Sporniket's log on hardware stuff
sporniket
Re: Sporniket's log on hardware stuff
Post by sporniket »
russellnash wrote: Fri Apr 21, 2023 8:09 am It looks like it would cost around €15. You will have to be a bit patient, parcels only get collected and delivered on a couple of days a week in my part of the world. Nobody tries to do too much, too fast, which is something that I really like. :)
No problem about that.
sporniket
Post by sporniket »
Today I finished the YM2149 with the parallel port and the sound amp circuit
subsheet_103-U19-40-YM2149 ; J5-Parallel port.png (337.54 KiB) Viewed 3388 times
I also forgot to link the parallel busy signal to the MFP, here is the fix
subsheet_100-U11-68901 ; U13-14 J4-RS-232 port.png (335.81 KiB) Viewed 3388 times
sporniket
Post by sporniket »
So, I finally completed the capture of the schematics, the projects advance into "v1 alpha" stage. No DRC ERC errors (I had to fix some typos from my symbols libraries).
motherboard.pdf
(1.48 MiB) Downloaded 74 times
As always, I welcome being corrected, if there is a typo or misunderstanding of the original schematics.
As always, the github repository is up to date, with an alpha release for people wanting to get the same pdf as the one attached to this post, without opening kicad.
edit: confused DRC and ERC...
sporniket
Post by sporniket »
Thanks to a donation from @russellnash, I got myself an actual motherboard (this is one of the motherboards he got from @frank.lukas) . That will help me a lot for my work on reconstructing the PCB.
Hmm... Intereting DB9 port configuration. Somehow I don't think that they're stock. :-)
russellnash
Post by russellnash »
To be fair it was Frank who let me know you were looking for a board, otherwise I might not have seen it. In your photo it looks truly beautiful, probably the best looking one I have ever seen.
frank.lukas
Post by frank.lukas »
... had all four boards to cannibalize for parts. The board in the picture was probably installed in a PC tower case I think.
sporniket
Post by sporniket »
russellnash wrote: Fri May 05, 2023 3:02 pm To be fair it was Frank who let me know you were looking for a board, otherwise I might not have seen it. In your photo it looks truly beautiful, probably the best looking one I have ever seen.
Then thank to @frank.lukas too :)
frank.lukas wrote: Fri May 05, 2023 3:36 pm ... had all four boards to cannibalize for parts. The board in the picture was probably installed in a PC tower case I think.
I don't mind, it's in good enough shape for using as reference :)
sporniket
Post by sporniket »
Working on the not so fun step of assigning footprints to components. Almost done, and I will have to craft some custom footprints, like the Atari DE9 ports, the modulator, the "shifter cage" and the power common mode chock L3.
Having an actual motherboard -and a Vernier caliper- helps a lot.
