Chue's TF534 Build
chue
Chue's TF534 Build
Post by chue »
Just started my build. So far I've put on both CPLDs, the 3.3 V regulator, and the resistor networks (all 1K arrays).
The regulator, resistor arrays, and small CPLD were leftover parts from my TF530 build. I took a risk and am using an eBay used part for the larger CPLD.
With these things on I was able to identify and program the CPLDs. Now I am waiting for other parts to arrive from Digikey.
!Message from: Moderator
@chue, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
techniplex
Re: Chue's TF534 Build
Post by techniplex »
Aren't the resistor networks 2.2k for the TF534 and 1K on the TF530? Just know they are harder to swap once everything is on there.
8 Bit Dreams
Post by 8 Bit Dreams »
both work. Quaranteed.
chue
Post by chue »
I've put on some more components on the top of the board:
10uF caps
Shmitt buffers
Bus transceiver
Resistors R1 & R2 - outlined in yellow in the image. Are these in the correct place? The silk screen is hard to read.
chue
Post by chue »
It's mostly finished, just missing the SPI flash.
Final Specs:
68EC030 (RP40B) CPU
68882 (FN40A) FPU
40 mhz clock
4 MB of RAM
4 GB CF card
Here is some TF 534 eye candy:
Return to “TF534 (OBSOLETE)”
