TF1260 / TF360 Weirdness with OS3.9 (AKA Why i'm not releasing them just yet)
Re: TF1260 / TF360 Weirdness with OS3.9 (AKA Why i'm not releasing them just yet)
8 Bit Dreams wrote: 17 Jun 2020 11:28 @terriblefire
What memory range are You using? Should be in $08000000- $0FFFFFFF i think... 🤔
I dont use a fixed memory range. Its done by the OS. Its normally allocated to 0x40000000 - 0x47ffffff.
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
Have checked Amiga Memory map, and noticed not all regions are fee to use:
https://www.amigacoding.com/index.php/Amiga_memory_map
If You allocate 128MB in 0x40000000 - 0x47ffffff this will probably not work, since this area is Reserved for motherboard RAM expansion, You need to try from $10000000 then...
Like i've said. I'm not allocating the ram there. Its done by Autoconfig. The RAM is given a base address by the operating system. Exactly the same thing happens with the Blizzard and it works.
8 Bit Dreams wrote: 17 Jun 2020 19:54 If You allocate 128MB in 0x40000000 - 0x47ffffff this will probably not work, since this area is Reserved for motherboard RAM expansion, You need to try from $10000000 then...
This is not correct. The range you said and the diagram you posted say its ZIII expansion area. Which is exactly what is happening.
8 Bit Dreams
Moderator Team
Moderator Team
Ah, ok,
was under impression that this address space is reserved for Motherboard ram, hence it makes trouble if it's more than 64MB...
8 Bit Dreams wrote: 17 Jun 2020 21:18 Ah, ok,
No its 0x4000_0000 that we have the board at. The expansion area you are talking about is 0x0400_0000
supaduper
Post by supaduper »
Ok I have not had time to muck about with this in the last couple of days, anyways, I realized like the dumbass that I am that I had not got the 060 lib installed on my own OS_39..Doh
So I dropped the 060 into libs took the 040 one out and yatzi bingo, its now seeing and working fine on my CD32 with 128mb and a Dual OS, on which I have installed OS 39 and OS 3.1 ( I just use HDtoolbox to swap the sys boot to which one I want to use ), oh this was using a Kingston 8gb CF with PFSaio filesytem
I can`t try the A1200 till tomorrow will report back then
8 Bit Dreams
Moderator Team
Moderator Team
Fantastic news bud! ☺
And yes, 060 libs are indeed needed 😂
8 Bit Dreams wrote: 21 Jun 2020 18:53 Fantastic news bud! ☺
Mine has MMUlib in it and it made no difference. :/
Just got an email from @chucky trying out @supaduper's latest image.
unfortunally this image doesnt contain updates.. like updated exec.library. thats why it works
supaduper
Post by supaduper »
terriblefire wrote: 21 Jun 2020 20:18 Just got an email from @chucky trying out @supaduper's latest image.
So when you say updates you mean BB2 updates?
And still the puzzle is that your test OS39 does work on mine all very puzzling
Return to “TF360”
