TFMSX Arrives
PaulJ_2.0
Re: TFMSX Arrives
Post by PaulJ_2.0 »
Maybe this could work: https://uk.rs-online.com/web/p/real-tim ... /6676221p/
Disclaimer: I didn't look at the pinouts, I've just seen them used on modern amiga ram/clock boards.
Re: TFMSX Arrives
its not just the pinouts. Its got to be RP5C01 compatible.
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: TFMSX Arrives
Post by arkadiusz.makarenko »
terriblefire wrote: Thu Sep 23, 2021 2:39 pm its not just the pinouts. Its got to be RP5C01 compatible.
It could be emulated in arm?
~ Stanislaw Lem
Re: TFMSX Arrives
Probably well enough yes. We dont need the time to be correct.. just that it ticks.
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: TFMSX Arrives
If precision and keeping time is not important then even clock oscillator and battery would not be required.
~ Stanislaw Lem
Re: TFMSX Arrives
i've basically wired up every spare CPLD pin to the arm now.
Matej
Re: TFMSX Arrives
Post by Matej »
Can be there 12v/+- for soundcards? Like opl4 or carnivore2 (got scc in fpga) cartridge? Also instead of SCC can be there MSXmusic standard?
3x Falcon030 1x TT030 2x ATX-ST 9x A130XE
Re: TFMSX Arrives
Matej wrote: Fri Sep 24, 2021 8:34 pm Can be there 12v/+- for soundcards? Like opl4 or carnivore2 (got scc in fpga) cartridge? Also instead of SCC can be there MSXmusic standard?
no.
Re: TFMSX Arrives
I presume the MSX2 uses the ram on the clock chips for config settings then? A bit like the Falcon I guess.
I've googled the chip and it does seem to be available still easily enough but if you can easily emulate it then I guess it's a nobrainer unless you need to use the arm horsepower somewhere else?
Re: TFMSX Arrives
PhilC wrote: Fri Sep 24, 2021 10:24 pm I presume the MSX2 uses the ram on the clock chips for config settings then? A bit like the Falcon I guess.
There is a bit of a penalty transferring stuff between the arm and CPLD. Really at this point i'm trying to give us the tools to do what we need.
