@dad664npc and @Badwolf :
Thanks both of you for the advice. I vaguely remember BW explaining about the problems of extending the pins.
Looks like I will have to join the party a bit later then.
PiStorm Chat
Darklord
Re: PiStorm Chat
Okay, I find myself really intrigued by this.
Currently I have my STacy opened up, working on it. It has a
socketed CPU.
So...does PiSTorm require an STe or will it work in an ST also?
Is Mint required?
Will any Pi4 do or are there special requirements?
The Github page seems to indicate that the Pi3 variations now work,
as well as either 373 or 374 latches. Is that correct?
Thanks.
socketed CPU.
Is Mint required?
Thanks.
dad664npc
Re: PiStorm Chat
PiStorm works in both ST and STe
STe requires an adaptor board - DIL to PLCC
Mint is not required
Any Pi4 model B will work
Pi3A+ is shown to work
badwolf has shown that the latch type no longer matters
I have never seen a STacy in person, but from images, it seems compact. I very much doubt you could install a PiStorm and run it encased - but am happy to be told otherwise
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
sporniket
Re: PiStorm Chat
STe requires a motherboard version with socketed CPU.
Cyprian
Re: PiStorm Chat
ST:
STE:
STE:
http://260ste.atari.org
dad664npc
Re: PiStorm Chat
STe PLCC socketed CPU requires exxos adaptor board to convert to DIL socket
sporniket
Re: PiStorm Chat
What I meant is that motherboards with soldered CPU cannot host a pistorm (as well as any other kind of accelerator)
Cyprian
Re: PiStorm Chat
Besides @Badwolf PLCC PiSTorm board there is also Pistorm600 https://programatory.archi-tech.com.pl/ ... ga-600/268 with PLCC socket. I wonder whether it is ok for STE?
dad664npc
Re: PiStorm Chat
Unfortunately not - it's designed to sit atop of the 68k (Amiga 600 has the cpu soldered to board)
Re: PiStorm Chat
I have no direct knowledge of it, but AFAICT the only way to shut up the CPU you're slotting over the top of would be to perform bus arbitration to one extent or the other.Cyprian wrote: 06 Oct 2023 10:07 Besides @Badwolf PLCC PiSTorm board there is also Pistorm600 https://programatory.archi-tech.com.pl/ ... ga-600/268 with PLCC socket. I wonder whether it is ok for STE?
The easiest way to do this on an A500 would be to simply tie BGK to ground since no bus arb is needed to operate the computer. If the A600 is the same then I suspect this is what is happening here.
The ST uses bus arbitration extensively, so full bus arbitration would be required and it would be complicated (like I had to do on the DFB1) as you're effectively trying to usurp the CPU totally rather than just do a bit of DMA here and there.
If I had to guess, therefore, I'd guess the simple option were taken so it's unlikely to work on an STE with a soldered chip.
Users browsing this forum: ClaudeBot and 44 guests
