TF330 rev2 is here
- Admin sponsor
Re: TF330 rev2 is here
The connectors I have have no spring in them at all. The card had a serious tendency to flop around.
@supaduper what do you think?
supaduper
No real problems here Steve, I suppose if you wanted to manually file more of a bevel on the TF330 you can I suppose, because you moved the inner layers on the PCB so they do not encroach into the card edge like on the Rev1 am I correct bud ?terriblefire wrote: 08 Feb 2019 14:04 The connectors I have have no spring in them at all. The card had a serious tendency to flop around.
Just to say that if you can file a bigger bevel easily, as I did on a few of the TF328`s with ease :)
- Admin sponsor
Yeah there are no inner layers beyond the notch.
supaduper
Cheers Steve
Then what I say to Alen is get a small needle file and manually increase the bevel on the Rev 2 , like I said I have done a few of the TF328`s when they did not put a bevel on them and I filed a bevel on one in less than a couple of minutes. piece of pi$$ :)
- Admin sponsor
I pay the board house to do this but they never do
8 Bit Dreams
- Moderator Team
Hello Stephen,
got parcels You sent to me, have built rev.2 TF330 with XC95288XL,
can You please recompile firmware for it, otherwise i am unable to flash
Thank You
Thank You
- Admin sponsor
8 Bit Dreams
- Moderator Team
Nope Steve,terriblefire wrote: 08 Feb 2019 22:13 already published
https://github.com/terriblefire/terribl ... _alpha.zip
this jed is for 144 , not for 288 :?
- Admin sponsor
you nutcase.. i'll do that in in the morning
alenppc
- Moderator Team
Closeup pic of the damage...
And a 1.2mm board sitting nicely ;)
