Thanks !Darklord wrote: 22 Mar 2026 12:54 Good luck with this project - it looks like it's coming along nicely. :)
And just in case, here is a link to the TwiSTEr page (in German only):
https://wiki.newtosworld.de/index.php?title=TwiSTEr
Could you remove the (redundant) RF modulator and then route a HDMI cable out through the existing TV out hole?
I was thinking about (I'm not so keen on cutting cases), but the HDMI connector is too close to the case to route a cable...alexh wrote: 13 May 2026 10:48 Could you remove the (redundant) RF modulator and then route a HDMI cable out through the existing TV out hole?
I guess STe cases are probably not rare and so cutting one is probably not like cutting a TT030 or MegaSTe case which IMO would only devalue it.
Definitely something to feedback to Alan for any future batches.HigashiJun wrote: 13 May 2026 11:24 If the Monster bus connector was slightly further back, it would be feasible.
How would I connect it ?chronicthehedgehog wrote: 13 May 2026 20:05 What about replacing the hdmi connector with a vertically mounted connector?
Yes, sorry I meant de-solder and replace. It's not something I'd attempt but you have the soldering skills 8-)HigashiJun wrote: 13 May 2026 21:38How would I connect it ?chronicthehedgehog wrote: 13 May 2026 20:05 What about replacing the hdmi connector with a vertically mounted connector?
There is no room to plug anything between the HDMI connector and plastic case.
Or do you mean de-solder the horizontal one and replace it with a vertical one ?
Thanks for this clarification.chronicthehedgehog wrote: 13 May 2026 22:40 Yes, sorry I meant de-solder and replace. It's not something I'd attempt but you have the soldering skills 8-)
assuming you can find something with the same footprint I suppose
Users browsing this forum: ClaudeBot and 24 guests
