The TF330 is here
68030 + SDRAM + IDE
The TF330 is here
First look at the new board
supaduper
Re: The TF330 is here
Post by supaduper »
They look great Steve and a +1 for the packaging by JLC :)
A little bit concerned about the process here. I think my choice to use a 7 mi clearance was wise... they only just managed it
supaduper wrote: Mon Nov 19, 2018 6:35 pm They look great Steve and a +1 for the packaging by JLC :)
Perfect box for sending 328s to you in :)
terriblefire wrote: Mon Nov 19, 2018 6:41 pm A little bit concerned about the process here. I think my choice to use a 7 mi clearance was wise... they only just managed it
wow! The last boards I got were from JLC.. will see if I can check quality on one later..
Mine isn't perfect, but not as bad as yours I think..
exxos wrote: Mon Nov 19, 2018 6:50 pm
Judging by this.. Its the drill holes that are the problem. SMD pads are fine. in the next revision i'll tighten the trace to trace and give more clearance to the drill point. Probably trace to trace 6.5mil and Trace to pad 8mil.
terriblefire wrote: Mon Nov 19, 2018 7:06 pm Judging by this.. Its the drill holes that are the problem. SMD pads are fine. in the next revision i'll tighten the trace to trace and give more clearance to the drill point. Probably trace to trace 6.5mil and Trace to pad 8mil.
The 0.8mm holes look ok on my board, looks like the smaller drill holes are running out..
Might be worth reporting a quality problem to them ?
alenppc
Post by alenppc »
That board looks a bit thick... I hope it's just the picture, as 1.6 mm won't fit in the riser
alenppc wrote: Mon Nov 19, 2018 7:59 pm That board looks a bit thick... I hope it's just the picture, as 1.6 mm won't fit in the riser
Its 1.6mm. All my TF328s have been that. They fit no issue.
EDIT: Although i will say they were supposed to do bevelled edges and they didnt.
Return to “TF330”
