Getting Tyrian up and running
Hi all.
So I'm struggling a bit with getting Tyrian to run
I've downloaded the Raven port of OpenTyrian, have downloaded the data files and even the x86 be soon of the original game.
I'm presuming I copy the data files and OpenTyrian Raven files into the game directory and then run it? If I do that it mentions about having no cfh file etc
I'm using an LC060;at the mo if it makes a difference.
luciodra
Re: Getting Tyrian up and running
Post by luciodra »
viewtopic.php?p=123346#p123346
If I understand correctly, this version works great on my LC. You just need to add the DATA directory.
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra wrote: 21 May 2025 07:40 viewtopic.php?p=123346#p123346
Thanks, I'll give it a go today
So I've tried the following:
created the tyrian directory
within that created a data directory and copied the datafile into that
copied the tyrian60.prg and tyrian00.prg into the tyrian directory
then in mint I click on tyrian60 and it opens a window which complains about the cfg file not being present, doesn't detect sound card then goes to a black OpenTyrian window and doesn't seem to do anything else.
What am I doing wrong guys? is it my graphics card or something else maybe?
luciodra
Post by luciodra »
These are the files present in the two versions that I tried and which work well.
ET4000AX 1Mb T0
PicoGUS 2.0
@luciodra the top photo is the same as my directory.
Could you do me a favour please, to rule out an error I've made with copying, could you zip up the directory and pm me the zip?
luciodra
Post by luciodra »
PhilC wrote: 21 May 2025 17:55 @luciodra the top photo is the same as my directory.
File sent. Let us know...
ET4000AX 1Mb T0
PicoGUS 2.0
@luciodra that also doesn't work for me, either by using a Mach32 or ET4000AX
This is as far as it gets
luciodra
Post by luciodra »
You are using Freemint ! I Emutos...
I also tried it on Freemint and it works the same, but I would try it on Emutos...
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra wrote: 21 May 2025 19:02 You are using Freemint ! I Emutos...
Okay, it doesn't like my Mach32 at all.
On the two ET4000 cards I have, the best I get using the T4 driver is this
It proves that my Tyrian installation should work as it does exactly the same
