Sporniket's log on hardware stuff
sporniket
Re: Sporniket's log on hardware stuff
Post by sporniket »
olivier.jan wrote: Mon Nov 08, 2021 8:38 pm If you haven’t ordered yet, I would really recommend getting a Pinecil instead : similar to TS100, but can use USB-C and only 24USD. I’ve been using it for a few months, and it’s really awesome for the price.
And if you are in «Region Parisienne » and want to test, feel free to PM me.
https://pine64.com/product/pinecil-smar ... ring-iron/
I've already ordered.
Yes, I know and am interested in the Pinecil too, but I will need the power supply, the cable, and a set of tips too. That's why I postpone that buy until next summer of Xmas 2022 -I really want a scope for now-. Thanks for the testing offer though, and yes, I am living in Region Parisienne. I will keep the offer in mind, if it still holds when I am ready to buy next year :) .
sporniket
Post by sporniket »
VHDL, I am slowly getting the hang of it, and succeeded to tell ISE to keep its files separated from my sources. Going back to basic, I wrote a bunch of basic stuff (serializer/deserializer, buffer, counter) to focus on 3 things :
  • Follow the same kind of workflow that I implemented at work : start with writing specs, including behavior test suite.
  • Simplify the coding of testbenches as "just iterate over an array of test descriptors"
  • for those simple stuff, generalize whatever I can think of, and write simple use cases as an instanciation of the general use case.
It's clean enough to be seen here https://github.com/sporniket/seed-vhdl , the specs are in the wiki
Electronic load project, yesterday I printed the datasheet of my op-amps, and put the sheets in indivudual sleeve for storing in a binder, and I stumbled on the recommandations about unused opamps pins (I took a dual channel op-amp). I can already see that I will need some bodge-wire, and will have to update my schematpics & PCB later...
edit : "electronic charge" --> "electronic load"
sporniket
Post by sporniket »
Electronic load project, I finally got the PCBs, I will be able to train my SMD soldering skill, as well as my wire bodging skill...
sporniket
Post by sporniket »
A little update of the module of my project of electronic load : the wiring of the unused op-amp... and it will be easy to bodge on my already printed pcbs
bridge-uc-to-modules.pdf
(159.52 KiB) Downloaded 101 times
Now waiting january to get thermal paste for the contact between the mosfet and the heatsink.
EDIT: Got my christmas presents from myself to me, there is a spare flex pcb for my not working lynx, and some games for the one working...
sporniket
Post by sporniket »
The celebrations for the end of the year 2021 are gones, the Christmas tree is shelved, and a new year has started...
My "key battles" for 2022 :
  • Hack the IKBD port to be able to use Bluetooth HID devices. And first, convert the IKBD unit into such HID device by writing a firmware for the ESP32 micro-controller : Kimchi on the beach
  • Create a module to power the ST(e)/H5 using a USB-PD (power delivery) power supply. And first, create an electronic load (see previous posts). I will also need to buy a good enough oscilloscope to check the regulation of the voltage.
mrbombermillzy
Post by mrbombermillzy »
sporniket wrote: Thu Jan 06, 2022 5:16 pm The celebrations for the end of the year 2021 are gones, the Christmas tree is shelved, and a new year has started...
Hurrah! :cheers:
You know, I was thinking exactly the same thing earlier. I really have to finish some projects though, rather than begin any new ones.
sporniket
Post by sporniket »
Not a lot of time to setup a soldering session.
So after one session last week and one this morning, I have finally prepared my work on my STe for next month :
  • replacement of the big capacitor with exxos kit #0090 (with a twist : I will have to place it to have supplemental clearance on the right, to fit a montage over the soldered CPU)
  • apply the video ghost fix
sporniket
Post by sporniket »
This morning, I did the video ghost fix on my STe. I couldn't take picture of before/after, as I could not reproduce the ghosting to start with. (I had it previously, but I was having longer session, I guess I do not give time to my old chap to getting warm...) Anyway, it still works after the installation, so that's something.
So first I confirmed the orientation of the electrolytic capacitor from the page describing the fix. I also put a little piece of polyimide tape to avoid shorting something while doing the fix.
Done ! I tried to keep the leads short, and I previously mounted the ceramic capacitor like piggy backing over the electrolytic one.
sporniket
Post by sporniket »
This morning I was motivated to setup my temporary workshop -just a foldable table big and sturdy enough to host the atari and all the stuff-.
So today's goal is to install the 4,700 AXIAL CAP REPLACEMENT KIT [0090] (shameless product placement :D )
DISCLAIMER : my installation will be unconventionnal, as I have to get enough clearance to install an IDE extension provided by @frank.lukas. And with the original big cap, I have a problem when trying to install the extension with a Compact Flash adaptor and said Compact Flash card :
So first, I assess how I should place the replacement to have enough place :
Then, it's time to remove the original capacitor, and i keep the leads, hoping to reuse them.
Finally, I cut flush the lead connected to VCC, given the offset that I need, I will connect to VCC with a wire soldered at C104 that is just on the same trace. I also put some polyimide tape ("Kapton© tape") on the area to avoid shorts.
Now since I have several holes on the kit for VCC and GND, I install two wires on each side to spread the load. And then more polyimide tape on the bottom...
Moving on, I solder the red wires to the pin of C104 connected to VCC, and the black wires to the lead of the original capacitor connected to ground, that I kept an twisted a little to the left.
Now, regarding the fitting of the IDE + adaptor + card, it's all right :
Removing the extension and closing the case, it's time to check that the STe still works :
I did a power cycle to install a mouse and launch maxymiser to play some tune...
OK, time to close the workshop, to shelf the STE and clean some more stuff...
sporniket
Post by sporniket »
I feel like I found my project for this summer... I am not sure of the directionality of some signals, though..
subsheet_100-U15–MMU ; U22-23-26-27–Bus isolator.png (389.29 KiB) Viewed 2542 times
edit : typos
