H5 SIMM socket issues
All related information and builds for the 2025 edition.
SciFi9000
Re: H5 SIMM socket issues
Post by SciFi9000 »
Hi, has anyone had any success with MIDI output. This is a big deal for me as it's prime reason I got my original Atari. On the H5 I can't get it working at all with equipment that works fine with an original Atari . Is there something I'm missing like a jumper setting maybe? Has anyone tested MIDI on an H5 please?
SciFi9000 wrote: Fri Oct 09, 2026 2:12 pm Hi, has anyone had any success with MIDI output. This is a big deal for me as it's prime reason I got my original Atari. On the H5 I can't get it working at all with equipment that works fine with an original Atari . Is there something I'm missing like a jumper setting maybe? Has anyone tested MIDI on an H5 please?
Midi works fine on the H5. I posted in your other topic to check the orientation of the optocoupler and that its the correct type and of course not faulty.
Swapped the ACIA chips ? Checked for bent pins ?
SciFi9000
Post by SciFi9000 »
Oh sorry I didn't see your reply. I was thinking it may be upside down (didn't look yet) just based on the fact that if one item was upsidedown.. well, it could be more. Was yours from the same batch I wonder? If it was it should be the same.
There's only been one batch of C5B. Looking at my build blog the opto is in the right way around.
SciFi9000
Post by SciFi9000 »
exxos wrote: Fri Oct 09, 2026 2:19 pm Swapped the ACIA chips ? Checked for bent pins ?
Ahh yes the 6850 chips. Great call. Will test tomorrow. I didn't realise that those were the chips responsible for MIDI until I just looked them up. Cheers and here's hoping. I have a spare
SciFi9000
Post by SciFi9000 »
SciFi9000 wrote: Sat Oct 10, 2026 1:11 pm
Great news, it was 2 bent pins on the MIDI side 6580. I swear I didn't bash it in using my forehead as a hammer, though you'd be forgiven for thinking I had. Both pins folded up exactly 180 deg halfway down so they looked dead straight from every angle. Once I straightened them out, all is good with the MIDI side of things.. phew.
That leaves the TOS 2.06 jumper. I bridged the solder bridge and the jumper for the decoder, but when i select the 2.06 jumper it hangs to a white screen at boot, but works perfect when selecting 1.04. Do I need a decoder board to get this working, or it is built in?
The DIMM socket issue is still there, but as it's stable at 2Mb I'm just going to live with it until I get a replacement socket.
Moved the jumper link?
viewtopic.php?t=7532#p125032
SciFi9000
Post by SciFi9000 »
exxos wrote: Tue Oct 13, 2026 9:46 am Moved the jumper link?
Hi yes, I moved both jumper links as well as the solder bridge. Do I take it it's supposed to work without any extra add on mod boards then? I have a replacement SIMM module coming. I'm thinking the 2gb limit and the tos 2.06 issues may stem from that.
Noting else to do other than what I did in the post.
I suggest you check the resistor the ROM bank select and make sure you get 5v and 0v stable when moving the jumper.
Return to “H5 C5B USER BUILDS”
