Stuck Bleep.
Re: Stuck Bleep.
Yeah mine sometimes does it if I move the mouse by accident when turning it on.
Cosmic Puppet
Re: Stuck Bleep.
Thanks Steve. My Atari's horizontal is still bang on! Every time I switch it on I'm like Waayy! :DSteve wrote: 26 Aug 2020 22:20 Yeah mine sometimes does it if I move the mouse by accident when turning it on.
Cosmic Puppet
Re: Stuck Bleep.
Just been checking my double click setting on control panel and realised that I can turn the keyboard click off. So I'll see if this has any effect on this bug.
Re: Stuck Bleep.
I've heard it also in steem now and then, so rules out hardware I think :lol:
Cosmic Puppet
Re: Stuck Bleep.
:lol: :lol: :lol:exxos wrote: 27 Aug 2020 01:07 I've heard it also in steem now and then, so rules out hardware I think :lol:
Cosmic Puppet
Re: Stuck Bleep.
Okay, so assuming the bleep can't malfunction if it's deactivated, so I turned it off in control panel on my gaming/demo watching SD card.
All that's left is to do the same on my music setup.
For this I'm using EmuTos boosted with NVDI5.
There doesn't seem to be a function to turn off the keuboard bleep in EmuTos (It's not the Sound Effects button. Tried it.)
So I tried using control panel, which bricks the system. The desktop icons never appear.
Tried Xcontrol and cops which, while not bricking the system don't work. One only has a bell box which does nothing, and the other only seems to have an audio switch which isn't applicable to my machine.
Is there a way to turn off the keyboard bleeps when using EmuTos?
This is the last thing I need to do. :?
czietz
Re: Stuck Bleep.
This is a documented bug in CONTROL.ACC: https://github.com/emutos/emutos/blob/m ... e.txt#L166Cosmic Puppet wrote: 27 Aug 2020 17:56 So I tried using control panel, which bricks the system. The desktop icons never appear.
Switching off the key clicks with XCONTROL.ACC (and GENERAL.CPX) works as expected for me under EmuTOS: Obviously, merely switching off the sound (key clicks) does not resolve your issue of a key being stuck.Cosmic Puppet wrote: 27 Aug 2020 17:56 Tried Xcontrol and cops which, while not bricking the system don't work.
Cosmic Puppet
Re: Stuck Bleep.
[/quote]
[/quote]
Hi. Thanks. I did that in xcontrol, but when I reset the system the keyboard click returned.
I'm obviously missing something. Maybe my file locations?
I'm convinced it isn't a stuck key.
[/quote]
czietz
Re: Stuck Bleep.
Did you click on "Save" in the CPX? Was the CPX perhaps write protected? Did you make sure that XCONTROL.ACC and GENERAL.CPX were loaded again after reset?Cosmic Puppet wrote: 27 Aug 2020 18:09 Hi. Thanks. I did that in xcontrol, but when I reset the system the keyboard click returned.
Cosmic Puppet
Re: Stuck Bleep.
Do I have to physically load them even with XCONTROL.ACC in the route directory?czietz wrote: 27 Aug 2020 18:13Did you click on "Save" in the CPX? Was the CPX perhaps write protected? Did you make sure that XCONTROL.ACC and GENERAL.CPX were loaded again after reset?Cosmic Puppet wrote: 27 Aug 2020 18:09 Hi. Thanks. I did that in xcontrol, but when I reset the system the keyboard click returned.
