STFM PAK020 - 16MHz 32BIT ROM
I-CACHE OFF (SET VIA JUMPER ON PCB)
I-CACHE ON
Re: STFM PAK020 - 16MHz 32BIT ROM
Quick Q here, I presume the original 68K cpu is removed from the mainboard, and a socket put in it's place, or is the PAK soldered into where the 68K used to be?
I had to put it into a socket, simply because as the board is so large it would not seat down to the motherboard as the MMU is in the way.rubber_jonnie wrote: 23 Feb 2018 16:23 Quick Q here, I presume the original 68K cpu is removed from the mainboard, and a socket put in it's place, or is the PAK soldered into where the 68K used to be?
Cool thanks, much as I had planned too, hence why I ordered 2 sockets from you :)exxos wrote: 23 Feb 2018 16:43I had to put it into a socket, simply because as the board is so large it would not seat down to the motherboard as the MMU is in the way.rubber_jonnie wrote: 23 Feb 2018 16:23 Quick Q here, I presume the original 68K cpu is removed from the mainboard, and a socket put in it's place, or is the PAK soldered into where the 68K used to be?
