Getting Tyrian up and running
Hi all.
So I'm struggling a bit with getting Tyrian to run
I've downloaded the Raven port of OpenTyrian, have downloaded the data files and even the x86 be soon of the original game.
I'm presuming I copy the data files and OpenTyrian Raven files into the game directory and then run it? If I do that it mentions about having no cfh file etc
I'm using an LC060;at the mo if it makes a difference.
Re: Getting Tyrian up and running
https://www.exxosforum.co.uk/forum/view ... 80#p123346
If I understand correctly, this version works great on my LC. You just need to add the DATA directory.
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
Thanks, I'll give it a go todayluciodra wrote: Wed May 21, 2025 7:40 am https://www.exxosforum.co.uk/forum/view ... 80#p123346
So I've tried the following:
created the tyrian directory
within that created a data directory and copied the datafile into that
copied the tyrian60.prg and tyrian00.prg into the tyrian directory
then in mint I click on tyrian60 and it opens a window which complains about the cfg file not being present, doesn't detect sound card then goes to a black OpenTyrian window and doesn't seem to do anything else.
What am I doing wrong guys? is it my graphics card or something else maybe?
These are the files present in the two versions that I tried and which work well.
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
@luciodra the top photo is the same as my directory.
Could you do me a favour please, to rule out an error I've made with copying, could you zip up the directory and pm me the zip?
File sent. Let us know...PhilC wrote: Wed May 21, 2025 5:55 pm @luciodra the top photo is the same as my directory.
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
@luciodra that also doesn't work for me, either by using a Mach32 or ET4000AX
This is as far as it gets
You are using Freemint ! I Emutos...
I also tried it on Freemint and it works the same, but I would try it on Emutos...
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
Okay, it doesn't like my Mach32 at all.
On the two ET4000 cards I have, the best I get using the T4 driver is this
It proves that my Tyrian installation should work as it does exactly the same
