First look at the new board
The TF330 is here
- Admin sponsor
The TF330 is here
supaduper
Re: The TF330 is here
They look great Steve and a +1 for the packaging by JLC :)
- Admin sponsor
A little bit concerned about the process here. I think my choice to use a 7 mi clearance was wise... they only just managed it
- Admin sponsor
Perfect box for sending 328s to you in :)
wow! The last boards I got were from JLC.. will see if I can check quality on one later..terriblefire wrote: 19 Nov 2018 18:41 A little bit concerned about the process here. I think my choice to use a 7 mi clearance was wise... they only just managed it
Mine isn't perfect, but not as bad as yours I think..
- Admin sponsor
Judging by this.. Its the drill holes that are the problem. SMD pads are fine. in the next revision i'll tighten the trace to trace and give more clearance to the drill point. Probably trace to trace 6.5mil and Trace to pad 8mil.exxos wrote: 19 Nov 2018 18:50wow! The last boards I got were from JLC.. will see if I can check quality on one later..terriblefire wrote: 19 Nov 2018 18:41 A little bit concerned about the process here. I think my choice to use a 7 mi clearance was wise... they only just managed it
The 0.8mm holes look ok on my board, looks like the smaller drill holes are running out..terriblefire wrote: 19 Nov 2018 19:06 Judging by this.. Its the drill holes that are the problem. SMD pads are fine. in the next revision i'll tighten the trace to trace and give more clearance to the drill point. Probably trace to trace 6.5mil and Trace to pad 8mil.
Might be worth reporting a quality problem to them ?
alenppc
- Moderator Team
That board looks a bit thick... I hope it's just the picture, as 1.6 mm won't fit in the riser
- Admin sponsor
Its 1.6mm. All my TF328s have been that. They fit no issue.alenppc wrote: 19 Nov 2018 19:59 That board looks a bit thick... I hope it's just the picture, as 1.6 mm won't fit in the riser
EDIT: Although i will say they were supposed to do bevelled edges and they didnt.
