STFM PAK020 - 16MHz 32BIT ROM
Benchmark screenshots for various boosters & machines.
I-CACHE OFF (SET VIA JUMPER ON PCB)
I-CACHE ON
Re: STFM PAK020 - 16MHz 32BIT ROM
Quick Q here, I presume the original 68K cpu is removed from the mainboard, and a socket put in it's place, or is the PAK soldered into where the 68K used to be?
rubber_jonnie wrote: Fri Feb 23, 2018 4:23 pm Quick Q here, I presume the original 68K cpu is removed from the mainboard, and a socket put in it's place, or is the PAK soldered into where the 68K used to be?
I had to put it into a socket, simply because as the board is so large it would not seat down to the motherboard as the MMU is in the way.
exxos wrote: Fri Feb 23, 2018 4:43 pm
Cool thanks, much as I had planned too, hence why I ordered 2 sockets from you :)
Return to “BENCHMARKS”
