Sporniket's log on hardware stuff
sporniket
Post by sporniket »
Well, the H5 is pre-ordered and I have pleeeeenty of time before having receiving. And that's good, because I have other ongoing projects on the software side.
Anyway, I already have a little todo list.
  • find some place to put my project when not working on it - DONE
  • do some soldering practice (a little audio switch 1 input / 3 output, stereo 3.5'' jack) - DONE
  • study schematics of the H5 and the STE (even printed on A3, the magnifier is mandatory) - DOING
  • The STE schematics is a PITA to decipher, I'm feeling like learning Kicad to make a clean rewrite of it
  • Buy the list of parts from Mouser - DONE
  • Buy some parts from Exxos
  • Find a donor STF - DOING (waiting for PhilC to post the pictures in his thread)
sporniket
Re: Sporniket's log on hardware stuff
Post by sporniket »
This is not the donor machine I'm looking for...
I got a little bit side-tracked. BUT unexpectedly won a bid at a fair price for it, with reasonable postage (because not from another countries)...
More pics later, I plan to do a checkup, recap as needed, ditch the floppy drive for a goex (later). This machine ought to be for testing my programs on real hardware.
sporniket
Post by sporniket »
So, I disassembled the STE to see what's inside. It's a CA401177 motherboard with a Mitsumi SR98 psu, and I was surprise do discover that I have a component video output ?? (The one I had when I was young did not have that).
I struggled a little bit to remove the top shield, until I understood that I had to take the whole (shield + motherboard) out of the case before being able to separe them without problem.
sporniket wrote: Fri Oct 23, 2020 9:58 pm So, I disassembled the STE to see what's inside. It's a CA401177 motherboard with a Mitsumi SR98 psu, and I was surprise do discover that I have a component video output ?? (The one I had when I was young did not have that).
I think if it has a RF box it probably has component output.. though some machines may still have it anyway.. can't remember off-hand.
Post by JezC »
:coolpics:
Looks like it has an AJAX chip in there instead of a 1772?
All 3 of my STEs have TOS in EPROMs...looks like you have mask ROMs. Any idea whether it's 1.6 or 1.62?
sporniket
Post by sporniket »
exxos wrote: Fri Oct 23, 2020 10:05 pm
Anyway, it means that I can try to plug it to my TV set and see how it looks.
JezC wrote: Fri Oct 23, 2020 10:10 pm :coolpics:
I got it without any cable, I have to look in my things for a spare one, if I still kept one. So cannot say for now. And in the motherboard section of the forum, it mentions the AJAX chip.
For now, I will give the plastic case a good scrub...
tzok
Post by tzok »
sporniket wrote: Fri Oct 23, 2020 9:58 pmI was surprise do discover that I have a component video output ?? (The one I had when I was young did not have that).
Component Video (Y, Pb, Pr)? Are you sure? All STEs, except french (SECAM) ones, have RF output, and Composite Video.
sporniket
Post by sporniket »
tzok wrote: Fri Oct 23, 2020 10:41 pm
ha sorry, you're right, "composite" not "component". A.k.a. "the yellow plug" :D
tzok
Post by tzok »
Composite video is on DIN-13 (Monitor) socket, extra RCA socket is for RF (TV) out.
sporniket
Post by sporniket »
Today, a bit of unboxing :
Unfortunately, my TV set does not supports the 15kHz color mode, as well as my computer monitor... anyway, let's continue with high resolution...
I tried to adjust some settings to get rid of the stripes (+ going into 4:3 mode).
It seems I have TOS 1.06 on this one, if i believe the copyright year extended to 1989 and a little check on this page
So, all in all this little one is operationnal, before undergoing some of the mandatory fixes. Since I have a soldered CPU, I obviously will let it be.
