My (attempted) PiSTorm STacy installation
Darklord
Re: My (attempted) PiSTorm STacy installation
Post by Darklord »
Gotcha, so the warning message I got is what is expected and I should be good.
Should I run it again and do the "-vvvv" anyway? Thanks.
Darklord
Post by Darklord »
I decided to go ahead - here's the results. It looks okay to me.
Darklord
Post by Darklord »
Here's my config.txt file - what part(s) am I supposed to change? Thanks.
config.txt
(482 Bytes) Downloaded 314 times
I'm assuming it's something from this section:
[pi4]
#over_voltage=9 # if arm_freq > 2.1GHz
arm_freq=1500
gpu_freq=700
gpu_mem=16
You're not expected to change anything. The config is pre-configured for you. The GitHub instructions don't tell you to change it, just to copy it to your boot directory.
Darklord
Post by Darklord »
Hmm, I sincerely hope that something is to be changed. "core_freq" keeps getting mentioned but I can't find that
in the config.txt file except under the Pi 2 and Pi 3 sections and I've got a Pi 4. It was mentioned that it's set too
high but I'm not sure what to change since "core_freq" isn't mentioned in the Pi 4 section.
Thanks.
Darklord
Post by Darklord »
So I decided to experiment a bit. Yeah, I know, asking for trouble.
I changed gpu_freq-700 to 500 and then 600.
[pi4]
arm_freq=1500
gpu_freq=700 (this one)
gpu_mem=16
At 500, the memory test just freezes up and the loop test won't even start. I
had to <control C> to end it.
At 600, the tests work, albeit slower but doesn't fix anything that I could tell.
So I changed it back to the original 700.
Next... :)
Darklord
Post by Darklord »
Okay, for anyone following this, I'm stuck at the moment.
Best estimate/guess from the Discord team (thanks gang, for
all your help!), is that my PiSTorm board, which I purchased
from the AmigaKit Store (I know, heresy, right? :) ) is simply
not communicating.
Using SSH, I can access the Pi4b I'm currently using, I can
run tests, access files, and update the firmware on the
PiSTorm itself, etc - but that's about it.
I've got a Pi3a+ on the way, should be here tomorrow, and we
will do further testing then.
Thanks all.
Darklord
Post by Darklord »
Here is what the running Pi4b looks like sitting on top of the PiSTorm, in the 68000 CPU socket, in the STacy:
dad664npc
Post by dad664npc »
What's the bubble wrap for? It's not a good idea to have that stuff near/on electronic components. If it's ant-static, then it's conductive, and if it's not ant-static, it generates static
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
Darklord
Post by Darklord »
Already discussed this on Discord but the STacy's keyboard has a metal backing
and with all the shielding removed it would sit right on top of the daughterboard
that houses the TOS 1.4 ROMs, memory, etc., so I put something in between.
Same thing for the internal P/S. I didn't want to leave it where it could make
contact with anything and potentially destroy stuff. It is anti-static around it.
I'll swap that out for something safer....
