Yes, that's what I did with 3 different CPUs.
ATARI STE TwiSTEr
HigashiJun
Re: ATARI STE TwiSTEr
frank.lukas
I once had similar problems with a Mega STE and I was looking for a fault and can not find one ... (habe mir einen Wolf gesucht)
With a thin and fine needle I went directly with the multimeter to the contacts on the PLCC 68k chip and not to the contacts of the PLCC socket. All looking good but I found a pin that had no or very last contact. So I order a gold atari like PLCC socket from BEST and the problem was fixed ...
HigashiJun
@frank.lukas
Do you remember if Best's sockets are also 8mm high ?
@HigashiJun Another socket I have here (new) is ~8.1mm high, but it has "tabs" on the bottom I guess you could break off ? It would be 6.5mm then , BUT, you would need some card under the socket to stop the pins shorting out on the motherboard.
HigashiJun
Could you post a picture of it ?exxos wrote: 15 Jun 2023 10:58 @HigashiJun Another socket I have here (new) is ~8.1mm high, but it has "tabs" on the bottom I guess you could break off ? It would be 6.5mm then , BUT, you would need some card under the socket to stop the pins shorting out on the motherboard.
Thanks.
HigashiJun
Thank you guys !
@exxos
It's the same socket I got from Frank Lukas.
I still have another one but I am not really keen on soldering it, as I might encounter the same problem I had with the first one.
@frank.lukas
Looks good !
I will contact Bradley and ask him for a quote.
@exxos
@frank.lukas
Looks good !
frank.lukas
Ask him it's the same 7,8mm height before you buy ...
HigashiJun
Yes, I will.
Users browsing this forum: ClaudeBot and 11 guests
