The reset switch has pi$$ed me off. As for some reason the holes are the wrong size for the switch frame
My only solution is to bend the front metal tab sideways and scratch a bit of the resist of the PCB to make a solder point.
The other back pin I did not bother with I just cut it off.
I also noticed that the left back pin could actually wear through the solder resist and short out on the track so I have bent that rear pin upwards to miss it and I will update the PCB files to correct that problem. That problem must of been there for a while and went unnoticed until just
I think the hole size thing might have happened because the holes were not part of the switch template actually just on the PCB.. I think at some point I moved all the holes to 0.3mm instead of 0.2mm (which involved a fair bit of re-routing as well) as larger holes will be stronger and can be a bit cheaper in some fab houses. Though the switch holes must have got "caught" in the resize
- IMG_2895.JPG (270.26 KiB) Viewed 3017 times
- IMG_2897.JPG (299.81 KiB) Viewed 3017 times
- f1.jpg (287.91 KiB) Viewed 3017 times
Also noticed the PLCC location dots on the silkscreen also seem to have fallen victim to the hole resizing
