exxos wrote: Sun Jun 07, 2020 9:05 pm
That looks like the blitter isn't issuing dtack to the CPU.
Seems a lot of different things are not happening. Occasionally the error I'm getting out of the diag software is "Bus error not detected", indicating that the MCU (same chip as the Blitter in this hardware of course) isn't successfully talking to the CPU as the system is coming up. It's all very strange, and seems rather random.
I am comfortable with the soldering on the Glue. I've done it multiple times, with multiple Glues, and inspected with a microscope. (Not to mention I was seeing these same kind of symptoms withe factory Glue.) I have reflowed the booster. I've reflowed the TOS switcher. I've used different RAM. I've even socketed and swapped out the MFP, all to no avail.
I noticed earlier, when the system had not booted successfully, that the CPU was getting an 8 MHz clock, which I am assuming is normal until the system boots. I just checked the clock pin now and found 32 MHz on it...and measuring it made the system crash.
I also noticed something rather odd, which I have not yet compared to my working STE (it's gotten rather late tonight, so I'm not going to be doing much more poking around tonight). This is what I see on GND on the shifter:
- shifter-74.png (41.34 KiB) Viewed 3811 times
That's 16 MHz, fwiw. I don't know if it's normal to see that much AC in the ground. Seems like probably not. I'll compare with the working STE tomorrow.
