TF330 rev2 is here
68030 + SDRAM + IDE
Re: TF330 rev2 is here
The connectors I have have no spring in them at all. The card had a serious tendency to flop around.
@supaduper what do you think?
supaduper
Post by supaduper »
terriblefire wrote: Fri Feb 08, 2019 2:04 pm The connectors I have have no spring in them at all. The card had a serious tendency to flop around.
No real problems here Steve, I suppose if you wanted to manually file more of a bevel on the TF330 you can I suppose, because you moved the inner layers on the PCB so they do not encroach into the card edge like on the Rev1 am I correct bud ?
Just to say that if you can file a bigger bevel easily, as I did on a few of the TF328`s with ease :)
Yeah there are no inner layers beyond the notch.
supaduper
Post by supaduper »
Cheers Steve
Then what I say to Alen is get a small needle file and manually increase the bevel on the Rev 2 , like I said I have done a few of the TF328`s when they did not put a bevel on them and I filed a bevel on one in less than a couple of minutes. piece of pi$$ :)
I pay the board house to do this but they never do
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
Hello Stephen,
got parcels You sent to me, have built rev.2 TF330 with XC95288XL,
can You please recompile firmware for it, otherwise i am unable to flash
Thank You
8 Bit Dreams
Moderator Team
Moderator Team
terriblefire wrote: Fri Feb 08, 2019 10:13 pm already published
https://github.com/terriblefire/terribl ... _alpha.zip
Nope Steve,
this jed is for 144 , not for 288 :?
you nutcase.. i'll do that in in the morning
alenppc
Moderator Team
Moderator Team
Post by alenppc »
Closeup pic of the damage...
And a 1.2mm board sitting nicely ;)
Return to “TF330”
