INT2 Signal on TF 534 Board
chue
Post by chue »
I understand that the TF 534 does not need the INT 2 signal from the A500. Is there a reason why INT 2 is on the board? I ask only because I previously had a TF 530 in my Amiga, and can wire the INT 2 signal to the 534 if it would provide any benefit.
!Message from: Moderator
@chue, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
Re: INT2 Signal on TF 534 Board
chue wrote: Sun Apr 21, 2019 1:58 am I understand that the TF 534 does not need the INT 2 signal from the A500. Is there a reason why INT 2 is on the board? I ask only because I previously had a TF 530 in my Amiga, and can wire the INT 2 signal to the 534 if it would provide any benefit.
It was there until I got the feature that makes it redundant working. And as insurance incase I couldnt.
chue
Post by chue »
Thank you, that makes sense.
Return to “TF534 (OBSOLETE)”
