I sometimes watch videos on repair and troubleshooting for old hardware, and happened on this Asteroids Cocktail table refurb yesterday: https://www.youtube.com/watch?v=R9peQ7NmCqQ
The video itself is quite generic, but if you fast forward to about 28 minutes, they are using an oscilloscope connected to the X & Y outputs of the board to see the image, albeit in poor quality, on the oscilloscope.
I found this fascinating and a very interesting way to see the video out of this board and verify it has video output. Not sure if it would work elsewhere, but interesting nonetheless.
Interesting use for an Oscilloscope
Re: Interesting use for an Oscilloscope
It'd work for any vector display but not for raster displays.
Yeah, that would make perfect sense.stephen_usher wrote: Mon Jan 03, 2022 1:49 pm It'd work for any vector display but not for raster displays.
- mrbombermillzy
@rubber_jonnie . If you like that, you should check out the osc. generated mushrooms vid:
There was also Quake too:
Cheers, I'll have to take a look at those.mrbombermillzy wrote: Mon Jan 03, 2022 2:40 pm @rubber_jonnie . If you like that, you should check out the osc. generated mushrooms vid:
UnderTheRain
Can't believe I hadn't see those before they're really cool
Just had a look at these, I've seen the mushroom type stuff before, I think there was something similar on the CuriousMarc channel, but the Quake one is quite astounding, it's like Quake in the Matrixmrbombermillzy wrote: Mon Jan 03, 2022 2:40 pm @rubber_jonnie . If you like that, you should check out the osc. generated mushrooms vid:
Impressive stuff.
