Gotcha, so the warning message I got is what is expected and I should be good.
Should I run it again and do the "-vvvv" anyway? Thanks.
My (attempted) PiSTorm STacy installation
Darklord
Re: My (attempted) PiSTorm STacy installation
Darklord
I decided to go ahead - here's the results. It looks okay to me.
Darklord
Here's my config.txt file - what part(s) am I supposed to change? Thanks.
I'm assuming it's something from this section:
[pi4]
#over_voltage=9 # if arm_freq > 2.1GHz
arm_freq=1500
gpu_freq=700
gpu_mem=16
[pi4]
arm_freq=1500
gpu_freq=700
gpu_mem=16
You're not expected to change anything. The config is pre-configured for you. The GitHub instructions don't tell you to change it, just to copy it to your boot directory.
Darklord
Hmm, I sincerely hope that something is to be changed. "core_freq" keeps getting mentioned but I can't find that
in the config.txt file except under the Pi 2 and Pi 3 sections and I've got a Pi 4. It was mentioned that it's set too
high but I'm not sure what to change since "core_freq" isn't mentioned in the Pi 4 section.
Thanks.
Thanks.
Darklord
So I decided to experiment a bit. Yeah, I know, asking for trouble.
I changed gpu_freq-700 to 500 and then 600.
[pi4]
arm_freq=1500
gpu_freq=700 (this one)
gpu_mem=16
At 500, the memory test just freezes up and the loop test won't even start. I
had to <control C> to end it.
At 600, the tests work, albeit slower but doesn't fix anything that I could tell.
So I changed it back to the original 700.
Next... :)
[pi4]
arm_freq=1500
gpu_mem=16
Next... :)
Darklord
Okay, for anyone following this, I'm stuck at the moment.
Best estimate/guess from the Discord team (thanks gang, for
all your help!), is that my PiSTorm board, which I purchased
from the AmigaKit Store (I know, heresy, right? :) ) is simply
not communicating.
Using SSH, I can access the Pi4b I'm currently using, I can
run tests, access files, and update the firmware on the
PiSTorm itself, etc - but that's about it.
I've got a Pi3a+ on the way, should be here tomorrow, and we
will do further testing then.
Thanks all.
not communicating.
Thanks all.
Darklord
Here is what the running Pi4b looks like sitting on top of the PiSTorm, in the 68000 CPU socket, in the STacy:
dad664npc
What's the bubble wrap for? It's not a good idea to have that stuff near/on electronic components. If it's ant-static, then it's conductive, and if it's not ant-static, it generates static
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
Darklord
Already discussed this on Discord but the STacy's keyboard has a metal backing
and with all the shielding removed it would sit right on top of the daughterboard
that houses the TOS 1.4 ROMs, memory, etc., so I put something in between.
Same thing for the internal P/S. I didn't want to leave it where it could make
contact with anything and potentially destroy stuff. It is anti-static around it.
I'll swap that out for something safer....
Users browsing this forum: ClaudeBot, jmorden, Marcopolomint1, semrush [bot] and 8 guests
