My (attempted) PiSTorm STacy installation
Okay, I like the thoughts of the PiSTorm accelerator for the ST line. I find it very interesting.
It just so happens that I've got my STacy, equipped currently with a Pak 68/3 board, apart
for some other long wished-for upgrades and mods.
So I thought, why not? Let's play around with the PiSTorm and the STacy.
I didn't want to hijack the "PiSTorm Chat" message thread so I decided to start a separate one
here. Honestly, this may be a very short (and short lived!) thread as I'm off to a rocky start
and there's a very big (and real!) question about trying to squeeze the PiSTorm setup into a
STacy (the Pak 68/3 board was a nightmare).
This is the STacy, opened up and showing the Pak 68/3 board. I'd forgotten just how tight it
is. You can see the original P/S now sitting in the battery compartment where I had to move it.
This is the PiSTorm board itself, sitting in the socketed 68k CPU slot (Pak 68/3 removed).
Here you can see the PiSTorm board, with the Pi 4 attached (hat), and just how tall it is.
Re: My (attempted) PiSTorm STacy installation
As you can see from the pictures above, the PiSTorm, together with the Pi 4 and the
necessary extender, is tall. It's really tall, and that's a serious problem for replacing
the shields and the keyboard. I'll look at/work on that problem later.
Currently, I got the PiSTorm in (I'm using the pre-made one from the AmigKit store),
as well as the Pi 4 (4 gig model) with a 32 gig SanDisk micro SD card. I attached a
USB keyboard, Raspberry Pi 4 specific P/S and sent the output via HDMI cable to my
27" Dell monitor that I regularly use with my Mega STe.
Okay, good to go - or should be. I used "Pi Imager" on my Windows 10 box to install the
Pi 4 OS file onto the 32 gig SD card. (I know, I should have used my Kubuntu Linux laptop
to do this). Success reported.
I booted the Pi 4 up. The initial run and first reboot appears to be successful. I didn't
notice any red flags (text) or errors and I wound up at a command prompt.
Next I issued the commands per the PiSTorm github site:
sudo apt-get install git libasound2-dev
sudo apt-get install git ffmpeg
I had printed these out and only afterwards realized that the first command actually
has a line drawn thru it (it doesn't show up here with cut 'n paste or printed out).
It failed, not finding things it needed so I hope I didn't screw something up. After
that, the second command also failed, unable to find what it needed. The github
site says to issue a "sudo apt full-upgrade" if you get the mysterious "not found"
messages so I did. It failed as well.
Here are a couple of screenshots showing the output from the terminal:
So basically, from my understanding, the Pi OS is basically Linux. I've got
Kubuntu Linux on my laptop and I've been playing around with Linux since
my first Mandrake install in 1999. I've also used MINT/Naes/Thing with my
Falcon 060. So I'm *somewhat* familiar with it, but an expert by no means.
With that in mind, I know it's not uncommon to get error messages that are
not *fatal* to what you're doing. So I'm asking the experts here if that is the
case or maybe some helpful suggestions as to how to proceed at this point.
Thanks all (and yeah, I'm in very deep waters here).
Does you pi have internet access at all?
Did you configure your WiFi?
I think it was previously suggested to you that when you use pi imager, you click advanced and put your WiFi details in and enable SSH.
Then you don't need to plug the Pi into a monitor or anything. You just SSH into your Pi from your Linux terminal.
Then all your commands will work.
It's the simplest of things sometimes...
When I used "Pi Imager" to setup the 32gig SD card, I also
configured things at that time, although it seems what it does
is a bare minimum, skeletal version of what "raspi-config" does.
I ran "ifconfig" after I initially set everything up but only glanced
at the output after I saw that it listed an assigned IP address of
"10.59.1.135".
So apparently, the Pi 4 did not have 'net access. After running
"raspi-config" and re-entering the pertinent information, it seems
to be working better now.
I've gotten as far as "make CACHE=ON".
It responds with, "make: Nothing to be done for 'all'."
Thanks.
"10.59.1.135".
Thanks.
Can I safely assume that means there's nothing to be done, that
it's complete?
Thanks...
it's complete?
Thanks...
GitHub README has been updated this morning - this will help you with the next steps
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
Thanks, I'll go through it and give it a shot in the morning.
Appreciated.
Appreciated.
Trying to double check things before I fatally mess something up.
I'm at this section:
Copy the linux boot configuration file:
sudo cp configs/config.txt /boot/
Append the following to your /boot/cmdline.txt file
quiet vt.global_cursor_default=0 fsck.mode=force fsck.repair=yes
NOTE Do not add new-lines to this file. The entries must be one continuous line
Congratulate yourself - You've gotten this far! Shutdown the linux operating system
sudo halt
The copy went fine, no problems. I attempted to use vi to edit the cmdline.txt file.
(Admittedly, it's been quite some time since I used anything besides kate to edit a text
file in Linux)
When I had entered the line above and attempted to save with :wq! it complained
that it couldn't save the file (seems it's linked to another file and a "dir -l" shows this).
(I seem to remember that I could have used "zz" to save and quit but I forgot about
that until just now)
So I went looking and found that the copy of cmdline.txt in /boot seems to be linked
to a cmdline.txt file in /boot/firmware.
So I guess my question is should I edit that cmdline.txt file in /boot/firmware?
Also, shouldn't I be making backups of these files somewhere before modifying them?
Thanks all.
sudo halt
file in Linux)
Thanks all.
1) I wouldn't test with CACHE=ON until you have it working without cache. I'm not even sure the cache is working at all at present.
2) make can't pick up on the command line changes so do a make clean first.
It's a root-owned file. You'll need to edit it with sudo.Darklord wrote: Wed Dec 06, 2023 7:00 am When I had entered the line above and attempted to save with :wq! it complained
sudo vi /boot/cmdline.txt
