I dont use a fixed memory range. Its done by the OS. Its normally allocated to 0x40000000 - 0x47ffffff.8 Bit Dreams wrote: 17 Jun 2020 11:28 @terriblefire
What memory range are You using? Should be in $08000000- $0FFFFFFF i think... 🤔
TF1260 / TF360 Weirdness with OS3.9 (AKA Why i'm not releasing them just yet)
- Admin sponsor
Re: TF1260 / TF360 Weirdness with OS3.9 (AKA Why i'm not releasing them just yet)
8 Bit Dreams
- Moderator Team
Have checked Amiga Memory map, and noticed not all regions are fee to use:
https://www.amigacoding.com/index.php/Amiga_memory_map
If You allocate 128MB in 0x40000000 - 0x47ffffff this will probably not work, since this area is Reserved for motherboard RAM expansion, You need to try from $10000000 then...
- Admin sponsor
Like i've said. I'm not allocating the ram there. Its done by Autoconfig. The RAM is given a base address by the operating system. Exactly the same thing happens with the Blizzard and it works.
This is not correct. The range you said and the diagram you posted say its ZIII expansion area. Which is exactly what is happening.8 Bit Dreams wrote: 17 Jun 2020 19:54 If You allocate 128MB in 0x40000000 - 0x47ffffff this will probably not work, since this area is Reserved for motherboard RAM expansion, You need to try from $10000000 then...
8 Bit Dreams
- Moderator Team
Ah, ok,
was under impression that this address space is reserved for Motherboard ram, hence it makes trouble if it's more than 64MB...
- Admin sponsor
No its 0x4000_0000 that we have the board at. The expansion area you are talking about is 0x0400_00008 Bit Dreams wrote: 17 Jun 2020 21:18 Ah, ok,
supaduper
Ok I have not had time to muck about with this in the last couple of days, anyways, I realized like the dumbass that I am that I had not got the 060 lib installed on my own OS_39..Doh
So I dropped the 060 into libs took the 040 one out and yatzi bingo, its now seeing and working fine on my CD32 with 128mb and a Dual OS, on which I have installed OS 39 and OS 3.1 ( I just use HDtoolbox to swap the sys boot to which one I want to use ), oh this was using a Kingston 8gb CF with PFSaio filesytem
I can`t try the A1200 till tomorrow will report back then
8 Bit Dreams
- Moderator Team
Fantastic news bud! ☺
And yes, 060 libs are indeed needed 😂
- Admin sponsor
Mine has MMUlib in it and it made no difference. :/
- Admin sponsor
Just got an email from @chucky trying out @supaduper's latest image.
unfortunally this image doesnt contain updates.. like updated exec.library. thats why it works
supaduper
So when you say updates you mean BB2 updates?terriblefire wrote: 21 Jun 2020 20:18 Just got an email from @chucky trying out @supaduper's latest image.
And still the puzzle is that your test OS39 does work on mine all very puzzling
