now...
Yay! passing all tests now!
Just testing the new floppy IDC header, working great!
mrbombermillzy
Post by mrbombermillzy »
And here we are, all safely delivered and re-installed at home (very hastily, I might add):
Just keeping this little critter occupied (currently watching the Hmmm... demo) was worth the price! :lol:
(Sorry about the blurry picture; too many 'sticky paws' on the lens I'm guessing. I wonder who would have done that?)
Many thank Steve! Just made my Christmas!! :thumbup:
Brilliant!!!! Cheers for the update!
