This morning I was motivated to setup my temporary workshop -just a foldable table big and sturdy enough to host the atari and all the stuff-.
So today's goal is to install the
4,700 AXIAL CAP REPLACEMENT KIT [0090] (shameless product placement
DISCLAIMER : my installation will be unconventionnal, as I have to get enough clearance to install an IDE extension provided by
@frank.lukas. And with the original big cap, I have a problem when trying to install the extension with a Compact Flash adaptor and said Compact Flash card :
- 2022-02-27--01-i-need-clearance.jpg (175.33 KiB) Viewed 3268 times
So first, I assess how I should place the replacement to have enough place :
- 2022-02-27--02-assess-situation.jpg (263.67 KiB) Viewed 3268 times
Then, it's time to remove the original capacitor, and i keep the leads, hoping to reuse them.
- 2022-02-27--03-snip.jpg (218.77 KiB) Viewed 3268 times
Finally, I cut flush the lead connected to VCC, given the offset that I need, I will connect to VCC with a wire soldered at C104 that is just on the same trace. I also put some polyimide tape ("Kapton© tape") on the area to avoid shorts.
- 2022-02-27--04-polyimide-everywhere.jpg (239.69 KiB) Viewed 3268 times
Now since I have several holes on the kit for VCC and GND, I install two wires on each side to spread the load. And then more polyimide tape on the bottom...
- 2022-02-27--05-preparations-complete-top.jpg (157.84 KiB) Viewed 3268 times
- 2022-02-27--06-preparations-complete-bottom.jpg (138.26 KiB) Viewed 3268 times
Moving on, I solder the red wires to the pin of C104 connected to VCC, and the black wires to the lead of the original capacitor connected to ground, that I kept an twisted a little to the left.
- 2022-02-27--07-top-view.jpg (190.58 KiB) Viewed 3268 times
Now, regarding the fitting of the IDE + adaptor + card, it's all right :
- 2022-02-27--08-shoe-fitting-ok.jpg (249.18 KiB) Viewed 3268 times
Removing the extension and closing the case, it's time to check that the STe still works :
- 2022-02-27--09-it-still-works.jpg (190.07 KiB) Viewed 3268 times
I did a power cycle to install a mouse and launch maxymiser to play some tune...
- 2022-02-27--10-warming-up.jpg (222.68 KiB) Viewed 3268 times
OK, time to close the workshop, to shelf the STE and clean some more stuff...
- 2022-02-27--11-time-to-clean.jpg (171.9 KiB) Viewed 3268 times
