INT2 Signal on TF 534 Board
I understand that the TF 534 does not need the INT 2 signal from the A500. Is there a reason why INT 2 is on the board? I ask only because I previously had a TF 530 in my Amiga, and can wire the INT 2 signal to the 534 if it would provide any benefit.
- Attachments
- int2.jpg (90.5 KiB) Viewed 3003 times
- Admin sponsor
Re: INT2 Signal on TF 534 Board
It was there until I got the feature that makes it redundant working. And as insurance incase I couldnt.chue wrote: Sun Apr 21, 2019 1:58 am I understand that the TF 534 does not need the INT 2 signal from the A500. Is there a reason why INT 2 is on the board? I ask only because I previously had a TF 530 in my Amiga, and can wire the INT 2 signal to the 534 if it would provide any benefit.
Thank you, that makes sense.
