Weird. I can start diagrom and all mem test ok (on fast test and 5mb slow reported ok before skipping it), but can't start normal kickstart 3.1terriblefire wrote: 28 Jan 2020 21:26Yeah you really need a basic temperature controlled iron and always use the "proper" amount of fluxarkadiusz.makarenko wrote: 28 Jan 2020 21:07 My TF536 is stable under Diagrom.
I am still troubleshooting build.
Forgot that 4 layer board are pain to solder correctly. I really need to invest in better soldering station.
Limited TF536 Run - Sort of Sales (All gone)
arkadiusz.makarenko
- Moderator Team
Re: Limited TF536 Run - Sort of Sales (All gone)
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Slow ram?arkadiusz.makarenko wrote: 28 Jan 2020 21:36Weird. I can start diagrom and all mem test ok (on fast test and 5mb slow reported ok before skipping it), but can't start normal kickstart 3.1terriblefire wrote: 28 Jan 2020 21:26
Can you edit memory manually at 0x40000000?
arkadiusz.makarenko
- Moderator Team
Sorry. It was slow test option on manual mem test.terriblefire wrote: 28 Jan 2020 21:50Slow ram?arkadiusz.makarenko wrote: 28 Jan 2020 21:36
It takes ages to test 64mb.
It must be dry solder somwhere.
~ Stanislaw Lem
~ Stanislaw Lem
kludge
I’ve had that with TF534. Diagrom doesn’t test the RAM 100%, and the Kickstart power on routine does some other tests. For me it was a bridge or floating pin or something like that.
Try putting KS 1.3 on there just to see if it boots. 1.3 doesn’t test the memory as thoroughly as the later versions do.
I think Stephen made a special firmware build for me that didn’t autoconfig the fast ram, so that I could boot on a floppy and then add the RAM with addmem and run AmigaTestKit to figure out where the fault was.
A kludge is a workaround or quick-and-dirty solution that is clumsy, inelegant, inefficient, difficult to extend and hard to maintain.
My lack of focus:
[ 8 * A500 ][ 2 * A500+ ][ 2 * A600 ][ 2 * A1200 ][ 2 * A2000 w/ A2386 ][ A4000 w/ TF4060, CyberVision 64 3D, FastLane SCSI Z3 ][ CD32 ][ VIC-20 ][ 4 * C64 Breadbin ][ 5 * C64C ][ 2 * C128 ][ C128D ][ C64 DTV ][ 3 * Mac Classics of different types ]
My lack of focus:
arkadiusz.makarenko
- Moderator Team
Got my TF536 booting to workbench now.
Cpld and CPU is not getting hot.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
What was up?arkadiusz.makarenko wrote: 29 Jan 2020 10:21 Got my TF536 booting to workbench now.
arkadiusz.makarenko
- Moderator Team
terriblefire wrote: 29 Jan 2020 12:45What was up?arkadiusz.makarenko wrote: 29 Jan 2020 10:21 Got my TF536 booting to workbench now.
It had to be soldering on cpld.
It seems that I still have some issues. Looks like my hdd image, as everything is ok from floppy.
EDIT: yes partition is corrupted. Need to set it up again.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
The CPLDs are v difficult without magnification
Justme14
Hi ,
I finally received the 2 missing IC and soldered them,TF536 is now finished.
Did a run whith Frontier for 2 hours , no crash
IDE preformance seems slow get only just 1 mb , but with fastrom option , I get even more then 4 MB and Workbench feels rather snapy then.
Some Sysinfo Pics
Some Sysinfo Pics
- Admin sponsor
Looks like a winner.
any major changes requested?
